Setting up Eclipse to Develop Firmware
Ok, I will try what you said above.
Leaving out the "/bin" part resulted in no changes in the error.
For your other suggestion (putting full path instead of just gcc), I replaced gcc with arm-none-eabi-gcc (in the command box of the "Cross G++ Linker"). I got this error:
Building target: DuetWiFiFirmware.elf
Invoking: Cross G++ Linker
arm-none-eabi-arm-none-eabi-gcc -L"/Users/John/eclipse-worksp … [ … ] … robeProgrammer.o -lCoreNG -Wl,--end-group -lm -gcc
/bin/sh: arm-none-eabi-arm-none-eabi-gcc: command not found make: *** [DuetWiFiFirmware.elf] Error 127So it didn't work, so I'll change it back to just gcc.
For reference, when changing it back to just gcc, I get the same error as before. Although from the above error, it looks like it was looking in /bin/sh. So maybe I should put the gcc file in a folder called sh?
arm-none-eabi-gcc -L"/Users/John/eclipse-w … [ … ] … rc/ZProbeProgrammer.o -lCoreNG -Wl,--end-group -lm -gcc
arm-none-eabi-gcc: error: : No such file or directory
make: *** [DuetWiFiFirmware.elf] Error 1Interesting how the prior error was "command not found", but then this error is "No such file or directory."
Notice the lone colon in the error?
Maybe it was looking for a file or directory that had no name? Or had a space in the name or something?
@jml:
Good catch! There is a "" after the -Wl,–start-group in your linker command line. When I'm in the office I'll see what should be there.
@jml:
This is a common mistake, due to poor error messages: in the first case, this is sh which can't find gcc, in the second case, this is gcc which can't find a file. sh reports which file it can't find (gcc, here), but gcc does not report the missing file…
I suspect a library path not setup correctly, so gcc can't find a .o to build something else.
Here is the link command I get:
arm-none-eabi-gcc -L"C:\Eclipse\Firmware\CoreNG\SAM4E8E" -Os -Wl,–gc-sections -Wl,--fatal-warnings -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -TC:\Eclipse\Firmware\CoreNG\variants\duetNG\linker_scripts\gcc\flash.ld -Wl,-Map,C:\Eclipse\Firmware\RepRapFirmware\DuetWiFi/DuetWiFiFirmware.map -o "DuetWiFiFirmware.elf" -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group "C:\Eclipse\Firmware\CoreNG\SAM4E8E\cores\arduino\syscalls.o" ./src/Tools/Filament.o ./src/Tools/Tool.o ./src/Storage/CRC32.o ./src/Storage/FileStore.o ./src/Storage/MassStorage.o ./src/Movement/Kinematics/CartesianKinematics.o ./src/Movement/Kinematics/CoreBaseKinematics.o ./src/Movement/Kinematics/CoreXYKinematics.o ./src/Movement/Kinematics/CoreXYUKinematics.o ./src/Movement/Kinematics/CoreXZKinematics.o ./src/Movement/Kinematics/Kinematics.o ./src/Movement/Kinematics/LinearDeltaKinematics.o ./src/Movement/Kinematics/PolarKinematics.o ./src/Movement/Kinematics/ScaraKinematics.o ./src/Movement/Kinematics/ZLeadscrewKinematics.o ./src/Movement/BedProbing/Grid.o ./src/Movement/BedProbing/RandomProbePointSet.o ./src/Movement/DDA.o ./src/Movement/DriveMovement.o ./src/Movement/Move.o ./src/Libraries/sha1/sha1.o ./src/Libraries/Math/Isqrt.o ./src/Libraries/General/IP4String.o ./src/Libraries/General/StringRef.o ./src/Libraries/Fatfs/ccsbcs.o ./src/Libraries/Fatfs/diskio.o ./src/Libraries/Fatfs/fattime_rtc.o ./src/Libraries/Fatfs/ff.o ./src/Heating/Sensors/CpuTemperatureSensor.o ./src/Heating/Sensors/CurrentLoopTemperatureSensor.o ./src/Heating/Sensors/DhtSensor.o ./src/Heating/Sensors/RtdSensor31865.o ./src/Heating/Sensors/SpiTemperatureSensor.o ./src/Heating/Sensors/TemperatureSensor.o ./src/Heating/Sensors/Thermistor.o ./src/Heating/Sensors/ThermocoupleSensor31855.o ./src/Heating/Sensors/ThermocoupleSensor31856.o ./src/Heating/Sensors/TmcDriverTemperatureSensor.o ./src/Heating/FOPDT.o ./src/Heating/Heat.o ./src/Heating/Pid.o ./src/Heating/TemperatureError.o ./src/GCodes/GCodeBuffer.o ./src/GCodes/GCodeInput.o ./src/GCodes/GCodeMachineState.o ./src/GCodes/GCodeQueue.o ./src/GCodes/GCodes.o ./src/GCodes/GCodes2.o ./src/GCodes/RestorePoint.o ./src/FilamentSensors/Duet3DFilamentSensor.o ./src/FilamentSensors/FilamentSensor.o ./src/FilamentSensors/SimpleFilamentSensor.o ./src/DuetNG/DuetWiFi/Network.o ./src/DuetNG/DuetWiFi/Socket.o ./src/DuetNG/DuetWiFi/WifiFirmwareUploader.o ./src/DuetNG/DueXn.o ./src/DuetNG/FirmwareUpdater.o ./src/DuetNG/FtpResponder.o ./src/DuetNG/HttpResponder.o ./src/DuetNG/NetworkBuffer.o ./src/DuetNG/NetworkResponder.o ./src/DuetNG/SX1509.o ./src/DuetNG/TMC2660.o ./src/DuetNG/TelnetResponder.o ./src/Fan.o ./src/IoPort.o ./src/Logger.o ./src/OutputMemory.o ./src/Platform.o ./src/PortControl.o ./src/PrintMonitor.o ./src/RepRap.o ./src/RepRapFirmware.o ./src/Roland.o ./src/Scanner.o ./src/SoftTimer.o ./src/ZProbeProgrammer.o -lCoreNG -Wl,--end-group -lm -gcc
So the file it's missing on your machine is, on my machine, "C:\Eclipse\Firmware\CoreNG\SAM4E8E\cores\arduino\syscalls.o". That should come from this "Command line pattern" setting in the Cross G++ Linker settings:
${COMMAND} ${FLAGS} ${OUTPUT_FLAG} ${OUTPUT_PREFIX}${OUTPUT} ${LINK_FLAGS_1} "${workspace_loc:/${CoreName}/SAM4E8E/cores/arduino/syscalls.o}" ${INPUTS} ${LINK_FLAGS_2}
I've noticed before that if Eclipse can't find a file, it just omits it from the command line. If you built the SAM4E configuration of CoreNG before you built RRF, that file should be there.
HTH David
Ok we are getting closer to a solution.
I found the missing file here:
/Users/John/eclipse-workspace/CoreNG/SAM4E8E/cores/arduino/syscalls.o
[it appears there with a bunch of other files after building CoreNG]In the RRF Cross G++ Linker "Command line pattern" box, I see this written:
${COMMAND} ${FLAGS} ${OUTPUT_FLAG} ${OUTPUT_PREFIX}${OUTPUT} ${LINK_FLAGS_1} "${workspace_loc:/${CoreName}/SAM4E8E/cores/arduino/syscalls.o}" ${INPUTS} ${LINK_FLAGS_2}Its the same as yours, so seems like its not a problem.
Maybe the problem is with how I build CoreNG and RRF:
- First I right click CoreNG, Build Configurations > Clean All.
- Repeat for RepRapFirmware folder
- Right click CoreNG, Build Configurations > Build Selected… then I select SAM4E8E and hit ok.
- Wait for build to finish (8 seconds)
- Repeat for RepRapFirmware folder, but select DuetWiFi and hit ok.
- Error
Should I build it differently?
That's the correct build order.
In Properties -> C/C++ Build -> Build Variables, do you have CoreName defined as CoreNG ?
For the RepRapFirmware folder, yes it is there. Name: CoreName || Type: String || Value: CoreNG
For the CoreNG folder, nothing is listed in the list. Should it be there?
I really just need to make some small firmware changes and some custom g-code commands.
I purchased the DuetWifi, PanelDue, and am waiting for the Duex5. Hoping to have it solved by the time it arrives! If I can't get it to work on Mac or Windows, I may just uninstall everything and try again when firmware version 1.2 is out.
Thanks for all the help you've provided so far!
I had no problem installing/compiling under linux. You may try to install a linux system in a Virtualbox env, and compile from there.
Ok, I will try. I'm using a decently powered Mac using Parallels to run windows and I assume I can put Linux on here too. Which Linux OS/distribution do you recommend? Ubuntu? I have limited experience with Linux, but I can learn!
So strange though. It seems like the only thing I need to fix is these empty quotation marks and it will fix everything:
-Wl,–start-group ""The file it is looking for is 100% in the right folder. And the command line pattern is exactly how dc42's is.
I run debian, but I think ubuntu is fine too (all dev libs exist).
About the missing path, you can try to replace:
${CoreName}
by
CoreNG
or ${workspace_loc:/${CoreName}
by
to see if it fixes the problem.
LOL, I literally just tried it before reading your post AND IT WORKED!!!!!!
Just in case someone in the future has this problem, this is what I changed:
changed it to:
${COMMAND} ${FLAGS} ${OUTPUT_FLAG} ${OUTPUT_PREFIX}${OUTPUT} ${LINK_FLAGS_1} "/Users/John/eclipse-workspace/CoreNG/SAM4E8E/cores/arduino/syscalls.o" ${INPUTS} ${LINK_FLAGS_2}(make sure the quotes are there but the curly brackets and dollar signs removed).
Thanks everyone!
I'm so happy
Good!
But I think I found the issue. The string:
should be :
"${workspace_loc}:/${CoreName}/SAM4E8E/cores/arduino/syscalls.o}"
There where a missing bracket at the end of the workspace_loc var…
Can you confirm?
When I browse around in the settings, the way that all of the Includes are is like this:
"${workspace_loc:/${CoreName}/asf/common/utils}"So I don't think that was the issue.
Eg. when you write it like this:
"${workspace_loc}:/${CoreName}/SAM4E8E/cores/arduino/syscalls.o}"you have an extra curly bracket because there is one on the far right 2nd last to the end.
