    Idiot's Guide To Upgrading Duet Firmware
    Firmware installation
    5.1k
    • gbartschundefined
      gbartsch @Phaedrux
      @Phaedrux said in Idiot's Guide To Upgrading Duet Firmware:
      Now that you're up and running, I would suggest uploading the 3.4.5 zip file once more in DWC. This will make sure you have all the needed files for the next update in place. These files would have been missed when doing the manual upgrade path.
      Thanks! I uploaded that .zip file and everything went up but when I clicked install (I hope I was supposed to) this error appeared:
      Custom cartesian dinosaur machine; it's a tank but just works so I just keep tweaking it. / Duet Ethernet 1.02 or later / RepRapFirmware for Duet 2 WiFi/Ethernet: 3.4.5 / SuperSlicer
      • gbartschundefined
        gbartsch @Phaedrux
        Glad you got it all up and going.
        😃 I could not have done it without you. Thank you again!!
        I looked at your profile and funnily enough we're almost neighbors; I live in Alberta. If you ever are in Edmonton stop by and visit.
        • gbartschundefined
          gbartsch
          Aside from making some adjustments to some acceleration and speed change settings I believe everything is working except the part cooling fans won't turn on automatically; I can turn them on manually in DWC.
          The definitions are as follows:
          ; Fans. The comments are mixed up I think. They dont match the definitions
          M950 F0 C"fan1" Q500                                  ; create fan 1 on pin fan1 and set its frequency / this is the hotend fan
          M106 P0 S0 H1 T45                                     ; set fan 1 value. Thermostatic control is turned on
          M950 F2 C"fan0" Q500                                  ; create fan 0 on pin fan0 and set its frequency
          M106 P2 S0 H-1                                        ; set fan 0 value. Thermostatic control is turned off
          I think something is mixed up.
          I also think the fans may be wired to wrong pins on the board but wasn't the one who set up the board and can't check on my own.
          The hotend fan works properly. The two part cooling fans spin as one.
            Phaedrux Moderator @gbartsch
            @gbartsch said in Idiot's Guide To Upgrading Duet Firmware:
            Small world. I have two brothers living in Edmonton actually. I don't get down there very often anymore though.
            gbartschundefined 1 Reply Last reply Reply Quote 0
              Can you post the full config.g as it is now? Would need to see the tool definition as well. Also ideally know which is connected where.
              Are they wired together in parallel to a single header, or one to each?
              • gbartschundefined gbartsch referenced this topic
              • gbartschundefined
                gbartsch @Phaedrux
                @Phaedrux I'm thinking they are wired together in parallel. I can't look but my friend who set up the machine might be able to take a look at the wiring in a little over a week. Then I could say for sure.
                I played with the fan definitions after looking at the old working definitions and came up with this:
                M950 F0 C"fan0" Q500                      ; create fan 0 on pin fan0 and set its frequency
                M106 P0 S0 H-1                                  ; set fan 0 value. Thermostatic control is turned off
                M950 F1 C"fan1" Q500                       ; create fan 1 on pin fan1 and set its frequency / hotend fan
                M106 P1 S1 H1 T45                            ; set fan 1 value. Thermostatic control is turned on
                The fans are working now but DWC looks like this ...
                Aren't Tool Fan and Fan 0 different things? 35% is the part cooling speed I set in the slicer. The hotend fan is spinning 100%.
                Here's my entire config.g ..
                ; Configuration file for Duet WiFi (firmware version 3.3)
                ; generated by RepRapFirmware Configuration Tool v3.3.15 on Sun Jan 29 2023 19:52:14 GMT-0700 (Mountain Standard Time)
                M575 P1 S1 B57600                                  ; enable support for PanelDue
                G90                                                ; send absolute coordinates...
                M83                                                ; ...but relative extruder moves
                M550 P"Brutus"                                     ; set printer name
                M552 P0.0.0.0 S1                                   ; enable network and acquire dynamic address via DHCP
                M586 P0 S1                                         ; enable HTTP
                M586 P1 S1                                         ; enable FTP
                M586 P2 S0                                         ; disable Telnet
                M569 P0 S1                                         ; physical drive 0 goes forwards
                M569 P1 S1                                         ; physical drive 1 goes forwards
                M569 P2 S1                                         ; physical drive 2 goes forwards
                M569 P3 S1                                         ; physical drive 3 goes forwards
                M584 X0 Y1 Z2 E3                                   ; set drive mapping
                M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
                M92 X99.96 Y100.07 Z400.00 E523.52                 ; set steps per mm
                M566 X1000.00 Y1000.00 Z24.00 E3000.00             ; set maximum instantaneous speed changes (mm/min)
                M203 X30000.00 Y30000.00 Z900.00 E2700.00          ; set maximum speeds (mm/min)
                M201 X1000.00 Y1000.00 Z200.00 E3000.00            ; set accelerations (mm/s^2)
                M906 X800 Y800 Z800 E500 I30          		       ; set motor currents (mA) and motor idle factor in per cent
                M84 S30                                            ; Set idle timeout
                ; Dimensions
                M208 X-10 Y0 Z0 S1                                 ; set axis minima
                M208 X214 Y214 Z218.315 S0                         ; set axis maxima
                M574 X2 S1 P"xstop"                                ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
                M574 Y2 S1 P"ystop"                                ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
                M574 Z2 S1 P"zstop"                                ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop
                M558 P0 H5 F120 T6000                              ; disable Z probe but set dive height, probe speed and travel speed
                M557 X40:195 Y5:195 S20                            ; define mesh grid
                M308 S0 P"bedtemp" Y"thermistor" T100000 B4092        ; configure sensor 0 as thermistor on pin bedtemp
                M950 H0 C"bedheat" T0                                 ; create bed heater output on bedheat and map it to sensor 0
                M307 H0 B0 S1.00                                      ; disable bang-bang mode for the bed heater and set PWM limit
                M140 H0                                               ; map heated bed to heater 0
                M143 H0 S120                                          ; set temperature limit for heater 0 to 120C
                M308 S1 P"e0temp" Y"thermistor" T100000 B4267         ; configure sensor 1 as thermistor on pin e0temp
                M950 H1 C"e0heat" T1                                  ; create nozzle heater output on e0heat and map it to sensor 1
                M307 H1 B0 S1.00                                      ; disable bang-bang mode for heater  and set PWM limit
                M143 H1 S280                                          ; set temperature limit for heater 1 to 280C
                M950 F1 C"fan1" Q500                       ; create fan 1 on pin fan1 and set its frequency / this is the hotend fan
                M563 P0 S"E3D-V6" D0 H1 F0                         ; define tool 0
                G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
                G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
                ; Custom settings
                M912 P0 S1.6                                       ; 2020.06.15 - Calibrate the MCU temp
                M501                                               ; load saved parameters from non-volatile memory
                T0                                                 ; select first tool
                • gbartschundefined
                  gbartsch @Phaedrux
                  Small world.
                  Wow, that's cool. It's surely is a small world.
                    Nope. The tool fan slider is the same as your part cooling fan of the currently selected tool, so if you had multiple tools, that slider would work for whichever tool was selected.
                    That sounds correct for your config.
                    • gbartschundefined
                      gbartsch @Phaedrux
                      Awesome! Thank you for checking that. Then this firmware upgrade is a success!
                      I'm printing now and can see some differences immediately. Infill is now connecting to perimeters; that was a thorny issue I could not solve for a long time but is much better now.
                      tasundefined 1 Reply Last reply Reply Quote 1
                      • tasundefined
                        tas @gbartsch
                        @gbartsch
                        Nice print for a custom cartesian dinosaur machine!
                        • gbartschundefined
                          gbartsch @tas
                          @tas Thank you! You figure this is OK? It's PET-G at 230C and 40mm/s (dino; ergo slow). I'm pleased for it being one of the first prints after a major firmware update. There's tweaking to do but I feel this is a good start. 😊
                          tasundefined 1 Reply Last reply Reply Quote 0
                          • tasundefined
                            tas @gbartsch
                            @gbartsch
                            I find that to print a really good part you have to print slowly. You also have to print several of the parts and tweak the settings for that specific part.
                            Then, when you finally have your really good part, you will have had enough time to think up some design changes and start all over again.
                            gbartschundefined 1 Reply Last reply Reply Quote 1
                            • gbartschundefined
                              gbartsch @tas
                              @tas It's a game of iteration and never being satisfied. 🤣
                              Here's another print that has improved markedly after this firmware upgrade. I'm not sure why but wonder if part of the reason is pressure advance is working and tuned, and my acceleration and speed change settings are higher than before? Regardless, I'm pleased.
                              tasundefined Phaedruxundefined 2 Replies Last reply Reply Quote 1
                              • tasundefined
                                tas @gbartsch
                                @gbartsch
                                I have found that every upgrade brings some improvement to print quality.
                                Of course the slicers have improved too.
                                  Yes most likely. Pressure advance will be helping for sure, and if you're using the speed values from the config I provided some things are probably a bit faster which can help quality as you don't want the print head hanging around oozing out plastic when it shouldn't be.
                                  • gbartschundefined
                                    gbartsch @tas
                                    @tas said in Idiot's Guide To Upgrading Duet Firmware:
                                    For sure; it's exciting to be along for the ride!
                                    • gbartschundefined
                                      gbartsch @Phaedrux
                                      ... some things are probably a bit faster which can help quality as you don't want the print head hanging around oozing out plastic when it shouldn't be
                                      The settings are definitely faster. I'll try increasing acceleration and maximum instantaneous speed changes as much as possible before the machine complains.
                                        dc42 administrators @gbartsch
                                        The maximum instantaneous speed settings are best left alone unless the machine stutters when printing circles.
                                        • gbartschundefined
                                          gbartsch @dc42
                                          @dc42 said in Idiot's Guide To Upgrading Duet Firmware:
                                          Thank you.
                                          Sorry, I mislead you. After upgrading I reduced some speeds and now want to try increasing them to as close to the defaults as possible.
                                          My machine has heavy axes so bangs hard if the speeds are too high.
                                          These are its current settings:
                                          • gbartschundefined
                                            gbartsch
                                            Just a follow up; since the upgrade I've printed steadily and have yet to experience a disconnect from DWC. That appears to be fixed (crossing my fingers).
