    Max number of parameters?
    Gcode meta commands
    rrf 3.5.0-b2 duet 3 mini 5+ standalone
    690
    • Exerqtorundefined
      Exerqtor
      Is there a maximum number of parameters one can pass over to a macro file as of RRF 3.5.0b2?
      I'm currently working on a macro that's trying to pass A,B,C,D,E & F, A-D pass over without an issue, but E & F come out as "null".
      I've also tried changing E & F too H & I respectively in the case RRF might look funny at a parameter called E, but it's still the same problem.
      OwenDundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • OwenDundefined
        OwenD @Exerqtor
        @Exerqtor
        I'm not seeing your results but this might be the reason
        When using a macro as custom gcode, do not use G, M, N, or T as parameters in a custom 'G' gcode file. Do not use G, M, or N as parameter in a custom 'M' gcode file. There are no standard G or M commands that use these parameters and RRF will treat the parameter as being the start of the next command.
        You also can't use the P parameter inside the macro
        e.g. echo param.P won't work
        I did this macro to test
        var parameters = vector(12,null)
        if exists(param.A)
            set var.parameters[0] = param.A
        else
            set var.parameters[0] = "A"
        if exists(param.B)
            set var.parameters[1] = param.B
        else
            set var.parameters[1] = " B"
        if exists(param.C)
            set var.parameters[2] = param.C
        else
            set var.parameters[2] = "C"
        if exists(param.D)
            set var.parameters[3] = param.D
        else
            set var.parameters[3] = "D"
        if exists(param.E)
            set var.parameters[4] = param.E
        else
            set var.parameters[4] = "E"
        if exists(param.F)
            set var.parameters[5] = param.F
        else
            set var.parameters[5] = "F"
        if exists(param.H)
            set var.parameters[6] = param.H
        else
            set var.parameters[6] = "H"
        if exists(param.I)
            set var.parameters[7] = param.I
        else
            set var.parameters[7] = "I"
        if exists(param.J)
            set var.parameters[8] = param.J
        else
            set var.parameters[8] = "J"
        if exists(param.K)
            set var.parameters[9] = param.K
        else
            set var.parameters[9] = "K"
        if exists(param.L)
            set var.parameters[10] = param.L
        else
            set var.parameters[10] = "L"
        if exists(param.O)
            set var.parameters[11] = param.O
        else
            set var.parameters[11] = "O"
        echo "Params passed were " ^ var.parameters
        • Exerqtorundefined Exerqtor marked this topic as a question
          dc42 administrators @Exerqtor
          @Exerqtor are you invoking the macro using M98, or in some other way?
          Are you running standalone or in SBC mode?
          Make sure you have a space between E or F and whatever precedes it, for example use D1 E2 not D1E2 (which would be interpreted as just a D parameter with value 1e2 i.e. 100).
          Exerqtorundefined 1 Reply Last reply Reply Quote 0
          • Exerqtorundefined
            Exerqtor @dc42
            @dc42 said in Max number of parameters?:
            By M98 yeah,
            Standalone.
            There are spaces allready so that shouldn't be the case, this is the two macro's in question:
            ; /sys/print/a_mesh.g  v2.1
            ; Called by print_probe.g before a print starts
            ; Used to probe a new bed mesh at the start of a print
            ; Settings section
            ; Minimum deviation from default mesh
            var minDev              = 20                                                   ; The minimum deviation between the default mesh points before an adaptive mesh is generated.
            ; Probing points for adaptive mesh
            var minMeshPoints       = 3                                                    ; The minimum amount of probing points for both X & Y.
            var maxMeshPoints       = 10                                                   ; The maximum amount of probing points for both X & Y
            ; Don't touch anyting beyond this point(unless you know what you're doing)!!
            ; Prep phase
            ; Grab default probing grid
            var m557MinX = move.compensation.probeGrid.mins[0]                             ; Grabs your default x min
            var m557MaxX = move.compensation.probeGrid.maxs[0]                             ; Grabs your default x max
            var m557MinY = move.compensation.probeGrid.mins[1]                             ; Grabs your default y min
            var m557MaxY = move.compensation.probeGrid.maxs[1]                             ; Grabs your default y max
            ; Grab the default mesh spacing
            var meshSpacing_X = {move.compensation.probeGrid.spacings[0]}                  ; Grabbing the X spacing of the current M557 settings
            var meshSpacing_Y = {move.compensation.probeGrid.spacings[1]}                  ; Grabbing the Y spacing of the current M557 settings
            ; Setup print area
            ; Define a variable to represent the min/max mesh coordinates
            var pamMinX = {global.paMinX}                                                  ; The min X position of the print job
            var pamMaxX = {global.paMaxX}                                                  ; The max X position of the print job
            var pamMinY = {global.paMinY}                                                  ; The min Y position of the print job
            var pamMaxY = {global.paMaxY}                                                  ; The max Y position of the print job
            ; Check if adaptive mesh is needed
            var enabled = "PLACEHOLDER"
            var msg = "PLACEHOLDER"
            if (var.m557MinX + var.minDev) >= var.pamMinX                                  ; Check if the difference between default min X and the print area min X is smaller than the set deviation
              set var.pamMinX = {var.m557MinX}                                             ; The difference is smaller than min deviation so set pamMinX to m557MinX
            if (var.m557MaxX - var.minDev) <= var.pamMaxX                                  ; Check if the difference between default max X and the print area max X is smaller than the set deviation
              set var.pamMaxX = {var.m557MaxX}                                             ; The difference is smaller than min deviation so set pamMaxX to m557MaxX
            if (var.m557MinY + var.minDev) >= var.pamMinY                                  ; Check if the difference between default min Y and the print area min Y is smaller than the set deviation
              set var.pamMinY = {var.m557MinY}                                             ; The difference is smaller than min deviation so set pamMinY to m557MinY
            if (var.m557MaxY - var.minDev) <= var.pamMaxY                                  ; Check if the difference between default max X and the print area max Y is smaller than the set deviation
              set var.pamMaxY = {var.m557MaxY}                                             ; The difference is smaller than min deviation so set pamMaxY to m557MaxY
            if var.m557MinX = var.pamMinX && var.m557MaxX = var.pamMaxX && var.m557MinY = var.pamMinY  && var.m557MaxY = var.pamMaxY
              set var.enabled = false
              set var.msg = "Print area bellow min deviation, using default mesh!"         ; Set the message
            else
              set var.enabled = true
              ; Get the number of probes for X taking minMeshPoints and maxMeshPoints into account
              var meshX = floor(min(var.maxMeshPoints - 1, (max(var.minMeshPoints - 1, (var.pamMaxX - var.pamMinX) / var.meshSpacing_X) + 1)))
              ; Get the number of probes for Y taking minMeshPoints and maxMeshPoints into account
              var meshY = floor(min(var.maxMeshPoints - 1, (max(var.minMeshPoints - 1, (var.pamMaxY - var.pamMinY) / var.meshSpacing_Y) + 1)))
              ; Set message about the Adaptive mesh that's been created
              set var.msg = "Adaptive mesh, X-min: " ^ var.pamMinX ^ "; X-max: " ^ var.pamMaxX ^ "; Y-min: " ^ var.pamMinY ^ "; Y-max: " ^ var.pamMaxY ^ "; Probes, X: " ^ var.meshX ^ "; Y: " ^ var.meshY
            ; Info message
            M291 P{var.msg} T6                                                             ; Display message about what's going to happen
            ; *--DEBUGGING--*
            echo {var.msg}
            ; If a adaptive grid is to be used
            if var.enabled
              ; Transfere grid
              ; Transfere print area probing grid to mesh.g
              M98 P"mesh.g" A{var.pamMinX} B{var.pamMaxX} C{var.pamMinY} D{var.pamMaxY} E{var.meshX} F{var.meshY}
            ; /sys/mesh.g  v2.2
            ; Called as response to G29 or a_mesh.g
            ; THIS MACRO ONLY WORKS WITH RRF 3.5.0b1 AND LATER!!
            ; Prep phase
            if exists(param.A)
              var m577meshX = {move.compensation.probeGrid.spacings[0]}                    ; Grabbing the X spacing of the current M557 settings
              var m577meshY = {move.compensation.probeGrid.spacings[1]}                    ; Grabbing the Y spacing of the current M557 settings
              ; Parse the print area probing grid
              var pamMinX = {param.A}                                                      ; min X position of the print area mesh
              var pamMaxX = {param.B}                                                      ; max X position of the print area mesh
              var pamMinY = {param.C}                                                      ; min Y position of the print area mesh
              var pamMaxY = {param.D}                                                      ; max Y position of the print area mesh
              ; Parse the print area mesh spacing
              var meshX = {param.E}                                                        ; Number of points to probe in the X axis
              var meshY = {param.F}                                                        ; Number of points to probe in the Y axis
              ; LED status
              if exists(global.sb_leds)
                set global.sb_leds = "meshing"                                             ; StealthBurner LED status
              ; *--DEBUGGING--*
              var msg = "PLACHOLDER"
              echo {var.msg}
              ; Set the probing mesh
              M557 X{var.pamMinX}:{var.pamMaxX} Y{var.pamMinY}:{var.pamMaxY} P{var.meshX}:{var.meshY}
              ; Move to the center of the print area
              G0 X{var.pamMinX + ((var.pamMaxX - var.pamMinX)/2) - sensors.probes[0].offsets[0]} Y{var.pamMinY + ((var.pamMaxY - var.pamMinY)/2) - sensors.probes[0].offsets[1]}
            else
              G28        ; Home all axis
              ; Level the bed
              set global.bed_trammed = false                                               ; Set trammed state to false to make it re-level before mesh probing
              if fileexists("/sys/lib/print/print_tram.g")
                M98 P"/sys/lib/print/print_tram.g"                                         ; Level the bed
              else
                echo "print_tram.g missing, aborting!"
                abort
              ; LED status
            ; Lower currents
            if fileexists("/sys/lib/current/xy_current_low.g")
              M98 P"/sys/lib/current/xy_current_low.g" C60                                 ; Set low XY currents
            else
              M913 X60 Y60        ; Set X Y motors to 60% of their max current
            if fileexists("/sys/lib/current/z_current_low.g")
              M98 P"/sys/lib/current/z_current_low.g"                                      ; Set low Z currents
            else
              M913 Z60        ; Set Z motors to 60% of their max current
            ; Get the reference Z offset
            G30 K0 S-3        ; Probe the bed and set the Z probe trigger height to the height it stopped at
            G91        ; Relative positioning
            G1 Z2 F1500        ; Lower bed 2mm relative to when the probe just triggered
            G90        ; Absolute positioning
            M400        ; Wait for moves to finish
            ; Probing code
            ; Probe a new bed mesh!
            M291 R"Mesh Probing" P"Probing now! Please wait..." T10                        ; Probing new mesh bed message
            if exists(param.A)
              ; Probe the new adaptive mesh
              G29 S0        ; Probe the bed, save height map to heightmap.csv and enable compensation
              G29 S3 P"adaptive_heightmap.csv"                                             ; Save the current height map to file "adaptive_heightmap.csv"
              G29 S1 P"adaptive_heightmap.csv"                                             ; Load height map file "adaptive_heightmap.csv" and enable mesh bed compensation
            else
              ; Probe the new default mesh
              G29 S3 P"default_heightmap.csv"                                              ; Save the current height map to file "default_heightmap.csv"
              G29 S1 P"default_heightmap.csv"                                              ; Load height map file "default_heightmap.csv" and enable mesh bed compensation
            ; Finish up
            if exists(param.A)
              ; Restore the default probing mesh
              M557 X{var.m557MinX}:{var.m557MaxX} Y{var.m557MinY}:{var.m557MaxY} P{var.m577meshX}:{var.m577meshY}
            ; Full currents
            if fileexists("/sys/lib/current/xy_current_high.g")
              M98 P"/sys/lib/current/xy_current_high.g"                                    ; Set high XY currents
            else
              M913 X100 Y100                                                               ; Set X Y motors to var.100% of their max current
            if fileexists("/sys/lib/current/z_current_high.g")
              M98 P"/sys/lib/current/z_current_high.g"                                     ; Set high Z currents
            else
              M913 Z100        ; Set Z motors to var.100% of their max current
            ; Uncomment the following lines to lower Z(bed) after probing
            G1 Z{global.Nozzle_CL} F2400                                                   ; Move to Z global.Nozzle_CL
            M291 R"Mesh Probing" P"Done" T4                                                ; Mesh probing done
            ; If using Voron TAP, report that probing is completed
            if exists(global.TAPPING)
              set global.TAPPING = false
              M402 P0        ; Return the hotend to the temperature it had before probing
            ; LED status
              set global.sb_leds = "ready"                                                 ; StealthBurner LED status
            This is how it looks in console if I run it:
            Adaptive mesh, X-min: 53.594; X-max: 128.131; Y-min: 65.0065; Y-max: 104.985; Probes, X: 3; Y: 3
            Adaptive mesh, X-min: 53.594; X-max: 128.131; Y-min: 65.0065; Y-max: 104.985; Probes, X: null; Y: nu
            Error: in file macro line 45: M557: Wrong number of values in array, expected 2
              @Exerqtor said in Max number of parameters?:
              Does it work if you invoke it with constant parameters instead of variables?
              I checked the code and found a problem if you use lowercase parameter letters (which will be fixed in 3.5beta3), but found no other limits or bugs.
              dc42undefined Exerqtorundefined 2 Replies Last reply Reply Quote 0
                dc42 administrators @dc42
                PS:
                You don't need the { } there, you can just use:
                var pamMinX = param.A
                The { } are needed when you use an expression as a parameter value in a regular GCode command.
                • Exerqtorundefined
                  Exerqtor @dc42
                  I'll give that a go in soon. But just for sanity's sake it SHOULD work the way i have it writen now too right?
                  PS:
                  Oh cool, i'll change that right away. Still not know all those "rules" one may say.
                  Edit: Edit2:
                  I just tried manually setting the E & F too 3 when i send M98 P"mesh.g" rather than using variables, same issue.
                  I then tried manually setting var.meshX & var.meshY too 3 in mesh.g, same issue.
                  Then I manually set M557 P3: while still trying to use variables to set X & Y, same issue.
                  I still got:
                  Ok, so the issue apparently ain't just in parameter E & F.... I manually input the coordinates to the M557 to see what happened(m557 X154.491:191.633 Y58.4547:85.9547 P3:3).
                  And sure AF it went past that point now. BUT it threw another error farther down when it was supposed to restore the default mesh. Console readout bellow:
                  6.4.2023, 13:14:46	9 points probed, min error -0.027, max error 0.046, mean 0.010, deviation 0.019
                                          Height map saved to file 0:/sys/heightmap.csv
                                          Height map saved to file 0:/sys/adaptive_heightmap.csv
                                          Error: in file macro line 114 column 22: M557: unknown variable 'm557MinX'
                  6.4.2023, 13:14:21	Z probe trigger height set to -0.639 mm
                  6.4.2023, 13:14:18	Adaptive mesh min-max: X:154.491-191.633; Y:58.4547-85.9547; Probe points, X:3; Y:3
                                          Inserting Adaptive M557
                                          Adaptive M557 insterted
                  It's like RRF "forgets" the variables once they've been used once inside the same program.
                  The current state of mesh.g for referance:
                  ; /sys/mesh.g  v2.2
                  ; Prep phase
                  if exists(param.A)
                    var m577meshX = move.compensation.probeGrid.spacings[0]                      ; Grabbing the X spacing of the current M557 settings
                    var m577meshY = move.compensation.probeGrid.spacings[1]                      ; Grabbing the Y spacing of the current M557 settings
                    var pamMinX = param.A                                                        ; min X position of the print area mesh
                    var pamMaxX = param.B                                                        ; max X position of the print area mesh
                    var pamMinY = param.C                                                        ; min Y position of the print area mesh
                    var pamMaxY = param.D                                                        ; max Y position of the print area mesh
                    ;var meshX = param.E                                                          ; Number of points to probe in the X axis
                    ;var meshY = param.F                                                          ; Number of points to probe in the Y axis
                    var meshX = 3                                                          ; Number of points to probe in the X axis
                    var meshY = 3                                                         ; Number of points to probe in the Y axis
                    ; LED status
                    ; *--DEBUGGING--*
                    ;set var.msg = "Adaptive mesh, X-min: " ^ var.pamMinX ^ "; X-max: " ^ var.pamMaxX ^ "; Y-min: " ^ var.pamMinY ^ "; Y-max: " ^ var.pamMaxY ^ "; Probes, X: " ^ var.meshX ^ "; Y: " ^ var.meshY
                    set var.msg = "Adaptive mesh min-max: X:" ^ var.pamMinX ^ "-" ^ var.pamMaxX ^ "; Y:" ^ var.pamMinY ^ "-" ^ var.pamMaxY ^ "; Probe points, X:" ^ var.meshX ^ "; Y:" ^ var.meshY
                    echo {var.msg}
                    echo "Inserting Adaptive M557"
                    ;M557 X{var.pamMinX}:{var.pamMaxX} Y{var.pamMinY}:{var.pamMaxY} P{var.meshX}:{var.meshY}
                    M557 X154.491:191.633 Y58.4547:85.9547 P3:3
                    echo "Adaptive M557 insterted"
                  else
                    G28        ; Home all axis
                    ; Level the bed
                    else
                      abort
                    ; LED status
                  ; Lower currents
                  else
                  else
                  ; Probing code
                  if exists(param.A)
                  else
                  ; Finish up
                  if exists(param.A)
                  ; Full currents
                  else
                  else
                  ; LED status
                  • infiniteloopundefined
                    infiniteloop @Exerqtor
                    @Exerqtor
                    For reference, see here.
                    Every call of a macro "resets" the local variables, in other words, their scope is limited to the macro they are declared in. To inspect the actual contents of a var at a certain place in your code, insert echo commands.
                    • Exerqtorundefined
                      Exerqtor @infiniteloop
                      @infiniteloop
                      Yeah that I know, but i thought they should persist inside the macro they were created (intil it finish). For instance if you look at mesh.g. The variables I declare between line 17-35 at the start of the macro should still exisist at the end(or in this case in line 114 where i try to restore the default grid)?
                      Or will they be forgotten after tramming (line 56-69) or current adjustement's (line 71-79)?
                      I was onder the imopression they were to persist at least, if not that would certainly explain alot.
                      EDIT:
                      Well i just restructured the macro so that no "sub macros" get called after the variables get declared, and it still shits the bed in the exact same fashion.
                      The "new" mesh.g:
                      ; /sys/mesh.g  v2.2
                      ; Prep phase
                      if !exists(param.A)                                                            ; If this isn't part of a print job with adaptive mesh, tram the bed
                        G28        ; Home all axis
                        ; Level the bed
                        else
                          abort
                      ; LED status
                      ; Lower currents
                      else
                      else
                      if exists(param.A)                                                             ; This is part of a print job with adaptive mesh, bed has allready been trammed
                        ;var meshX = 3        ; Number of points to probe in the X axis
                        ;var meshY = 3        ; Number of points to probe in the Y axis
                        ; LED status
                        ; *--DEBUGGING--*
                        echo {var.msg}
                        ;M557 X154.491:191.633 Y58.4547:85.9547 P3:3
                      ; Probing code
                      if exists(param.A)
                      else
                      ; Finish up
                      if exists(param.A)
                      ; Full currents
                      else
                      else
                      ; LED status
                      infiniteloopundefined gloomyandyundefined dc42undefined 3 Replies Last reply Reply Quote 0
                        @Exerqtor
                        The variables I declare between line 17-35 at the start of the macro should still exisist at the end(or in this case in line 114…
                        And, do they? Use echo to monitor their values.
                        • gloomyandyundefined
                          gloomyandy @Exerqtor
                          @Exerqtor Hmm the variables you created are inside the body of an if statement. In most programming language variables like this would be considered to be local to that block and so would cease to exist at the end of the block. I'm not 100% if that is also the case with the language used here, but I would not be surprised. You might want to move them so that they are created outside the scope of the if statement (and give them a default value), then update that default value (if it makes sense in the body of the if).
                          Exerqtorundefined 1 Reply Last reply Reply Quote 2
                            No! Lines 17-25 are within the if-block that starts at line 15. Any variables declared within this if-block cease to exist when the if-block ends at line 50. This is completely standard behaviour in block-structured languages.
                            • Exerqtorundefined
                              Exerqtor @gloomyandy
                              @gloomyandy @dc42
                              Aha! Then it all makes sense, i had no idea that was how it worked (or that it's the standard in block structured languages). I've never worked with variables, conditional statements etc. before it got implemented in RRF so i'm learning as i go 😮‍💨.
                              But with that knowledge i'm sure I will figure it out 😅
                              So if i create the local variable within the main body of the macro, but assign it a new value within a if-block it will cary along outside the if block right?
                              • Exerqtorundefined
                                Exerqtor @Exerqtor
                                That sure did the trick (for the most part), who would think playing by the rules would help 🤣
                                I've got all but one "function" of the script to work at this point: restoring the default mesh (line 117).
                                mesh.g
                                ; /sys/mesh.g  v2.5
                                ; Prep phase
                                  G28        ; Home all axis
                                  ; Level the bed
                                  else
                                    abort
                                ; LED status
                                ; Lower currents
                                else
                                else
                                ; Variable placeholders
                                var pamMinX = "PLACEHOLDER"                                                    ; min X position of the print area mesh
                                var pamMaxX = "PLACEHOLDER"                                                    ; max X position of the print area mesh
                                var pamMinY = "PLACEHOLDER"                                                    ; min Y position of the print area mesh
                                var pamMaxY = "PLACEHOLDER"                                                    ; max Y position of the print area mesh
                                var meshX = "PLACEHOLDER"                                                      ; Number of points to probe in the X axis
                                var meshY = "PLACEHOLDER"                                                      ; Number of points to probe in the Y axis
                                  set var.pamMinX = param.A                                                    ; min X position of the print area mesh
                                  set var.pamMaxX = param.B                                                    ; max X position of the print area mesh
                                  set var.pamMinY = param.C                                                    ; min Y position of the print area mesh
                                  set var.pamMaxY = param.D                                                    ; max Y position of the print area mesh
                                  set var.meshX = param.E                                                      ; Number of points to probe in the X axis
                                  set var.meshY = param.F                                                      ; Number of points to probe in the Y axis
                                  ; *--DEBUGGING--*
                                  set var.msg = "Adaptive mesh min:max: X:" ^ var.pamMinX ^ ":" ^ var.pamMaxX ^ "; Y:" ^ var.pamMinY ^ ":" ^ var.pamMaxY ^ "; Probe points, X:" ^ var.meshX ^ " Y:" ^ var.meshY
                                  echo {var.msg}
                                  M557 X{var.pamMinX, var.pamMaxX} Y{var.pamMinY, var.pamMaxY} P{var.meshX, var.meshY}
                                ; Probing code
                                if exists(param.A)
                                else
                                ; Finish up
                                ; *--DEBUGGING--*
                                var msg1 = "PLACHOLDER"
                                set var.msg1 = "Default mesh min:max: X:" ^ var.m557MinX ^ ":" ^ var.m557MaxX ^ "; Y:" ^ var.m557MinY ^ ":" ^ var.m557MaxY ^ "; Probe points, X:" ^ var.m577meshX ^ " Y:" ^ var.m577meshY
                                echo {var.msg1}
                                ;Restore the default probing mesh
                                M557 X{var.m557MinX, var.m557MaxX} Y{var.m557MinY, var.m557MaxY} P{var.m577meshX, var.m577meshY}
                                ; Full currents
                                else
                                else
                                ; LED status
                                This is what console outputs, and given the echo i can't for the life of me understand what might be causing it to act up:
                                7.4.2023, 11:30:17	9 points probed, min error -0.014, max error 0.066, mean 0.016, deviation 0.026
                                                        Default mesh min:max: X:10.0:340.0; Y:10.0:340.0; Probe points, X:30.0 Y:30.0
                                                        Error: in file macro line 117 column 81: M557: expected non-negative integer value
                                7.4.2023, 11:29:57	Z probe trigger height set to -0.629 mm
                                7.4.2023, 11:29:53	Adaptive mesh min:max: X:248.186:287.586; Y:141.312:209.3; Probe points, X:3 Y:3
                                  T3P3Tony administrators @Exerqtor
                                  so translating from the values you echoed you are sending:
                                  M557 X{10.0,340.0} Y{10.0,340.0} P{30.0,30.0}
                                  Which is invalid because you cannot have non integer number of probe points (its also invalid because you can't have 900 probe points 30x30 = 900)
                                  the P values need to be integers not floats. so you can use the "floor" command to round down those floats to integers:
                                  M557 X{10.0,340.0} Y{10.0,340.0} P{floor(10.0),floor(10.0)}
                                  so
                                  M557 X{var.m557MinX, var.m557MaxX} Y{var.m557MinY, var.m557MaxY} P{floor(var.m577meshX), floor(var.m577meshY)}
                                  you still need to change your logic so you cannot exceed the maximum number of points. one option would be to use the "spacing" rather the number of points option, alternatively add a check and set to a maximum if the earlier calculations come up with too many points.
                                  Exerqtorundefined 1 Reply Last reply Reply Quote 1
                                  • Exerqtorundefined
                                    Exerqtor @T3P3Tony
                                    @T3P3Tony
                                    Aaah that's what I've been doing wrong the whole time! When i originally started writing this i wanted it to fetch the NUMBER of probe points not the spacing between them.
                                    This sould do the trick shouldn't it?:
                                    ; Calculate the default numbber of probe points
                                    var m577meshX = floor((var.m557MaxX - var.m557MinX / move.compensation.probeGrid.spacings[0]) + 1)))
                                    var m577meshY = floor((var.m557MaxY - var.m557MinY / move.compensation.probeGrid.spacings[1]) + 1)))
                                    Maybe I'm asking for too much, but wouldn't a node for number of probe points pr. axis be handy?
                                      @Exerqtor that looks about right - although you need to test to make sure.
                                      you can just use the spacing setting, rather than the number of points, in you M557 command, since those values come from the spacings reported in the OM.
                                      • Exerqtorundefined Exerqtor has marked this topic as solved
