    Pre-release 3.5 beta 2 now available
    Beta Firmware
    14
    30
    2.4k
    • DIY-O-Sphereundefined
      DIY-O-Sphere @dc42
      Is there any news on restoring the old error handling in the case of a heater fault ?
      (UTC+1)
      • JoergS5undefined
        JoergS5 @Ghazi
        @Ghazi I'm sorry, development will take longer, as I changed the internal algorithms. So it will not be included in 3.5.
        The original method was to iterate inverse kinematics solutions. But a few % of the solutions didn't iterate correctly, i.e. the solution will fail, ruining the print. The solution now is to calculate inverse kinematics for all possible solutions and will give an answer in every situation. But this change will take a while.
        • Marcossfundefined
          Marcossf
          We tested this 3.5 beta 2 in our 6XD + several 1LCs machine in SBC mode, and it gives constant SPI reseting.
          Going back to 3.4.5 stable version revert the normal behaviour of the printer.
          All firmware on the boards in the beta 2 are been updated, just in case it needs to be same version than mainboard.
          dc42undefined chrishammundefined 2 Replies Last reply Reply Quote 0
            dc42 administrators @DIY-O-Sphere
            @DIY-O-Sphere said in Pre-release 3.5 beta 2 now available:
            What aspect of the old error handling is it that you want, that can't be achieved using the event system?
            DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
              dc42 administrators @Marcossf
              @Marcossf thanks for your report. I've asked @chrishamm to look into this.
              For now the 3.5beta builds of expansion boards are compatible with RRF 3.4 on the main board, and vice versa. This will change in a future beta release.
                DIY-O-Sphere @dc42
                This topic is really getting annoying.
                I expect the firmware to shut down the system as announced here.
                "Currently, RRF does not attempt to turn off power to the whole machine in the case of machines with firmware controlled power supplies if the user does not respond to the heater fault. We plan to reinstate this or a similar function in release 3.5"
                (UTC+1)
                Diamondbackundefined 1 Reply Last reply Reply Quote 0
                • Diamondbackundefined
                  Diamondback @DIY-O-Sphere
                  @DIY-O-Sphere This sounds easy enough to handle yourself with the use of daemon.g?
                    DIY-O-Sphere @Diamondback
                    @Diamondback
                    https://forum.duet3d.com/topic/28636/is-there-a-work-around-to-restore-the-old-heater-fault-handling
                    (UTC+1)
                      @DIY-O-Sphere What do you want to say with that?
                      I'd simply write a piece of code for daemon that checks if a heater has been in fault state for some time and if it does, turn off the power supply.
                      Even if I don't really see why you'd want to do that, you clearly appear have a use case for it and it it's easy enough to add?
                      • chrishammundefined
                        chrishamm administrators @Marcossf
                        @Marcossf Please can you share your config and/or the M122 output after a SPI reset.
                        Duet software engineer
                        Marcossfundefined 1 Reply Last reply Reply Quote 0
                        • Marcossfundefined
                          Marcossf @chrishamm
                          Hi @chrishamm
                          Our config file is not going to clarify anything for you as it makes calls to several other files that it loads from where there are hundreds of variables.
                          We would have to figure out a way to get an M122 out because when it connects and disconnects it does it often, with no time to see what is going on. I think we have a console log where we can see it, but it never connects stable, not even once. I'll look for it.
                          With version 3.4.5 it works perfectly.
                          Sorry I can't give you more clues.
                          gloomyandyundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                          • gloomyandyundefined
                            gloomyandy @Marcossf
                            @Marcossf You should be able to connect via USB to get the M122 output.
                              T3P3Tony administrators @Marcossf
                              @Marcossf you can also share a zip of the /sys directory and and other macro directories. If that's sensitive information then we can arrange to get it another way
                              • gman10192undefined
                                gman10192 @dc42
                                This post is deleted!
                                • chrishammundefined chrishamm unpinned this topic
