    Duet 3 mini 5+ wifi sensorless homing - Help
    1.7k
    • Karimundefined
      Karim @moth4017
      @moth4017 Hey no I did try M201.1, I been working on this printer for two weeks now trying to get sensor-less homing to work properly . I have two duet 2 wifi with duex5 and they working flawlessly. I know what you are saying about homing, I have to home x and y separately then home all works it’s a hit or miss.
      moth4017undefined 1 Reply Last reply Reply Quote 0
      • moth4017undefined
        moth4017 @Karim
        @Karim hi, testing tonight , if i turn down the acceleration while homing it stall less, M201.1 X800 Y800 remember to put the values back after homing.
        i was at , M201.1 X1200 Y1200
          dc42 administrators @Karim
          @Karim said in Duet 3 mini 5+ wifi sensorless homing - Help:
          It’s just the first power up and home all stalls on X axis
          Try using a G1 H2 move to move the motors a few mm away from the endstops at the start of homeall.g or at the start of homex.g and homey.g. That should clear the stall status.
          • moth4017undefined
            moth4017 @dc42
            @dc42 Hi, i tried doing the small move first this didnt work for me , it stalled the "first moved" but moved on the second time.
            ; homex.g
            echo "home x stelh chop mode"
            M569 P0.0										; Check status in console
            M569 P0.1										; Check status in console
            G91                                             ; relative positioning
            M569 P0.0 S1 D3 V10                             ; set to stealth chop
            M569 P0.1 S1 D3 V10								; set to stealth chop
            M915 P0.0 S10 F0 R1 H150                   		; Configure Z-Axis Stall Detection
            M915 P0.1 S10 F0 R1 H150						; Configure Z-Axis Stall Detection
            M201.1 X800 Y800
            echo "stall detection setup"
            M17 X Y											; Check status in console
            G1 P140											;pause to allow the drivers to characterise the motor
            G1 H1 X-0.2 F3000								; move a  little  for cal of sensorless homing / not stalled
            G1 H1 Y-0.2 F3000    							; move a  little  for cal of sensorless homing / not stalle
            echo "lower motor current"
            M913 X30 Y30									; Lower motor current %
            G4 P150											; wait 150ms
            M574 X1 Y2 S3									; Configure Z-Axis stall detection homing
            echo "home x"
            G1 H1 X-350 F6000
            G1 H2 X10 Y10
            G1 H1 X-350 F6000
            G1 H2 X10 Y10; Home Z-Axis actuators independently
            G90 											; absolute positioning
            ;G1 X150 F6000									; move to center of bed
            ;revert back
            echo "after revert back"
            M915 P0.0 S128 F0 R1 H550                   		; Configure Z-Axis Stall Detection
            M915 P0.1 S128 F0 R1 H550						; Configure Z-Axis Stall Detection
            M913 X100  Y100									; Reset motor current %
            M569 P0.0 S1 D2									; reset motors back to spread cycle,
            M569 P0.1 S1 D2									; reset motors back to spread cycle,
            M201.1 X1200 Y1200
              dc42 administrators @moth4017
              @moth4017 try a longer move such as 1mm and use H2 not H1 in those moves. It needs to be more than 1 full step, or more than 4 full steps if you are using the filtering option in M915.
              • moth4017undefined
                moth4017 @dc42
                @dc42 Hi tried the H2 and changing distance moved , 1mm = 10 full steps on my printer , but still have random stalls on the Y axis so far .
                  @moth4017 said in Duet 3 mini 5+ wifi sensorless homing - Help:
                  Are they stalls right at the start of the homing move (i.e. immediately after your 1mm G1 H2 move), or stalls part way through the homing move? If they are right at the start then try lower M201.1 values e.g. X300 Y300.
                  Which firmware version are you using?
                  moth4017undefined 2 Replies Last reply Reply Quote 0
                  • moth4017undefined
                    moth4017 @dc42
                    @dc42 3.5.0 beta2. The stall is after the small movement
                    Karimundefined dc42undefined 2 Replies Last reply Reply Quote 0
                    • Karimundefined
                      Karim @moth4017
                      @moth4017 Mine stall at first homing, X would stall, but if you get X to home successfully. Home all work every time, but if printer is power off overnight in the morning you have to go through that procedure again.
                      • moth4017undefined
                        moth4017 @dc42
                        @dc42 Did some testing tonight setting M201.1 to x300 y300 seems to be working at the moment , ill keep an eye on it over the weekend
                        Karimundefined 1 Reply Last reply Reply Quote 0
                        • Karimundefined
                          Karim @moth4017
                          @moth4017 Which printer do you have , This is a Voron 0.2 Corexy.
                          • moth4017undefined
                            moth4017 @Karim
                            @Karim core XY valkyrie
                            https://vkingprinter.com/project-valkyrie/
                              Try using M201.1 to reduce the acceleration during homing.
                              • Karimundefined
                                Karim @moth4017
                                @moth4017 Very nice Printer, I never heard of it.
                                • Karimundefined
                                  Karim @Karim
                                  @Karim This is my X Axis homing, it's not stalling now .I will let you know if this is working.
                                  ; homeX.g
                                  ; called to home the X axis
                                  M84 X
                                  M400						    ; Wait for current moves to finish
                                  M569 P0.1 D3 V10				; X -> B axis reduce V parameter so driver operates in stealthChop
                                  M569 P0.2 D3 V10				; Y -> A axis reduce V parameter so driver operates in stealthChop
                                  G4 P200						    ; Pause for 200ms to let StealthChop do some sh!t
                                  M17 X						    ; Energize Motors X Y
                                  M913 X20 Y20				    ; drop motor current to 20%
                                  M915 X S20 R0 F0 H200	        ; Sensitivity 9 [-64 --> 64], R - take no action, F - No filter, 200steps/sec
                                  M201.1 X250 Y250
                                  G4 P200						    ; wait 200ms
                                  G91					            ; set relative
                                  M400                            ; Wait for moves to finish
                                  G1 H2 X-1 F3000                 ; Move X axis back a little bit to clear stall flag if it's triggered
                                  G1 H1 X350 F3500			    ; [ First Pass ] move quickly to X axis endstop and stop there
                                  M400
                                  M913 X100 Y100				    ; return current to 100%
                                  M569 P0.1 D2					; Take driver out of StealthChop Mode
                                  M569 P0.2 D2					; Take driver out of StealthChop Mode
                                  M201.1 X650 Y650
                                  • moth4017undefined
                                    moth4017 @dc42
                                    I had a whole weekend without a stall for the first time ,
                                    Thanks everyone
                                    ;homey.g
                                    echo "Home Y"
                                    M569 P0.0										; check status in console Y
                                    M569 P0.1										; check status in console X
                                    G91												; Relative positioning
                                    M569 P0.0 S1 D3 V10                             ; set to stelth chop
                                    M569 P0.1 S1 D3 V10								; set to stelth chop
                                    M915 P0.0 S10 F0 R1 H200						; Configure y-Axis Stall Detection
                                    M915 P0.1 S10 F0 R1 H200                    	; Configure x-Axis Stall Detection
                                    M201.1 X300 Y300
                                    M17 X Y
                                    G1 P140
                                    G1 H2 X-1 F3000                               ; move a  little  for cal of sensorless homing / not stalled
                                    G1 H2 Y-1 F3000    							; move a  little  for cal of sensorless homing / not stalled
                                    M913 X60 Y60									; Lower motor current %
                                    G4 P150
                                    echo "Home Y"
                                    G1 H1 Y350 F6000
                                    G1 H2 X-10 Y10
                                    G1 H1 Y350 F6000                       			; Home Z-Axis actuators independently
                                    G1 Y150 F6000									; move to center of bed
                                    ;revert back
                                    M915 P0.0 S128 F0 R1 H550						; Configure x-Axis Stall Detection
                                    M915 P0.1 S128 F0 R1 H550                    	; Configure x-Axis Stall Detection
                                    M201.1 X1000 Y1000
                                    • moth4017undefined
                                      moth4017
                                      @dc42 Mark as solved ... i think 🙂
                                      moth4017undefined 1 Reply Last reply Reply Quote 1
                                        What did you end up changing to get it right?
                                        • moth4017undefined
                                          moth4017 @moth4017
                                          @moth4017 i added the M201.1 x300 y300 just before the stall detection setup
                                          • Karimundefined
                                            Karim @moth4017
                                            @moth4017 I don’t know what’s going on with my setup because mine works for a few days and the have homing problems and then works again, I guess it’s have to deal with it the way it’s working.
