    New Input Shaping plugin v3.4.1-b1
    Plugins for DWC and DSF
    25
    51
    6.5k
    • chrishammundefined
      chrishamm administrators
      Version 3.4.1 is now available to fix the record dialog for users who have tools with gaps defined (e.g. T1 but no T0).
      In addition, the shaper prediction now supports custom shapers - just make sure to be on 3.4.1 before you attempt to use this feature. When you enable it, the shaper parameters are copied from the current input shaper and by using the arrow keys in the edit dialog inputs, you can immediately get an estimate of the resulting damping curve. There is no further documentation about this feature yet and most users should not need it either. I meant to release v3.4.0 with this feature enabled but it still required a fix from v3.4.1.
      Duet software engineer
      Adamfilipundefined Fred-Yundefined 2 Replies Last reply Reply Quote 2
      • Adamfilipundefined
        Adamfilip @chrishamm
        Is there an easy to follow wiring diagram for the LIS3DH and the Duet2Wifi.
        I find matching pins tricky and confusing that are listed on
        https://docs.duet3d.com/en/User_manual/Tuning/Input_shaping_plugin
        need something for my simpler brain lol
        • Fred-Yundefined
          Fred-Y @chrishamm
          @chrishamm Installed it this evening on my Predator, it's fairly easy to use and compare the different graphs.
          I would suggest 2 things:
          1- Add the damping factor used in the records
          I started to "play" with the damping factor to see the impact on the graphs but I lost track of the value used at one point.
          2- It took me a little bit of time to realize that I needed to click on the check-mark for set the Shaper Center Frequency and Damping factor.
          I think I was "deceived" because changing the Shaper Center value immediately moves the blue bar in the graph so I wrongly assumed it would use it when doing a new record.
          I must admit that I didn't paid much attention to the summary in the first modal box.
          This has been mentioned before, I don't know if it has been fixed in this beta but I'm getting this message as well
          This printer has a Duet 2 Wifi and a Smart Effector v3
            Adamfilip
            Wish there was a video tutorial on the input shaping process with RRF and this plugin. So much content using klipper, yet to find one with duet
            • oliofundefined
              oliof @Adamfilip
              @adamfilip by and large, the procedure is the same, with the distinction that the tooling around using the accelerometer on Klipper is (naturally) a bit more mature. Not many people do RRF videos though ... but there is not much to it.
              1. on belt driven axes, multiple peaks on one axis indicate something is loose and is adding additional vibrations. Trying to find those and fixing them is a valuable venture anyways.
              2. on kinematics combining drives such CoreXY it is desirable that the measured curves match, since it indicates similar tension. Do not confuse this with finding the right tension though. That is dependent on belt lengths and your motion system.
              3. On Cartesian systems, individual axes may have different curves.
              4. On RepRapFirmware -- other than klipper -- you can only set one input shaping algorithm, frequency, and damping setting. In practice, the damping factor is enough to cover the usual span of different frequencies on different axes.
              5. The InputShaping plugin visualizes the measured vibration per axis, but also a recommended frequency, and you can tell it to show the effect on the frequency graph by a given algorithm and damping factor. Ideally, the damping factor is as low as possible to reduce the effect of input shaping on speeds/accelerations that aren't inducing ringing.
              6. It's likely useful to retune PA after tuning input shaping since there is some interaction between InputShaping and PA.
              • tfjieldundefined
                tfjield
                @oliof As I had posted in another thread, I measured my frequencies and applied a shaper and measured again and it looked good. (I haven't posted my results, yet.) But when I printed a test part, the ringing was noticeably worse.
                What would this be an indication of? Damping factor too high?
                • oliofundefined
                  oliof @tfjield
                  @tfjield very hard to say without seeing the curves and the before/after. It might be possible that you saw something on the graph that was just loose and overshadowed the actual measurement.
                  If all else fails, you can print the klipper ringing tower to validate what you measured.
                  • Norderundefined
                    Norder @dc42
                    @dc42 said in New Input Shaping plugin v3.4.1-b1:
                    @ratrig0331 thanks for your M122 report. I've seen this issue once before. I am fairly sure it is caused by problems with the accelerometer wiring that result in communication issues between the accelerometer and the Duet.
                    I still use the integrated input shaper that is integrated in RRF 3.4.2rc1 (2022-07-06), until I read about the input shaping plugin 3.4.1-b1 today and installed it right away.
                    After about 30 minutes of use, I had several disconnections with the new plug-in, which I did not have with the previous input shaping plug-in from RRF 3.4.2rc1 (2022-07-06), so I rule out problems with the cable.
                    I then turned my printer off and on again at the power switch.
                    After that everything was OK and I haven't had these disconnections anymore.
                    Just for info, maybe it will help !?
                    Google Translate
                    ----- Original Text -----
                    Ich nutze bis heute den integrierten Input Shaper der in RRF 3.4.2rc1 (2022-07-06) integriert ist, bis ich heute von dem Input Shaping PlugIn 3.4.1-b1 gelesen hatte und es gleich installierte.
                    Ich hatte mit dem neuen PlugIn nach etwa 30 Minuten Nutzungszeit mehrere Verbindungsabbrüche, die ich mit dem vorherigen Input Shaping PlugIn aus RRF 3.4.2rc1 (2022-07-06) nicht hatte, daher schließe ich Probleme mit dem Kabel aus.
                    Ich machte dann meinen Drucker einmal Aus und wieder An, am Netzschalter.
                    Danach war alles OK und diese Verbindungsabbrüche hatte ich bis jetzt nicht mehr.
                    Das nur zur Info, vielleicht hilft es weiter !?
                    DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
                    Thingiverse
                    PCRundefined 1 Reply Last reply Reply Quote 0
                    • PCRundefined
                      PCR @Norder
                      @chrishamm @dc42
                      When will be a release for 3.5:-)
                      chrishammundefined Adamfilipundefined 2 Replies Last reply Reply Quote 1
                        chrishamm administrators @PCR
                        @PCR Here you go: https://github.com/Duet3D/InputShapingPlugin/releases/tag/v3.5.0-b1
                        Adamfilipundefined 1 Reply Last reply Reply Quote 5
                          Adamfilip @PCR
                          @PCR great can you share the release notes?
                            @chrishamm cant seem to install gives error saying
                            but i have 3.4.5 installed
                            jay_s_ukundefined chrishammundefined 2 Replies Last reply Reply Quote 0
                              jay_s_uk @Adamfilip
                              @Adamfilip you can't install 3.5.0-b1 on 3.4.5, only on 3.5b1
                                chrishamm administrators @Adamfilip
                                @Adamfilip Use this one for 3.4.5: https://github.com/Duet3D/InputShapingPlugin/releases/tag/v3.4.1-b1
