    M703 inside load.g not supported
    rrf 3.5.0-b2 duet 3 mini 5+ standalone
    469
    • Exerqtorundefined
      Exerqtor
      Having M703 inside load.g don't work for some reason even though load.g is completed fully with M703 being the last line (before the echo confirming that the file has been completed).
      Happening on a Duet 3 Mini 5+ in standalone btw
        Can you share the full contents of load.g?
        Exerqtorundefined 1 Reply Last reply Reply Quote 0
        • Exerqtorundefined
          Exerqtor @Phaedrux
          Ofc:
          ; filaments/"filament"/load.g
          ; called when M701 S"filament" is sent
          ; Settings section
          ; Filament settings
          var FilamentType = "ABS"                                                       ; Input the filament type (only for the message)
          ; Message placeholders
          var Message1 = "N/A"
          ; Message section
          ; Generate message
          set var.Message1 = "" ^ var.FilamentType ^ " filament loaded"
          ; Filament loaded message
          M118 P0 S{var.Message1}                                                        ; Send message to DWC
          M118 P2 S{var.Message1}                                                        ; Send message to PanelDue
          M703        ; Load filament config.g for the selected filament
          echo "load.g end"
          This is what shows up in DWC console:
          8.3.2023, 16:52:10	ABS filament loaded
          And this is what config.g (filament) contains:
          ; filaments/ABS/config.g  (v2.1)
          ; called when M703 is sent and ABS is loaded
          ; Settings section
          ; Filament settings
          var Default             = false        ; Use default settings (retraction and PA), true/yes or false/no
          var PA                  = 0.045        ; Pressure advance amount (s)
          var RLen                = 0.400        ; Retraction length (mm)
          var X_URLen             = 0.010        ; Extra unretract length (mm)
          var RSpd                = 4200         ; Retraction speed (mm/min)
          var URSpd               = 4200         ; Unretract speed (mm/min)
          var Z_Lift              = 0.200        ; Zlift amount (mm)
          var Message2 = "N/A"
          ; Config section
          if !var.Default
            ; Pressure Advance
            M572 D0 S{var.PA}                                                            ; Set extruder 0 pressure advance to 0.1 seconds
            ;Retraction & Zlift
            M207 S{var.RLen} R{var.X_URLen} F{var.RSpd} T{var.URSpd} Z{var.Z_Lift}       ; Set firmware retraction length, extra un-retract lenght, retract speed, unretract speed & zlift
          ; Define & send messages
          if var.Default
            set var.Message1 = "" ^ var.FilamentType ^ " config applied (default settings)"
          else
            set var.Message1 = "" ^ var.FilamentType ^ " config applied"
          if move.extruders[0].pressureAdvance = 0
            set var.Message2 = "Pressure Advance disabled"
          else
            set var.Message2 = "Pressure Advance set to " ^ move.extruders[0].pressureAdvance ^ " seconds"
          ; Config applied message
          ; Pressure advance info message
          M118 P0 S{var.Message2}                                                        ; Send message to DWC
          M118 P2 S{var.Message2}                                                        ; Send message to PanelDue
          None of the settings or messages within config.g gets applied/ran.
            dc42 administrators @Exerqtor
            @Exerqtor which Duet are you using, and are you running in standalone mode or SBC mode? Did it work in RRF 3.4.5 ?
            • Exerqtorundefined
              Exerqtor @dc42
              @dc42 Added tags to the first post.
              I haven't tried it earlier myself, BUT i know of at least one person thats been/are doing it in different 3.4 versions on Duet 3's in standalone.
              OwenDundefined 1 Reply Last reply Reply Quote 0
              • OwenDundefined
                OwenD @Exerqtor
                @Exerqtor
                I think this may have been the case for a while.
                I assume (but aren't sure) it's because the filament isn't "loaded" until load.g actually exits. The docs say if you call M703 with no filament loaded it completes without warning.
                In my own files I seem to have gotten around it by using M98 to call the filament config.g
                I set up my filaments a long time ago using a single universal load and unload so can't remember the exact details regarding M703.
                • Exerqtorundefined
                  Exerqtor @OwenD
                  @OwenD said in M703 inside load.g broken in 3.5.0b2:
                  @Exerqtor
                  Yeah that might be the deal, but i suspect that ain't the intended behavior 😅
                  I ended up swaping out M703 with M98 in my load.g too. Since I allready have the "filament type" defined by a variable so it's not a huge hazzle. Buuuut it would be easier/less code to just deploy a M703 lol.
                  pfnundefined 1 Reply Last reply Reply Quote 0
                  • pfnundefined
                    pfn @Exerqtor
                    @Exerqtor
                    I already responded in discord, but I looked at my filament setting macro and it calls M703 discretely from M701. load.g probably never called config.g for me, but that didn't matter, because M702 must be called before M701 anyway, so I combined all that into the macro.
                    • chrishammundefined
                      chrishamm administrators @pfn
                      @pfn I don't think this has ever worked because the filament isn't set before the load.g macro completes AFAIR. Call your filament config.g manually if you need to configure it as part of the load macro. Note that at least DWC calls M703 after M701 anyway.
                      Duet software engineer
                      • Exerqtorundefined
                        Exerqtor @chrishamm
                        Yeah with @pfn retracting his statement regarding it working pre 3.5 i have no grounds to say it's ever worked either (since he was my reference lol).
                          T3P3Tony administrators @Exerqtor
                          @Exerqtor I hope you don't mind but i have changed the title of this topic and moved it to general discussion because its not an issue specifically with 3.5b2.
                          • T3P3Tonyundefined T3P3Tony moved this topic from Beta Firmware
                          • Exerqtorundefined
                            Exerqtor @T3P3Tony
                            @T3P3Tony Yeah ofc, sorry I should have done that myself once we discovered it wasn't an isolated thing 🤦‍♂️
