Z motors need more power
    axiom
    Z motors need more power. I have a total of 4 Z motors a 1800 mA. Officially, the board only supports 2400 mA. I connected them to the 2 slots on the board as intended and then wired them to 2 points each. I have the feeling that the 1.8 amps don't get through to the motors, but less. Is there a possibility, e.g. a load switch or something similar so that the motors can be sufficiently supplied.
    undefined 1 Reply Last reply 19 Feb 2023, 18:04 Reply Quote 0
      jay_s_uk @axiom
      @axiom how have you split the z motors? In serials or parallel? Series gives full current and parallel half's the current to the motors
      undefined 1 Reply Last reply 19 Feb 2023, 19:15 Reply Quote 0
        axiom @jay_s_uk
        @jay_s_uk Thanks for the tip, yes I connected them in parallel....do I have to solder them for a serial circuit, or do you have a link/tip where I can order such turnouts ready-made. In my search I only found parallel switches
        undefined 1 Reply Last reply 20 Feb 2023, 20:03 Reply Quote 0
          https://www.instructables.com/Wiring-Your-Z-Stepper-Motors-in-Series/
            axiom @Phaedrux
            @Phaedrux Thanks to both of you! That seems to have been the solution!!!
            Best regards
              axiom @axiom
              @axiom Thanks to both of you! That seems to have been the solution!!!
              Best regards
              6 out of 6
