    Voron 2.4 3MB6 §EB config issues.
    1.4k
    • Titus A Duxassundefined
      Titus A Duxass @jay_s_uk
      @jay_s_uk Thanks, that forced it -
      21.12.2022, 11:21:12 M115 B1
      Duet EXP3HC rev 1.01 or earlier firmware version 3.4.4 (2022-10-14 11:45:56)
      21.12.2022, 11:22:45 M122 B1
      Diagnostics for board 1:
      Bootloader ID: SAME5x bootloader version 2.4 (2021-12-10)
      All averaging filters OK
      Never used RAM 158932, free system stack 200 words
      Tasks: Move(notifyWait,0.0%,160) HEAT(notifyWait,0.0%,108) CanAsync(notifyWait,0.0%,69) CanRecv(notifyWait,0.0%,82) CanClock(notifyWait,0.0%,71) TMC(notifyWait,7.4%,99) MAIN(running,91.2%,441) IDLE(ready,0.0%,40) AIN(delaying,1.3%,263), total 100.0%
      Last reset 00:02:06 ago, cause: power up
      Last software reset data not available
      Driver 0: pos 0, 1746.2 steps/mm,standstill, SG min 0, mspos 2, reads 27429, writes 16 timeouts 0, steps req 0 done 0
      Driver 1: pos 0, 320.0 steps/mm,standstill, SG min 0, mspos 2, reads 27430, writes 16 timeouts 0, steps req 0 done 0
      Driver 2: pos 0, 320.0 steps/mm,standstill, SG min 0, mspos 2, reads 27430, writes 16 timeouts 0, steps req 0 done 0
      Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
      Peak sync jitter -1/8, peak Rx sync delay 178, resyncs 0/0, no step interrupt scheduled
      VIN voltage: min 24.1, current 24.2, max 24.2
      V12 voltage: min 12.2, current 12.2, max 12.2
      MCU temperature: min 32.5C, current 33.8C, max 33.9C
      Last sensors broadcast 0x00000000 found 0 173 ticks ago, 0 ordering errs, loop time 0
      CAN messages queued 1045, send timeouts 0, received 1146, lost 0, free buffers 37, min 37, error reg 0
      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
      M122
      RepRapFirmware for Duet 3 MB6HC version 3.4.5 (2022-11-30 19:35:23) running on Duet 3 MB6HC v1.01 (standalone mode)
      Board ID: 08DJM-9P63L-DJ3T8-6JKDA-3SJ6N-KB7MA
      Used output buffers: 3 of 40 (18 max)
      Static ram: 152760
      Dynamic ram: 97332 of which 184 recycled
      Never used RAM 100396, free system stack 202 words
      Tasks: NETWORK(ready,31.9%,210) ETHERNET(notifyWait,0.1%,441) HEAT(notifyWait,0.0%,322) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,799) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,339) TMC(notifyWait,7.9%,91) MAIN(running,60.0%,925) IDLE(ready,0.1%,30), total 100.0%
      Owned mutexes:
      Last reset 00:02:34 ago, cause: power up
      Last software reset details not available
      Error status: 0x00
      Step timer max interval 126
      MCU temperature: min 33.1, current 41.5, max 41.6
      Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 0, mspos 8, reads 6751, writes 11 timeouts 0
      Driver 1: standstill, SG min 0, mspos 2, reads 6748, writes 14 timeouts 0
      Driver 2: standstill, SG min 0, mspos 8, reads 6751, writes 11 timeouts 0
      Driver 3: standstill, SG min 0, mspos 2, reads 6748, writes 14 timeouts 0
      Driver 4: standstill, SG min 0, mspos 2, reads 6748, writes 14 timeouts 0
      Driver 5: standstill, SG min 0, mspos 2, reads 6749, writes 14 timeouts 0
      Date/time: 2022-12-21 11:23:11
      Slowest loop: 21.06ms; fastest: 0.05ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.0ms, write time 0.0ms, max retries 0
      DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty
      === CAN ===
      Messages queued 1401, received 1276, lost 0, boc 0
      Longest wait 2ms for reply type 6024, peak Tx sync delay 6, free buffers 50 (min 49), ts 773/772/0
      Tx timeouts 0,0,0,0,0,0
      === Network ===
      Slowest loop: 17.69ms; fastest: 0.03ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
      HTTP sessions: 1 of 8
      = Ethernet =
      State: active
      Error counts: 0 0 0 0 0 0
      === Multicast handler ===
      Responder is inactive, messages received 0, responses 0
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @Titus A Duxass
        @Titus-A-Duxass fantastic. now go back to using your printer as you were before and see if you still have issues. there are a few of us (me included) that run v2.4's with RRF
          dc42 administrators @Titus A Duxass
          @Titus-A-Duxass so is it working now or are there still problems?
          How did two drivers on the 6HC come to be faulty?
          Titus A Duxassundefined 1 Reply Last reply Reply Quote 0
            Titus A Duxass @dc42
            @dc42 No it still has issues.
            X and Y home as should.
            Z motors along to 0X0Y and then hangs until it times out, you can here some motors running.
            I bought the board knowing that the two drivers are kaputt, I suspect that there are more failures on the board.
            So I either have to find another board or strip it out and fit a BTT Manta M8P that I have. This is not something that I want to do as a it means replacing all the connectors.
              @Titus-A-Duxass can you try downgrading the mainboard to 3.4.4?
              Titus A Duxassundefined 2 Replies Last reply Reply Quote 0
                @jay_s_uk Wait - my mistake! The Z is homing, it's just going extremely slow! Should be done about Tuesday.
                  @Titus-A-Duxass said in Voron 2.4 3MB6 §EB config issues.:
                  You should remove that line. Endstop mode S2 is used only when the Z probe is used to home axes other than Z.
                  Please post your homeall.g and homez.g files.
                    @jay_s_uk Oops!
                    21.12.2022, 11:34:07 G28 Z
                    Error: Probe was not triggered during probing move
                    This happened with the Z at about +100mm
                      ; homeall.g
                      ; called to home all axes
                      ; generated by RepRapFirmware Configuration Tool v3.3.15 on Sun Dec 18 2022 17:39:32 GMT+0100 (Mitteleuropäische Normalzeit)
                      G91 ; relative positioning
                      G1 H1 X295 Y295 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                      G1 H1 X295 ; home X axis
                      G1 H1 Y295 ; home Y axis
                      G1 X-5 Y-5 F6000 ; go back a few mm
                      G1 H1 X295 F360 ; move slowly to X axis endstop once more (second pass)
                      G1 H1 Y295 ; then move slowly to Y axis endstop
                      G90 ; absolute positioning
                      G1 X40 Y15 F6000 ; go to first bed probe point and home Z
                      ;G91 ; relative positioning
                      ;G90 ; absolute positioning
                      ; homez.g
                      ; called to home the Z axis
                      G1 X40 Y15 F6000 ; go to first probe point
                      jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                        @Titus-A-Duxass can you post your config as well just so we can see your probe settings?
                        btw, what probe arrangement are you using?
                          @jay_s_uk
                          Okay, I switch it off and manually lowered Z, it now homes. I think there maybe a time out issue.
                          ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
                          M550 P"voron" ; set printer name
                          M669 K1 ; select CoreXY mode
                          ; Wait a moment for the CAN expansion boards to start
                          G4 S2
                          M586 P0 S1 ; enable HTTP
                          M586 P1 S0 ; disable FTP
                          M586 P2 S0 ; disable Telnet
                          M584 X1.1 Y1.2 Z0.1:0.5:0.3:0.4 E1.0 ; set drive mapping
                          M569 P1.1 S0 ; A motor goes forwards
                          M569 P1.2 S0 ; B motor goes forwards
                          M569 P0.1 S1 ; FL goes forwards
                          M569 P0.5 S0 ; RL goes backwards
                          M569 P0.3 S0 ; RR goes forwards
                          M569 P0.4 S1 ; FR goes backwards
                          M569 P1.0 S0 ; Extruder goes backwards
                          M350 Z64 I0 ; configure microstepping without interpolation
                          M350 X64 Y64 E64 I1 ; configure microstepping with interpolation
                          M92 X320.00 Y320.00 Z400.00 E1746.16 ; set steps per mm
                          M203 X60000.00 Y60000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
                          M201 X6000.00 Y6000.00 Z4000.00 E250.00 ; set accelerations (mm/s^2)
                          M906 X1500 Y1500 Z1200 E400 I30 ; set motor currents (mA) and motor idle factor in per cent
                          M84 S10 ; Set idle timeout
                          M208 X290 Y290 Z250 S0 ; set axis maxima
                          M574 X2 S1 P"^io1.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin ^io1.in
                          M574 Y2 S1 P"^io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ^io2.in
                          M558 P5 C"^io3.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
                          G31 P500 X0 Y25 Z2.5 ; set Z probe trigger value, offset and trigger height
                          M557 X40:260 Y40:260 S20 ; define mesh grid
                          M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0
                          M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
                          M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
                          M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
                          M106 P1 S0 H1 T45 ; set fan 1 value. Thermostatic control is turned on
                          M563 P0 S"Revo" D0 H1 F0:1 ; define tool 0
                          ; Custom settings
                          M584 Z0.1:0.5:0.3:0.4
                          T0 ; select first tool
                            so really you want to change that to the centre of your bed, taking into account the probe offset (i.e if the centre of X is 150 and the probe is 10mm to the left of the nozzle you would move to 160)
                            same goes for homez
                            M350 X64 Y64 E64 I1
                            i would stick to x16 rather than x64. you don't gain anything
                            F120
                            your probe speed is to move at 2mm/s. thats ok for a second pass but your first pass probably wants to be quicker. you can set a first and second probing speed like this F1200:120
                            ; Custom settings
                            you don't need this again
                              Titus A Duxass
                              I really appreciated your help this.
                              Now you are stretching my 61yr old brain.
                              I have a bed that is 300 x 300 so centre will be 150 x 150 - you can see the probe/nozzle set up in the photos.
                                @jay_s_uk
                                M350 X64 Y64 E64 I1
                                So I simply overwrite 64 with 16 in config.g?
                                  @Titus-A-Duxass you'll also have to divide your steps per mm by 4
                                  for the probe point you'd move to X150 Y125
                                    @jay_s_uk said in Voron 2.4 3MB6 §EB config issues.:
                                    F120
                                    Sorry but you've lost me there.
                                    Which file is this in and what am I editing.
                                    I'm going to need a beer after this!
                                      @Titus-A-Duxass the M558 F value in config.g
                                        Again, you've lost me. Unfortunately I have zero knowledge of G code and configuration. I have been following a youtube video to set this lot up.
                                          @jay_s_uk
                                          Okay, so F1200 is the first pass speed and 120 the second pass speed.
                                          my line now looks like this:
                                          M558 P5 C"^io3.in" H5 F1200:120 T6000
                                            @Titus-A-Duxass
                                            these lines
                                            change to
                                            M350 Z16 I0 ; configure microstepping without interpolation
                                            M350 X16 Y16 E16 I1 ; configure microstepping with interpolation
                                            M92 X80.00 Y80.00 Z400.00 E436.54 ; set steps per mm
                                            your Z steps were wrong for X64 which is probably why your moves were so slow and it was erroring out after 100mm (as the machine had thought you'd moved 400mm which is greater than your Z height)
