    3.5 B3 Toolboard stepper intermittently running backwards
    Beta Firmware
    12
    83
    4.7k
    • Exerqtorundefined
      Exerqtor @gloomyandy
      @gloomyandy said in 3.5 B3 Toolboard stepper intermittently running backwards:
      @Exerqtor Which docs? I've just checked the source and there is no pin called either D0 or DO as far as I can tell. What pin are you trying to drive the neopixels from?
      The only pin that supports it on a Duet 3 Mini, which from what I can see lacks a proper explanation on what the "DO" pin is actually called. "ctrl+f" search for DO here and look at the 14th entry. Thats the only mention of it (that i'm able to find) in all the docs / schematics.
      It's also just called "DO" in the schematics:
        dc42 administrators @Exerqtor
        @Exerqtor the dedicated LED port is known as "led" in the firmware. This needs to be added to the documentation.
        Exerqtorundefined 1 Reply Last reply Reply Quote 1
        • Exerqtorundefined
          Exerqtor @dc42
          @dc42 Then i bet a beer on the problem being solved for both me and @ctilley79 now that we know that. Thx!
          ctilley79undefined 1 Reply Last reply Reply Quote 1
          • ctilley79undefined
            ctilley79 @wieman01
            This post is deleted!
              ctilley79 @Exerqtor
              @Exerqtor said in 3.5 B3 Toolboard stepper intermittently running backwards:
              Does the M150 P parameter to work for you on this firmware build? I'm also using RGBW neopixels. The P parameter does nothing right now.
              Exerqtorundefined dc42undefined 2 Replies Last reply Reply Quote 0
              • Exerqtorundefined
                Exerqtor @ctilley79
                @ctilley79 said in 3.5 B3 Toolboard stepper intermittently running backwards:
                I don't use the P parameter, only the R/G/B/W component "amount", it should yeld the same result although you would have to play around with the values to get the same effect.
                  dc42 administrators @ctilley79
                  @ctilley79 you are correct, the P parameter doesn't work for Neopixels. I will correct this before we release beta4.
                  hestiahuangundefined 1 Reply Last reply Reply Quote 2
                  • ctilley79undefined ctilley79 has marked this topic as solved
                  • hestiahuangundefined
                    hestiahuang @dc42
                    @dc42 said in 3.5 B3 Toolboard stepper intermittently running backwards:
                    May I know how to define M950 for Duet2Wifi? It can use M150 directly before, however it is failed and need definition first now. But not pin name found...
                    hestiahuangundefined 1 Reply Last reply Reply Quote 0
                      hestiahuang @hestiahuang
                      @hestiahuang said in 3.5 B3 Toolboard stepper intermittently running backwards:
                      Add the source code to confirm my finding.
                        so don't miss Duet2Wifi...
                          dc42 administrators @hestiahuang
                          @hestiahuang thanks, this is now fixed ready for 3.5beta4.
                          • Exerqtorundefined Exerqtor referenced this topic
