    M671 like function for Delta printer
    Gcode meta commands
    1.2k
    • tecnoundefined
      tecno @tecno
      Just tested to see if my Ubuntu woks with this = Nothing
      Tested with another W10 = Nothing
      • tecnoundefined
        tecno @droftarts
        @droftarts
        2023-02-03 12:50:21 Echo "Hi Ian"
        Error: Bad command: Echo "Hi Ian"
          droftarts administrators @tecno
          @tecno lower case 'e' in "echo". However, that doesn't explain why your browser isn't saving the console.txt. What version DWC and RRF?
          tecnoundefined 1 Reply Last reply Reply Quote 0
          • tecnoundefined
            tecno @droftarts
            @droftarts
            🙂 did notice that with echo
            Duet Web Control 3.4.5
            Board: Duet 3 Mini 5+ (Mini5plus)
            Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.4.5 (2022-11-30)
            • tecnoundefined
              tecno @tecno
              Tested with 3 browser = nothing
                T3P3Tony administrators @tecno
                @tecno your browsers may be set to block downloads? not sure why but i just tested this as well and it works with Chrome on windows.
                • tecnoundefined
                  tecno @T3P3Tony
                  @T3P3Tony
                  No problems here with dowload, just tested to dowload stl file from thingiverse.
                  Can this be a languae problem, my OS is in Swedish.
                  • tecnoundefined
                    tecno @tecno
                    Any ideas what is causing this problem??
                    OwenDundefined 1 Reply Last reply Reply Quote 0
                    • OwenDundefined
                      OwenD @tecno
                      @tecno
                      Exactly what steps are you taking?
                      If you're trying to use echo then you have to use the correct syntax to write to a file.
                      https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands
                      If you're trying to save the console then click on the icon with the horizontal lines and select download as text or csv
                      The file will be saved wherever your browser normally saves files.
                      If it doesn't then there is something blocking it. Either browser settings or anti virus perhaps.
                      • tecnoundefined
                        tecno @OwenD
                        @OwenD said in M671 like function for Delta printer:
                        I have no problems dowloading files.
                        I can run backups with ```
                        c:/backup/rfm backup -domain bigdelta -password ******** c:/backup/bigdelta 0:/
                        • tecnoundefined
                          tecno @tecno
                          Tested M122 on 3 of my printers now and it works OK, a window with where to save pops up so it isOK.
                          But this I get nowhere
                          Want to have the output from macro to a CSV. So what is my problem with this?
                          • OwenDundefined
                            OwenD @tecno
                            @tecno
                            I'm going to have to eat my words on this one.
                            There does indeed seem to be some sort of issue with saving echo commands that are not sent from the DWC channel.
                            I tried putting M118 in the macro as well with no joy.
                            Your only option at this point is to use echo to write to the file directly from the macro.
                            echo >"0:/sys/savedData.txt"
                            G30 S-1 ; do probe at current point
                            echo >>"Stopped at height " ^ move.axes[2].machinePosition ^ "mm"
                            • tecnoundefined
                              tecno @OwenD
                              @OwenD
                              Trying this
                              M562                    ; clear any bed transform from mesh leveling
                              G90                     ; absolute positioning
                              G1 Z50 F4000
                              G1 X0 Y0				; 1 point
                              G30 S-1
                              echo >>"Stopped at height" ^ move.axes[2].machinePosition ^ "mm"
                              And get this error:
                              M98 P"0:/macros/test"
                              Stopped at height 0.758 mm
                              Error: in file macro line 7 column 28: meta command: expected an expression
                              Above creates 2 empty files
                              OwenDundefined dc42undefined 2 Replies Last reply Reply Quote 0
                              • OwenDundefined
                                OwenD @tecno
                                @tecno
                                Apologies.
                                Should have had the filename in both echo commands.
                                echo >>"0:/sys/savedData.txt" "Stopped at height " ^ move.axes[2].machinePosition ^ "mm"
                                • tecnoundefined
                                  tecno @OwenD
                                  @OwenD
                                  No reason to apoligise, I am thankful for all help I can get.
                                  Now I get these values in txtfile, they also show up in console but nothing can be done there.
                                  How to save the file so it can be exported as CSV directly from console.
                                  • OwenDundefined
                                    OwenD @tecno
                                    @tecno
                                    I'm not sure I understand what you are looking for.
                                    The use of the echo command is detailed here
                                    https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands#echo-command
                                    If you want each probe point on a single line then use three > symbols
                                    echo >"0:\sys\testFile.csv" "Test1,Test2,Test3,Test4,Test5,"
                                    while iterations < 5
                                       G30 S-1
                                       echo >>>"0:\sys\testFile.csv" move.axes[2].machinePosition  ^ ","
                                    The resulting file will be something like
                                    1.388,1.595,1.595,2.015,2.213,
                                    • tecnoundefined
                                      tecno @OwenD
                                      @OwenD
                                      Error: in file macro line 8 column 8: meta command: expected string expression
                                      achrnundefined 1 Reply Last reply Reply Quote 0
                                      • achrnundefined
                                        achrn @tecno
                                        @tecno said in M671 like function for Delta printer:
                                        @OwenD
                                        None of the macro extracts you've posted in teh thread recently even have an eighth line. What does line 8 of the macro file say?
                                        • tecnoundefined
                                          tecno @achrn
                                          @achrn
                                          echo >>>"0:\sys\testFile.csv" ^ move.axes[2].machinePosition ^ ","
                                          • achrnundefined
                                            achrn @tecno
                                            @tecno https://docs.duet3d.com/en/User_manual/Reference/Gcode_meta_commands#echo-command says >>> is only supported in firmware 3.5beta2 and later, what are you running?
