    unable to connect to duet 2 wifi
    • baird1faundefined
      baird1fa
      Hello everyone.
      I'm having an issue with my duet 2 board. I powered it down last week and when I went to power it up this weekend I cannot connect to it. I can see it connecting to my network then drop, then it connects again and drops. It just keeps cycling like this over and over again.
      Does this mean that the board is fried or is there something I can do to fix it.
        T3P3Tony administrators @baird1fa
        @baird1fa when you say you can see it connect to the network and drop again do you mean from reporting on your router?
        Please connect to it over YAT or a similar terminal program over USB and see what is being reported there.
        baird1faundefined 1 Reply Last reply Reply Quote 0
        • baird1faundefined
          baird1fa @T3P3Tony
          @T3P3Tony The issue seems to have resolved itself. I connected it via USB and ran the M552 and M587 commands and could see that it was connected. I then powered it up normally and I would stay connected. I think there must have been an issue with too many devices connected to the wifi or an issue with IP address assignments. but it seems to be fine now.
          • Phaedruxundefined Phaedrux has marked this topic as solved
