    3.5 B3 Toolboard stepper intermittently running backwards
    Beta Firmware
    12
    83
    4.7k
    • oliofundefined
      oliof @Exerqtor
      @Exerqtor Are you sure DO is right and not D0?
      Exerqtorundefined 1 Reply Last reply Reply Quote 0
      • Exerqtorundefined
        Exerqtor @oliof
        @oliof I copied it from the docs since I was unsure about the exact same thing 😆 So unless it's written wrong there as well it should be correct.
        gloomyandyundefined 1 Reply Last reply Reply Quote 0
        • gloomyandyundefined
          gloomyandy @Exerqtor
          @Exerqtor Which docs? I've just checked the source and there is no pin called either D0 or DO as far as I can tell. What pin are you trying to drive the neopixels from?
          • Exerqtorundefined
            Exerqtor @gloomyandy
            @gloomyandy said in 3.5 B3 Toolboard stepper intermittently running backwards:
            The only pin that supports it on a Duet 3 Mini, which from what I can see lacks a proper explanation on what the "DO" pin is actually called. "ctrl+f" search for DO here and look at the 14th entry. Thats the only mention of it (that i'm able to find) in all the docs / schematics.
            It's also just called "DO" in the schematics:
              dc42 administrators @Exerqtor
              @Exerqtor the dedicated LED port is known as "led" in the firmware. This needs to be added to the documentation.
              Exerqtorundefined 1 Reply Last reply Reply Quote 1
              • Exerqtorundefined
                Exerqtor @dc42
                @dc42 Then i bet a beer on the problem being solved for both me and @ctilley79 now that we know that. Thx!
                ctilley79undefined 1 Reply Last reply Reply Quote 1
                • ctilley79undefined
                  ctilley79 @wieman01
                  This post is deleted!
                    ctilley79 @Exerqtor
                    @Exerqtor said in 3.5 B3 Toolboard stepper intermittently running backwards:
                    Does the M150 P parameter to work for you on this firmware build? I'm also using RGBW neopixels. The P parameter does nothing right now.
                    Exerqtorundefined dc42undefined 2 Replies Last reply Reply Quote 0
                    • Exerqtorundefined
                      Exerqtor @ctilley79
                      @ctilley79 said in 3.5 B3 Toolboard stepper intermittently running backwards:
                      I don't use the P parameter, only the R/G/B/W component "amount", it should yeld the same result although you would have to play around with the values to get the same effect.
                        dc42 administrators @ctilley79
                        @ctilley79 you are correct, the P parameter doesn't work for Neopixels. I will correct this before we release beta4.
                        hestiahuangundefined 1 Reply Last reply Reply Quote 2
                        • ctilley79undefined ctilley79 has marked this topic as solved
                        • hestiahuangundefined
                          hestiahuang @dc42
                          @dc42 said in 3.5 B3 Toolboard stepper intermittently running backwards:
                          May I know how to define M950 for Duet2Wifi? It can use M150 directly before, however it is failed and need definition first now. But not pin name found...
                          hestiahuangundefined 1 Reply Last reply Reply Quote 0
                            hestiahuang @hestiahuang
                            @hestiahuang said in 3.5 B3 Toolboard stepper intermittently running backwards:
                            Add the source code to confirm my finding.
                              so don't miss Duet2Wifi...
                                dc42 administrators @hestiahuang
                                @hestiahuang thanks, this is now fixed ready for 3.5beta4.
                                • Exerqtorundefined Exerqtor referenced this topic
