    Reboots/resets randomly - RRF 3.5.0-b4
    Beta Firmware
    12
    112
    7.9k
    • Exerqtorundefined
      Exerqtor @dc42
      Todays first reset M122 😅
      M122
      RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-beta.3+ (2023-06-05 14:42:23) running on Duet 3 Mini5plus WiFi (standalone mode)
      Board ID: FAP55-Q967A-G65J0-401GL-0S02Z-RF9TL
      Used output buffers: 1 of 40 (30 max)
      Static ram: 101940
      Dynamic ram: 124180 of which 12 recycled
      Never used RAM 13068, free system stack 182 words
      Tasks: NETWORK(1,ready,167.8%,211) HEAT(3,nWait,0.2%,327) Move(4,nWait,0.0%,352) CanReceiv(6,nWait,0.4%,662) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.1%,351) TMC(4,nWait,11.1%,108) MAIN(1,running,113.9%,442) IDLE(0,ready,3.6%,29) AIN(4,delaying,7.5%,266), total 304.7%
      Owned mutexes: WiFi(NETWORK)
      Last reset 07:08:23 ago, cause: software
      Last software reset at 2023-06-05 23:36, reason: AssertionFailed, Platform spinning, available RAM 11636, slot 1
      Software reset code 0x4120 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x20011bec Task NETW Freestk 503 ok
      Stack: 00000139 000ace48 0002f52d 00000000 0002f8a9 00000000 00000000 00000000 20031d54 00000800 20035a48 2002c138 20018260 2002bfd5 20018260 2001e500 0002fa47 00000000 00000000 00000000 20011c48 00000014 00000000 00000002 d07a0050 640aa8c0 0800019e
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU revision 3, ADC conversions started 25703859, completed 25703859, timed out 0, errs 0
      MCU temperature: min 35.5, current 35.9, max 42.1
      Supply voltage: min 23.7, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/28, heap memory allocated/used/recyclable 2048/916/532, gc cycles 961
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 119, reads 42919, writes 13, timeouts 0, DMA errors 0, CC errors 0
      Driver 1: standstill, SG min 2, read errors 0, write errors 1, ifcnt 119, reads 42919, writes 13, timeouts 0, DMA errors 0, CC errors 0
      Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 199, reads 42919, writes 13, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 200, reads 42919, writes 13, timeouts 0, DMA errors 0, CC errors 0
      Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 198, reads 42920, writes 13, timeouts 0, DMA errors 0, CC errors 0
      Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 252, reads 42923, writes 10, timeouts 0, DMA errors 0, CC errors 0
      Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 252, reads 42922, writes 10, timeouts 0, DMA errors 0, CC errors 0
      Date/time: 2023-06-06 06:44:52
      Slowest loop: 20.42ms; fastest: 0.13ms
      === Storage ===
      Free file entries: 18
      SD card longest read time 4.3ms, write time 2.1ms, max retries 0
      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
      no step interrupt scheduled
      === DDARing 0 ===
      === DDARing 1 ===
      Heater 1 is on, I-accum = 0.0
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is doing "G4 S1        " in state(s) 0 0, running macro
      Aux2 is idle in state(s) 0
      File2 is idle in state(s) 0
      Queue2 is idle in state(s) 0
      Q0 segments left 0, axes/extruders owned 0x0000803
      Code queue 0 is empty
      Code queue 1 is empty
      === CAN ===
      Messages queued 231343, received 514122, lost 0, boc 0
      Longest wait 3ms for reply type 6053, peak Tx sync delay 274, free buffers 18 (min 17), ts 128520/128519/0
      Tx timeouts 0,0,0,0,0,0
      === Network ===
      Slowest loop: 20.40ms; fastest: 0.00ms
      Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 2 of 8
      = WiFi =
      Interface state: active
      Module is connected to access point
      Firmware version 2.1beta4
      MAC address bc:ff:4d:e6:b1:62
      Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 43000
      WiFi IP address 192.168.10.50
      Signal strength -53dBm, channel 1, mode 802.11n, reconnections 0
      Clock register 00002001
        dc42 administrators @Exerqtor
        @Exerqtor thanks, that's helped me to pin it down some more.
        When the machine is idle, is anything on the Duet running apart from the web server responding to DWC, for example something in daemon.g, or an FTP client?
        Exerqtorundefined 2 Replies Last reply Reply Quote 0
        • Exerqtorundefined
          Exerqtor @dc42
          @dc42 said in Extruder stops extruding (again) & reboots randomly - RRF 3.5b3+:
          Glad to hear!
          Hmm no it shouldn't be as far as i'm aware? I added a "stopper" for the neopixel commands getting hammered every time daemon.g was ran before newyears so that shouldn't do anything atlesst.
          I can post my current daemon.g later incase it's something there that might trigger the issue.
          EDIT:
          Just grabbed daemon.g from the printer (global.accel_control = false btw):
          ; /sys/daemon.g  v2.4
          ; Used to execute regular tasks, the firmware executes it and once the end of file is reached it waits. If the file is not found it waits and then looks for it again.
          ; THIS MACRO ONLY WORKS WITH RRF 3.5.0b1 AND LATER!!
          ; Loop, to be able to turn on/off daemon.g
          while global.RunDaemon
            ; Stuff goes here
            ; Resume after filament change
            if exists(global.FilamentCHG)
              if global.FilamentCHG = true && state.status="paused"
                M24        ; Resume the pause automatically now that the manual filament change is done
                set global.FilamentCHG = false
            ; Refresh chamber lights status
            if exists(global.chamber_leds)
              set global.chamber_leds = state.gpOut[0].pwm * 100
            ;Check sb_leds status
            ;if fileexists("/sys/lib/led/sb_leds-state.g")
              M98 P"/sys/lib/led/sb_leds-state.g"                                        ; Check if global.sb_leds has changed since last run/loop (comment out tho "turn off" neopixel controll)
            ; Print acceleration & input shaping control
            if global.accel_control
              ; Low accel on the whole first layer so that it gets good adhesion
              if global.layer_number = 1
                M204 P500        ; Set printing acceleration(mm/s²)
              ; Everything else
              else
                if global.line_type = "External perimeter"
                  if move.printingAcceleration != global.low_accel
                    M204 P{global.low_accel}                                             ; Set printing acceleration(mm/s²)
                  ;if move.shaping.type != global.input_shaper
                    ;M593 P{global.input_shaper}                                          ; Configure input shaping
                elif global.line_type = "Perimeter"
                  if move.printingAcceleration != 2000
                    M204 P2000                                                           ; Set printing acceleration(mm/s²)
                elif global.line_type = "Solid infill"
                  ;if move.shaping.type != "none"
                    ;M593 P"none"                                                         ; Configure input shaping
                elif global.line_type = "Top solid infill"
                ; When none of the above line extrusion types
                else
                  if move.printingAcceleration != global.def_print_accel
                    M204 P{global.def_print_accel}                                       ; Set printing acceleration(mm/s²)
                    ;M593 P"none"                                                         ; Disable input shaping
            ; Daemon loop delay
            G4 S1        ; Delay running again or next command for at least 1 second
          And for sake of good measure here is sb_leds-state.g as well:
          ; /sys/lib/led/sb_leds-state.g  v1.0
          ; Created by sb_leds.g to store the current/active LED colors
          ; Called by daemon.g to check if global.sb_leds status has changed since last run
          var sb_leds = "boot"
          if var.sb_leds = global.sb_leds
            ; Same status, do nothing
          else
            ; New status, change colors
            M98 P"/sys/lib/led/sb_leds.g"
          • Exerqtorundefined
            Exerqtor @dc42
            Just checked in on the debug log, and it's sure been a few resets today (while i'm at work and the house is empty):
            2023-06-06 06:44:52 [debug]  0
            power up + 00:00:03 [info] Event logging started at level debug
            power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-beta.3+ (2023-06-05 14:42:23)
            power up + 00:00:03 [debug] Done!
            power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running.
            power up + 00:00:04 [warn] WiFi module started
            power up + 00:00:07 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.50
            power up + 00:00:09 [warn] HTTP client 192.168.10.100 login succeeded (session key 0)
            2023-06-06 07:13:20 [warn] Date and time set at power up + 00:00:09
            power up + 00:00:08 [warn] HTTP client 192.168.10.100 login succeeded (session key 0)
            2023-06-06 09:20:26 [warn] Date and time set at power up + 00:00:08
            2023-06-06 10:58:17 [warn] Date and time set at power up + 00:00:08
            power up + 00:00:07 [warn] HTTP client 192.168.10.100 login succeeded (session key 0)
            2023-06-06 11:03:51 [warn] Date and time set at power up + 00:00:07
            2023-06-06 13:11:17 [warn] Date and time set at power up + 00:00:08
            The 06:44:52 entry is the last line of the M122 i posted early today btw.
              @Exerqtor thanks. Please post your complete config,g file and any macro files that it or daemon.g call. I'll run a similar system and see if I can reproduce the problem.
              Exerqtorundefined 1 Reply Last reply Reply Quote 0
              • Exerqtorundefined
                Exerqtor @dc42
                Yeah OFC! I'm pretty sure this should be everything.
                (Change filetype to ".rar")
                I posted sb_leds-state.g inside of the last reply if that's of any interest, as you see it don't do much unless global.sb_leds changes value (which it don't when idle) lol.
                EDIT:
                Just as a FYI, the machine haven't reset since 13:11:17 yesterday.
                Should i keep posting M122's when it eventualy resets or do you have as much info as you can for the time being?
                  @Exerqtor thanks, I've been running your configuration for nearly 3 hours now - hasn't reset yet.
                  I included a PanelDue in the setup because I saw that you had the line to enable it in config.g .
                  I also saw that you have enabled FTP. The comment says it is for remote backups. Do you have anything running on your PC that makes FTP requests when the printer is idle?
                  • Exerqtorundefined
                    Exerqtor @dc42
                    I haven't had any resets myself today either so I have no clue whats going on. And I have NOT changed anything just to be clear 😂
                    Yeah I have a 5" PD v3 connected.
                    I only use ftp manually with WinSCP for the times I need to extract something, it's not automated process for backups anywhere 😊
                    EDIT:
                    Still no more resets as of 6:40 in the morning of June 8th on my end 🤷‍♂️
                    • Exerqtorundefined
                      Exerqtor @dc42
                      And there it happened again, a new reset. This time it was in the home stretch of a 6h46min print 💩
                      I have since last time moved over to 3.5b4 on everything, so i'm changing the post title to reflect on that (with a note in the first post).
                      2023-06-10 15:02:08 [warn] Started printing file 0:/gcodes/job_file_0.16mm_ABS_0.4n_6h46m.gcode
                      2023-06-10 15:02:08 [debug] File 0:/gcodes/job_file_0.16mm_ABS_0.4n_6h46m.gcode selected for printing
                      2023-06-10 15:02:11 [info] M291: - [no title] - Print started, preheating.
                      2023-06-10 15:02:12 [info] G10 P0 S150 R150
                      2023-06-10 15:02:52 [info] G10 P0 S150.0
                      2023-06-10 15:02:53 [info] G10 P0 S150.0
                      2023-06-10 15:02:53 [info] M291: - [no title] - Pre-print mesh probing enabled, probing new bed mesh!
                      2023-06-10 15:02:53 [debug] Default grid: X10.0:340.0, Y10.0:340.0, Number of points: X12 Y12, 144 points
                      2023-06-10 15:02:53 [debug] Adaptive grid: X78.9777:271.022, Y108.141:158.156, Number of points: X7 Y3, 21 points
                      2023-06-10 15:02:58 [info] G10 P0 S150.0
                      2023-06-10 15:02:58 [debug] Z probe trigger height set to -1.434 mm
                      2023-06-10 15:02:58 [info] M291: - Mesh Probing - Probing now! Please wait...
                      2023-06-10 15:03:29 [info] G10 P0 S150.0
                      2023-06-10 15:03:29 [warn] 21 points probed, min error -0.041, max error 0.010, mean -0.012, deviation 0.013
                      Height map saved to file 0:/sys/heightmap.csv
                      2023-06-10 15:03:29 [debug] 21 points probed, min error -0.041, max error 0.010, mean -0.012, deviation 0.013
                      2023-06-10 15:03:29 [debug] Height map saved to file 0:/sys/adaptive_heightmap.csv
                      2023-06-10 15:03:35 [info] M291: - Mesh Probing - Done
                      2023-06-10 15:03:35 [info] G10 P0 S150.0
                      2023-06-10 15:03:36 [info] G10 P{global.initial_extruder} R{global.hotend_temp} S{global.hotend_temp}
                      2023-06-10 15:04:01 [info] M291: - [no title] - Purge location, X min: 53.9777; Y min: 98.141; Purge move speed: 4.802495; Prepurge speed: 4.158004
                      2023-06-10 15:04:12 [debug] ABS filament loaded & config applied
                      2023-06-10 18:28:09 [warn] HTTP client 192.168.10.226 login succeeded (session key 0)
                      power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-beta.4 (2023-06-08 23:40:14)
                      power up + 00:00:08 [warn] HTTP client 192.168.10.100 login succeeded (session key 767325465)
                      2023-06-10 19:08:45 [warn] Date and time set at power up + 00:00:08
                      2023-06-10 19:08:45 [warn] HTTP client 192.168.10.226 login succeeded (session key 0)
                      M122
                      RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-beta.4 (2023-06-08 23:40:14) running on Duet 3 Mini5plus WiFi (standalone mode)
                      Used output buffers: 4 of 40 (40 max)
                      Static ram: 102996
                      Dynamic ram: 125612 of which 12 recycled
                      Never used RAM 10580, free system stack 182 words
                      Tasks: NETWORK(1,ready,17.9%,215) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,672) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,351) TMC(4,nWait,1.2%,108) MAIN(1,running,79.6%,704) IDLE(0,ready,0.4%,29) AIN(4,delaying,0.8%,266), total 100.0%
                      Last reset 00:59:15 ago, cause: software
                      Last software reset at 2023-06-10 19:08, reason: HardFault bfarValid precise, Gcodes spinning, available RAM 2588, slot 2
                      Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00000803 BFAR 0x00000004 SP 0x20011fa8 Task NETW Freestk 482 ok
                      Stack: 0000019e 00000002 200014ec 0000019d 2003337a 0009d43d 0002fcde 810f0000 0002fcd5 00000000 00000000 00000000 200321ac 00000800 20035ea0 2002c558 20018670 2002c3f5 20018670 2001e920 0002fe6f 00000000 00000000 00000000 20012058 00000014 b5dd9f97
                      Error status: 0x04
                      Aux0 errors 0,0,0
                      MCU revision 3, ADC conversions started 3556399, completed 3556399, timed out 0, errs 0
                      MCU temperature: min 38.5, current 39.2, max 48.2
                      Supply voltage: min 23.5, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
                      Heap OK, handles allocated/used 99/32, heap memory allocated/used/recyclable 2048/1244/820, gc cycles 138
                      Driver 0: standstill, SG min 4, read errors 0, write errors 1, ifcnt 78, reads 61095, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 78, reads 61095, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 45, reads 61095, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 45, reads 61095, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 45, reads 61096, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 21, reads 61098, writes 10, timeouts 0, DMA errors 0, CC errors 0
                      Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 21, reads 61098, writes 10, timeouts 0, DMA errors 0, CC errors 0
                      Date/time: 2023-06-10 20:07:52
                      Slowest loop: 38.41ms; fastest: 0.14ms
                      === Storage ===
                      SD card longest read time 4.3ms, write time 3.9ms, max retries 0
                      === DDARing 0 ===
                      === DDARing 1 ===
                      === CAN ===
                      Messages queued 32011, received 71157, lost 0, boc 0
                      Longest wait 3ms for reply type 6023, peak Tx sync delay 271, free buffers 18 (min 17), ts 17780/17779/0
                      === Network ===
                      Slowest loop: 22.10ms; fastest: 0.00ms
                      HTTP sessions: 1 of 8
                      = WiFi =
                      Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42980
                      Signal strength -55dBm, channel 1, mode 802.11n, reconnections 0
                      M122 B121
                      Diagnostics for board 121:
                      Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-beta.4 (2023-06-08 16:22:30)
                      Bootloader ID: SAMC21 bootloader version 2.4 (2021-12-10)
                      All averaging filters OK
                      Never used RAM 708, free system stack 88 words
                      Tasks: Move(3,nWait,28.2%,111) HEAT(2,nWait,25.8%,57) CanAsync(5,nWait,0.0%,53) CanRecv(3,nWait,5.0%,75) CanClock(5,nWait,0.9%,66) ACCEL(3,nWait,0.0%,53) TMC(2,nWait,153.0%,57) MAIN(1,running,443.9%,336) IDLE(0,ready,0.0%,27) AIN(2,delaying,249.5%,142), total 906.2%
                      Last reset 09:44:30 ago, cause: power up
                      Last software reset data not available
                      Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 6, write errors 0, ifcnt 19, reads 6302, writes 19, timeouts 28, DMA errors 0, CC errors 0, failedOp 0x6a, steps req 0 done 40949660
                      Moves scheduled 513631, completed 513631, in progress 0, hiccups 9486, step errors 0, maxPrep 1375, maxOverdue 28990, maxInc 7907, mcErrs 0, gcmErrs 0, ebfmin -1.00, ebfmax 1.00
                      Peak sync jitter -5/11, peak Rx sync delay 345, resyncs 0/1, no timer interrupt scheduled
                      VIN voltage: min 23.4, current 24.3, max 24.6
                      MCU temperature: min 51.1C, current 55.1C, max 83.3C
                      Last sensors broadcast 0x00000012 found 2 40 ticks ago, 0 ordering errs, loop time 1
                      CAN messages queued 703196, send timeouts 0, received 834690, lost 0, free buffers 18, min 17, error reg 110000
                      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 533, adv 35645/74663
                      Accelerometer: LIS3DH, status: 00
                      I2C bus errors 0, naks 3, other errors 0
                      RogerPodacterundefined 1 Reply Last reply Reply Quote 0
                      • RogerPodacterundefined
                        RogerPodacter @Exerqtor
                        i'm getting nearly continuous reboots with the new Beta 4. the fans, pumps etc spin up upon each reset as an actual reboot.
                        gloomyandyundefined Exerqtorundefined dc42undefined 3 Replies Last reply Reply Quote 0
                        • gloomyandyundefined
                          gloomyandy @RogerPodacter
                          @RogerPodacter From your other post https://forum.duet3d.com/topic/32674/rrf-3-5-0-beta-4-broken-kinematics it looks like you were able to run some commands etc. after a reboot. What has changed since then, this might provide an indication as to what is causing the problem. If possible grabbing the output from M122 might also help. You could also try replacing your config.g file with a minimal version, that might allow you to boot the board and grab the m122 output.
                          • Exerqtorundefined
                            Exerqtor @RogerPodacter
                            @RogerPodacter
                            Yeah it's a full out reboot here to, the first time it happened i thought i had left something up against the main power switch of the printer that momenteraly switched it off and on again 🤣
                              dc42 administrators @RogerPodacter
                              @RogerPodacter as @gloomyandy says, please get a M122 report if you can. If you can't, then please revert to whichever firmware version you used before and then run M122.
                              @Exerqtor thanks for the new M122 report. It is resetting at the same point that it did under beta3. I haven't managed to pin down the problem yet, and I ran your configuration for a whole day without it resetting. Please try disabling FTP protocol to see if that makes a difference.
                              Exerqtorundefined RogerPodacterundefined 2 Replies Last reply Reply Quote 0
                              • Exerqtorundefined
                                Exerqtor @dc42
                                @dc42 said in Reboots/resets randomly - RRF 3.5.0-beta4:
                                Ok, FTP is disabled as of now. Let's see if that makes any difference 🤞
                                It ran without any resets almost 3 days before it shat the bed last time, so it's for sure intermittent.
                                Oh i just came to remember, have you included the extra checks you added in the last beta3 binaries you gave me on the "over the shelf" beta4? If their still of any value i mean.
                                  RogerPodacter @dc42
                                  @dc42 here is my M122 immediately after a reboot.
                                  /11/2023, 8:13:23 AM 	M122 B0
                                  Board ID: J6RFD-NR6KL-K65J0-409NN-LK02Z-7M5YU
                                  Used output buffers: 1 of 40 (40 max)
                                  Error in macro line 7 while starting up: in file macro line 7 column 13: M669: array too long, max length = 3
                                  Static ram: 102996
                                  Dynamic ram: 125476 of which 104 recycled
                                  Never used RAM 10624, free system stack 188 words
                                  Tasks: NETWORK(2,ready,47.7%,173) HEAT(3,nWait,0.1%,333) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.1%,658) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,351) TMC(4,delaying,1.1%,108) MAIN(2,running,38.0%,672) IDLE(0,ready,12.2%,29) AIN(4,delaying,0.8%,266), total 100.0%
                                  Owned mutexes: HTTP(MAIN)
                                  Last reset 00:05:35 ago, cause: software
                                  Last software reset at 2023-06-11 08:07, reason: HardFault imprec, Gcodes spinning, available RAM 10624, slot 2
                                  Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00000400 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x200120a0 Task NETW Freestk 544 ok
                                  Stack: 00000000 000af3d0 200014ec 2000dfe0 ffffffff 0009ded7 000120fe 210f0000 00012121 2000dfe0 00000000 000af350 00000083 e000e000 2001e920 a5a5a5a5 00012195 20036408 00000000 016c82f6 00031b41 00000000 2001a590 00000001 20036408 00000000 00033dc7
                                  Error status: 0x04
                                  Aux0 errors 0,0,0
                                  MCU revision 3, ADC conversions started 335765, completed 335765, timed out 0, errs 0
                                  MCU temperature: min 36.2, current 37.1, max 37.1
                                  Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                                  Heap OK, handles allocated/used 99/4, heap memory allocated/used/recyclable 2048/484/368, gc cycles 426
                                  Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 41, reads 5479, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 41, reads 5479, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 41, reads 5479, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 41, reads 5479, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 41, reads 5479, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 5: standstill, SG min 0, read errors 0, write errors 0, ifcnt 41, reads 5479, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 6: standstill, SG min 0, read errors 0, write errors 0, ifcnt 41, reads 5479, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                  Date/time: 2023-06-11 08:13:22
                                  Cache data hit count 553598465
                                  Slowest loop: 407.58ms; fastest: 0.19ms
                                  === Storage ===
                                  Free file entries: 19
                                  SD card longest read time 6.3ms, write time 0.0ms, max retries 0
                                  DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: mesh, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
                                  === DDARing 0 ===
                                  === DDARing 1 ===
                                  Bed heaters 0 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0
                                  HTTP is ready with "M122 B0" in state(s) 0
                                  Daemon is idle in state(s) 0 0, running macro
                                  Q0 segments left 0, axes/extruders owned 0x0000000
                                  === CAN ===
                                  Messages queued 543, received 3374, lost 0, boc 0
                                  Longest wait 0ms for reply type 0, peak Tx sync delay 6, free buffers 18 (min 18), ts 302/302/0
                                  === Network ===
                                  Slowest loop: 217.65ms; fastest: 0.06ms
                                  = WiFi =
                                  Module is providing access point
                                  Firmware version 2.1beta3
                                  MAC address ea:68:e7:e5:63:f4
                                  Module reset reason: Power up, Vcc 3.39, flash size 2097152, free heap 39484
                                  WiFi IP address 192.168.1.10
                                  Connected clients 1
                                  6/11/2023, 8:13:13 AM 	Error in start-up file macro line 7: in file macro line 7 column 13: M669: array too long, max length = 3
                                  6/11/2023, 8:13:11 AM 	Connection established
                                  6/11/2023, 8:13:05 AM 	Connection interrupted, attempting to reconnect...
                                  HTTP request timed out
                                  6/11/2023, 8:12:23 AM 	M122 B0
                                  Used output buffers: 24 of 40 (36 max)
                                  Static ram: 102996
                                  Tasks: NETWORK(2,nWait,16.7%,181) HEAT(3,nWait,0.1%,333) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.1%,658) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,351) TMC(4,delaying,1.2%,108) MAIN(1,running,78.1%,704) IDLE(0,ready,3.0%,29) AIN(4,delaying,0.8%,266), total 100.0%
                                  Owned mutexes: WiFi(NETWORK) HTTP(MAIN)
                                  Last reset 00:04:35 ago, cause: software
                                  Error status: 0x00
                                  Aux0 errors 0,0,0
                                  MCU revision 3, ADC conversions started 275495, completed 275495, timed out 0, errs 0
                                  MCU temperature: min 29.4, current 36.2, max 36.4
                                  Heap OK, handles allocated/used 99/4, heap memory allocated/used/recyclable 2048/1492/1376, gc cycles 384
                                  Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 41, reads 24999, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 41, reads 24998, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 41, reads 24998, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 41, reads 24998, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 41, reads 24998, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 41, reads 24998, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 41, reads 24998, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Date/time: 2023-06-11 08:12:22
                                  Cache data hit count 471457659
                                  Slowest loop: 304.77ms; fastest: 0.16ms
                                  === Storage ===
                                  === DDARing 0 ===
                                  === DDARing 1 ===
                                  === CAN ===
                                  Messages queued 2525, received 15490, lost 0, boc 0
                                  Longest wait 3ms for reply type 6053, peak Tx sync delay 7, free buffers 18 (min 17), ts 1377/1376/0
                                  === Network ===
                                  Slowest loop: 207.85ms; fastest: 0.00ms
                                  Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(2) HTTP(0) FTP(0) Telnet(0)
                                  = WiFi =
                                  Module reset reason: Power up, Vcc 3.39, flash size 2097152, free heap 36540
                                  Connected clients 1
                                  6/11/2023, 8:12:14 AM 	Error in start-up file macro line 7: in file macro line 7 column 13: M669: array too long, max length = 3
                                  6/11/2023, 8:12:13 AM 	Connection established
                                  6/11/2023, 8:07:54 AM 	Connection interrupted, attempting to reconnect...
                                  6/11/2023, 8:07:41 AM 	Error in start-up file macro line 7: in file macro line 7 column 13: M669: array too long, max length = 3
                                  6/11/2023, 8:07:39 AM 	Connection established
                                  6/11/2023, 8:07:21 AM 	Connection interrupted, attempting to reconnect...
                                  6/11/2023, 8:06:48 AM 	Error in start-up file macro line 7: in file macro line 7 column 13: M669: array too long, max length = 3
                                  6/11/2023, 8:06:46 AM 	Connection established
                                  6/10/2023, 2:15:03 PM 	Connection interrupted, attempting to reconnect...
                                  6/11/2023, 8:14:24 AM 	M122 B1
                                  Diagnostics for board 1:
                                  Duet EXP3HC rev 1.02 or later firmware version 3.5.0-beta.4 (2023-06-08 16:24:05)
                                  Bootloader ID: SAME5x bootloader version 2.4 (2021-12-10)
                                  Never used RAM 156280, free system stack 202 words
                                  Tasks: Move(3,nWait,0.0%,182) HEAT(2,nWait,0.0%,90) CanAsync(5,nWait,0.0%,67) CanRecv(3,nWait,0.0%,79) CanClock(5,nWait,0.0%,70) TMC(2,nWait,5.9%,103) MAIN(1,running,92.7%,405) IDLE(0,ready,0.0%,40) AIN(2,delaying,1.3%,265), total 100.0%
                                  Last reset 00:08:02 ago, cause: power up
                                  Driver 0: pos 0, 690.0 steps/mm, standstill, SG min 0, mspos 8, reads 44125, writes 32 timeouts 0, steps req 0 done 0
                                  Driver 1: pos 0, 690.0 steps/mm, standstill, SG min 0, mspos 8, reads 44126, writes 32 timeouts 0, steps req 0 done 0
                                  Driver 2: pos 0, 80.0 steps/mm, standstill, SG min 0, mspos 8, reads 44141, writes 17 timeouts 0, steps req 0 done 0
                                  Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00, ebfmax 0.00
                                  Peak sync jitter -8/9, peak Rx sync delay 182, resyncs 0/2, no timer interrupt scheduled
                                  VIN voltage: min 21.0, current 24.2, max 28.6
                                  V12 voltage: min 12.3, current 12.3, max 12.3
                                  MCU temperature: min 22.2C, current 29.9C, max 29.9C
                                  Last sensors broadcast 0x00003000 found 2 33 ticks ago, 0 ordering errs, loop time 0
                                  CAN messages queued 7784, send timeouts 0, received 8203, lost 0, free buffers 38, min 38, error reg 0
                                  dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
                                  6/11/2023, 8:15:26 AM 	M122 B20
                                  Diagnostics for board 20:
                                  Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
                                  Never used RAM 1504, free system stack 142 words
                                  Tasks: Move(3,nWait,0.0%,175) HEAT(2,nWait,0.3%,100) CanAsync(5,nWait,0.0%,54) CanRecv(3,nWait,0.0%,77) CanClock(5,nWait,0.0%,66) ACCEL(3,nWait,0.0%,53) TMC(2,delaying,3.0%,57) MAIN(1,running,91.7%,336) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.9%,142), total 100.0%
                                  Last reset 00:09:04 ago, cause: VDD brownout
                                  Driver 0: pos 0, 690.0 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 10157, writes 21, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0
                                  Peak sync jitter -3/8, peak Rx sync delay 215, resyncs 0/2, no timer interrupt scheduled
                                  VIN voltage: min 20.8, current 24.1, max 27.7
                                  MCU temperature: min 21.1C, current 27.6C, max 27.7C
                                  Last sensors broadcast 0x00000312 found 4 190 ticks ago, 0 ordering errs, loop time 0
                                  CAN messages queued 10952, send timeouts 0, received 9271, lost 0, free buffers 18, min 18, error reg 0
                                    @RogerPodacter please can you add the following command to config.g and reboot:
                                    M122 P500 S0
                                    That will provide more data in the M122 report after the next uncommanded reset.
                                    Also please upgrade to wifi firmware 2.1beta4 which is now the version in the RRF 3.5.0-beta.4 github release.
                                    Please post your config.g file, daemon.g (if you have one), config-override.g (if you have one), and any other macro files that those call.
                                    When this problem next occurs, please post a new M122 report.
                                      dc42 administrators @dc42
                                      @Exerqtor in reply to your question in the firmware announcement thread, you are already running wifi firmware 2.1beta4 according to your M122 reports - but please check that you haven't inadvertently downgraded to 2.1beta3.
                                      • Exerqtorundefined
                                        Exerqtor @dc42
                                        From the last M122 i posted exactly that seems to be the case, that i downgraded to 2.1b3 😅
                                          @Exerqtor I will run my test setup with your config and RRF3.5.0-beta.4 and wifi server 2.1beta4 to see if the problem occurs; but if @RogerPodacter responds with his configuration then I will switch to that, as it seems that the issue occurs much more frequently on his machine.
                                            RogerPodacter @dc42
                                            @dc42 here is my config.g. my reboots happened right after boot up but in certain homed states. it was combinations of homing individual axis vs a homeall which would crash and not complete successfully. and i was experimenting with adding K11 and removing K11 vs K1 from my M669. i dont recall which i was using at the time. they all rebooted, but some worse than others in terms of repeating over and over.
                                            M669 K11 X1:0:0:0 Y1:-1:0:-1 Z0:0:1:0 U0:0:0:1
                                            G90                                     ; send absolute coordinates...
                                            M83                                     ; ...but relative extruder moves
                                            M550 P"V-Core3"                         ; set printer name
                                            ;M669 K11 Y1:-1:0:-1                     ; Dual Markforged Kinematics  https://forum.duet3d.com/topic/7796/haq-xy/125  https://forum.duet3d.com/topic/21021/dual-markforged-kinematics?_=1672244913067
                                            ;M669 K1 X1:0:0:0 Y1:-1:0:-1 Z0:0:1:0 U0:0:0:1	; Matrix mapping for Axis - X:Y:Z:U
                                            M669 X1:0:0:0 Y1:-1:0:-1 Z0:0:1:0 U0:0:0:1	; Matrix mapping for Axis - X:Y:Z:U
                                            G21                                     ; Set Units to Millimeters
                                            M552 S2                   				; enable network, note P0.0.0.0 sets auto DHCP
                                            M553 P255.255.255.0						; set subnet mask
                                            M554 P192.168.1.20						; set gateway
                                            M586 P0 S1                              ; enable HTTP
                                            M586 P1 S0                              ; disable FTP
                                            M586 P2 S0                              ; disable Telnet
                                            G4 S2 									; wait for expansion boards to start
                                            M569 P0.0 S0 D2								; Left Z physical drive 0.0 goes forwards
                                            M569 P0.1 S0 D2								; Rear Z physical drive 0.1 goes forwards
                                            M569 P0.2 S0 D2								; Right Z physical drive 0.2 goes forwards
                                            M569 P0.3 S1 D2								; Right U toolhead drive 0.3 goes forwards
                                            M569 P0.4 S1 D2								; Left X toolhead drive 0.4 goes forwards
                                            M569 P0.5 S0 D2								; Left Y drive 0.5 goes forwards
                                            M569 P0.6 S1 D2								; Right Y drive 0.6 goes reverse
                                            M569 P20.0 S1 D2                            ; Extruder physical drive 20.0 goes forwards Toolboard 1LC
                                            M569 P21.0 S1 D2                            ; Extruder physical drive 21.0 goes forwards Toolboard 1LC
                                            M569 P1.0 S0 D2                            ; Extruder physical drive 1.0 goes forwards Expansion 3HC
                                            M569 P1.1 S0 D2                            ; Extruder physical drive 1.1 goes forwards Expansion 3HC
                                            M569 P1.2 S1 D2                            ; Extruder physical drive 1.2 goes forwards Expansion 3HC
                                            M584 Z0.0:0.1:0.2 Y0.5:0.6 X0.4 U0.3 E20.0:21.0:1.0:1.1        ; set drive mapping
                                            M350 U16 X16 Y16 Z16 E16:16:16:16 I1                 			; configure microstepping with interpolation
                                            M92 U80.0 X80.00 Y80.00 Z800.00 E690:690:690:690				; set steps per mm
                                            M906 U2000 X2000 Y2000 Z1800 E1000:1000:1000:1000 I30				; set motor currents (mA) and motor idle factor in per cent -- safe for Duet 3 mini 5+
                                            M84 S30                                 				; Set idle timeout
                                            ;M98 P"0:/sys/setspeeds.g"               				; Set speed and acceleration
                                            M566 U500.00 X500.00 Y500.00 Z60.00 E300:300:300:300 P1 ;E300:300 P1				;X1500.00 Y1500.00 Z6.00 E300 P1 ;E120.00 P1          ; set maximum instantaneous speed changes (mm/min)
                                            M203 U30000.00 X30000.00 Y30000.00 Z1000.00 E7200:7200:7200:7200 ;E7200:3600 			;E3600.00     ; set maximum speeds (mm/min)
                                            M201 U10000.00 X10000.00 Y10000.00 Z100.00 E10000:10000:10000:10000 ;E10000:3600 		;E3600.00        ; set accelerations (mm/s^2)
                                            M207 S0.6 F7200 Z0.2						; firmware retraction orbiter 2.0
                                            M208 X-70 U0 Y0 Z0 S1                               ; set axis minima
                                            M208 X300 U380 Y306 Z300 S0 ; X310                        ; set axis maxima
                                            ;M208 X-70:310 Y0:308 U0:308 Z0:300
                                            M574 X1 S1 P"20.io2.in"                           ; configure active high endstops Toolhead 1 X low end
                                            M574 U2 S1 P"21.io2.in"                           ; configure active high endstops Toolhead 2 U high end
                                            M574 Y2 S1 P"io2.in"                           ; configure active high endstops Y.  IO0 and IO1 also are UART, so do not put endstops on them, use them elsewhere to free up UART.
                                            M574 Z1 S2
                                            M671 X-71:155:381 Y-1.5:305:-1.5 S5       ; NEW WIDEBOI WITH EXTRUSION SUPPORT LEADSCREW POSITIONS define positions of Z leadscrews or bed levelling screws
                                            ;M671 X-4.5:155:304.5 Y-4.5:305:-4.5 S5       ; OLD NON-WIDEBOI EXTRUION SUPPORT LEADSCREW POSITIONS define positions of Z leadscrews or bed levelling screws
                                            ;M557 X30:280 Y20:300 P5                        ; define 5x5 mesh grid
                                            M557 X30:270 Y20:270 P5
                                            M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Keenevo 600W Bed"    ; configure sensor 0 as thermistor on pin temp0
                                            M950 H0 C"out0" T0 Q10												; Define Heater0 as the heated bed, bind to Sensor0
                                            M140 H0 P0															; Define Heated Bed
                                            M307 H0 R0.602 K0.401:0.000 D2.44 E1.35 S1.00 B0							; PID Tuning for Heater0, Heated Bed (100C)
                                            M143 H0 S140 T0 A0														; Set temperature limit for Heater0 to 120C
                                            M308 S1 P"20.temp0" Y"thermistor" T100000 B4725 C7.060000e-8 A"Slice Hotend 0"  ;Slice Engineering 300C thermistor, settings are online
                                            M950 H1 C"20.out0" T1 Q100													; Define Heater1 as Extruder0 heater, bind to Sensor1
                                            M307 H1 R2.808 K0.368:0.000 D4.56 E1.35 S1.00 B0 V23.8					; PID Tuning for Heater1, Extruder0 (240C)
                                            M143 H1 S325 T1 A0													; Set temperature limit for heater 1 to 285C
                                            M308 S2 P"temp1" Y"thermistor" T100000 B3950 C7.060000e-8 A"Chamber" ; configure sensor 2 as thermistor on pin temp1
                                            M950 H2 C"out1" T2 ;Q10												; create chamber heater output on out1 and map it to sensor 2
                                            M307 H2 R0.01 K0.200:0.000 D60 E1.35 S1.00 B1                              ; enable bang-bang mode for the chamber heater and set PWM limit
                                            M141 H2												; map chamber to heater 2
                                            M143 H2 S120 T2 A0									; set temperature limit for heater 2 to 60C
                                            M308 S3 P"21.temp0" Y"pt1000" A"Slice Hotend 1"  ;Slice Engineering RTD PT1000 450C, settings are online
                                            M950 H3 C"21.out0" T3 Q100													; Define Heater1 as Extruder0 heater, bind to Sensor1
                                            M307 H3 R2.808 K0.368:0.000 D4.56 E1.35 S1.00 B0 V23.8					; PID Tuning for Heater1, Extruder0 (240C)
                                            M143 H3 S425 T3 A0 ; S325														; Set temperature limit for heater 1 to 285C
                                            M308 S4 P"20.temp1" Y"thermistor" A"Cooling Block" T100000 B3950 C7.060000e-8 ; Define Sensor as Chamber temperature
                                            M308 S5 Y"drivers" A"4028 Power"    								; 4028 power using spare heater
                                            M308 S6 Y"mcu-temp" A"Mini 5+ MCU"											; Define Sensor3 as the integrated MCU temperature sensor
                                            M308 S7 Y"drivers" A"Mini 5+ TMC Drivers"									; Define Sensor4 as the TMC overheat sensor
                                            M308 S8 Y"mcu-temp" P"20.dummy" A"Toolboard0 MCU"
                                            M308 S9 Y"drivers" P"20.dummy" A"1LC0 Stepper"
                                            M308 S10 Y"mcu-temp" P"21.dummy" A"Toolboard1 MCU"
                                            M308 S11 Y"drivers" P"21.dummy" A"1LC1 Stepper"
                                            M308 S12 Y"mcu-temp" P"1.dummy" A"3HC MCU"
                                            M308 S13 Y"drivers" P"1.dummy" A"3HC TMC Drivers"
                                            M308 S14 P"temp2" Y"thermistor" T100000 B3950 C7.060000e-8 A"Orbiter Motor" ; configure sensor 9 as thermistor on pin temp2
                                            M308 S15 P"spi.cs1" Y"thermocouple-max31856" K"K" A"TC0 Chamber Heater"; define temperature sensor number 10 as a K Type thermocouple on the first port of a temperature daughter board plugged into the expansion board with CAN bus address 3.
                                            M308 S16 P"spi.cs2" Y"thermocouple-max31856" K"K" A"TC1 Chamber Fins"; define temperature sensor number11 as a T Type thermocouple on the first port of a temperature daughter board plugged into the expansion board with CAN bus address 3.
                                            ;M308 S17 P"21.temp1" Y"thermistor" T4500000 B5315 C3.219245e-9 A"BLUE MELLOW" 	; blue Mellow high temp thermistor (toolboard)https://duet3d.dozuki.com/Wiki/Connecting_thermistors_or_PT1000_temperature_sensors#Section_RepRapFirmware_3_x
                                            ;M308 S17 P"21.temp1" Y"pt1000" T500000 B4666 C1.117125e-7 A"WHITE MELLOW" 	; white Mellow high temp pt1000 (toolboard)https://duet3d.dozuki.com/Wiki/Connecting_thermistors_or_PT1000_temperature_sensors#Section_RepRapFirmware_3_x
                                            M950 H4 C"!out2" T2 Q10	;H2											; Define Heater2 as the 4028 fan power, bind to Sensor3
                                            M143 H4 P2 S200 A0														; Needed M143 to set max temp so the graph scaled correctly
                                            M950 F0 C"!20.out1+out1.tach" Q25000 ;Q500							; create fan 0 on pin out4 and set its frequency
                                            M106 P0 C"T0 Layer Fan" L0.0 X1.0 S0 H-1 B0.1							; set fan 0 name and value. Thermostatic control is turned off
                                            M950 F1 C"20.out2+out2.tach" Q500 								; Fan 1 uses out3, and using out3.tach as a tacho input
                                            M106 P1 C"T0 Hotend Fan" S0 H1 T45        						; For M106 the H is sensor # and NOT heater #.  set fan 1 name and value. Thermostatic control turned on for Hotend
                                            M950 F2 C"out5" Q500                   						; create fan 1 on pin out5 and set its frequency
                                            M106 P2 C"Mini 5+ Board Fan" S0 H5:6:7 T45        			; set fan 1 name and value. Thermostatic control turned on for Hotend
                                            M950 F3 C"!out3+out3.tach" Q25000 ; Q500                 ; Chamber Heater Fan Noctua NF-F12 Industrial
                                            M106 P3 C"Chamber Heater Fan" H15 T30 ; H15 S0.3  L0.3 X0.6 B0.1 T30:40       ; set fan 1 name and value. Thermostatic control turned on for Hotend.
                                            M950 F4 C"1.out3" Q500 ; ; out6 on old mini 5+                 				; create fan 4 for Water Cooling 12V Fan 4 on pin out4 and set its frequency
                                            M106 P4 C"Radiator Cooling Fan" S0 H4 T35       		; set fan 1 name and value. Thermostatic control turned on for liquid cooling hotend
                                            M950 F5 C"!out4+out4.tach" Q25000 ;Q500                   				; create fan 4 for Water Cooling 12V Fan 4 on pin out4 and set its frequency
                                            M106 P5 C"Liquid Cooling Pump" L0.0 X1.0 S0.5 H4 ;S0.0 T20        	; set fan 4 name and value. Thermostatic control turned on for liquid cooling hotend
                                            M950 F6 C"!21.out1+out1.tach" Q25000 ;Q500							; create fan 6 on pin out4 and set its frequency
                                            M106 P6 C"T1 Layer Fan" L0.0 X1.0 S0 H-1 B0.1							; set fan 6 name and value. Thermostatic control is turned off
                                            M950 F7 C"21.out2+out2.tach" Q500 				; Fan 7 uses out3, and using out3.tach as a tacho input
                                            M106 P7 C"T1 Hotend Fan" S0 H3 T45        ; set fan 7 name and value. Thermostatic control turned on for Hotend
                                            M950 F8 C"1.out6" Q500                   ; create fan 1 on pin out5 and set its frequency
                                            M106 P8 C"3HC Board Fan" S0 H12:13 T45        ; set fan 1 name and value. Thermostatic control turned on for Hotend
                                            M950 F9 C"!1.out4+out4.tach" Q25000 ;Q500	4028 filter fan						; create fan 0 on pin out4 and set its frequency
                                            M106 P9 C"Testing Chamber Fan" H-1 T30
                                            ; Tool 0 X Axis
                                            M563 P0 D0 H1 X0 F0 S"Mosquito Mag Liquid"           										; define tool 0
                                            G10 P0 X0 Y0 Z-0.54 ; Z-0.54	S210 R175						; set tool 0 axis offsets, set initial tool 0 active 60C and standby temperatures to 0C
                                            M568 P0 S210 R175
                                            ; Tool 1 U Axis
                                            M563 P1 D1 H3 X3 F6 S"Mosquito Mag Air"           										; define tool 0
                                            G10 P1 U0 X0 Y0 Z0 ; S210 R175	; L1					; set tool 1 axis offsets, set initial tool 1 active 60C and standby temperatures to 0C
                                            M568 P1 S210 R175
                                            ; Tool 2-- Toolhead 2 with ROME 1
                                            M563 P2 D1:2 H3 X3 F6 S"ROME 1"						; tool 2 uses both extruders and hot end heaters, maps X to both X and U, and uses both print cooling fans
                                            G10 P2 U-2.31 X0 Y0.24 Z0.00 ; Z0.04	S210 R175	; L1		; set tool 0 axis offsets, set initial tool 0 active 60C and standby temperatures to 0C
                                            M567 P2 E1:1										; set mix ratio 100% on both extruders for copy mode
                                            M568 P2 S210 R175
                                            ; Tool 3-- Toolhead 2 with ROME 2
                                            M563 P3 D1:3 H3 X3 F6 S"ROME 2"						; tool 2 uses both extruders and hot end heaters, maps X to both X and U, and uses both print cooling fans
                                            G10 P3 U-2.31 X0 Y0.24 Z0.00 ; Z0.04	S210 R175	; L1		; set tool 0 axis offsets, set initial tool 0 active 60C and standby temperatures to 0C
                                            M567 P3 E1:1										; set mix ratio 100% on both extruders for copy mode
                                            M568 P3 S210 R175
                                            ; Tool 4-- copy mode
                                            ;M563 P4 D0:1 H1:3 X0:3 F0:6 S"copy mode"           ; tool 2 uses both extruders and hot end heaters, maps X to both X and U, and uses both print cooling fans
                                            ;G10 P4 U-77.5 X77.5 Y0 S210 R175                              ; set tool offsets and temperatures for tool 2
                                            ;M567 P4 E1:1                                         ; set mix ratio 100% on both extruders for copy mode
                                            ; Tool 5-- mirror mode
                                            ;M563 P5 D0:1 H1:3 X0:3 F0:6 S"mirror mode"          ; tool for mirror mode
                                            ;G10 P5 U-77.5 X77.5 Y0 S210 R175                             ; tool offset for mirror mode (flipped X offset)
                                            ;M567 P5 E1:1                                         ; set mix ratio 100% on both extruders for mirror mode
                                            ; Z-Probe Euclid Probe
                                            ;M558 P5 C"20.io0.in" H5 F400 T5000       ; set Z probe type to unmodulated and the dive height + speeds
                                            M558 P8 C"^20.io0.in" H8 F400 T9000 A1 ; S0.01       ; set Z probe type to unmodulated and the dive height + speeds
                                            G31 P1000 X-28 Y-20 Z9.71 ; Z9.21   ; K0           ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed
                                            ;; BLTouch
                                            ; M950 S0 C"io7.out"                     ; Create a servo pin on io7
                                            ; M558 P9 C"io7.in" H5 F240 T10800 A5    ; set Z probe type to unmodulated and the dive height + speeds
                                            ; G31 P25 X-28.00 Y-13.00 Z0.78          ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed
                                            ;Accelerometer
                                            M955 P20.0 I14
                                            ;Input Shaper
                                            M593 P"zvdd" F31		; for 10k acceleration
                                            ;M593 P"mzv" F42.5		; for 15k acceleration
                                            ;Filament Sensor0
                                            ;M591 D0 P3 C"20.io1.in" S1
                                            ;M591 D0 L27 R10:190
                                            ;ROME Filament Sensor0
                                            ;M591 D2 P1 C"21.io0.in" S1
                                            ;M591 D2 L27 R10:190
                                            ;M574 U2 S1 P"21.io0.in"                           ; configure active high endstops Toolhead 2 ROME toolhead filament sensor
                                            ;M577 wait until endstop is triggered.  Does equivalent exist for a general IO sensor?
                                            M950 J0 C"^!21.io0.in"
                                            ;PanelDue 5i
                                            M575 P1 S1 B57600
                                            ;NeoPixels x3
                                            M150 X3 Q4000000 ;R128 U128 B128 P128 S2 F0
                                            M150 X3 R255 U255 B255 W255 P255 S2 F0      ; display led
                                            ; Custom settings
                                            G29 S1
                                            M572 D0:1:2:3 S0.045		; set Pressure Advance K-factor
                                            M501
                                            M376 H3
                                            ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                                            global daemonLoop = true
                                            ; init filament sensor error global variables
                                            if !exists(global.filamentTimestamp)
                                            	global filamentCounter = 0
                                            	global filamentTimestamp = state.Uptime
                                            ; init print time logging
                                            if !exists(global.runtime)
                                              M98 P"runtime.g"
                                            ; init LED variables
                                            if !exists(global.warmUp)
                                            	global warmUp = false
                                            ; Select default tool
                                            M404 N1.75															; Define filament diameter for print monitor
                                            T0
