    Parallel Scara based on Morgan.
    My Duet controlled machine
    754
    • JoergS5undefined
      JoergS5 @Phospherus
      @Phospherus I'd wish you open it in a iFixit style and post some images to discuss the quality. Unfortunately - I completely understand it - you'll not want to do it because of the guarantee. But if it's damaged in the future, this would be valuable. They are out of stock and a bit too expensive to buy it just for testing.
      • o_lampeundefined
        o_lampe @Phospherus
        @Phospherus It surprised me, that they took a short NEMA17 motor with low torque for it. I guess a full size motor would exceed the max. output torque of the harmonic drive.
        • Phospherusundefined
          Phospherus
          First printing with the Scara looking good so far. No z endstop so set it with piece of paper and no heated bed as my PSU mount is printing so running off a 5 amp 24V power pack. Using a Bondtech BMG for bowden drive with a Phaetus BMO hotend. Link to youtube video below. This is my first time ever uploading to youtube so if it does not work I apologize and will fix it.
          https://youtu.be/9VRnl9GF-Sk
          o_lampeundefined 1 Reply Last reply Reply Quote 2
          • o_lampeundefined
            o_lampe @Phospherus
            This post is deleted!
            Phospherusundefined 2 Replies Last reply Reply Quote 0
              Phospherus @o_lampe
                Phospherus @o_lampe
                @o_lampe Video link should work now.
                • o_lampeundefined
                  o_lampe @Phospherus
                  @Phospherus Looks good for a first print on a cold bed. 👍
                    Phospherus
                    A couple pictures of the first print complete. I am amazed how good it came out without part cooling even.20230309_121359.jpg 20230309_121421.jpg
                      Phospherus
                      Finally got a test set of arms printed and a mount for the Nema 17 harmonic drives. Here it is in action. https://youtube.com/shorts/bj47uQ08zV0?feature=share
                      o_lampeundefined 1 Reply Last reply Reply Quote 1
                      • o_lampeundefined
                        o_lampe @Phospherus
                        @Phospherus It's always hard to qualify mechanics from a video. The first impression is good, no visible backlash or springiness.
                        Will be interesting to see it work, maybe with a feltpen for starters?
                        Would you use a direct drive extruder as toolhead or is it strictly Bowden-setup? How much does the head sag?
