    SBC Problem
    512
    • Macwolfundefined
      Macwolf
      I have a tool changer (E3D self-made) boards Duet 3 6XD, 3HC and toolboards.
      it runs in normal mode, with a Raspberry4/4GB in SBC mode, it's a disaster. when I press Home All, coupler, 15s delay,Y, 30s delay. and Z is not moved at all.
      the 6XD controls 5 JMC-CloseLoop X,Y and 3xZ
      does anyone have any ideas thanks
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @Macwolf
        @Macwolf maybe provide more details? Start with your config.g, homing files and M122 outputs for each board
        • Macwolfundefined
          Macwolf
          homez.g homey.g homex.g homec.g homeall.g config.g
          M122 Report.txt
          the machine is running in stand alone mode, but there is this delay in connection with the SBC.
          M122 in SBC or Stand olone?
          jay_s_ukundefined Macwolfundefined 2 Replies Last reply Reply Quote 0
            jay_s_uk @Macwolf
            @Macwolf m122 from the 3HC and toolboards. Send M122 BX where X is the CAN address of the board
            • Macwolfundefined
              Macwolf @Macwolf
              X, Y and 3xZ are all on the motherboard
              Bildschirmfoto 2022-12-30 um 12.04.45.png Bildschirmfoto 2022-12-30 um 12.05.15.png Bildschirmfoto 2022-12-30 um 12.05.30.png Bildschirmfoto 2022-12-30 um 12.05.51.png
                dc42 administrators @Macwolf
                @Macwolf it should be M122 B23, not M122 P23. And so on.
                  @Macwolf said in SBC Problem:
                  Do you mean that it runs OK in standalone mode, but doesn't run properly in SBC mode? If that's what you mean, are you certain that the config.g and homing files you are using on the SD card in the SBC are identical to the ones you used on the SD card in the Duet when you ran in standalone mode?
                  Macwolfundefined 1 Reply Last reply Reply Quote 0
                  • Macwolfundefined
                    Macwolf @dc42
                    @dc42 said in SBC Problem:
                    Yes the files are idendical
                    the config is of course a bit different (lan settings)
                    • Macwolfundefined
                      Macwolf
                      with the 3.5beta 1 the SBC mode works.
                      Z moves, but there are still bugs.
                      I'm looking forward to the 3.5 final
                        @Macwolf I'm not certain this is the problem, however M92 takes only a single Z parameter even if you have multiple Z drivers.
                        • Macwolfundefined
                          Macwolf @dc42
                          what do you mean by a parameter? a small example?
                          M92 Z640 ; only ?
                            Phaedrux Moderator @Macwolf
                            M92 Z640 ; only ?
                            correct
                            • Macwolfundefined
                              Macwolf @Phaedrux
                              the error message is gone, only the speed of the Z axis is at 0.5mm/s is that due to the beta status?Z-Speed.jpg
                                M566 X566.00 Y566.00 C2 Z25.00:25.00:25.00 E300:300:300:300		                ; Set maximum instantaneous speed changes (mm/min)
                                M203 X35000.00 Y35000.00 Z3000.00:3000.00:3000.00 C5000 E7200:7200:7200:7200  ; Set maximum speeds (mm/min)
                                M201 X6000.00 Y6000.00 Z300.00:300.00:300.00 C500 E10000:10000:10000:10000			      ; Set accelerations (mm/s^2)
                                M906 X2000 Y2000 Z1500:1500:1500                            ; Set motor currents (mA) Idle motion motors to 30%
                                You should remove the multiple values for the Z axis in all of these commands. It is set per axis. The only time multiple values are required is for extruders as they are independent axis.
                                At what point are you seeing this speed?
                                • Macwolfundefined
                                  Macwolf @Phaedrux
                                  @Phaedrux said in SBC Problem:
                                  when homing above at "requested speed"
                                  and of course the bed that moves in slow motion. Z also moves at 0.5mm/s when moving
                                  • Macwolfundefined
                                    Macwolf @Phaedrux
                                    Great problem solved
                                    • Phaedruxundefined Phaedrux has marked this topic as solved
                                      Great. If you have any more questions, start a new thread and we'll be glad to help.
