    Problem with endstops Duet 3 MB 6HC
    340
    • imartinezundefined
      imartinez
      Good Morning....
      I have a Duet 3 MB 6HC in a cartesian printer and i can´t connect the endstops of igus (normaly closed) , the driver can not go home the axis .... Can you help me , please???
      Thanks
        droftarts administrators @imartinez
        @imartinez Is it a bare microswitch, or some kind of sensor on a board? Please link to the endstop product page. If it is a bare microswitch, you only need to connect two wires:
        Duet 3: connect the switch between the IN and GND pins of your chosen IO_x connector. (i.e. NOT to 3.3V)
        We recommend you use the normally-closed contacts of the microswitches, which are generally the outside two connections on the microswitch.
        See https://docs.duet3d.com/User_manual/Connecting_hardware/Sensors_endstops
        Don't use ^0.io1.in, you don't need the pull up resistor enabled. Use 0.io1.in or simply io1.in.
        If that doesn't help:
        • post your config.g
        • post the response to M115
        • post the response to M98 P"config.g".
        imartinezundefined 1 Reply Last reply Reply Quote 0
          imartinez @droftarts
          @droftarts Don´t work... i can´t home the axis because the endstops don`t works .....
          Thanks for help me...
          droftartsundefined imartinezundefined 2 Replies Last reply Reply Quote 0
            @imartinez You have two drives defined for X?
            M584 X0.0:0.5 Y0.1 Z0.2 E0.3
            Remove the second one for now.
            Please link to the Igus product page for this product, so I can see the type of endstop and the wiring.
              imartinez @imartinez
              @imartinez ....and this label is from the igus endstop...
              https://www.igus.com/search?q= INI-AB-I-025-A-AA
              link text
              Thanks again...
              jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
                jay_s_uk @imartinez
                @imartinez you're only powering it with 3.3v and yet it only works with 10-30v
                  dc42 administrators @imartinez
                  @imartinez it is PNP output so you will have to connect it to the Duet using some resistors, just as for a PNP-output Z-probe. See https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_connecting#pnp-output-normally-open-inductive-or-capacitive-sensor.
                  Next time, choose the NPN output version because it's simpler to connect to the Duet. The PNP ones are designed to interface to PLCs.
                  imartinezundefined 1 Reply Last reply Reply Quote 1
                    imartinez @dc42
                    @dc42 Ummm I think i going to buy others endstops ... Do you know any model that works well and is easy to configure?
                    Thanks for all
                      @imartinez I use bare microswitches and print whatever mounts I need for them. Omron low-current ones are best. Which country are you in?
                        imartinez @dc42
                        @dc42 In Spain.....
                          @imartinez here are some suitable microswitches. RS Components also has a presence in Spain. https://uk.rs-online.com/web/c/switches/micro-switches-detector-switches/micro-switches/?applied-dimensions=4294965413,4294885039,4294535212,4290612518,4294515253,4294535154,4294569646,4294864096,4294876631,4294864112,4294570867
