    SAMMYC21 ERCF
    Hardware dev
    8
    25
    1.6k
    • Th0mpyundefined
      Th0mpy @dc42
      @dc42 That seemed to fix it. Just updating alone to 3.5 was enough to handle the filament sensor, but when I enabled the end-stop it crashed again. I had to reduce a little further so I also reduced buffer sizes for UART.
      Everything works together now. Thank you for your help! I have a bunch of manual macros working now so I just need to automate it all.
      Usually the team that scores the most points wins the game.
      • oliofundefined
        oliof @o_lampe
        @o_lampe
        ERCF: https://github.com/EtteGit/EnragedRabbitProject
        Canned ERCF: https://github.com/gixxerfast/Canned-ERCF-board
        Th0mpyundefined 1 Reply Last reply Reply Quote 1
        • Th0mpyundefined
          Th0mpy @oliof
          If you decide to undertake the ERCF, hit me up. I have a few boards that I made. You can't buy just one. I also made some adjustments (manually) to the board to solve the servo issue experienced by some.
          I'll post about it later in another thread once I get it a little more automated.
          jay_s_ukundefined 1 Reply Last reply Reply Quote 1
            jay_s_uk @Th0mpy
            @Th0mpy are you using the ERCF sensor under the extruder?
            Th0mpyundefined 1 Reply Last reply Reply Quote 0
            • Th0mpyundefined
              Th0mpy @jay_s_uk
              @jay_s_uk Not at the moment. I am only using the 1/2 bondtech gear in the ERCF itself for confirmation of bowden distance to load the extruder.
              I am thinking of adding a sensor in the extruder to simplify, but there is no eloquent way to add a reliable filament sensor (i.e. magnetic filament monitor) to the stealthburner yet. They do have a simple switch sensor but I really don't like the washer approach.
              That said, I am playing with the laser filament monitor, which would fit into the stealthburner nicely. It does not, however, work as well with the PET filament. I did contact the manufacturer to get their specs and programming guide for the sensor, but I haven't had time to play with it yet.
              • oliofundefined
                oliof @Th0mpy
                @Th0mpy it may be worth looking into https://reprap.org/forum/read.php?424,889788
                Th0mpyundefined OwenDundefined 2 Replies Last reply Reply Quote 0
                • Th0mpyundefined
                  Th0mpy @oliof
                  @oliof Good ole Forest Mimms, I had a few of his books from Radio Shack when I grew up.
                  I will have to check this out, I was considering something like that but was leaning towards something already manufactured. This is cool!
                  • OwenDundefined
                    OwenD @oliof
                    @oliof
                    That is cool.
                    Have you integrated it on RRF?
                    If so, can you detail it (in a new post)?
                    Th0mpyundefined oliofundefined VoodooBaneundefined 3 Replies Last reply Reply Quote 0
                    • Th0mpyundefined
                      Th0mpy @OwenD
                      @OwenD Of course! I plan to share what I have this weekend(ish). I'll post a new thread on the subject.
                      • oliofundefined
                        oliof @OwenD
                        @OwenD I have not built that myself, nor integrated into RRF. I am just reading that section of the venerable reprapforum and sometimes interesting stuff comes up.
                        • VoodooBaneundefined
                          VoodooBane @OwenD
                          @OwenD Did you make a new Post? I am soldering my own canned ercf board now. Can you share the firmware card you used?
                          OwenDundefined 1 Reply Last reply Reply Quote 0
                          • OwenDundefined
                            OwenD @VoodooBane
                            @VoodooBane
                            I think you need to ask @Th0mpy
                            I'm just an onlooker
                              VoodooBane
                              @Th0mpy
                              Hey thompy, Do you have any of the boards still? I would like one from you if you do
                              @Gixxerfast I sourced a bunch of the SMD components myself. However, it looks to be that some components are missing from your Excel document. I didn't think to look for whatever reason before buying components.
                              The components you did not include in the Excel sheet and what I am missing.
                              D1, D2
                              C3, C4, C6
                              R8, R11, R12, R13, R14, R15, R16, R17, R18, R19
                              I really hope I am not screwed...
                              See my screenshot.
                              VoodooBaneundefined 1 Reply Last reply Reply Quote 0
                                VoodooBane @VoodooBane
                                @VoodooBane I was actually able to find what the components where in Kicad.
                                • Th0mpyundefined
                                  Th0mpy @VoodooBane
                                  @VoodooBane Hey there, sorry for the delay. I might have a couple left, let me know if you're still interested.
                                  • Th0mpyundefined
                                    Th0mpy @OwenD
                                    @OwenD Haven't touched it in a hot minute, but as I recall that I had a custom firmware to handle the two steppers. Are you still looking for this?
                                    EDIT: I found the firmware I used, it was the one originally from @Gixxerfast , you'll need to compile it: https://github.com/gixxerfast/Duet3Expansion/tree/cannedboard
                                      VoodooBane @Th0mpy
                                      @Th0mpy
                                      @Gixxerfast
                                      I need to look at the settings, so I get emailed when someone responds; sorry about that.
                                      I might be interested. I would like to see if I soldered correctly. (it is my first SMD DIY project)
                                      But I would like another one since it is going on an Idex printer if I want to go super extreme, lol.
                                      Do you know if @gixxer is planning to make a more modern firmware? That latest is 3.4 from what I remember on Gixxer's GitHub and the new stable release for duet is 3.46
                                      • Th0mpyundefined
                                        Th0mpy @VoodooBane
                                        @VoodooBane I don't know, I haven't seen them online for quite some time. It's pretty simple, however, to update and compile the firmware. To be honest it's been a hot minute since I touched it last.
                                        I was looking around for someone else and either I sold them all or completely lost them in my shop 😄
                                        I am considering a new order of them, if I get enough interest it would push my decision up a notch.
