    Duet2 WiFi generating polygons instead of circles
    Laser Cutters
    1.6k
      T3P3Tony administrators @flopes
      @flopes please try and reply here again
      • flopesundefined
        flopes @Phaedrux
        @Phaedrux
        Hi
        It seems I was not fully registered yet. Now I can reply
        I have firmware version 3 on the board
        Using cartesian machine.
        Everything works fine for larger features, but does not work ok for small features as described
        Please help
        Thnaks
          droftarts administrators @flopes
          @flopes please post your config.g and the response to M122. Without some information it is difficult to diagnose where the problem might be.
          T3P3Tonyundefined flopesundefined 3 Replies Last reply Reply Quote 0
          • T3P3Tonyundefined T3P3Tony referenced this topic
            T3P3Tony administrators @droftarts
            @flopes also please post a section for the gcode with the features that are being output incorrectly in it (not the whole file!)
            • flopesundefined
              flopes @droftarts
              @droftarts This is the M122
              m122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.4 (2022-10-20 16:17:41) running on Duet WiFi 1.02 or later
              Board ID: 0JD0M-9X6JA-JUNSS-6JKDJ-3SD6J-T9KRU
              Used output buffers: 3 of 26 (26 max)
              Static ram: 23860
              Dynamic ram: 75720 of which 0 recycled
              Never used RAM 12356, free system stack 104 words
              Tasks: LASER(notifyWait,0.6%,38) NETWORK(notifyWait,193.4%,231) HEAT(notifyWait,1.9%,324) Move(notifyWait,145.5%,294) MAIN(running,152.1%,410) IDLE(ready,12.4%,30), total 505.9%
              Owned mutexes: WiFi(NETWORK)
              Last reset 90:58:49 ago, cause: software
              Last software reset at 2023-03-17 12:46, reason: User, GCodes spinning, available RAM 12312, slot 1
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00417000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
              Error status: 0x0c
              Aux0 errors 0,0,0
              Step timer max interval 0
              MCU temperature: min 33.9, current 35.0, max 44.4
              Supply voltage: min 19.5, current 19.8, max 20.1, under voltage events: 0, over voltage events: 0, power good: yes
              Events: 0 queued, 0 completed
              Driver 0: standstill, SG min 0
              Driver 1: standstill, SG min 0
              Driver 2: standstill, SG min 0
              Driver 3: standstill, SG min n/a
              Driver 4: standstill, SG min n/a
              Driver 5:
              Driver 6:
              Driver 7:
              Driver 8:
              Driver 9:
              Driver 10:
              Driver 11:
              Date/time: 2023-03-21 07:45:41
              Slowest loop: 17.15ms; fastest: 0.11ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 9.6ms, write time 152.0ms, max retries 0
              DMs created 83, segments created 6, maxWait 366518ms, bed compensation in use: none, comp offset 0.000
              === MainDDARing ===
              Scheduled moves 1214398, completed 1214398, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 21], CDDA state -1
              === AuxDDARing ===
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              Daemon is idle in state(s) 0
              Code queue is empty
              === Network ===
              Slowest loop: 175.88ms; fastest: 0.00ms
              Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
              HTTP sessions: 1 of 8
              = WiFi =
              Network state is active
              Failed messages: pending 0, notready 0, noresp 1
              WiFi firmware version 1.27
              WiFi MAC address 48:3f:da:a6:ee:bb
              WiFi Vcc 3.46, reset reason Power up
              WiFi flash size 2097152, free heap 22296
              WiFi IP address 192.168.10.76
              WiFi signal strength -65dBm, mode 802.11n, reconnections 0, sleep mode modem
              Clock register 00002002
              flopesundefined 1 Reply Last reply Reply Quote 0
              • flopesundefined
                flopes @droftarts
                @droftarts This is the config.g
                ; generated by RepRapFirmware Configuration Tool v3.3.16 on Fri Mar 17 2023 12:42:29 GMT-0700 (Pacific Daylight Time)
                M550 P"Laser Cutter" ; set printer name
                M552 S1 ; enable network
                M586 P0 S1 ; enable HTTP
                M586 P1 S0 ; disable FTP
                M586 P2 S0 ; disable Telnet
                M350 X8 Y8 Z8 E8 I0 ; configure microstepping without interpolation
                M92 X160.00 Y160.00 Z160.00 E1.00 ; set steps per mm
                M566 X60.00 Y60.00 Z60.00 E6.00 ; set maximum instantaneous speed changes (mm/min)
                M203 X6600.00 Y6600.00 Z6600.00 E6.00 ; set maximum speeds (mm/min)
                M201 X10.00 Y10.00 Z10.00 E1.00 ; set accelerations (mm/s^2)
                M906 X1000 Y1000 Z1000 E300 I30 ; set motor currents (mA) and motor idle factor in per cent
                M84 S1 ; Set idle timeout
                M208 X0 Y0 Z-200 S1 ; set axis minima
                M208 X1100 Y1100 Z755.2 S0 ; set axis maxima
                M574 X2 S1 P"!^xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin !^xstop
                M574 Y1 S1 P"!^ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !^ystop
                M574 Z2 S1 P"!^zstop" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin !^zstop
                M558 P0 H0 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                M557 X5:100 Y5:100 S5 ; define mesh grid
                M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
                M563 P0 S"Z Pogo" D0 H1 F0 ; define tool 0
                G10 P0 X5 Y5 Z5 ; set tool 0 axis offsets
                M563 P1 S"Laser" F0 ; define tool 1
                • flopesundefined
                  flopes @flopes
                  @flopes This is actually the config.g when I enlarged the part 10x and tricked my printer to print 10x smaller with success.
                  • flopesundefined
                    flopes @flopes
                    @flopes This is the g code that fails:
                    G01 Z0 F6.
                    G01 X.087 Y-.064 Z0 F4.
                    G03 X.087 Y.064 Z0 I0 J.064 F4.
                    G01 X0 Y.064 Z0 F4.
                    G03 X0 Y-.064 Z0 I0 J-.064 F4.
                    G01 X.043 Y-.064 Z0 F4.
                      dc42 administrators @flopes
                      @flopes the minimum length for segments that make up arcs is currently set at 0.1mm. We should perhaps revise that value for situations with high steps/mm, low feed rates and small arc radius.
                      flopesundefined 2 Replies Last reply Reply Quote 0
                      • flopesundefined
                        flopes @dc42
                        Hi
                        Is there a quick fix, or something easily changeable in the firmware to get to produce arches of 5microns?
                        My printer is only 10cm by 10cm so I don't mind sacrificing the maximum length if that means increasing resolution
                        Thanks
                        • flopesundefined
                          flopes @flopes
                          @flopes The first obround is 100micron tall by 300 wide
                          • flopesundefined
                            flopes @flopes
                            @flopes Our feed is 6mm/min!
                            • flopesundefined
                              flopes @flopes
                              @flopes Also there is some uncertainty on the position of some features of about 25micron.
                              • flopesundefined
                                flopes @flopes
                                @flopes Some features are aligned most of time. IT IS NOT STEPPER MISSING STEPS.Random Misposition of 30micron.jpg
                                • flopesundefined
                                  flopes @flopes
                                  Any help on the matter would be greatly appreciated
                                    @flopes one option to try would be to setup the config as if the printer was 10* bigger, then set the microstepping to 64 instead of 8, and the steps/mm to an appropriately adjusted value. The idea being that the limit of 0.1mm segments would then be 0.01mm in reality due to the 10x scaling.
                                    • flopesundefined
                                      flopes @T3P3Tony
                                      @T3P3Tony
                                      Scaling 10:1 is how I have been operating. Do you know what is the minimum positioning resolution of the Duet2?
                                      I know It responds to G21G91G1X0.001 with 1 micron displacement, but would the motion control allow for such fine positioning? Could I laser drill a grid 5micron by 5micron?
                                      My tests show about 25micron uncertainty on the position of a cut, but once the cut starts, it can be very precise (5micron?)
                                        @flopes you are limited by the step resolution. If you have been operating at a 10:1 scaling then switch to a 100:1 as a work around for now.
                                        • flopesundefined
                                          flopes @T3P3Tony
                                          @T3P3Tony Thanks. I will run a test
                                          • flopesundefined
                                            flopes @T3P3Tony
                                            @T3P3Tony
                                            It seems to work fine. Polygons are gone at 100X. Error in mispositioning improved as well. May be good enough. Please advise when you will increase board resolution
                                            Thanks
                                            Fernando
                                            • flopesundefined flopes has marked this topic as solved
