    Vertical Banding Problem and Stepper Waveforms
    37
    7.2k
    • denosundefined
      denos
      After an extended struggle, I just cracked an issue that looks like this on my D-Bot (CoreXY). The issue was GT2 teeth hitting smooth idlers and the solution was a half twist in the belt so the smooth surface would contact the idlers instead of the teeth. Note: the pitch of the defect also didn't align perfectly with the GT2 teeth so I think the interaction of the teeth on the idler is more complex than a simple 1:1 with the surface defects. The album has all of the details including the (many) things that were ruled out before arriving at a solution: https://imgur.com/a/kb2nE
      Here's the side by side shot showing the result of the belt twist:
      I also posted this to Reddit. If you're interested the discussion links are:
      https://www.reddit.com/r/dbotcorexy/comments/7d1s8j/vertical_surface_ripples_banding_waves_solved/
      https://www.reddit.com/r/3Dprinting/comments/7d1pqe/vertical_surface_ripples_banding_waves_solved/
      I hope it helps!
        deckingman
        @denos. That's interesting. What diameter are your idlers? I ask because I don't have an issue running the toothed side of the belt over my idlers although I know that technically it's not ideal, but they are quite large diameter. It may also be that my 4Kg of mass that I throw around just damps everything out 🙂
        • denosundefined
          denos
          I'm not at home at the moment but they're small – similar in size to the diameter of my 16T pulleys. A larger idler might help. Here is some additional context from a response I posted on Reddit:
          "Keep in mind that this is a black, glossy filament that was printed too hot (making it less viscous / more susceptible to deflection) and the light has to be oriented just right to catch the surface ripples.
          It is worst when rotating prints by 45 degrees so each stepper motor is isolated and printing at higher speeds. In a typical orientation (flat surfaces parallel to the X and Y axis), the effect is more subtle and may just appear as slight surface texture (I suspect this occurs if the motors are offset by half a step). On cylindrical surfaces it looks more like moire or diagonally arcing defects.
          I didn't notice the issue with PLA printed at the low temperatures and speeds or using lighter colors. It can also be alleviated by loosening the belts at the expense of jerk / acceleration artifacts with higher speeds.
          It only became a problem as I tightened the belts down while testing the upper end of the speed range for the D-Bot (150 - 200 mm/s). Then it drove me nuts..."
            deckingman
            That may be why I've never had an issue then. Yours will be about 9mm diameter whereas mine are around 18mm. That and the fact that as I said, my 4Kg mass tends to dampen out any vibrations.
            • botundefined
              bot
              With the gates curvilinear profile (GT, GT2, GT3, etc), it's acceptable to run the teeth side against a smooth idler if it has a diameter equal to or greater than the effective diameter of a 40 tooth pulley of the same tooth pitch.
              With 2 mm pitch belt, this equates to a smooth pulley with about 26 mm diameter.
              (Source: Pg 174 https://www.gates.com/~/media/files/gates/industrial/power-transmission/manuals/powergripdrivedesignmanual_17195_2014.pdf?la=en))
              *not actually a robot
              hussainsail2002undefined 1 Reply Last reply Reply Quote 0
              • denosundefined
                denos
                I checked the D-Bot build guide and F623ZZ flanged bearings are the recommended idlers and I'm sure that's what I have. They have a diameter of 10mm which explains the artifacts. I'll pass it on so hopefully the Bill of Materials can be updated. Thanks Bot!
                  @RamonIn3D:
                  Hello, I have the same Issue on my P3Steel with a Duet WiFi, so I thought I'd share my experiences. For me, they're more noticeable along the Y-Axis (maybe a problem with the bed?) than along the X-Axis, but it's still there on both.
                  I too have an e3d Titan Extruder (with a 0.9° Stepper) and played around with the extrusion, but it didn't change much.
                  I tried various acceleration, jerk and speed settings. Also I don't seem to be getting those ripples on curved surfaces.
                  I also tried printing without any fan running on the Printer (Had to unclog my Hotend after that…) but it didn't help.
                  Another thing I tried was putting astrosyn dampeners on all motors, but that also didn't help.
                  Then I tried something "just for fun" and replaced the duet WiFi with an Ultimachine RAMBo 1.3, running the latest Marlin Firmware with the same Motion settings that I settled on in the Duet Firmware. Now it's still happening but its much less noticeable. On the Duet print I could easily feel the ripples when running over the surface with my fingernail, and on the RAMBo print I can't.
                  Very odd. Are you sure you were using the same motor currents on both controllers? What motors are you using?
                  • RamonIn3Dundefined
                    RamonIn3D
                    @dc42:
                    @RamonIn3D:
                    Yes, 800mA. I was using These Nema 17s from Robotdigg:https://www.robotdigg.com/m/product/1137/42HS40-1704-58-oz.in-stepper-motor#
                    I generally had good experiences with robotdigg Motors and I've used them in a different Duet equipped Machine before, and didn't have a Problem. Maybe it was just a coincidence that it came out better on the RAMBo, I didn't really do any further Testing on it because I couldn't directly compare everything in the Firmware since I only know enough about Firmware to configure it for a Printer and not much more.
                    I can easily install the RAMBo again with different Settings if that helps.
                    While searching around I found this thread in the reprap forum:http://forums.reprap.org/read.php?246,702962,723107 it's in German but they're having the Same problem, and their Solution was to have the left End of the X-Rods fixed and the other End slightly loose in the right End (Like fixed/floating bearings), so my Right x-end might be too tight. I'll try printing a new one with a looser fit, and I'm going to drill out one side of the y-rod holders in the frame.
                    • DjDemonDundefined
                      DjDemonD
                      @denos:
                      I certainly twist my belts when going over smooth idlers which are small diameter like 16t/20t pulley equivalents, I do this on my kossel XL. My corexy uses 608 bearings as idler pulleys which are 22mm outside diameter so I don't see these artefacts. I notice a lot of corexy designs use small pulleys, sometimes for necessity/packaging reasons, but often I suspect for aesthetic reasons. You could always consider replacing them with toothed idlers, especially if twisting belts isn't possible as it would limit axis travel - they're not quite as readily available but you can buy them.
                      www.precisionpiezo.co.uk
                      • fmaundefined
                        fma
                        I also twisted my belt on my CoreXY, as I could find toothed idlers for 3GT/9mm at reasonable price.
                        BTW, I don't see how it reduces axis travel… It is only twisted between motors and rear idlers, where length does not change.
                        Frédéric
                        • DjDemonDundefined
                          DjDemonD
                          Depends on the design, if I twisted belts on my modified smartrapcore I would not be able to move the y carriages close enough to the pulleys to print on all of the bed without frcing the twisted section into far too small length, which I am sure would have an effect on positional accuracy. I think it depends how much build volume you try to squeeze out of a given size corexy.
                          • fmaundefined
                            fma
                            Do you have a picture of the your modified smartrapcore belts path?
                            Frédéric
                            • DjDemonDundefined
                              DjDemonD
                              But as I said twisting the belts here doesn't help me as I don't get the repeating ripple artefact with my big pulleys.
                              • justine.hauptundefined
                                justine.haupt
                                Oh all interesting. I just logged in to post that I feel like I found a major contributing factor to the problem. Perhaps Denos has found the other factor.
                                In trying to rule out vibration of the linear shafts themselves (see photos above for my gantry arrangement) I again ran a print with a part in the center and in each of the four corners. Interesting result: The amplitude is reduced in the corners, but the period of the ripple didn't change. If my linear shafts were vibrating I'd expect higher frequency ripple closer to the edges of the bed. If it's mechanical vibration at all, it would seem to be something local to the toolhead.
                                Last night I found that if I push my finger against the lower part of the heatsink of the Titan extruder during a print, the ripples pretty much go away. I suspect the heatsink is vibrating, which may explain why the ripple frequency is independent of position on the build plate. It may also explain the reduced amplitude by the edges, but that would require too many words to write right now.
                                I ordered the Titan Aero upgrade kit and am redesigning things to suit. I kind of wanted to do that anyway, so if it wasn't the entirety of the problem I'll be OK with that. Will report back when that's working.
                                But clearly something is causing the heatsink to vibrate to begin with. I have a standard (non-Aero) e3d Titan on a work printer and that shows no ripple whatsoever.
                                Denos, youre test with the idlers is most excellent. I have toothed idlers for my GT2 belts, BUT, the quality control is bad: the holes for the bearings are clearly too small for the press fit, and they grind noticeably when rotated. I installed them anyway because I really didn't think it would cause trouble, but perhaps that's the source of the extraneous vibration that's driving the vibration in the heatsink. Eureka?
                                The frustrating thing is, I can't find a reliable (i.e. not super cheap Chinese) source of toothed GT2 idlers. Anyone know? Even good smooth ones seems hard to find. Toothed is preferable for me as my gantry style doesn't lend itself to half-twisting the belts.
                                EDIT:
                                The toothed idlers I used are from RepRap Champion (not as cheap as I recalled), so, not good.
                                ~Justine
                                • DjDemonDundefined
                                  DjDemonD
                                  If the toothed Chinese idlers do not appeal, then consider using large diameter bearings like the F608ZZ bearings I use. Running the belts on the toothed side is not a problem, certainly not for print quality.
                                    justine.haupt
                                    An update:
                                    After changing the idlers and switching to the Titan Aero, the ripples are exactly the same, though possibly a bit more crisp.
                                    I'm going back to blaming some kind of variation in the extrusion speed. Could the large (.8mm) nozzle have something to do with it?
                                    I'm in the process of making a second toolhead with a .5mm nozzle.
                                    This weekend going to redo all the motor wires using shielded twisted pairs too.
                                    Max Arnoldundefined 1 Reply Last reply Reply Quote 0
                                    • fmaundefined
                                      fma
                                      What hotend are you using, with the 0.8mm nozzle? You're right, and it can be related, if the filament does not have time to melt. Do you see any temperature variations?
                                      Frédéric
                                      • Max Arnoldundefined
                                        Max Arnold @justine.haupt
                                        @justine-haupt were you able to resolve the vertical banding? Did you find the reason for the vertical banding? I have a similiar issue.
                                        • hussainsail2002undefined
                                          hussainsail2002
                                          @justine-haupt
                                          I have been having this problem for a while as well. My theory is that the motors create a vibration that is transferred to the frames and to the z axis, this takes place at a micron level and the vibrations cannot be noticed by the eye.
                                          Most Industrial machines reduce vibrations by increasing the weight of the frames by adding concrete in them or using a strong concrete foundation. Even the older stratasys machines were built like tanks and they used nema stepper motors as well.
                                          Vibration meters can be used to measure the vibration of the frames while printing and then stiffeners or weights can be used to increase the rigidity of the machine. This should hopefully reduce the effect of vertical banding.
                                          Not sure if this is even the correct method.
                                          Thanks,
                                          Hussain.
                                            hussainsail2002 @bot
                                            @bot
                                            This is quite interesting, Would like to understand more about this.
                                            The attached link is not working though.
                                            Could you guide me to any other resource that explains this calculation.
                                            Thanks
                                            Hussain.
