    Unknown Board (probably some clone)
    22
    773
    • Dougal1957undefined
      Dougal1957 @o_lampe
      @o_lampe and a burnt socket for whatt looks to be Fan0
      droftartsundefined Dougal1957undefined 2 Replies Last reply Reply Quote 1
        droftarts administrators @Dougal1957
        @Dougal1957 jumper wire from 3V to R28 too.
          Dougal1957 @Dougal1957
          @Dougal1957 said in Unknown Board (probably some clone):
          think that may be what @o-lampe was referring to
          • oliofundefined
            oliof @o_lampe
            @o_lampe those driver boards seem to go sandwich on top of the main board, so it might be possible to blow air from left to right. It's not entirely clear though whether air can escape well enough with all the connectors on the board edges.
            • oliofundefined
              oliof @oliof
              the voltage select for VIN / 5V for the fan banks also seems bent.
              • dank0undefined
                dank0
                @oliof I am living in Shenzhen (I am not chinese), China and i saw this board in the used electronic store - it cost $10 CAD. So i was wondering if is somehow usable - I have two Vorons 2.4 and one Creality CR6-SE printer. I am planing to build one more printer so i was thinking to use this board with reprap to just see what it can do 😉
                oliofundefined 1 Reply Last reply Reply Quote 1
                • oliofundefined
                  oliof @dank0
                  @dank0 thats an amazing find. I would start powering it up via USB and then try to see what firmware is on there. There is a decent chance that it will run stock RepRapFirmware for the Duet2.
                  Exerqtorundefined 1 Reply Last reply Reply Quote 0
                  • Exerqtorundefined
                    Exerqtor @oliof
                    I found a couple clips of an identical board on bilibili, seems like the user that posted the clips is the one who made them given that one of the clips shows the board only partialy populated :
                    Clip1
                    Clip2
                    And this thing
                    elmoretundefined 1 Reply Last reply Reply Quote 0
                    • elmoretundefined
                      elmoret @Exerqtor
                      @Exerqtor Looks like it has a RAR - who dares to download it?
                      Phaedruxundefined Exerqtorundefined oliofundefined 3 Replies Last reply Reply Quote 0
                        Phaedrux Moderator @elmoret
                        @elmoret Look like you need an account to download.
                        • Exerqtorundefined
                          Exerqtor @elmoret
                          @elmoret said in Unknown Board (probably some clone):
                          Not me, that's for damned sure lmao.
                          • oliofundefined
                            oliof @elmoret
                            @elmoret I have a sacrificial chromebook for these things. Feel free to send me the file or the link, whatever you have at hand.
                            EDIT: Seems I cannot register with a non chinese number.
                            • dank0undefined
                              dank0
                              here is the file from the chinese website: DuetWIFI MB V1.1 Based On Duet3d 1.0.4
                              @Exerqtor thanks for the links
                              • dank0undefined
                                dank0
                                @oliof M115 returns:
                                FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.4.5 ELECTRONICS: Duet WiFi 1.0 or 1.01 + DueX5 FIRMWARE_DATE: 2022-11-30 19:36:12
                                • elmoretundefined
                                  elmoret @dank0
                                  @dank0 Kinda impressive that they seem to have honored the open source license, at least at first glance.
