    Horrible print quality since upgrading
    29
    5.7k
    • totalitarianundefined
      totalitarian
      Just for reference here is a 80mm box, you can clearly the diagonal lines. They are like little bulges (sorry - so hard to capture on camera clearly) It's a cyclic pattern.
        totalitarian
        DjDemonD, you sent me these settings on another forum, let me give them a try…
        [c]M92 E4130 ; 1.8 degree motor on 1/16th microstepping
        M906 X1100 Y1100 Z1100 E800 I60 ;e motor current 800 (though I am lead to believe you can get away with as little as 500ma depending on the motor, lower is better I'm told)
        M201 X3000 Y3000 Z200 E200 ;low E -accel to achieve faster reverses, go lower if your having stalling issues rather than upping the current
        M203 X15000 Y15000 Z15000 E3600 ;max speed
        M572 D0 S0 ; pressure advance off, although it might help to use a tiny bit like 0.025 to account for the twist in the drive cable but this is splitting hairs
        M566 X1000 Y1000 Z1000 E100 ;low jerk value, higher than with nimble which I use 40 for, but then flex3drive is geared higher and therefore has needs less torque to start[/c]
          totalitarian
          OK upped my acceleration and jerk to these below. Aside from the printer being a little noiser, not difference in quality 😞
          [c]M566 X1000 Y1000 Z1000 E100 ;low jerk value,
          M203 X30000 Y30000 Z600 E3000 ; Set maximum speeds (mm/min)
          M201 X500 Y500 Z100 E200 ; Set accelerations (mm/s^2)
          M572 D0 S0 ;pressure advance off
          M906 X800 Y800 Z600 E800 I60 ; Set motor currents (mA) and motor idle factor in per cent[/c]
          dc42 is the duet capable of 1/8 stepping?
            deckingman
            @totalitarian:
            The gcode Wiki is always a good resource for these sorts of question - see here https://duet3d.com/wiki/G-code#M350:_Set_microstepping_mode
            • Shenundefined
              Shen
              I'm also had a similar issue. I think it's caused by the non-linearity of micro steps. From my calculation, the pattern is repeating every full step of the stepper motor. I also tried a 0.9 degree stepper motor instead of the 1.8 degree motor I was using, the length of the pattern halved. Stepper motor current does affect micro stepping linearity, you need to find the optimal value. You may also try replacing the extruder motor which worked for me.
                totalitarian
                @deckingman:
                @totalitarian:
                Ah so that's why even though I set 1/8 my steps didn't need to change. Thanks. Running a new test at 1/8….
                  totalitarian
                  @Shen:
                  So are you saying it was the motor in the end that was causing the issue? Was it a failing motor?
                    totalitarian
                    Just noticed this in the wiki
                    If using a highly-geared extruder (for example, an extruder that uses a flexible drive cable to transmit the torque from the motor to a worm reduction gear), use a short low-inductance 1.8deg/step motor to drive it.
                    I'm not too electrically minded, but this is my motor, is it suitable?
                    https://www.amazon.co.uk/gp/product/B01J3IKKHW/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
                    Weight: 279g
                    Voltage: 3.3V
                    Current: 1.5A
                    Power: 35W
                    Step Angle: 1.8°
                    Phases: 2
                    Resistance: 5.2Ω±10%
                    Inductance: 9.0mH±20%
                    Holding Torque: 4.0Kg ·cm
                    Detent Torque: 150g·cm
                    Insulation resistance: 500VDC 100MΩ
                    Insulation class: B
                    Rotor inertia: 57g ·cm²
                      No. That motor is long and it has high inductance.
                      • Shenundefined
                        Shen
                        @totalitarian:
                        @Shen:
                        It's not failing, but it might not be the best option for your extruder.
                          totalitarian
                          @dc42:
                          Could you suggest a specific stepper?
                            totalitarian
                            BTW, I reduced the steps to 1/8 but it made no difference. The diagonal lines had the same frequency 😞
                            • botundefined
                              bot
                              Is there any way to revert to the original extruder setup, so that you can isolate the variables?
                              *not actually a robot
                                totalitarian
                                Sure, i'll refit my old titan this evening and do some more test prints
                                • DjDemonDundefined
                                  DjDemonD
                                  This type of motor works for me for both flex3drive/nimble and titan:
                                  https://www.omc-stepperonline.com/hybrid-stepper-motor/nema-17-bipolar-18deg-13ncm-184ozin-1a-35v-42x42x20mm-4-wires-17hs08-1004s.html
                                  Its lightweight, and has enough torque to drive a geared extruder.
                                  Long/large motors are needed when you need to achieve high holding torque, or to move a large heavy load such as a large 3 leadscrew bed etc.. for turning an extruder with gearing like 40:1 or 30:1 requires almost no torque at all. What more important is can you spin it up quickly and reverse it quickly.
                                  The image with the cube above, does show what appears to be pulsing of the extruder, maybe this is the effect of the drive cable tightening and loosening as it turns. Grease it up and look at the path it takes to see if you can keep it from having to go around a tight radius.
                                  www.precisionpiezo.co.uk
                                    totalitarian
                                    Yeah i'm not convinced I have the optimal route for the cable worked out yet. I've also noticed that the cable doesn't spin concentrically at the motor end. Not sure if this makes a difference or not or how I would fix this
                                    https://photos.app.goo.gl/lTdTj8taKpn6q29Z2
                                    The only other stepper I have kicking around is the one recommend for the titan
                                    https://e3d-online.com/nema17-slimline-stepper-motor
                                    but this is 0.9deg.
                                      T3P3Tony administrators
                                      I agree with bot, if its possible to split the issue to isolate the issue(s). I know people on this forum have had good success with flexible drives but minimising the number of variables changing at once can help to find the problem quicker.
                                        totalitarian
                                        OK I switched back to my E3D titian extruder. Not good news. Constantly skipping and then my x axis started stuttering too!
                                        https://photos.app.goo.gl/MGCq8oO2NUPvVVIT2
                                        Here is my config for the titian
                                        [[language]]
                                        M569 P0 S0 ; Drive 0 goes backwards
                                        M569 P1 S0 ; Drive 1 goes backwards
                                        M92 X80 Y80 Z400 E800 ; Set steps per mm
                                        M350 E16 I1 ; Configure microstepping with interpolation
                                        M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
                                        M566 X300 Y300 Z24 E300 ; Set maximum instantaneous speed changes (mm/min)
                                        M203 X30000 Y30000 Z600 E300 ; Set maximum speeds (mm/min)
                                        M201 X500 Y500 Z100 E250 ; Set accelerations (mm/s^2)
                                        M906 X800 Y800 Z800 E1100 I30 ; Set motor currents (mA) and motor idle factor in per cent
                                        M84 S30 ; Set idle timeout
                                        And here is my M112
                                        M122
                                        [[language]]
                                        Used output buffers: 3 of 32 (8 max)
                                        RepRapFirmware for Duet WiFi version 1.19 running on Duet WiFi 1.0
                                        Board ID: 08DGM-95BNL-MGPSJ-6J1F8-3SD6T-1KZ3W
                                        Static ram used: 21176
                                        Dynamic ram used: 95960
                                        Recycled dynamic ram: 1648
                                        Stack ram used: 1304 current, 4840 maximum
                                        Never used ram: 7448
                                        Last reset 00:02:17 ago, cause: software
                                        Last software reset reason: User, spinning module GCodes, available RAM 3232 bytes (slot 2)
                                        Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
                                        Error status: 0
                                        Free file entries: 10
                                        SD card longest block write time: 0.0ms
                                        MCU temperature: min 18.9, current 19.4, max 20.6
                                        Supply voltage: min 11.5, current 11.5, max 11.7, under voltage events: 0, over voltage events: 0
                                        Driver 0: stalled standstill
                                        Driver 1: standstill
                                        Driver 2: stalled standstill
                                        Driver 3: stalled standstill
                                        Driver 4: standstill
                                        Date/time: 2017-11-10 23:38:33
                                        Slowest main loop (seconds): 0.004425; fastest: 0.000034
                                        MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                                        Bed compensation in use: none
                                        Bed heater = 0, chamber heater = -1
                                        Heater 1 is on, I-accum = 0.0
                                        Segments left: 0
                                        Movement lock held by null
                                        http is idle in state(s) 0
                                        telnet is idle in state(s) 0
                                        file is idle in state(s) 0
                                        serial is idle in state(s) 0
                                        aux is idle in state(s) 0
                                        daemon is idle in state(s) 0
                                        queue is idle in state(s) 0
                                        Code queue is empty.
                                        Network state is running
                                        WiFi firmware version 1.19
                                        WiFi MAC address 2c:3a:e8:0b:07:75
                                        WiFi Vcc 3.02, reset reason Turned on by main processor
                                        WiFi flash size 4194304, free heap 38904
                                        WiFi IP address 192.168.1.56
                                        WiFi signal strength -37dBm
                                        HTTP sessions: 2 of 8
                                        Socket states: 2 0 0 0 0 0 0 0
                                        Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                          Was that M122 report produced after a print, or before? The power supply voltage is a little low, and if it drops further when the heaters are on then you could be getting motor driver dropout due to the voltage going too low. OTOH if that M122 report is the first one you did after a print, then the minimum voltage is OK and there are no under-voltage events reported.
                                            totalitarian
                                            It was after, i'll boost it up a little
