    3.5 B3 Toolboard stepper intermittently running backwards
    Beta Firmware
    12
    83
    4.5k
    • ctilley79undefined
      ctilley79
      My extruder motor running on Toolboard 1.2 connected to Duet3 6HC occasionally runs backwards when manually extruding from the dashboard in DWC. Once the motor has switched, manually extruding by gcode also runs in reverse. This has happened twice since using 3.5 b3.
      The only thing that fixes it is inverting the motor in config.g. An Estop does not return the motor to its normal direction. When the problem reoccurs, I have to invert the motor direction once again.
      Exerqtorundefined 1 Reply Last reply Reply Quote 0
        ctilley79
        Ok. I think I've narrowed down the problem. Theres a speed threshold when the problem occurs. For Ex.
        G1 E100 F180 the motor runs forwards
        G1 E100 F300 the motor runs in reverse
        I can now consistently reproduce the problem. Parts of my original question can be ignored because I hadn't realized it was speed based. Sometimes I was manually extruding at 5mm/s and sometimes I was extruding at 3mm/s.
        gloomyandyundefined 1 Reply Last reply Reply Quote 1
        • gloomyandyundefined
          gloomyandy @ctilley79
          @ctilley79 Can you post your config.g file so that we can see steps/mm acceleration PA/IS etc.
          ctilley79undefined 1 Reply Last reply Reply Quote 1
          • Exerqtorundefined
            Exerqtor @ctilley79
            I've had some similar behaviour, mine just totally stops though.
            ctilley79undefined 2 Replies Last reply Reply Quote 0
              ctilley79 @gloomyandy
              @gloomyandy said in 3.5 B3 Toolboard stepper intermittently running backwards:
              Here ya go. I’m running in SBC mode btw
              ; generated by RepRapFirmware Configuration Tool v3.2.1 on Sat Jan 09 2021 15:21:32 GMT-0500 (Eastern Standard Time)
              G90
              M83
              M550 P"Voron2"
              M669 K1
              G4 S2
              M955 P121.0 I01
              M593 P"zvddd" F50.0 S0.1
              M569 P0.0 S1 D2
              M569 P0.1 S0 D2
              M569 P0.2 S1 D2
              M569 P0.3 S0 D2
              M569 P0.4 S1 D2
              M569 P0.5 S0 D2
              M569 P121.0 S1 D2
              M584 X0.1 Y0.0 Z0.2:0.3:0.4:0.5 E121.0
              M671 X-50:-50:350:350 Y0:375:375:0 S5
              M350 X16 Y16 Z16 E16 I1
              M92 X160.00 Y160.00 Z400.00 E562.00
              M566 X600.00 Y600.00 Z300.00 E4000.00
              M203 X16800.00 Y16800.00 Z750.00 E5000.00
              M201 X3000.00 Y3000.00 Z350.00 E5000.00
              M906 X1000 Y1000 E900 I40
              M906 Z1100 I80
              M84 S60
              M208 X0 Y-3 Z0 S1
              M208 X300 Y300 Z250 S0
              M574 X1 S3
              M574 Y1 S3
              M574 Z1 S2
              M915 X Y S1 F0 R0 H400
              M558 P8 C"121.^io_0.in" H1.8 F300 T16800 A5 S0.01					; Euclit Probe
              G31 P500 X2 Y25 Z7.72
              M557 X20:280 Y30:270 P5
              ; Bed Heater
              M308 S0 P"0.temp1" Y"thermistor" T100000 B4725 C7.06e-8
              M950 H0 C"0.out0" T0 Q10
              M307 H0 B0 S1.0
              M140 H0
              M143 H0 S155 T2
              ; Nozzle Heater
              M308 S1 P"121.temp0" Y"pt1000"
              M950 H1 C"121.out0" T1
              M307 H1 B0 S1.0
              M143 H1 S310
              ; Heater Pad Thermistor
              M308 S2 P"0.temp0" Y"thermistor" T100000 B3950 A"Heater Pad"
              M950 F0 C"121.out_1" Q10
              M106 P0 C"Part Fan" S0 H-1
              M950 F1 C"121.out_2" Q10
              M106 P1 C"Heatsink Fan " S1.0 X0.5 H1 T45
              ; Case Fans
              M950 F2 C"0.out7" Q10
              M106 P2 S0.4 C"Case Fan 1"
              M950 F3 C"0.out8" Q10
              M106 P3 S0.4 C"Case Fan 2"
              M950 F4 C"0.out9" Q10
              M106 P4 S0 C"Exhaust Fan"
              M950 F5 C"0.out5"
              M106 P5 S0.0 C"Bed Fan"
              M563 P0 S"Extruder" D0 H1 F0
              G10 P0 X0 Y0 Z0
              G10 P0 R0 S0
              ; Neopixels
              M150 X3 Q3000000
              M150 R255 U255 B128 W255 P128 S2 F1
              M150 R100 U0 B120 W0 P100 S1 F0
              ; Defining Global variables
              if !exists(global.hotend_temp)
              	global diveHeight = sensors.probes[0].diveHeight
              if !exists(global.bed_temp)
              	global bedtemp = heat.heaters[0].active
              	global hotendtemp = heat.heaters[1].active
              if !exists(global.zprobestatus)
              	global zprobestatus = "none"
              if !exists(global.job_completion)
              	global jobcompletion = 0
              ;M575 P1 S1 B57600
              M501
              T0
              I keep PA in my filament configs
              ;M307 H1 R2.683 K0.418:0.000 D5.84 E1.35 S1.00 B0 V23.8 ; This is for the RayPedo
              M307 H1 R2.695 K0.425:0.000 D6.05 E1.35 S1.00 B0 V23.7	; This is for the Mosquito
              M307 H0 R0.179 K0.105:0.000 D6.97 E1.35 S1.00 B0
              M207 S0.6 F2100 Z0
              M572 D0 S0.035
                ctilley79 @Exerqtor
                @Exerqtor I just read through your issue and yours may still be speed based since it seems to print certain features and not the others.
                  ctilley79 @Exerqtor
                  @Exerqtor The problem persists even with input shaping and pressure advance disabled.
                  gloomyandyundefined Exerqtorundefined 2 Replies Last reply Reply Quote 0
                    @ctilley79 Trying to understand what is happening. If you run at F180 the motor always goes one way (the correct way?), but if you try to go faster with F300 then does it always run the other way? If you then perform a slow move is it back to normal again?
                    ctilley79undefined 1 Reply Last reply Reply Quote 0
                      @gloomyandy
                      correct. I don't know the precise threshold, but past a certain speed the motor direction changes.
                         G1 E100 F180 ;motor runs forwards
                         G1 E100 F300 ;motor runs backwards
                         G1 E-300 F300 ;motor runs forwards again
                      gloomyandyundefined 1 Reply Last reply Reply Quote 0
                        @ctilley79 Does the distance make any difference? So for instance if you move just 10mm at F300 does it move in the correct direction?
                          This post is deleted!
                            Ok. The threshold is F254 which makes sense because thats the last integer in an 8 bit number. Extrusion distance does not matter.
                            oliofundefined 1 Reply Last reply Reply Quote 1
                            • oliofundefined
                              oliof @ctilley79
                              I cannot reproduce this on my Pico based toolboards. I am at 16x microstepping to and 631 microsteps.
                              • Exerqtorundefined
                                Exerqtor @ctilley79
                                @ctilley79 said in 3.5 B3 Toolboard stepper intermittently running backwards:
                                It might be the case, since i'm short on time atm. I had to revert back to beta2 this time. Hope David has time to crunch this when he gets back to the UK.
                                  ctilley79 @oliof
                                  @oliof is your pico toolboard running 3.5 beta 3? Does the pico even support RRF? I’m confused.
                                  • oliofundefined
                                    oliof @ctilley79
                                    @ctilley79 Yes, 3.5-beta.3 on the Duet3 Mini 5+, and 3.5-beta.3 on the RP2040 toolboard, which has experimental support in 3.5b-eta.
                                      ctilley79 @oliof
                                      @oliof SBC or Standalone?
                                      • oliofundefined
                                        oliof @ctilley79
                                        @ctilley79 standalone
                                        • oliofundefined
                                          oliof @oliof
                                          My test may have been invalid since I tested with F360; I sae a report that direction corrects itself again at F327 and higher. I am now traveling so wont be able to test before Sunday.
                                            ctilley79
                                            @argo I'm experiencing similar behavior here
                                            Argoundefined 1 Reply Last reply Reply Quote 0
