    2 SD Cards - SBC - stop after pause.g 3.5beta2
    Beta Firmware
    2.4k
    • IndeX4Dundefined
      IndeX4D @Phaedrux
      @Phaedrux ah I did not check the pi then.. I´ll do it
      Should I do increase log level before?
        It would be good to increase the log level and then provoke the error.
        IndeX4Dundefined 3 Replies Last reply Reply Quote 0
        • IndeX4Dundefined
          IndeX4D @Phaedrux
          This post is deleted!
          • IndeX4Dundefined
            IndeX4D @Phaedrux
            @Phaedrux
            Can you please a small advice how I can open DCS to increase the log level?
            Thanks
            • IndeX4Dundefined
              IndeX4D
              • IndeX4Dundefined
                IndeX4D @Phaedrux
                • IndeX4Dundefined
                  IndeX4D
                  Printer is stucked every pause.
                  and gives the last info see picture
                  Pi still lives.
                  It´s doing this when get stucked.
                  • IndeX4Dundefined
                    IndeX4D
                    is that a normal output?
                      I'm not sure. With using closed loop and beta firmware, we will need to wait and see what @dc42 and @chrishamm have to say.
                      • chrishammundefined
                        chrishamm administrators @IndeX4D
                        @IndeX4D Please upgrade to 3.5.0-beta.3, send M122 using the G-code console after it gets stuck, and post the output here. That little excerpt from the debug log isn't really useful, I'll need the full log in case the problem persists with 3.5.0-beta.3 and M122 doesn't show anything significant.
                        Duet software engineer
                        IndeX4Dundefined 1 Reply Last reply Reply Quote 0
                        • IndeX4Dundefined
                          IndeX4D @chrishamm
                          @chrishamm already is 3.5 beta3 and same behaviour.
                          How can I give you the full log?
                          Edit:
                          When I print with an older dwc version then 3.5 beta1, I don´t have this problem.
                          • IndeX4Dundefined
                            IndeX4D
                            tell me when you find your bugs.
                            I won´t investigate anymore.
                            Sadly...... when I have more time, I would like to help you more, but can't let my printers standing still for such a long time.
                            thanks
                              Phaedrux Moderator @IndeX4D
                              @IndeX4D said in 2 SD Cards - SBC - stop after pause.g 3.5beta2:
                              Thanks. That's useful to know.
                              • IndeX4Dundefined
                                IndeX4D @Phaedrux
                                @Phaedrux
                                I think I have the solution.
                                I had a resurect.g folder in my system fiels. I deleted it and now it´s fine. Is that a normal behaviour?
                                Noe, I see the problem after resume.g.
                                Is there any solution for it?
                                  @IndeX4D Is it DWC (web UI) that hangs or the printer itself, i.e. does refreshing the web page fix it?
                                  If it is DWC, please have a look at the JS Console after pressing F12 in DWC once it's frozen and check for potential errors. If there are any errors, please share them here via copy&paste.
                                  If it is not DWC, please share a full DCS log - all your uploaded logs are incomplete. To obtain that, do the following once the problem has occurred again:
                                  1. Connect via PuTTY over SSH to your machine
                                  2. Run journalctl -u duetcontrolserver --no-pager --since today
                                  3. Right-click on the PuTTY window bar and click "Copy All to Clipboard"
                                  4. Open Notepad and paste the contents into it
                                  5. Save the file and upload it here
                                  I am still unable to reproduce it myself here.
                                  PS: Don't forget to change back the log level from debug to info when you're done.
                                  IndeX4Dundefined 4 Replies Last reply Reply Quote 0
                                  • IndeX4Dundefined
                                    IndeX4D @chrishamm
                                    @chrishamm
                                    ´´it´´? means the freezing/stuck when press pause button or the slow down after resume? what you wanna reproduce yourself?
                                    because I can work with the slow down for a while.
                                    Crazy behaviour also: When resuming, sometimes the printer abbreviate some corners. Never seen it before. That´s also better then stucked and dead.
                                    Do I have to delet resurect.g when printing new print or not?
                                    I just wanna know, if it was my fault.....
                                    DWC is showing actual temperatures, but I can´t make anything. No fans etc
                                    Seems it´s wait for something.
                                    but Pi is still working.
                                    • IndeX4Dundefined
                                      IndeX4D @chrishamm
                                      • IndeX4Dundefined
                                        IndeX4D @chrishamm
                                        • IndeX4Dundefined
                                          IndeX4D @chrishamm
                                          something like that is in dwc happen. Above is more, but quiet the same text. Do you need all?
                                          • IndeX4Dundefined
                                            IndeX4D @IndeX4D
                                            @IndeX4D
                                            EDIT:
                                            when I changed back to info mode, dwc was working again after ---> sudo systemctl restart duetcontrolserver.service
                                            • dwc is working normal when restart dcs
                                            • Temperatur is still working when dwc is stucked
                                            • When restart dcs, print has finished but everything else is fine.
                                            • sometimes it gets stucked, sometimes I can pause normal with following slow down after resume.g (which we already know as little bug).
                                            ---> sometimes upload rate for print files goes down from around 5 mb to 300kb or so. Is this normal? just one think I noticed
                                            Edit2: I´m not sure, if this is right, but duet always writes a new resurect.g file. I have the feeling, when I delete it before printing, the stuck occurs later and less often.
                                            ; File "0:/gcodes/sdfg.gcode" resume print after print paused at 2023-04-19 06:20
                                            G21
                                            M140 P0 S64.0
                                            G29 S1
                                            G92 X334.867 Y443.736 Z112.380 C21.000
                                            G60 S1
                                            G10 P0 S245 R242
                                            T0 P0
                                            M98 P"resurrect-prologue.g"
                                            M116
                                            M290 X0.000 Y0.000 Z-0.200 C0.000 R0
                                            T-1 P0
                                            T0 P6
                                            ; Workplace coordinates
                                            G10 L2 P1 X0.00 Y0.00 Z0.00 C0.00
                                            G10 L2 P2 X0.00 Y0.00 Z0.00 C0.00
                                            G10 L2 P3 X0.00 Y0.00 Z0.00 C0.00
                                            G10 L2 P4 X0.00 Y0.00 Z0.00 C0.00
                                            G10 L2 P5 X0.00 Y0.00 Z0.00 C0.00
                                            G10 L2 P6 X0.00 Y0.00 Z0.00 C0.00
                                            G10 L2 P7 X0.00 Y0.00 Z0.00 C0.00
                                            G10 L2 P8 X0.00 Y0.00 Z0.00 C0.00
                                            G10 L2 P9 X0.00 Y0.00 Z0.00 C0.00
                                            G54
                                            M106 S0.51
                                            M106 P0 S0.51
                                            M116
                                            G92 E0.00000
                                            M83
                                            G94
                                            M486 S0 A"pott1zsm.stl"
                                            M486 S0
                                            G17
                                            M23 "0:/gcodes/sdfg.gcode"
                                            M26 S33151653
                                            G0 F6000 Z135.680
                                            G0 F6000 X343.717 Y482.986 C21.000
                                            G0 F6000 Z133.680
                                            G1 F13500.0 P0
                                            G21
                                            M24
