    M671 like function for Delta printer
    Gcode meta commands
    1.5k
    • tecnoundefined
      tecno @tecno
      Tested with 3 browser = nothing
        T3P3Tony administrators @tecno
        @tecno your browsers may be set to block downloads? not sure why but i just tested this as well and it works with Chrome on windows.
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @T3P3Tony
          @T3P3Tony
          No problems here with dowload, just tested to dowload stl file from thingiverse.
          Can this be a languae problem, my OS is in Swedish.
          • tecnoundefined
            tecno @tecno
            Any ideas what is causing this problem??
            OwenDundefined 1 Reply Last reply Reply Quote 0
            • OwenDundefined
              OwenD @tecno
              @tecno
              Exactly what steps are you taking?
              If you're trying to use echo then you have to use the correct syntax to write to a file.
              https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands
              If you're trying to save the console then click on the icon with the horizontal lines and select download as text or csv
              The file will be saved wherever your browser normally saves files.
              If it doesn't then there is something blocking it. Either browser settings or anti virus perhaps.
              • tecnoundefined
                tecno @OwenD
                @OwenD said in M671 like function for Delta printer:
                I have no problems dowloading files.
                I can run backups with ```
                c:/backup/rfm backup -domain bigdelta -password ******** c:/backup/bigdelta 0:/
                • tecnoundefined
                  tecno @tecno
                  Tested M122 on 3 of my printers now and it works OK, a window with where to save pops up so it isOK.
                  But this I get nowhere
                  Want to have the output from macro to a CSV. So what is my problem with this?
                  • OwenDundefined
                    OwenD @tecno
                    @tecno
                    I'm going to have to eat my words on this one.
                    There does indeed seem to be some sort of issue with saving echo commands that are not sent from the DWC channel.
                    I tried putting M118 in the macro as well with no joy.
                    Your only option at this point is to use echo to write to the file directly from the macro.
                    echo >"0:/sys/savedData.txt"
                    G30 S-1 ; do probe at current point
                    echo >>"Stopped at height " ^ move.axes[2].machinePosition ^ "mm"
                    • tecnoundefined
                      tecno @OwenD
                      @OwenD
                      Trying this
                      M562                    ; clear any bed transform from mesh leveling
                      G90                     ; absolute positioning
                      G1 Z50 F4000
                      G1 X0 Y0				; 1 point
                      G30 S-1
                      echo >>"Stopped at height" ^ move.axes[2].machinePosition ^ "mm"
                      And get this error:
                      M98 P"0:/macros/test"
                      Stopped at height 0.758 mm
                      Error: in file macro line 7 column 28: meta command: expected an expression
                      Above creates 2 empty files
                      OwenDundefined dc42undefined 2 Replies Last reply Reply Quote 0
                      • OwenDundefined
                        OwenD @tecno
                        @tecno
                        Apologies.
                        Should have had the filename in both echo commands.
                        echo >>"0:/sys/savedData.txt" "Stopped at height " ^ move.axes[2].machinePosition ^ "mm"
                        • tecnoundefined
                          tecno @OwenD
                          @OwenD
                          No reason to apoligise, I am thankful for all help I can get.
                          Now I get these values in txtfile, they also show up in console but nothing can be done there.
                          How to save the file so it can be exported as CSV directly from console.
                          • OwenDundefined
                            OwenD @tecno
                            @tecno
                            I'm not sure I understand what you are looking for.
                            The use of the echo command is detailed here
                            https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands#echo-command
                            If you want each probe point on a single line then use three > symbols
                            echo >"0:\sys\testFile.csv" "Test1,Test2,Test3,Test4,Test5,"
                            while iterations < 5
                               G30 S-1
                               echo >>>"0:\sys\testFile.csv" move.axes[2].machinePosition  ^ ","
                            The resulting file will be something like
                            1.388,1.595,1.595,2.015,2.213,
                            • tecnoundefined
                              tecno @OwenD
                              @OwenD
                              Error: in file macro line 8 column 8: meta command: expected string expression
                              achrnundefined 1 Reply Last reply Reply Quote 0
                              • achrnundefined
                                achrn @tecno
                                @tecno said in M671 like function for Delta printer:
                                @OwenD
                                None of the macro extracts you've posted in teh thread recently even have an eighth line. What does line 8 of the macro file say?
                                • tecnoundefined
                                  tecno @achrn
                                  @achrn
                                  echo >>>"0:\sys\testFile.csv" ^ move.axes[2].machinePosition ^ ","
                                  • achrnundefined
                                    achrn @tecno
                                    @tecno https://docs.duet3d.com/en/User_manual/Reference/Gcode_meta_commands#echo-command says >>> is only supported in firmware 3.5beta2 and later, what are you running?
                                    • tecnoundefined
                                      tecno @achrn
                                      @achrn
                                      3.4.5 and nobody has said this before.
                                      It runs now but still I need to get correct syntax for the csv file for all results on same line.
                                      echo >>"0:\sys\testFile.csv" {move.axes[2].machinePosition} ,","
                                      point1,point2,point3,point4
                                      0.858 ,
                                      0.824 ,
                                      1.322 ,
                                      0.821 ,
                                      • achrnundefined
                                        achrn @tecno
                                        @achrn
                                        Well, it's been in the docs a while, I think.
                                        I don't think you can, working it in a loop like that. you could dump the loop and do five separate probes storing in single variables then write to file with a single line, I think. e.g.
                                            G30 S-1  ; probe
                                            set var.z1 = move.axes[2].machinePosition ; memorise probe position
                                            G30 S-1
                                            set var.z2 = move.axes[2].machinePosition
                                            G30 S-1
                                            set var.z3 = move.axes[2].machinePosition
                                            G30 S-1
                                            set var.z4 = move.axes[2].machinePosition
                                            G30 S-1
                                            set var.z5 = move.axes[2].machinePosition
                                           echo >>"0:\sys\testFile.csv" "whatever", var.z1,  var.z2, var.z3, var.z4, var.z5
                                        • tecnoundefined
                                          tecno @achrn
                                          @achrn
                                          OK, will play with your suggestion and see the results.
                                          • tecnoundefined
                                            tecno @tecno
                                            M98 P"0:/macros/test var.g"
                                            Stopped at height 0.708 mm
                                            Error: in file macro line 7 column 13: meta command: unknown variable 'z1'
                                            G28
                                            G1 Z50 F4000
                                            G1 X0 Y0				; 1 point
                                            G30 S-1
                                            G1 Z50 F4000
                                            G1 X-154 Y-164 F4000    ; 2 point
                                            G30 S-1
                                            G1 Z50 F4000
                                            G1 X-63 Y214 F4000      ; 3 point
                                            G30 S-1
                                            G1 Z50 F4000
                                            G1 X217 Y-52 F4000      ; 4 point
                                            G30 S-1
                                            G1 Z50 F4000
                                            G28
