    2 different brushes for 4 printheads
    578
      dc42 administrators @Mike 1
      @MIke-1 the reason that doesn't work is that you need to put "active" in double quotes. But an easier way is to use state.currentTool as @OwenD suggests.
      Mike 1undefined 1 Reply Last reply Reply Quote 0
      • Mike 1undefined
        Mike 1 @OwenD
        @OwenD
        Oh, I can't use this version because my tools are alternating.
        OwenDundefined 1 Reply Last reply Reply Quote 0
        • Mike 1undefined
          Mike 1 @dc42
          Oh thanks! Now it is working fine!
          You are all awsome!
          • OwenDundefined
            OwenD @Mike 1
            @MIke-1 said in 2 different brushes for 4 printheads:
            @OwenD
            Apologies
            I missed that
            • Mike 1undefined
              Mike 1 @OwenD
              @OwenD
              Thanks anyway!
              • OwenDundefined
                OwenD @Mike 1
                @MIke-1
                My clumsy effort was mainly to prompt you to try to condense your code if possible.
                Whilst manually creating an if / elif for every tool works, it's often more efficient in code and easier to read if you look for a pattern that will work regardless of the number of tools (or heaters or whatever).
                In your case, one pattern is whether the tool selected is an odd or even number.
                We can check that using mod()
                What I should have posted was something like this.
                if state.currentTool != -1 ; check if a tool selected
                  if mod(state.currentTool,2) = 0 ; tool must be even number or zero
                    M98 P"brush_right.g"
                  else
                    M98 P"brush_left.g" ; must be odd numbered tool
                else
                  echo "no tool selected"
                You do however have to ensure that there is indeed a tool selected, otherwise state.currentTool is -1 and it would resolve to false and run the brush left macro
                mod(-1,2)=0 is false
                Whereas in your code, you don't have a condition for -1, so that wouldn't occur.
                If the code works, it's not wrong and it terms of lines of code there's not much difference in this case, so there's no reason for you to change what you have now.
                Mike 1undefined 2 Replies Last reply Reply Quote 1
                • Mike 1undefined
                  Mike 1 @OwenD
                  @OwenD
                  Sorry for the late reply, I did not expect an answer.
                  But your code hepled me to better understand how the coding here works 🙂
                  I used the first line to make homing more save, as I can only do homing without a tool attached to the printheard.
                  I will keep my code because it ist more simpple to read and allows me to select a 3rd or 4th macro with different bush settings. It might get interesting, if I will use a vulacono hotened in the future.
                  Thanx!
                  • Mike 1undefined
                    Mike 1 @OwenD
                    @OwenD said in 2 different brushes for 4 printheads:
                    else
                    else
                    Can I use 2 commands after an if? How do I know when the if ends? I am missing () or endif to understand when something ends 🙂
                    gloomyandyundefined 1 Reply Last reply Reply Quote 0
                    • gloomyandyundefined
                      gloomyandy @Mike 1
                      @MIke-1 The meta commands in RRF use indentation to indicate which statements are part of the body for conditional statements so for instance
                          G28 X
                          G28 Y
                      Makes both home commands conditional but in
                          G28 X
                      G28 Y
                      only the G28 X is conditional
                      See: https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands#conditional-construct
                      • Mike 1undefined
                        Mike 1 @gloomyandy
                        @gloomyandy
                        Thanx!
                        Topic can be closed 🙂
                        • Phaedruxundefined Phaedrux has marked this topic as solved
