    Detect Skipping Extruder?
    525
    • Adamfilipundefined
      Adamfilip @jay_s_uk
      @jay_s_uk Can you set it to run a macro?
      Rn Action to take on detecting a stall from any of these drivers: 0 = no action (default), 1 = just log it, 2 = pause print, 3 = pause print, execute /sys/rehome.g, and resume print. See notes for RRF v3.4
      moth4017undefined jay_s_ukundefined T3P3Tonyundefined 3 Replies Last reply Reply Quote 0
      • moth4017undefined
        moth4017 @Adamfilip
        @Adamfilip you have given me an idea ... if the stall detection of the extruder was on the fist layer , could you auto baby step the nozzle away from the bed ?
        Adamfilipundefined 1 Reply Last reply Reply Quote 1
          Adamfilip @moth4017
          @moth4017 interesting idea to compensate for being too close on layer 1
          moth4017undefined dc42undefined 2 Replies Last reply Reply Quote 0
          • moth4017undefined
            moth4017 @Adamfilip
            @Adamfilip yes
              jay_s_uk @Adamfilip
              @Adamfilip yes. You can set it via macro or the console
                T3P3Tony administrators @Adamfilip
                @Adamfilip be aware that stall detection may not work well at typical extruder speeds, see this:
                https://docs.duet3d.com/en/User_manual/Connecting_hardware/Sensors_stall_detection#minimum-recommended-speed-for-stall-detection
                YMMV and you do need to tune it in.
                From 3.4 your detected stalls will be handled by the event system:
                In RRF v3.4 and later there is no longer a distinction between R2 and R3; both cause an event to be created when the driver stalls. To handle the event, RRF calls driver-stall.g passing the stalled local driver number in param.D and the CAN address of the board concerned in param.B. File rehome.g is no longer used. If file driver-stall.g is not found then the print is paused without running pause.g and the error is reported.
                https://docs.duet3d.com/User_manual/RepRapFirmware/Events
                  dc42 administrators @Adamfilip
                  @Adamfilip a caveat is that if the extruder is driven by a TMC2209 then the driver would have to be in stealthChop mode for stall detection to work, and using stealthChop on extruder motors is almost certainly a bad idea. It might be OK using TMC2660 or TMC2160/5160 drivers, although stall detection is easier at reduced current.
                  • RandyL00123undefined
                    RandyL00123
                    I started thinking of how stall detection works, and I was wondering if it's possible to monitor the extruder stepper voltage. It seems to me that if you have a filament run out, the voltage would suddenly drop significantly as the motor force would drop. On the other end of the spectrum, a filament snag would cause the motor voltage to spike before the extruder started to grind, leading to a reduction in motor torque as the filament disappeared from under the drive gear. So, is it possible to monitor the extruder stepper voltage, and have an acceptable range? Any voltage outside of that range would trigger a problem.
                    moth4017undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                    • moth4017undefined
                      moth4017 @RandyL00123
                      @RandyL00123 I'm not sure there is a way to monitor that in duet/DWC ,
                        T3P3Tony administrators @RandyL00123
                        @RandyL00123 see the reply here:
                        https://forum.duet3d.com/topic/31798/monitor-extruder-stepper-voltage-to-detect-filament-errors?_=1679398375558
