    Duet 3 6HC V1.01 VS V1.02
    901
    • weed2allundefined
      weed2all @jay_s_uk
      @jay_s_uk is what I was thinking as well...seeing now the pdf of both version of the boards...
      https://www.thingiverse.com/weed2all/designs
        jay_s_uk @weed2all
        @weed2all I'm pretty sure there was a post somewhere where Tony said it wasn't possible
          dc42 administrators @weed2all
          @weed2all the version 1.01 board has 12V and 5V buck regulators supplied by VIN, both rated at 40V. The version 1.02 has a different buck regulator circuit rated at 60V that provides 12V, and 5V buck regulator that is powered from that 12V rail. In addition the OUT mosfets on the version 1.02 are rated at 60V instead of 40V, and various capacitors are rated at 63V instead of 5V.
          chimaeraghundefined oliofundefined weed2allundefined Ironman777undefined 4 Replies Last reply Reply Quote 0
          • chimaeraghundefined
            chimaeragh @dc42
            Add a 2x6 header for an ESP wifi module - note this requires the module and firmware support to be completed.
            Any info on whether this will be supported in RRF3.5? Also what wifi modules will be supported?
            Duet 2 Wifi, Ooznest Workbee CNC 1510
            • oliofundefined
              oliof @dc42
              @dc42 is 12V still limited to 800mA on 1.02?
              EDIT: Reviewing the documentation, the wiring diagram says 12V is limited to 800mA, but the description of the OUT banks says the limit is 2A ... so if I were to use a 12V fan with 2A power draw, could I use one bank for that, i.e. OUT7-9 with nothing else connected on that bank?
              • weed2allundefined
                weed2all @dc42
                @dc42 thanks for reply...I think I'll sell my duet 3 unused board and buy the new version!
                  dc42 administrators @chimaeragh
                  @chimaeragh yes RRF 3.5beta1 supports the optional wifi module. The module uses a ESP32S3.
                    dc42 administrators @oliof
                    @oliof the maximum 12V current is still 800mA in version 1.02. The 2A limit on each of OUT4 thru OUT9 applies when the corresponding jumper is set to VIN.
                    oliofundefined 1 Reply Last reply Reply Quote 1
                    • oliofundefined
                      oliof @dc42
                      @dc42 thanks for clarification. The way it's documented on the Duet3 mini 5+ page is a bit more clear on this.
                        @oliof I've passed your comment on to our documentation maintainer.
                        • Ironman777undefined
                          Ironman777 @dc42
                          @dc42 said in Duet 3 6HC V1.01 VS V1.02:
                          Can I apply 36 volts to this 1.01 with the VIN being rated at 40 volts
                            droftarts administrators @Ironman777
                            @Ironman777 We recommend 32V maximum for the 6HC v1.01. This gives some headroom for voltage generated by stepper motors coming to a sudden stop.
