    3.5 B3 Toolboard stepper intermittently running backwards
    Beta Firmware
    12
    83
    4.7k
      dc42 administrators @Argo
      @Argo @tas thanks for the feedback! This gives us more confidence to release 3.5.0-beta.4.
      ctilley79undefined 1 Reply Last reply Reply Quote 0
      • ctilley79undefined
        ctilley79 @dc42
        @dc42 Worked for me too. Thank you.
          dc42 administrators @ctilley79
          @ctilley79 thanks.
          Exerqtorundefined 1 Reply Last reply Reply Quote 0
          • Exerqtorundefined
            Exerqtor @dc42
            Seems to be working here too!
            It's off-topic but happened after moving too b3+ so i'll drop it here and open another thread if it's more than a one line reply to fix it. Now I'm having some issues with the new neopixel assignement, it won't accept M950 E0 C"DO" T2 and returns:
            M950 E0 C"DO" T2
            Error: M950: Unknown pin name 'do'
            This is on the Duet 3 Mini.
              dc42 administrators @Exerqtor
              @Exerqtor the configuration of LED strips has changed for 3.5 beta4. See the new E parameter of the M950 command and the updated M150 description in the GCode dictionary.
              • Exerqtorundefined
                Exerqtor @dc42
                Yeah I allready have the GCode dictionary for M150 & M950 up trying to figgure out what i'm doing wrong.
                The reason i "had" to look into it now is that it threw Error: LED strip #0 has not been configured . And when i try to configure it it won't let me lol. (Or do i have to wait for b4 for it to work again?).
                  ctilley79 @Exerqtor
                  @Exerqtor said in 3.5 B3 Toolboard stepper intermittently running backwards:
                  If I'm reading the M950 G-code section correctly, some of those parameters aren't available until 3.5.0-beta.4. I'm just living with the error at the moment.
                  Exerqtorundefined dc42undefined 2 Replies Last reply Reply Quote 1
                  • Exerqtorundefined
                    Exerqtor @ctilley79
                    @ctilley79 said in 3.5 B3 Toolboard stepper intermittently running backwards:
                    Yeah that's how i'm interpreting it to, Same here even though it's flooding DWC & PD at the start / end of a print lmao.
                      @ctilley79 the new commands for configuring and controlling LED strips are implemented in the 3.5.0-beta.3+ binaries that I posted. They have been tested on Duet 3 Mini and 6HC.
                      @Exerqtor please post the M950 and M150 commands you used.
                      Exerqtorundefined 1 Reply Last reply Reply Quote 1
                      • wieman01undefined
                        wieman01
                        Hello, @ctilley79,
                        I generally have these issues when there is a problem with the wiring or the connectors. Manual extruding via DWC works fine, but then the motor needs higher currents, it move backwards because the wires only let through so much current.
                        I would check every wiring the in particular the soldering joints and connectors. This solves this particular problem for me every time.
                        wieman01
                        • Exerqtorundefined
                          Exerqtor @dc42
                          @dc42 said in 3.5 B3 Toolboard stepper intermittently running backwards:
                          That's weird, since i'm quiiiite sure i'm using the right command set (for a Duet3 Mini).
                          I TRY to send M950 E0 C"DO" T2, but i get the error mentioned above.
                          The M150's have been changed to this (for example):
                          M150 E0 R150 U150 B150 W150 S1 F1
                          M150 E0 R150 U150 B150 W150 S2 F0
                          gloomyandyundefined oliofundefined 2 Replies Last reply Reply Quote 0
                          • gloomyandyundefined
                            gloomyandy @Exerqtor
                            @Exerqtor Is "DO" a valid pin name on the mini? I had a quick look and couldn't find any pins with that name. Is this for the neopixels in a display attached via the exp headers?
                            • oliofundefined
                              oliof @Exerqtor
                              @Exerqtor Are you sure DO is right and not D0?
                              • Exerqtorundefined
                                Exerqtor @oliof
                                @oliof I copied it from the docs since I was unsure about the exact same thing 😆 So unless it's written wrong there as well it should be correct.
                                gloomyandyundefined 1 Reply Last reply Reply Quote 0
                                  @Exerqtor Which docs? I've just checked the source and there is no pin called either D0 or DO as far as I can tell. What pin are you trying to drive the neopixels from?
                                  • Exerqtorundefined
                                    Exerqtor @gloomyandy
                                    @gloomyandy said in 3.5 B3 Toolboard stepper intermittently running backwards:
                                    The only pin that supports it on a Duet 3 Mini, which from what I can see lacks a proper explanation on what the "DO" pin is actually called. "ctrl+f" search for DO here and look at the 14th entry. Thats the only mention of it (that i'm able to find) in all the docs / schematics.
                                    It's also just called "DO" in the schematics:
                                      @Exerqtor the dedicated LED port is known as "led" in the firmware. This needs to be added to the documentation.
                                      • Exerqtorundefined
                                        Exerqtor @dc42
                                        @dc42 Then i bet a beer on the problem being solved for both me and @ctilley79 now that we know that. Thx!
                                        ctilley79undefined 1 Reply Last reply Reply Quote 1
                                          ctilley79 @wieman01
                                          This post is deleted!
                                            ctilley79 @Exerqtor
                                            Does the M150 P parameter to work for you on this firmware build? I'm also using RGBW neopixels. The P parameter does nothing right now.
                                            Exerqtorundefined dc42undefined 2 Replies Last reply Reply Quote 0
