Prusa Mk2.5S Pinda V2 Probe issue
I have converted an old Prusa MK2.5S to the Duet 3 Mini5+ Ethernet from stock. I was following the CNCkitchen guide and I am having difficulties with the PindaV2 probe. When I run the Z probe trigger height. The G30 S-1 command triggers an "Error: Probe was not triggered during probing move". I notice that in the user interface the probe triggers, going from 0 to 1000 as the probe approaches the bed. The probe light also turns off when it hits 1000.
In addition, when I try to run G32, the printer will do the first 3 probe sections and then stop at the 4th with multiple errors: Error: SetPositions called when DDA ring not empty
Error: Probe already triggered at start of probing moveAny thoughts on how to solve these issue?
Firmware: FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.4.5 ELECTRONICS: Duet 3 Mini5plus Ethernet FIRMWARE_DATE: 2022-11-30 19:41:16
Thank you.
@nat495 Here's you config for the probe
; ##### Z-Probe Settings for PINDA 2 M558 P5 C"io2.in" H1 F1000 T6000 A3 ; Prusa PindaV2 Endstop M308 S2 P"temp2" A"Pinda V2" Y"thermistor" T100000 B3950 ; Prusa PindaV2 Thermistor ;G31 P1000 X23 Y5 Z1.4 S21 H2 T0.02 ; Nozzle offset - Powder Coated Sheet with temperature compensation (0.02mm/°C) G31 P1000 X23 Y5 Z1.1 S21 H2 T0.02 ; Nozzle offset - Smooth Sheet M574 Z1 S2 ; Set Z axis endstop, controlled by probe M557 X24:228 Y6:210 P5 ; Define mesh grid for probing M376 H5 ; Fade height 5mm
Try setting G31 P parameter to P500. Also set M558 P parameter to P8 (unfiltered switch, faster response).
@droftarts Hi Ian,
Thank you for responding. I have made the following changes to my config. However, I'm still having some odd behavior. Now I'm noticing that when I run G30 S-1 close to the bed when the probe is already triggered I get the error Error: Probe already triggered at the start of probing move. When I run the same code a bit further from the bed and the trigger is not already triggered, I get the error: Error: Probe was not triggered during probing move. The Z-Axis will move until the probe triggers and then stops.
Running G32 now gets the following errors and does not complete:
G32
Error: Probe was not triggered during probing moveThanks,
Nathan; ##### Z-Probe Settings for PINDA 2 M558 P8 C"io2.in" H1 F1000 T6000 A3 ; Prusa PindaV2 Endstop M308 S2 P"temp2" A"Pinda V2" Y"thermistor" T100000 B3950 ; Prusa PindaV2 Thermistor ;G31 P500 X23 Y5 Z1.4 S21 H2 T0.02 ; Nozzle offset - Powder Coated Sheet with temperature compensation (0.02mm/°C) G31 P500 X23 Y5 Z1.1 S21 H2 T0.02 ; Nozzle offset - Smooth Sheet M574 Z1 S2 ; Set Z axis endstop, controlled by probe M557 X24:228 Y6:210 P5 ; Define mesh grid for probing M376 H5 ; Fade height 5mm
@nat495 best downgrade to 3.4.4. The DDA issue seems to only occur in 3.4.5
Thank you. Reverting the firmware solved the issue. The printer is printing a test print now.
Thank you.
@nat495 the issue with firmware 3.4.5 on the Duet 3 Mini is resolved. Please see https://forum.duet3d.com/topic/30814/homing-issues-with-rrf-3-4-5.
