Problem with all axis/motors (D3Mini+extension board)
@Phaedrux
I tried that at very begining. Even before writing here.I ran many tests tonight.
I unplugged everything from the board and plugged it in one by one - I didn't notice that anything had an effect.
I see that the motors sometimes respond. Sometimes. They don't move in the correct way - for example, they just whirl. But a piece move by jumping.
I could not find the correlation. I unplugged and tried to check each one individually - on each it happens - either it does not work at all or works completely incorrectly.Occasionally, from time to time, there is a message about a driver short circuit. But not every time. Happens with different drives.
@Maciek please can you try and take a clearer picture of U9:
Its the best I can get with my phone.
For me it looks normal. -
This post is deleted! -
@Maciek yep that looks normal
Ok I know at least it's a D3m board issue. I borrowed duet mini from a friend. I plugged everything in and powered it up - it works as it should :/.
So for sure something with the board -
Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
Are you using the same mini2 board with the new mini5+?
Yes its same board.
Are there any measurement points on the board where I can check if everything is OK?
@domzduzt I think you should start a new thread and give some more information.
