    Help with hotend not showing in DWC
    Duet Web Control
    494
    • frnknstn518undefined
      frnknstn518
      code_text
      ```; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.16 on Sat May 13 2023 19:27:15 GMT-0400 (Eastern Daylight Time)
      M575 P1 S1 B57600                            ; enable support for PanelDue
      G90                                          ; send absolute coordinates...
      M83                                          ; ...but relative extruder moves
      M550 P"Duet 3"                               ; set printer name
      M669 K1                                      ; select CoreXY mode
      , | 2 | 3 |
      , | 1 | 4 |
      ,   FRONT
      M569 P1.0 S0                                 ; physical drive 1.1 goes forwards Y DRIVE
      M569 P1.1 S0                                 ; physical drive 1.0 goes forwards X DRIVE
      M569 P0.1 S0                                 ; physical drive 0.1 goes forwards FL Z DRIVE
      M569 P0.2 S1                                 ; physical drive 0.1 goes forwards RL Z DRIVE
      M569 P0.3 S0                                 ; physical drive 0.1 goes forwards RR Z DRIVE
      M569 P0.4 S1                                 ; physical drive 0.1 goes forwards RF Z DRIVE
      M569 P0.0 S0                                 ; physical drive 0.0 goes forwards EXTRUDER DRIVE
      M584 X1.1 Y1.0 Z0.1;0.2;0.3;0.4 E0.0                     ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                      ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E420.00            ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00          ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00      ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00          ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30                 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                      ; Set idle timeout
      M208 X25 Y25 Z30 S1                          ; set axis minima
      M208 X300 Y300 Z200 S0                       ; set axis maxima
      M574 X2 S3                                   ; configure sensorless endstop for high end on X
      M574 Y2 S3                                   ; configure sensorless endstop for high end on Y
      M574 Z1 S1 P"!121.io2.in"                    ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin !121.io2.in
      M558 P0 H5 F120 T6000                        ; disable Z probe but set dive height, probe speed and travel speed
      M557 X40:215 Y40:195 S20                     ; define mesh grid
      ; Bed Heater
      M308 S0 A"Bed Heater" P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" Q10 T0                           ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B1 S1.00                             ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                      ; map heated bed to heater 0
      M143 H0 S120                                 ; set temperature limit for heater 0 to 120C
      ; Hotend Heater
      M308 S1 P"121.temp0" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"121.out0" T1                       ; create nozzle heater output on 121.out0 and map it to sensor 1
      M307 H1 B0 S1.00                             ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                 ; set temperature limit for heater 1 to 280C
      M950 F0 C"121.out1" Q500                     ; create fan 0 on pin 121.out1 and set its frequency
      M106 P0 S0 H-1                               ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"121.out2" Q500                     ; create fan 1 on pin 121.out2 and set its frequency
      M106 P1 S1 H1 T45                            ; set fan 1 value. Thermostatic control is turned on
      ; M563 P0 S"HOTEND" D0 H1 F0                             ; define tool 0
      ; G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
      ; G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
      frnknstn518undefined 1 Reply Last reply Reply Quote 0
        frnknstn518 @frnknstn518
        @frnknstn518 I have been trying to get this correct but i think i am making it worse. Any help would be appreciated
        OwenDundefined 1 Reply Last reply Reply Quote 0
        • OwenDundefined
          OwenD @frnknstn518
          @frnknstn518
          Your tool definition section is commented out
            frnknstn518 @OwenD
            @OwenD ```
            code_text
            , | 2 | 3 |
            , | 1 | 4 |
            ,   FRONT
            M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
            M950 H0 C"out0" T0                           ; create bed heater output on out0 and map it to sensor 0
            M308 S1 P"temp1" Y"thermistor" T100000 B4725 ; configure sensor 1 as thermistor on pin temp1
            M950 H1 C"121.out0" T2                       ; create nozzle heater output on 121.out0 and map it to sensor 1
            M563 P0 D0 H1 F0                             ; define tool 0
            frnknstn518undefined OwenDundefined 2 Replies Last reply Reply Quote 0
              @frnknstn518 5/13/2023, 11:09:42 PM Error: in file macro line 77: G10: Invalid tool number
              5/13/2023, 11:09:42 PM Error: M563: bad drive number
              5/13/2023, 11:09:42 PM Error: in file macro line 76: G10: Invalid tool number
              these are what i get when uncommented
              • OwenDundefined
                OwenD @frnknstn518
                @frnknstn518
                Probably because you also have half of your M584 commented out
                  frnknstn518 @OwenD
                  @OwenD i fixed that now.
                    @frnknstn518 Warning: M950: Sensor number 2 has not been defined
                    This is the only warning now
                    • OwenDundefined
                      OwenD @frnknstn518
                      @frnknstn518 said in Help with hotend not showing in DWC:
                      You have created sensor 1 in M308 but tried to mp to sensor 2 in M950
                      Change it to
                      frnknstn518undefined 1 Reply Last reply Reply Quote 1
                        frnknstn518 @OwenD
                        @OwenD i changed it now its temp reading is -273.1
                          @frnknstn518 its also telling me sensor 1 is not defined
                            Can you post your full config.g as it is now?
                              frnknstn518 @Phaedrux
                              @Phaedrux no problem.
                              , | 2 | 3 |
                              , | 1 | 4 |
                              ,   FRONT
                              M569 P0.2 S1                                 ; physical drive 0.2 goes forwards RL Z DRIVE
                              M569 P0.3 S0                                 ; physical drive 0.3 goes forwards RR Z DRIVE
                              M569 P0.4 S1                                 ; physical drive 0.4 goes forwards RF Z DRIVE
                              M584 X1.1 Y1.0 Z0.1:0.2:0.3:0.4 E0.0                     ; set drive mapping
                              M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"BedTemp" ; configure sensor 0 as thermistor on pin temp0
                              M307 H0 B0 S1.00                             ; disable bang-bang mode for the bed heater and set PWM limit
                              M308 S1 P"temp1" Y"thermistor" T100000 B4725 A"NozzleTemp" ; configure sensor 1 as thermistor on pin temp1
                                @frnknstn518 I figured it out. Just not the -273 temp
                                , | 2 | 3 |
                                , | 1 | 4 |
                                ,   FRONT
                                M569 P0.1 S1                                 ; physical drive 0.1 goes forwards FL Z DRIVE
                                M569 P0.2 S0                                 ; physical drive 0.2 goes forwards RL Z DRIVE
                                M569 P0.3 S1                                 ; physical drive 0.3 goes forwards RR Z DRIVE
                                M569 P0.4 S0                                 ; physical drive 0.4 goes forwards RF Z DRIVE
                                M950 H0 C"out0" T0 Q10                          ; create bed heater output on out0 and map it to sensor 0
                                M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 A"NozzleTemp" ; configure sensor 1 as thermistor on pin temp1
                                • OwenDundefined
                                  OwenD @frnknstn518
                                  @frnknstn518
                                  Most likely a bad connection on the thermistor
                                  https://docs.duet3d.com/User_manual/Troubleshooting/FAQ
                                    frnknstn518 @OwenD
                                    @OwenD i checked wiring. i also put a new one in to see if that was it. It still says -273
                                      @frnknstn518 this is going to the out0 on the 1lc toolboard. is this correct?
                                        deckingman @frnknstn518
                                        @frnknstn518 That's the default value that DWC shows when a heater is "off". It should read ambient once you select a tool. You can do that automatically by adding "T0" to the end of your config.g file (without the quotes).
                                          frnknstn518
                                          @deckingman I feel like i dont have my heater settings correct.
                                          could someone look at this.
                                          M950 H0 C"out1" T0 Q10                          ; create bed heater output on out0 and map it to sensor 0
                                          I have bed heater on out1, the temp sensor on temp0
                                          the nozzle is on 1LC board 121 0ut0 and that temp sensor is on 121 temp0. just not sure what im missing
                                            @frnknstn518 ok so the bed heats up properly...just figuring out the nozzle heater
