    Upgrading after 1.5yrs
    Firmware installation
    505
      jay_s_uk @tsitalon1
      @tsitalon1 unless you're running DAA, there shouldn't be anything in your config which doesn't work (IIRC).
      I've ran the same config on 3.2.2, 3.3 and 3.4.4
      tsitalon1undefined 1 Reply Last reply Reply Quote 0
      • tsitalon1undefined
        tsitalon1 @jay_s_uk
        @jay_s_uk - Thank you.
        Can I go straight to 3.44, or do I need to take smaller upgrade steps to get to 3.44 ?
          jay_s_uk @tsitalon1
          @tsitalon1 you may need to go 3.3 then 3.4.5
            tsitalon1 @jay_s_uk
            @jay_s_uk Thx !
            tsitalon1undefined 1 Reply Last reply Reply Quote 1
              tsitalon1 @tsitalon1
              Well I got to 3.3, but 3.44 or 3.45 just causes an error when trying to update:
              Error M997: In-application programming binary "0:/firmware/Duet2_SDiap32_WiFiEth.bin" not found
                jay_s_uk @tsitalon1
                @tsitalon1 can you reupload the 3.3 zip file then try again?
                  tsitalon1 @jay_s_uk
                  @jay_s_uk said in Upgrading after 1.5yrs:
                  Won't re-apply 3.3 now, same error, even though I'm already on 3.3:
                  Board: Duet 2 WiFi (2WiFi)
                  Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.3 (2021-06-15)
                  Duet WiFi Server Version: 1.25
                  I'm using the Duet2CombinedFirmware.bin file
                  dc42undefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                    dc42 administrators @tsitalon1
                    @tsitalon1 upload file Duet2_SDiap32_WiFiEth.bin from the release to your Duet; then you should be able to upgrade to 3.4.x.
                      jay_s_uk @tsitalon1
                      @tsitalon1 I meant use the combinedduet2and3.zip or whatever it's called
                        tsitalon1 @jay_s_uk
                        Worked now on:
                        Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.5 (2022-11-30)
                        Duet WiFi Server Version: 1.27
                        Thank you both !
                        Now to see if things still work... 🙂
                          Looks like i lost my extruder after the upgrades:
                          M308 S0 P"bed_temp" Y"thermistor" R4700 T100000 B3950 				; define bed temperature sensor
                          M143 H0 S120                                                        ; Set temperature limit for heater 0 to 120C
                          M308 S1 P"e0_temp" Y"thermistor" T100000 B4815 C7.06e-8 R4700 		; define E0 temperature sensor
                          M950 H0 C"bed_heat" T0 ; heater 0 uses the bed_heat pin, sensor 0
                          M950 H1 C"e0_heat" T1 ; heater 1 uses the e0_heat pin and sensor 1
                          M140 H0 ; the bed heater is heater 0
                          M143 H1 S280                   				             			; Set temperature limit for heater 1 to 280C
                          M307 H1 R2.546 C123.4 D3.51 S1.00
                          M950 F0 C"fan0" Q125                           						; create fan 0 on pin fan0 and set its frequency
                          M106 P0 S0 H-1                                 						; set fan 0 value. Thermostatic control is turned off
                          M950 F1 C"fan1" Q500                           						; create fan 1 on pin fan1 and set its frequency
                          M106 P1 S1 H1 T45                              						; set fan 1 value. Thermostatic control is turned on
                          M950 F2 C"fan2" Q500                           						; create fan 2 on pin fan2 and set its frequency
                          M106 P2 S1 H0 T30                              						; set fan 2 value. Thermostatic control is turned on
                          M563 P0 D0 H1 S"HotEnd"                                             ; Define tool 0
                          G10 P0 X0 Y0 Z0                                                     ; Set tool 0 axis offsets
                          G10 P0 R0 S0                                                        ; Set initial tool 0 active and standby temperatures to 0C
                            T3P3Tony administrators @tsitalon1
                            @tsitalon1 send M98 P"config.g" to run your config.g file after the machine has booted it will show you which command(s) have errors in them.
                              tsitalon1 @T3P3Tony
                              @T3P3Tony No errors noted:
                                tsitalon1
                                M122 only listing one heater, but I see nothing wrong with my heater section in Config.g:
                                  tsitalon1
                                  Figured it out, 3.3 release notes listed this:
                                  All extruders must be declared explicitly using M584. In previous firmware versions, one default extruder was assign to driver 3.
                                  Once I input M584 E3 in my config.g, it now listed both heaters and my extruder... off to a test print
                                  • Phaedruxundefined Phaedrux has marked this topic as solved
