    Simplify3d and Filament Timings
    755
    • markzundefined
      markz
      I just updated Simplify3d (yes, after 5 years they actually did an update) and now my most reliable print timing (Filament Usage time) shows n/a. Anyone know what would cause that? I'm running RRF 3.4.2.
        T3P3Tony administrators @markz
        @markz no doubt they changed the syntax for a comment that RRF/DWC needs, can you post a gocde file (or at least the header and the first few hundred lines) here for us to look at.
        markzundefined GeneRisiundefined 3 Replies Last reply Reply Quote 0
        • markzundefined
          markz @T3P3Tony
          @T3P3Tony Here you go. TinyTest.gcode
          • markzundefined
            markz @T3P3Tony
            @T3P3Tony And here is more or less the same file in V4 (it failed to fully load the model def). TinyTestv4.gcode
            Proschi3Dundefined 1 Reply Last reply Reply Quote 0
            • GeneRisiundefined
              GeneRisi @T3P3Tony
              @T3P3Tony V4 says "Filament Length:" at the bottom. V5 says "Material Length:" at the bottom
              • Proschi3Dundefined
                Proschi3D @markz
                @markz post processing script:
                {REPLACE "Material Length" "Filament length"}
                Love my Duet 3 Mini.
                https://www.instagram.com/proschi3d
                https://youtube.com/@proschi3d
                https://www.proschi3d.de
                markzundefined 1 Reply Last reply Reply Quote 2
                • markzundefined
                  markz @Proschi3D
                  @Proschi78 @GeneRisi and @T3P3Tony
                  Yes, editing the summary line to Filament length from Material Length took care of it.
                  Thanks, all.
                  p.s. looking quickly at the code it's on line 729 of Storage\FileInfoParser.cpp in 3.4.2
                    dc42 administrators @markz
                    @markz I'll fix this in 3.5beta2. Please supply a sample GCode file produced by S3D v5 so that I can test it.
                    markzundefined 1 Reply Last reply Reply Quote 1
                    • markzundefined
                      markz @dc42
                      @dc42 Here you go. This prints a small object using PETG. Let me know if you want something different. Looking at the GCode file, line 266 calls my init macro - which you can just comment out - it does a home then wipes the nozzle.
                      Mark
                      SmallTestBody.stl
                      S3D_V5_Test.gcode
                        @markz thanks. It's a good thing I asked you for a file because I had failed to notice the change in case of the letter L in the text to search for! I now have this working in the 3.5 source code.
                        markzundefined dvmourikundefined 2 Replies Last reply Reply Quote 1
                        • markzundefined
                          markz @dc42
                          @dc42 Thank you very much.
                          • dvmourikundefined
                            dvmourik @dc42
                            @dc42 Just to let you know we updated one of our machines to 3.5.0-b3 still with Simplify3D 5.0.0 and 5.1.0 no filament usage in the Jobs lists.
                            Bigger and bigger… sky is the limit.
                            • salmankhan886111undefined
                              salmankhan886111
                              I am in the same exact boat. I’ve had s3d I think since it’s inception. It was unpleasantly expensive but it was also just far better that the slap dash free sliders at the time (manual supports and a good preview were a game changer). But I’ve just been using it on momentum for the last few years.
                              New slices have interesting infills and organic tree ports and all sorts of fun feature. I was hoping s3d would step up so I wouldn’t have to recalibrate everything for a new slicer, but I think we’ve reached that point.
                                dc42 administrators @dvmourik
                                @dvmourik please supply a sample GCode file.
                                dvmourikundefined 1 Reply Last reply Reply Quote 0
                                • dvmourikundefined
                                  dvmourik @dc42
                                  Here are 3 versions (5.0.0 and 5.0.1 and 5.1.0)
                                  S3D500-Cube250micron_30m_15gr_PLA_T3500SE_08n.gcode
                                  S3D510-Caps_2h40m_PLA_T3000SE_1n.gcode
                                  S3D501-Cube300micron_40m_8gr_PLA_T3500SE_04n.gcode
                                    @dvmourik thanks. The filament length in those files is already recognised in the 3.5.0-beta.3 build of RRF. I have back-ported the change so that it will be included in the forthcoming 3.4.6 release too.
                                      salmankhan886111
                                      This post is deleted!
                                      1 Reply Last reply Reply Quote -1
