    Delta bedlevelling
    Smart effector for delta printers
    855
    • tecnoundefined
      tecno @droftarts
      @droftarts
      1. M557 R240 S80 and it gives the result as seen in pictures
      droftartsundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @tecno
        @tecno Can you post your config.g? And M115 response.
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @droftarts
          @droftarts
          M115
          FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.4.5 ELECTRONICS: Duet 3 Mini5plus Ethernet FIRMWARE_DATE: 2022-11-30 19:41:16
          4f0dead3-6363-4140-b2fe-e93db7c36ceb-config.g
          1930649a-c3ad-4e83-8a70-1498e7f0b954-config-override.g
            @tecno said in Delta bedlevelling:
            Actually, it's the probe spacing S80 (ie 80mm) that is causing it to be square. It can't get into the edges with that value.
            • tecnoundefined
              tecno @droftarts
              @droftarts
              M557 R240 S30
                @tecno There definitely seems to be a lot of variation in the measurements. Your current probe setup is:
                M558 P8 R0.4 C"io3.in+io4.out" H50 F1200
                See M558 in the Gcode dictionary. I'd say reduce the probe feed speed (F) down to something slower (my delta probes at 120, but it isn't a smart effector) (see following post). You can always have a fast travel speed (T, which is missing from yours). Reduce the dive height (H) to speed up probing, doesn't need to lift 50mm each time. And you can probe multiple times (A) to improve accuracy based on tolerance (S). I'd try something like:
                M558 P8 R0.4 C"io3.in+io4.out" H10 F1200 T6000 A5
                Use that and see if you get a smoother mesh. It's difficult to tell what else is going on otherwise.
                  @tecno Sorry, the docs say to use F1200, so keep that for now. If the bed mesh doesn't improve with the other settings, try varying this speed, as it is possible the weight of the extruder makes a difference.
                  • tecnoundefined
                    tecno @droftarts
                    @droftarts
                    I can not run A in M558 errors out in
                    M140 P0 S0
                    Error: Z probe readings not consistent
                    Sensitivity is set like this after a lot of testing.
                    m672 s105:039:216
                    So I think that no extruder is working directly on the effector
                    • tecnoundefined
                      tecno @tecno
                      I have now tried to get the Smart Effector to work properly but no.
                      M672 is now set to 10:245 and still I do not get all points probed.
                      Only my Phaetus Dragon water cooled is mounted on the board.
                      So I want to get this board replaced.
                        dc42 administrators @tecno
                        @tecno when and where did you purchase it?
                        • tecnoundefined
                          tecno @dc42
                          Trying to PM you
                          WAC-UYIQAQU look tru all details!
                            Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
