    M671 like function for Delta printer
    Gcode meta commands
    1.2k
    • tecnoundefined
      tecno @tecno
      Any ideas what is causing this problem??
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @tecno
        @tecno
        Exactly what steps are you taking?
        If you're trying to use echo then you have to use the correct syntax to write to a file.
        https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands
        If you're trying to save the console then click on the icon with the horizontal lines and select download as text or csv
        The file will be saved wherever your browser normally saves files.
        If it doesn't then there is something blocking it. Either browser settings or anti virus perhaps.
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @OwenD
          @OwenD said in M671 like function for Delta printer:
          I have no problems dowloading files.
          I can run backups with ```
          c:/backup/rfm backup -domain bigdelta -password ******** c:/backup/bigdelta 0:/
          • tecnoundefined
            tecno @tecno
            Tested M122 on 3 of my printers now and it works OK, a window with where to save pops up so it isOK.
            But this I get nowhere
            Want to have the output from macro to a CSV. So what is my problem with this?
            • OwenDundefined
              OwenD @tecno
              @tecno
              I'm going to have to eat my words on this one.
              There does indeed seem to be some sort of issue with saving echo commands that are not sent from the DWC channel.
              I tried putting M118 in the macro as well with no joy.
              Your only option at this point is to use echo to write to the file directly from the macro.
              echo >"0:/sys/savedData.txt"
              G30 S-1 ; do probe at current point
              echo >>"Stopped at height " ^ move.axes[2].machinePosition ^ "mm"
              • tecnoundefined
                tecno @OwenD
                @OwenD
                Trying this
                M562                    ; clear any bed transform from mesh leveling
                G90                     ; absolute positioning
                G1 Z50 F4000
                G1 X0 Y0				; 1 point
                G30 S-1
                echo >>"Stopped at height" ^ move.axes[2].machinePosition ^ "mm"
                And get this error:
                M98 P"0:/macros/test"
                Stopped at height 0.758 mm
                Error: in file macro line 7 column 28: meta command: expected an expression
                Above creates 2 empty files
                OwenDundefined dc42undefined 2 Replies Last reply Reply Quote 0
                • OwenDundefined
                  OwenD @tecno
                  @tecno
                  Apologies.
                  Should have had the filename in both echo commands.
                  echo >>"0:/sys/savedData.txt" "Stopped at height " ^ move.axes[2].machinePosition ^ "mm"
                  • tecnoundefined
                    tecno @OwenD
                    @OwenD
                    No reason to apoligise, I am thankful for all help I can get.
                    Now I get these values in txtfile, they also show up in console but nothing can be done there.
                    How to save the file so it can be exported as CSV directly from console.
                    • OwenDundefined
                      OwenD @tecno
                      @tecno
                      I'm not sure I understand what you are looking for.
                      The use of the echo command is detailed here
                      https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands#echo-command
                      If you want each probe point on a single line then use three > symbols
                      echo >"0:\sys\testFile.csv" "Test1,Test2,Test3,Test4,Test5,"
                      while iterations < 5
                         G30 S-1
                         echo >>>"0:\sys\testFile.csv" move.axes[2].machinePosition  ^ ","
                      The resulting file will be something like
                      1.388,1.595,1.595,2.015,2.213,
                      • tecnoundefined
                        tecno @OwenD
                        @OwenD
                        Error: in file macro line 8 column 8: meta command: expected string expression
                        achrnundefined 1 Reply Last reply Reply Quote 0
                        • achrnundefined
                          achrn @tecno
                          @tecno said in M671 like function for Delta printer:
                          @OwenD
                          None of the macro extracts you've posted in teh thread recently even have an eighth line. What does line 8 of the macro file say?
                          • tecnoundefined
                            tecno @achrn
                            @achrn
                            echo >>>"0:\sys\testFile.csv" ^ move.axes[2].machinePosition ^ ","
                            • achrnundefined
                              achrn @tecno
                              @tecno https://docs.duet3d.com/en/User_manual/Reference/Gcode_meta_commands#echo-command says >>> is only supported in firmware 3.5beta2 and later, what are you running?
                              • tecnoundefined
                                tecno @achrn
                                @achrn
                                3.4.5 and nobody has said this before.
                                It runs now but still I need to get correct syntax for the csv file for all results on same line.
                                echo >>"0:\sys\testFile.csv" {move.axes[2].machinePosition} ,","
                                point1,point2,point3,point4
                                0.858 ,
                                0.824 ,
                                1.322 ,
                                0.821 ,
                                • achrnundefined
                                  achrn @tecno
                                  @achrn
                                  Well, it's been in the docs a while, I think.
                                  I don't think you can, working it in a loop like that. you could dump the loop and do five separate probes storing in single variables then write to file with a single line, I think. e.g.
                                      G30 S-1  ; probe
                                      set var.z1 = move.axes[2].machinePosition ; memorise probe position
                                      G30 S-1
                                      set var.z2 = move.axes[2].machinePosition
                                      G30 S-1
                                      set var.z3 = move.axes[2].machinePosition
                                      G30 S-1
                                      set var.z4 = move.axes[2].machinePosition
                                      G30 S-1
                                      set var.z5 = move.axes[2].machinePosition
                                     echo >>"0:\sys\testFile.csv" "whatever", var.z1,  var.z2, var.z3, var.z4, var.z5
                                  • tecnoundefined
                                    tecno @achrn
                                    @achrn
                                    OK, will play with your suggestion and see the results.
                                    • tecnoundefined
                                      tecno @tecno
                                      M98 P"0:/macros/test var.g"
                                      Stopped at height 0.708 mm
                                      Error: in file macro line 7 column 13: meta command: unknown variable 'z1'
                                      G28
                                      G1 Z50 F4000
                                      G1 X0 Y0				; 1 point
                                      G30 S-1
                                      G1 Z50 F4000
                                      G1 X-154 Y-164 F4000    ; 2 point
                                      G30 S-1
                                      G1 Z50 F4000
                                      G1 X-63 Y214 F4000      ; 3 point
                                      G30 S-1
                                      G1 Z50 F4000
                                      G1 X217 Y-52 F4000      ; 4 point
                                      G30 S-1
                                      G1 Z50 F4000
                                      G28
                                      • achrnundefined
                                        achrn @tecno
                                        Well yes, you need to initialise the variables.
                                        var z1 = 0
                                        var z2 = 0
                                        var z3 = 0
                                        var z4 = 0
                                        var z5 = 0
                                        before you first refer to any of them.
                                        • tecnoundefined
                                          tecno @achrn
                                          @achrn said in M671 like function for Delta printer:
                                          var z1 = 0
                                          var z2 = 0
                                          var z3 = 0
                                          var z4 = 0
                                          var z5 = 0
                                          Works like a charm now!
                                          Is there a way to replace "whatever" with date + time?
                                            dc42 administrators @tecno
                                            Should be:
                                            echo >>"0:/sys/savedData.txt" "Stopped at height" ^ move.axes[2].machinePosition ^ "mm"
                                            i.e. you need to specify the filename again.
                                            Instead of using move.axes[2].machinePosition I suggest you use sensors.probes[0].lastStopHeight as I suggested earlier.
                                            tecnoundefined 1 Reply Last reply Reply Quote 1
