Vertical Banding Problem and Stepper Waveforms
Jerk is set in mm/min in RRF just like all the other speeds, but some other firmwares use mm/sec for jerk. So 10 on your Taz 5 may correspond to 600 in RRF.
Ahhhhhh aha, okay, thank you dc42.
By the way, I just put the scope on my Makergear M2 and what I see is more or less consistent with what I'm getting on the Duet, so facepalm to me for not understanding the stepper waveform.
Anyway, the issue with the banding persists. I realized I have some NEMA 17s laying around. I'm going to swap the two X-axis motors with these and see what happens.
Well, I just tried switching the X-axis motors to NEMA 17s and the banding is exactly the same. Still quite stuck and seeking ideas.
If it was related to motors steps, the spacing of the bands would be constant. So I think the print head is vibrating, and something is maintaining the vibration. A constant vibration frequency will cause the bands to be more widely spaced when you increase the printing speed.
Huh, I'll try a print with the cooling fan off. Maybe it's exciting a resonance.
Hello, I have the same Issue on my P3Steel with a Duet WiFi, so I thought I'd share my experiences. For me, they're more noticeable along the Y-Axis (maybe a problem with the bed?) than along the X-Axis, but it's still there on both.
I too have an e3d Titan Extruder (with a 0.9° Stepper) and played around with the extrusion, but it didn't change much.
I tried various acceleration, jerk and speed settings. Also I don't seem to be getting those ripples on curved surfaces.
I also tried printing without any fan running on the Printer (Had to unclog my Hotend after that…) but it didn't help.
Another thing I tried was putting astrosyn dampeners on all motors, but that also didn't help.
Then I tried something "just for fun" and replaced the duet WiFi with an Ultimachine RAMBo 1.3, running the latest Marlin Firmware with the same Motion settings that I settled on in the Duet Firmware. Now it's still happening but its much less noticeable. On the Duet print I could easily feel the ripples when running over the surface with my fingernail, and on the RAMBo print I can't.
Would be interesting to swap the drivers, if you can, trying DRV8255, TMC2100, A4988…
After an extended struggle, I just cracked an issue that looks like this on my D-Bot (CoreXY). The issue was GT2 teeth hitting smooth idlers and the solution was a half twist in the belt so the smooth surface would contact the idlers instead of the teeth. Note: the pitch of the defect also didn't align perfectly with the GT2 teeth so I think the interaction of the teeth on the idler is more complex than a simple 1:1 with the surface defects. The album has all of the details including the (many) things that were ruled out before arriving at a solution: https://imgur.com/a/kb2nE
Here's the side by side shot showing the result of the belt twist:
I also posted this to Reddit. If you're interested the discussion links are:
https://www.reddit.com/r/dbotcorexy/comments/7d1s8j/vertical_surface_ripples_banding_waves_solved/
https://www.reddit.com/r/3Dprinting/comments/7d1pqe/vertical_surface_ripples_banding_waves_solved/I hope it helps!
@denos. That's interesting. What diameter are your idlers? I ask because I don't have an issue running the toothed side of the belt over my idlers although I know that technically it's not ideal, but they are quite large diameter. It may also be that my 4Kg of mass that I throw around just damps everything out
I'm not at home at the moment but they're small – similar in size to the diameter of my 16T pulleys. A larger idler might help. Here is some additional context from a response I posted on Reddit:
"Keep in mind that this is a black, glossy filament that was printed too hot (making it less viscous / more susceptible to deflection) and the light has to be oriented just right to catch the surface ripples.
It is worst when rotating prints by 45 degrees so each stepper motor is isolated and printing at higher speeds. In a typical orientation (flat surfaces parallel to the X and Y axis), the effect is more subtle and may just appear as slight surface texture (I suspect this occurs if the motors are offset by half a step). On cylindrical surfaces it looks more like moire or diagonally arcing defects.
I didn't notice the issue with PLA printed at the low temperatures and speeds or using lighter colors. It can also be alleviated by loosening the belts at the expense of jerk / acceleration artifacts with higher speeds.
It only became a problem as I tightened the belts down while testing the upper end of the speed range for the D-Bot (150 - 200 mm/s). Then it drove me nuts..." -
That may be why I've never had an issue then. Yours will be about 9mm diameter whereas mine are around 18mm. That and the fact that as I said, my 4Kg mass tends to dampen out any vibrations.
With the gates curvilinear profile (GT, GT2, GT3, etc), it's acceptable to run the teeth side against a smooth idler if it has a diameter equal to or greater than the effective diameter of a 40 tooth pulley of the same tooth pitch.
With 2 mm pitch belt, this equates to a smooth pulley with about 26 mm diameter.
(Source: Pg 174 https://www.gates.com/~/media/files/gates/industrial/power-transmission/manuals/powergripdrivedesignmanual_17195_2014.pdf?la=en))
I checked the D-Bot build guide and F623ZZ flanged bearings are the recommended idlers and I'm sure that's what I have. They have a diameter of 10mm which explains the artifacts. I'll pass it on so hopefully the Bill of Materials can be updated. Thanks Bot!
Very odd. Are you sure you were using the same motor currents on both controllers? What motors are you using?
Yes, 800mA. I was using These Nema 17s from Robotdigg:https://www.robotdigg.com/m/product/1137/42HS40-1704-58-oz.in-stepper-motor#
I generally had good experiences with robotdigg Motors and I've used them in a different Duet equipped Machine before, and didn't have a Problem. Maybe it was just a coincidence that it came out better on the RAMBo, I didn't really do any further Testing on it because I couldn't directly compare everything in the Firmware since I only know enough about Firmware to configure it for a Printer and not much more.
I can easily install the RAMBo again with different Settings if that helps.
While searching around I found this thread in the reprap forum:http://forums.reprap.org/read.php?246,702962,723107 it's in German but they're having the Same problem, and their Solution was to have the left End of the X-Rods fixed and the other End slightly loose in the right End (Like fixed/floating bearings), so my Right x-end might be too tight. I'll try printing a new one with a looser fit, and I'm going to drill out one side of the y-rod holders in the frame.
I certainly twist my belts when going over smooth idlers which are small diameter like 16t/20t pulley equivalents, I do this on my kossel XL. My corexy uses 608 bearings as idler pulleys which are 22mm outside diameter so I don't see these artefacts. I notice a lot of corexy designs use small pulleys, sometimes for necessity/packaging reasons, but often I suspect for aesthetic reasons. You could always consider replacing them with toothed idlers, especially if twisting belts isn't possible as it would limit axis travel - they're not quite as readily available but you can buy them.
I also twisted my belt on my CoreXY, as I could find toothed idlers for 3GT/9mm at reasonable price.
BTW, I don't see how it reduces axis travel… It is only twisted between motors and rear idlers, where length does not change.
Depends on the design, if I twisted belts on my modified smartrapcore I would not be able to move the y carriages close enough to the pulleys to print on all of the bed without frcing the twisted section into far too small length, which I am sure would have an effect on positional accuracy. I think it depends how much build volume you try to squeeze out of a given size corexy.
Do you have a picture of the your modified smartrapcore belts path?
But as I said twisting the belts here doesn't help me as I don't get the repeating ripple artefact with my big pulleys.
