    Duet2 Eth Klipper Firmware issues
    Firmware installation
    1.8k
      dc42 administrators @dtmcnamara
      @dtmcnamara it might be worth asking @Luke-sLaboratory if he has any ideas about this one.
      • oliofundefined
        oliof @droftarts
        @droftarts said in Duet2 Eth Klipper Firmware issues:
        I'm also not sure about using /dev/serial/by-id/ as the port.
        Thats normal under klipper because /dev/ttyACM* is not reliable to be stable across boots (USB enumeration can change with kernel and/or klipper formware updates), and you may have multiple boards (displays, toolboards, multiple control boards for larger numbers of drivers or additional IO). Configuring by id gives you a stable identifier.
          droftarts administrators @dtmcnamara
          @dtmcnamara Ah, yes, the binary is much smaller, so would flash faster. That makes sense. I still think using both the port name and the U parameter might cause conflicts. Did you try without the U parameter?
          @oliof Thanks for the info! Another Linux-command-line thing I didn't know about. Unfortunately it doesn't seem to have made it into macOS, where devices can't be connected to by id.
          • apakundefined
            apak @dtmcnamara
            @dtmcnamara need to use raspbian BUSTER (version 10)
            Raspbian bullseye (version 11) has a bug whan flashing klipper onto duet boards, and does a semibrick of the board.
            Lately it´s been said that flashing the LITE version of raspbian, and right after that using KIAUH you could flash it with both versions (buster and bullseye).
            I have a SD with buster that flashed successfully duet3 mini5 and duet2 wifi
            • oliofundefined
              oliof @apak
              @apak what does semibrick mean, and do you know how to recover?
              apakundefined 1 Reply Last reply Reply Quote 0
              • apakundefined
                apak @oliof
                @oliof when you flash klipper fw it doesn´t finish quite well, and board does not respond.
                Just reflash RRF again and it works fine.
                That´s a semibrick...board not working but you are able to recover it by regular procedure.
                oliofundefined 1 Reply Last reply Reply Quote 1
                • oliofundefined
                  oliof @apak
                  @apak is that captured in a bug on the klipper side? I worry that the conspiracy theorists talk about Duet3D "locking" the board.
                  apakundefined Luke'sLaboratoryundefined 2 Replies Last reply Reply Quote 0
                  • apakundefined
                    apak @oliof
                    @oliof nothing to do with klipper or duet, it´s a debian or bossa bug....
                    • Luke'sLaboratoryundefined
                      Luke'sLaboratory @oliof
                      @oliof its 100% a debian or bossa bug. Duet has been nothing but awesome in their quest for true open source.
                      Have you got it working? I've definitely run across that annoying bug 😞
                      Luke
                      http://lukeslab.online
                      • oliofundefined
                        oliof @Luke'sLaboratory
                        @Luke-sLaboratory I havent tried, I just like to be on the up and up (-:
                        • matthew 81undefined
                          matthew 81 @dtmcnamara
                          @dtmcnamara it took me several minutes to flash 100 pages or so on duet 2 upgrading the firmware,perhaps that is different
