    Duet 2 Ethernet - no Ethernet after Firmware upgrade
    Duet Web Control
    883
      droftarts administrators @xxexx
      @xxexx Is config.g being executed when powered from VIN? I don't know why it wouldn't be, and can't think of a way of checking without plugging in USB. You can connect USB under VIN power; you just need to take some precautions. See https://docs.duet3d.com/User_manual/Overview/USB_ground_loops
      What firmware version were you on previously? Maybe rerun the update, or try reverting to the previous version you were using. Though I can't think why the firmware version would be causing this issue.
      xxexxundefined 1 Reply Last reply Reply Quote 0
      • xxexxundefined
        xxexx @droftarts
          @xxexx I think the voltage regulators look okay. How old is this board? Where did you buy it from?
          • xxexxundefined
            xxexx @droftarts
            @droftarts
            i checked the system directory: it is empty (!). I now try to install the Duet2combinedfirmware .bin file - "Connection lost, attempting to reconnect..."
              jay_s_uk @xxexx
              @xxexx sounds like the sd card has been wiped then. maybe try a different sd card
              • xxexxundefined
                xxexx @jay_s_uk
                @jay_s_uk
                i now did copy all installation files on the SD Card again and the bboard did reboot and reinstall firmware when connected to USB Power.
                but ths Sytem directoty shows only:00572256-210b-44df-939a-c3058bd56d15-image.png
                  jay_s_uk @xxexx
                  @xxexx thats incorrect. whats in sys on the SD card?
                  • xxexxundefined
                    xxexx @jay_s_uk
                      jay_s_uk @xxexx
                      @xxexx then you need to put all your config files back. hopefully you've got a backup otherwise use the configurator to generate a base set of files
                      xxexxundefined 2 Replies Last reply Reply Quote 0
                      • xxexxundefined
                        xxexx @jay_s_uk
                        @jay_s_uk
                        • xxexxundefined
                          xxexx @jay_s_uk
                          @jay_s_uk
                          oh fuck me, i dont have a backup and it took me days to get everything right incl. the bltouch - i guess i just learned to make backups...
                          Any way, thanks a lot for your help, id did not occur to me to check the SD Card
