    2 SD Cards - SBC - stop after pause.g 3.5beta2
    Beta Firmware
    2.4k
      I would suggest maybe starting fresh with a clean SD card and a fresh download of DuetPi. I would also stay on 3.4.5 until everything is working, and then only updating to a beta release if you want to test something or need a specific fix.
      IndeX4Dundefined 1 Reply Last reply Reply Quote 0
      • IndeX4Dundefined
        IndeX4D @Phaedrux
        @Phaedrux
        No, just sbc with card.
        Maybe
        But the system is booting from sd card 0.
        I also cant delete config.g from s cards jobs folder.
        • IndeX4Dundefined
          IndeX4D @Phaedrux
          @Phaedrux
          Sadly I have to use any of 3.5 versions cause of closed loop steppers. I have a double y axis and it was not sufficient to print before.
          Now, everything is fine. In standalone mode I dont have this problem, so for important jobs I could go back to standalone mode, but I want to use some plug ins etc I need raspberry for.
          I don´t have a fresh sd card here.. do you mean completly new?
          They´re all quite old and I have lot´s of failed flashs with balena. Is that normal?
          May I really start from beginning.
          Can I also use M122 P104 S20 with sbc?
          I had 0.1mb yesterday....
          I would like to go ahead with investigation, If start from beginning is not helpful. I think, if you could answer some question then, I would be happy.
            I would try doing a full format on one of the sandisk ultra SD cards using the SD card formatter tool. Then try imaging it again with etcher. Failed flashes are not normal, no.
            @IndeX4D said in 2 SD Cards - SBC - stop after pause.g 3.5beta2:
            I don't think so, but maybe.
            Ah, I understand. Even so, it would be good to see how it behaves in 3.4.5 before updating to the 3.5 beta.
            IndeX4Dundefined 2 Replies Last reply Reply Quote 0
            • IndeX4Dundefined
              IndeX4D @Phaedrux
              @Phaedrux OK I format the cards and I´ll try it again to flash.
              Should I take the newest duetpi version?
              I´ll try 3.4.5. in a few min.
              Edit: Also when Flash Failed, I have the problem with 2 Sd Cards and printer is running.
              thanks
              • IndeX4Dundefined
                IndeX4D @Phaedrux
                @Phaedrux
                After format, flash is failed. Also with the other sd cards. But I can start duet and print with same problems.
                It makes no sense to go ahead with testing when flashing failed, right?
                  what is the error when the flash fails?
                  • IndeX4Dundefined
                    IndeX4D @Phaedrux
                    This post is deleted!
                    • IndeX4Dundefined
                      IndeX4D @Phaedrux
                      Strange that I can still print with failed flashing, but my problem occured with a succesful flash.
                      Can you say what kind of error it is?
                        I don't know. But it looks like it failed on verify near the end with a strange error. Maybe try re-installing etcher with a fresh download. Or try a different SD card flasher.
                        Did you do a full format of the SD card? That's a good way to force it to remap any bad sectors and make sure it's entirely writable.
                        As for what is happening with the second SD card showing, perhaps @chrishamm knows.
                        • IndeX4Dundefined
                          IndeX4D @Phaedrux
                          @Phaedrux
                          Strangely flashing is failed earlier. Feels like the sd cards are more crazy with every step.
                          I'll buy new sd card, flash from different computer and use different raspberry.
                          I'll tell my experience later.
                          • chrishammundefined
                            chrishamm administrators @IndeX4D
                            @IndeX4D In SBC mode do NOT touch any files on the second SD card partition (which is /boot on the SBC system or the first FAT partition). This partition contains boot files for the SBC Linux system and several files for standalone mode, so if you delete arbitrary files from there, your SBC will not start any more.
                            You can use the Raspberry Pi Imager if the other flash tools fail - just make sure you don't have read-only protection set on your SD adapter. M122 P104 is not supported in SBC mode, there are other Linux utilities for the same purpose.
                            Duet software engineer
                            • IndeX4Dundefined
                              IndeX4D @chrishamm
                              @chrishamm thanks for your answer
                              I´ll try everything again with completly new setup in a few minutes,
                              • IndeX4Dundefined
                                IndeX4D
                                Is it ok to run sbc with ethernet not only temporary?
                                  What do you mean?
                                  • IndeX4Dundefined
                                    IndeX4D @Phaedrux
                                    @Phaedrux
                                    Boot was successful. Can't connect WiFi.
                                    But I could use ethernet cable to connect with my router? Is this also fine?
                                    Connected to WIFI!
                                    New SD Card works fine.
                                    SO, only to be sure. Now, I see DWC and have a terminal open to update. Should I upload my sy files in sys folder first, or should I update first?
                                    thanks
                                      You can use wifi or ethernet on the SBC. That's up to you.
                                      You can update the pi first and then upload your config files later through DWC.
                                      • IndeX4Dundefined
                                        IndeX4D @Phaedrux
                                        @Phaedrux
                                        So I don´t know whats wrong. Everything was working fine, but same problem happens. Press pause --> stuck
                                        Interesting. First press pause was working fine with m226 in line in pause.g. But after resuming, it was printing slow till next zhop. then I executed pause again --> Stuck
                                        I changed
                                        Computer to flash
                                        NEW Sd card
                                        Other raspberry
                                        Software versions from 3.4.6 to 3.5 beta3.
                                        The last thing I do is to try it with a also complete new set up for another printer.
                                          Please post your pause.g and resume.g files
                                          • IndeX4Dundefined
                                            IndeX4D @Phaedrux
                                            @Phaedrux
                                            resume.g
                                            G1 R1 X0 Y0 Z5
                                            G1 E0.2 F3600  ; retract 10mm of filament
                                            G1 R1 X0 Y0 Z0
                                            pause.g
                                            ; pause.g
                                            ; called when a print from SD card is paused
                                            ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Aug 02 2021 16:15:35 GMT+0200 (Mitteleuropäische Sommerzeit
                                            M83            ; relative extruder moves
                                            G1 E-0.2 F3600  ; retract 10mm of filament
                                            G91            ; relative positioning
                                            G1 Z5 F360     ; lift Z by 5mm
                                            G90            ; absolute positioning
                                            G1 X200 Y200 F6000 ; go to X=0 Y=0
