Upgrading after 1.5yrs
Firmware installation
487
    tsitalon1
    Hey guys,
    Long story short, my printers sat in storage for 1.5 years, just go them back online and working.
    I'm currently rocking the below versions:
    Board: Duet 2 WiFi (2WiFi)
    Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2.2 (2021-02-11)
    Duet WiFi Server Version: 1.25
    I'd like to upgrade to the latest stable releases for all the nifty new bells and whistles, but the release notes are longer than a college essay - LOL
    Anyone have any cliff notes as far as config changed needed to remain functional after the upgrade?
    undefined 1 Reply Last reply 7 Jan 2023, 08:46 Reply Quote 0
      jay_s_uk @tsitalon1
      @tsitalon1 unless you're running DAA, there shouldn't be anything in your config which doesn't work (IIRC).
      I've ran the same config on 3.2.2, 3.3 and 3.4.4
      undefined 1 Reply Last reply 8 Jan 2023, 01:12 Reply Quote 0
        tsitalon1 @jay_s_uk
        @jay_s_uk - Thank you.
        Can I go straight to 3.44, or do I need to take smaller upgrade steps to get to 3.44 ?
        undefined 1 Reply Last reply 8 Jan 2023, 06:41 Reply Quote 0
          jay_s_uk @tsitalon1
          @tsitalon1 you may need to go 3.3 then 3.4.5
          undefined 1 Reply Last reply 8 Jan 2023, 17:45 Reply Quote 0
            tsitalon1 @jay_s_uk
            @jay_s_uk Thx !
            undefined 1 Reply Last reply 8 Jan 2023, 17:58 Reply Quote 1
              tsitalon1 @tsitalon1
              Well I got to 3.3, but 3.44 or 3.45 just causes an error when trying to update:
              Error M997: In-application programming binary "0:/firmware/Duet2_SDiap32_WiFiEth.bin" not found
              undefined 1 Reply Last reply 8 Jan 2023, 17:59 Reply Quote 0
                jay_s_uk @tsitalon1
                @tsitalon1 can you reupload the 3.3 zip file then try again?
                undefined 1 Reply Last reply 8 Jan 2023, 18:16 Reply Quote 0
                  tsitalon1 @jay_s_uk
                  @jay_s_uk said in Upgrading after 1.5yrs:
                  Won't re-apply 3.3 now, same error, even though I'm already on 3.3:
                  Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.3 (2021-06-15)
                  I'm using the Duet2CombinedFirmware.bin file
                  undefined undefined 2 Replies Last reply 8 Jan 2023, 18:23 Reply Quote 0
                    dc42 administrators @tsitalon1
                    @tsitalon1 upload file Duet2_SDiap32_WiFiEth.bin from the release to your Duet; then you should be able to upgrade to 3.4.x.
                      jay_s_uk @tsitalon1
                      @tsitalon1 I meant use the combinedduet2and3.zip or whatever it's called
                      undefined 1 Reply Last reply 8 Jan 2023, 18:39 Reply Quote 0
                        tsitalon1 @jay_s_uk
                        Worked now on:
                        Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.5 (2022-11-30)
                        Duet WiFi Server Version: 1.27
                        Thank you both !
                        Now to see if things still work... 🙂
                        undefined 1 Reply Last reply 8 Jan 2023, 18:45 Reply Quote 0
                          Looks like i lost my extruder after the upgrades:
                          M308 S0 P"bed_temp" Y"thermistor" R4700 T100000 B3950 ; define bed temperature sensor
                          M308 S1 P"e0_temp" Y"thermistor" T100000 B4815 C7.06e-8 R4700 ; define E0 temperature sensor
                          M950 H0 C"bed_heat" T0 ; heater 0 uses the bed_heat pin, sensor 0
                          M950 H1 C"e0_heat" T1 ; heater 1 uses the e0_heat pin and sensor 1
                          M140 H0 ; the bed heater is heater 0
                          M307 H1 R2.546 C123.4 D3.51 S1.00
                          M950 F0 C"fan0" Q125 ; create fan 0 on pin fan0 and set its frequency
                          M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
                          M106 P2 S1 H0 T30 ; set fan 2 value. Thermostatic control is turned on
                          M563 P0 D0 H1 S"HotEnd" ; Define tool 0
                          undefined 1 Reply Last reply 8 Jan 2023, 18:58 Reply Quote 0
                            T3P3Tony administrators @tsitalon1
                            @tsitalon1 send M98 P"config.g" to run your config.g file after the machine has booted it will show you which command(s) have errors in them.
                            undefined 1 Reply Last reply 8 Jan 2023, 19:30 Reply Quote 0
                              tsitalon1 @T3P3Tony
                              @T3P3Tony No errors noted:
                                tsitalon1
                                M122 only listing one heater, but I see nothing wrong with my heater section in Config.g:
                                  tsitalon1
                                  Figured it out, 3.3 release notes listed this:
                                  All extruders must be declared explicitly using M584. In previous firmware versions, one default extruder was assign to driver 3.
                                  Once I input M584 E3 in my config.g, it now listed both heaters and my extruder... off to a test print
                                  • undefined Phaedrux marked this topic as a question 10 Jan 2023, 04:53
                                  • undefined Phaedrux has marked this topic as solved 10 Jan 2023, 04:53
                                  6 out of 16
