    Voron 2.4 3MB6 §EB config issues.
    1.4k
      dc42 administrators @Titus A Duxass
      @Titus-A-Duxass said in Voron 2.4 3MB6 §EB config issues.:
      You should remove that line. Endstop mode S2 is used only when the Z probe is used to home axes other than Z.
      Please post your homeall.g and homez.g files.
      Titus A Duxassundefined 1 Reply Last reply Reply Quote 0
      • Titus A Duxassundefined
        Titus A Duxass @jay_s_uk
        @jay_s_uk Oops!
        21.12.2022, 11:34:07 G28 Z
        Error: Probe was not triggered during probing move
        This happened with the Z at about +100mm
          Titus A Duxass @dc42
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v3.3.15 on Sun Dec 18 2022 17:39:32 GMT+0100 (Mitteleuropäische Normalzeit)
          G91 ; relative positioning
          G1 H1 X295 Y295 F1800 ; move quickly to X or Y endstop and stop there (first pass)
          G1 H1 X295 ; home X axis
          G1 H1 Y295 ; home Y axis
          G1 X-5 Y-5 F6000 ; go back a few mm
          G1 H1 X295 F360 ; move slowly to X axis endstop once more (second pass)
          G1 H1 Y295 ; then move slowly to Y axis endstop
          G90 ; absolute positioning
          G1 X40 Y15 F6000 ; go to first bed probe point and home Z
          ;G91 ; relative positioning
          ;G90 ; absolute positioning
          ; homez.g
          ; called to home the Z axis
          G1 X40 Y15 F6000 ; go to first probe point
          jay_s_ukundefined 2 Replies Last reply Reply Quote 0
            jay_s_uk @Titus A Duxass
            @Titus-A-Duxass can you post your config as well just so we can see your probe settings?
            btw, what probe arrangement are you using?
              @jay_s_uk
              Okay, I switch it off and manually lowered Z, it now homes. I think there maybe a time out issue.
              ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
              M550 P"voron" ; set printer name
              M669 K1 ; select CoreXY mode
              ; Wait a moment for the CAN expansion boards to start
              G4 S2
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M584 X1.1 Y1.2 Z0.1:0.5:0.3:0.4 E1.0 ; set drive mapping
              M569 P1.1 S0 ; A motor goes forwards
              M569 P1.2 S0 ; B motor goes forwards
              M569 P0.1 S1 ; FL goes forwards
              M569 P0.5 S0 ; RL goes backwards
              M569 P0.3 S0 ; RR goes forwards
              M569 P0.4 S1 ; FR goes backwards
              M569 P1.0 S0 ; Extruder goes backwards
              M350 Z64 I0 ; configure microstepping without interpolation
              M350 X64 Y64 E64 I1 ; configure microstepping with interpolation
              M92 X320.00 Y320.00 Z400.00 E1746.16 ; set steps per mm
              M203 X60000.00 Y60000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
              M201 X6000.00 Y6000.00 Z4000.00 E250.00 ; set accelerations (mm/s^2)
              M906 X1500 Y1500 Z1200 E400 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S10 ; Set idle timeout
              M208 X290 Y290 Z250 S0 ; set axis maxima
              M574 X2 S1 P"^io1.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin ^io1.in
              M574 Y2 S1 P"^io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ^io2.in
              M558 P5 C"^io3.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
              G31 P500 X0 Y25 Z2.5 ; set Z probe trigger value, offset and trigger height
              M557 X40:260 Y40:260 S20 ; define mesh grid
              M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0
              M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
              M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
              M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
              M106 P1 S0 H1 T45 ; set fan 1 value. Thermostatic control is turned on
              M563 P0 S"Revo" D0 H1 F0:1 ; define tool 0
              ; Custom settings
              M584 Z0.1:0.5:0.3:0.4
              T0 ; select first tool
                so really you want to change that to the centre of your bed, taking into account the probe offset (i.e if the centre of X is 150 and the probe is 10mm to the left of the nozzle you would move to 160)
                same goes for homez
                M350 X64 Y64 E64 I1
                i would stick to x16 rather than x64. you don't gain anything
                F120
                your probe speed is to move at 2mm/s. thats ok for a second pass but your first pass probably wants to be quicker. you can set a first and second probing speed like this F1200:120
                ; Custom settings
                you don't need this again
                Titus A Duxassundefined 2 Replies Last reply Reply Quote 0
                  Titus A Duxass
                  I really appreciated your help this.
                  Now you are stretching my 61yr old brain.
                  I have a bed that is 300 x 300 so centre will be 150 x 150 - you can see the probe/nozzle set up in the photos.
                    @jay_s_uk
                    M350 X64 Y64 E64 I1
                    So I simply overwrite 64 with 16 in config.g?
                      @Titus-A-Duxass you'll also have to divide your steps per mm by 4
                      for the probe point you'd move to X150 Y125
                        @jay_s_uk said in Voron 2.4 3MB6 §EB config issues.:
                        F120
                        Sorry but you've lost me there.
                        Which file is this in and what am I editing.
                        I'm going to need a beer after this!
                          @Titus-A-Duxass the M558 F value in config.g
                            Again, you've lost me. Unfortunately I have zero knowledge of G code and configuration. I have been following a youtube video to set this lot up.
                              @jay_s_uk
                              Okay, so F1200 is the first pass speed and 120 the second pass speed.
                              my line now looks like this:
                              M558 P5 C"^io3.in" H5 F1200:120 T6000
                                @Titus-A-Duxass
                                these lines
                                change to
                                M350 Z16 I0 ; configure microstepping without interpolation
                                M350 X16 Y16 E16 I1 ; configure microstepping with interpolation
                                M92 X80.00 Y80.00 Z400.00 E436.54 ; set steps per mm
                                your Z steps were wrong for X64 which is probably why your moves were so slow and it was erroring out after 100mm (as the machine had thought you'd moved 400mm which is greater than your Z height)
                                  This post is deleted!
                                    @Titus-A-Duxass because we're setting x16 rather than x64, so the values need to be dividing by 4 as we're using 4 times less microsteps
                                        @jay_s_uk Okay, I think I understand. I need to do a bit of reading about microsteps.
                                          @jay_s_uk My config.g now looks like this.
                                          G4 S2
                                          M92 X320.00 Y320.00 Z400.00 E436.54 ; set steps per mm
                                          M558 P5 C"^io3.in" H5 F1200:120 T6000 ; set Z probe type to switch and the dive height + speeds
                                            @Titus-A-Duxass you need to change the X and Y steps too from 320 to 80
