Connection issues to external Closed Loop Stepper Driver
I will try that out, thank you.
Is the wiring correct with?
EN -EN
STEP - STEP
DIR -DIR
GROUND -GROUND
or should it be connected like the polulu in the image above? -
@dc42 It didnt work with 1k or 500ohms pullup resistors
@Kruix said in Connection issues to external Closed Loop Stepper Driver:
why would the image show the enable, step, direction pins swapped around so they are not connecting to the correct pins? where did that image come from?
https://docs.duet3d.com/User_manual/Connecting_hardware/Motors_connecting_external
Yes it didn't make sense to me too at least
@Kruix ahh right, that example adaptor board must swap pins over or something. If you are not suing that then step-step, dir-dir etc is correct.
@Kruix have you tried changing the enable polarity jumper on the 6XD ?
@T3P3Tony
Firstly thanks for the support!
changing the Polarity didn't work. But one more question, if there is no error signal of a motor, nothing needs to be connected there, right?
What Polarity does the jumper change? Is the standard active high or low? -
@Kruix the polity for the enable jumper changes active high/low
The error pull up/down relates only to an error input if you are using it.
from the documentation:
A jumper in the "left" position is used for external drivers which are enabled when a voltage is applied to the enable connection (Active Enable). A jumper in the "right" position is used for external drivers which are disabled when a voltage is applied to the enable connection (Active Disable) (Note the v0.1 boards have the silkscreen reversed).
@T3P3Tony
Is it possible to set the STEP/DIR Signal itself active High instead of pulling it to ground? -
@jay_s_uk
The question was because of the article in https://docs.duet3d.com/User_manual/Overview/Getting_started_Duet_3_MB6XD
that states at the bottom that
"The Step, Dir and Enable outputs from the 6XD are either low (when "on") or floating/high impedence when "off". "
thats why I assumed the R command would only refer to the Polarity of the Enable Pin -
@jay_s_uk You are totally right, I was questioning my sanity but I tried the same with a different driver and it worked now. I guess that my driver was broken. There were also some software issues.Thanks everyone for your help!
