    Reboots/resets randomly - RRF 3.5.0-b4
    Beta Firmware
    12
    112
    7.3k
    • Exerqtorundefined
      Exerqtor @dc42
      @dc42 said in Reboots/resets randomly - RRF 3.5.0-beta4:
      @Exerqtor thanks for the new M122 report. It is resetting at the same point that it did under beta3. I haven't managed to pin down the problem yet, and I ran your configuration for a whole day without it resetting. Please try disabling FTP protocol to see if that makes a difference.
      Ok, FTP is disabled as of now. Let's see if that makes any difference 🤞
      It ran without any resets almost 3 days before it shat the bed last time, so it's for sure intermittent.
      Oh i just came to remember, have you included the extra checks you added in the last beta3 binaries you gave me on the "over the shelf" beta4? If their still of any value i mean.
      • RogerPodacterundefined
        RogerPodacter @dc42
        @dc42 here is my M122 immediately after a reboot.
        /11/2023, 8:13:23 AM 	M122 B0
        RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-beta.4 (2023-06-08 23:40:14) running on Duet 3 Mini5plus WiFi (standalone mode)
        Board ID: J6RFD-NR6KL-K65J0-409NN-LK02Z-7M5YU
        Used output buffers: 1 of 40 (40 max)
        Error in macro line 7 while starting up: in file macro line 7 column 13: M669: array too long, max length = 3
        Static ram: 102996
        Dynamic ram: 125476 of which 104 recycled
        Never used RAM 10624, free system stack 188 words
        Tasks: NETWORK(2,ready,47.7%,173) HEAT(3,nWait,0.1%,333) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.1%,658) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,351) TMC(4,delaying,1.1%,108) MAIN(2,running,38.0%,672) IDLE(0,ready,12.2%,29) AIN(4,delaying,0.8%,266), total 100.0%
        Owned mutexes: HTTP(MAIN)
        Last reset 00:05:35 ago, cause: software
        Last software reset at 2023-06-11 08:07, reason: HardFault imprec, Gcodes spinning, available RAM 10624, slot 2
        Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00000400 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x200120a0 Task NETW Freestk 544 ok
        Stack: 00000000 000af3d0 200014ec 2000dfe0 ffffffff 0009ded7 000120fe 210f0000 00012121 2000dfe0 00000000 000af350 00000083 e000e000 2001e920 a5a5a5a5 00012195 20036408 00000000 016c82f6 00031b41 00000000 2001a590 00000001 20036408 00000000 00033dc7
        Error status: 0x04
        Aux0 errors 0,0,0
        MCU revision 3, ADC conversions started 335765, completed 335765, timed out 0, errs 0
        MCU temperature: min 36.2, current 37.1, max 37.1
        Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
        Heap OK, handles allocated/used 99/4, heap memory allocated/used/recyclable 2048/484/368, gc cycles 426
        Events: 0 queued, 0 completed
        Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 41, reads 5479, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 41, reads 5479, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 41, reads 5479, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 41, reads 5479, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 41, reads 5479, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Driver 5: standstill, SG min 0, read errors 0, write errors 0, ifcnt 41, reads 5479, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Driver 6: standstill, SG min 0, read errors 0, write errors 0, ifcnt 41, reads 5479, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Date/time: 2023-06-11 08:13:22
        Cache data hit count 553598465
        Slowest loop: 407.58ms; fastest: 0.19ms
        === Storage ===
        Free file entries: 19
        SD card longest read time 6.3ms, write time 0.0ms, max retries 0
        DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: mesh, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
        no step interrupt scheduled
        === DDARing 0 ===
        === DDARing 1 ===
        Bed heaters 0 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0
        HTTP is ready with "M122 B0" in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is idle in state(s) 0 0, running macro
        Aux2 is idle in state(s) 0
        File2 is idle in state(s) 0
        Queue2 is idle in state(s) 0
        Q0 segments left 0, axes/extruders owned 0x0000000
        Code queue 0 is empty
        Code queue 1 is empty
        === CAN ===
        Messages queued 543, received 3374, lost 0, boc 0
        Longest wait 0ms for reply type 0, peak Tx sync delay 6, free buffers 18 (min 18), ts 302/302/0
        Tx timeouts 0,0,0,0,0,0
        === Network ===
        Slowest loop: 217.65ms; fastest: 0.06ms
        Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
        HTTP sessions: 1 of 8
        = WiFi =
        Interface state: active
        Module is providing access point
        Firmware version 2.1beta3
        MAC address ea:68:e7:e5:63:f4
        Module reset reason: Power up, Vcc 3.39, flash size 2097152, free heap 39484
        WiFi IP address 192.168.1.10
        Connected clients 1
        Clock register 00002001
        6/11/2023, 8:13:13 AM 	Error in start-up file macro line 7: in file macro line 7 column 13: M669: array too long, max length = 3
        6/11/2023, 8:13:11 AM 	Connection established
        6/11/2023, 8:13:05 AM 	Connection interrupted, attempting to reconnect...
        HTTP request timed out
        6/11/2023, 8:12:23 AM 	M122 B0
        Used output buffers: 24 of 40 (36 max)
        Static ram: 102996
        Tasks: NETWORK(2,nWait,16.7%,181) HEAT(3,nWait,0.1%,333) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.1%,658) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,351) TMC(4,delaying,1.2%,108) MAIN(1,running,78.1%,704) IDLE(0,ready,3.0%,29) AIN(4,delaying,0.8%,266), total 100.0%
        Owned mutexes: WiFi(NETWORK) HTTP(MAIN)
        Last reset 00:04:35 ago, cause: software
        Error status: 0x00
        Aux0 errors 0,0,0
        MCU revision 3, ADC conversions started 275495, completed 275495, timed out 0, errs 0
        MCU temperature: min 29.4, current 36.2, max 36.4
        Heap OK, handles allocated/used 99/4, heap memory allocated/used/recyclable 2048/1492/1376, gc cycles 384
        Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 41, reads 24999, writes 13, timeouts 0, DMA errors 0, CC errors 0
        Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 41, reads 24998, writes 13, timeouts 0, DMA errors 0, CC errors 0
        Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 41, reads 24998, writes 13, timeouts 0, DMA errors 0, CC errors 0
        Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 41, reads 24998, writes 13, timeouts 0, DMA errors 0, CC errors 0
        Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 41, reads 24998, writes 13, timeouts 0, DMA errors 0, CC errors 0
        Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 41, reads 24998, writes 13, timeouts 0, DMA errors 0, CC errors 0
        Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 41, reads 24998, writes 13, timeouts 0, DMA errors 0, CC errors 0
        Date/time: 2023-06-11 08:12:22
        Cache data hit count 471457659
        Slowest loop: 304.77ms; fastest: 0.16ms
        === Storage ===
        === DDARing 0 ===
        === DDARing 1 ===
        === CAN ===
        Messages queued 2525, received 15490, lost 0, boc 0
        Longest wait 3ms for reply type 6053, peak Tx sync delay 7, free buffers 18 (min 17), ts 1377/1376/0
        === Network ===
        Slowest loop: 207.85ms; fastest: 0.00ms
        Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(2) HTTP(0) FTP(0) Telnet(0)
        = WiFi =
        Module reset reason: Power up, Vcc 3.39, flash size 2097152, free heap 36540
        Connected clients 1
        6/11/2023, 8:12:14 AM 	Error in start-up file macro line 7: in file macro line 7 column 13: M669: array too long, max length = 3
        6/11/2023, 8:12:13 AM 	Connection established
        6/11/2023, 8:07:54 AM 	Connection interrupted, attempting to reconnect...
        6/11/2023, 8:07:41 AM 	Error in start-up file macro line 7: in file macro line 7 column 13: M669: array too long, max length = 3
        6/11/2023, 8:07:39 AM 	Connection established
        6/11/2023, 8:07:21 AM 	Connection interrupted, attempting to reconnect...
        6/11/2023, 8:06:48 AM 	Error in start-up file macro line 7: in file macro line 7 column 13: M669: array too long, max length = 3
        6/11/2023, 8:06:46 AM 	Connection established
        6/10/2023, 2:15:03 PM 	Connection interrupted, attempting to reconnect...
        6/11/2023, 8:14:24 AM 	M122 B1
        Diagnostics for board 1:
        Duet EXP3HC rev 1.02 or later firmware version 3.5.0-beta.4 (2023-06-08 16:24:05)
        Bootloader ID: SAME5x bootloader version 2.4 (2021-12-10)
        All averaging filters OK
        Never used RAM 156280, free system stack 202 words
        Tasks: Move(3,nWait,0.0%,182) HEAT(2,nWait,0.0%,90) CanAsync(5,nWait,0.0%,67) CanRecv(3,nWait,0.0%,79) CanClock(5,nWait,0.0%,70) TMC(2,nWait,5.9%,103) MAIN(1,running,92.7%,405) IDLE(0,ready,0.0%,40) AIN(2,delaying,1.3%,265), total 100.0%
        Last reset 00:08:02 ago, cause: power up
        Last software reset data not available
        Driver 0: pos 0, 690.0 steps/mm, standstill, SG min 0, mspos 8, reads 44125, writes 32 timeouts 0, steps req 0 done 0
        Driver 1: pos 0, 690.0 steps/mm, standstill, SG min 0, mspos 8, reads 44126, writes 32 timeouts 0, steps req 0 done 0
        Driver 2: pos 0, 80.0 steps/mm, standstill, SG min 0, mspos 8, reads 44141, writes 17 timeouts 0, steps req 0 done 0
        Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00, ebfmax 0.00
        Peak sync jitter -8/9, peak Rx sync delay 182, resyncs 0/2, no timer interrupt scheduled
        VIN voltage: min 21.0, current 24.2, max 28.6
        V12 voltage: min 12.3, current 12.3, max 12.3
        MCU temperature: min 22.2C, current 29.9C, max 29.9C
        Last sensors broadcast 0x00003000 found 2 33 ticks ago, 0 ordering errs, loop time 0
        CAN messages queued 7784, send timeouts 0, received 8203, lost 0, free buffers 38, min 38, error reg 0
        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
        6/11/2023, 8:15:26 AM 	M122 B20
        Diagnostics for board 20:
        Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-beta.4 (2023-06-08 16:22:30)
        Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
        Never used RAM 1504, free system stack 142 words
        Tasks: Move(3,nWait,0.0%,175) HEAT(2,nWait,0.3%,100) CanAsync(5,nWait,0.0%,54) CanRecv(3,nWait,0.0%,77) CanClock(5,nWait,0.0%,66) ACCEL(3,nWait,0.0%,53) TMC(2,delaying,3.0%,57) MAIN(1,running,91.7%,336) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.9%,142), total 100.0%
        Last reset 00:09:04 ago, cause: VDD brownout
        Driver 0: pos 0, 690.0 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 10157, writes 21, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0
        Peak sync jitter -3/8, peak Rx sync delay 215, resyncs 0/2, no timer interrupt scheduled
        VIN voltage: min 20.8, current 24.1, max 27.7
        MCU temperature: min 21.1C, current 27.6C, max 27.7C
        Last sensors broadcast 0x00000312 found 4 190 ticks ago, 0 ordering errs, loop time 0
        CAN messages queued 10952, send timeouts 0, received 9271, lost 0, free buffers 18, min 18, error reg 0
        Accelerometer: LIS3DH, status: 00
        I2C bus errors 0, naks 3, other errors 0
          dc42 administrators @RogerPodacter
          @RogerPodacter please can you add the following command to config.g and reboot:
          M122 P500 S0
          That will provide more data in the M122 report after the next uncommanded reset.
          Also please upgrade to wifi firmware 2.1beta4 which is now the version in the RRF 3.5.0-beta.4 github release.
          Please post your config.g file, daemon.g (if you have one), config-override.g (if you have one), and any other macro files that those call.
          When this problem next occurs, please post a new M122 report.
            dc42 administrators @dc42
            @Exerqtor in reply to your question in the firmware announcement thread, you are already running wifi firmware 2.1beta4 according to your M122 reports - but please check that you haven't inadvertently downgraded to 2.1beta3.
            Exerqtorundefined 2 Replies Last reply Reply Quote 0
            • Exerqtorundefined
              Exerqtor @dc42
              From the last M122 i posted exactly that seems to be the case, that i downgraded to 2.1b3 😅
                dc42 administrators @Exerqtor
                @Exerqtor I will run my test setup with your config and RRF3.5.0-beta.4 and wifi server 2.1beta4 to see if the problem occurs; but if @RogerPodacter responds with his configuration then I will switch to that, as it seems that the issue occurs much more frequently on his machine.
                RogerPodacterundefined 1 Reply Last reply Reply Quote 0
                  RogerPodacter @dc42
                  @dc42 here is my config.g. my reboots happened right after boot up but in certain homed states. it was combinations of homing individual axis vs a homeall which would crash and not complete successfully. and i was experimenting with adding K11 and removing K11 vs K1 from my M669. i dont recall which i was using at the time. they all rebooted, but some worse than others in terms of repeating over and over.
                  M669 K11 X1:0:0:0 Y1:-1:0:-1 Z0:0:1:0 U0:0:0:1
                  G90                                     ; send absolute coordinates...
                  M83                                     ; ...but relative extruder moves
                  M550 P"V-Core3"                         ; set printer name
                  ;M669 K11 Y1:-1:0:-1                     ; Dual Markforged Kinematics  https://forum.duet3d.com/topic/7796/haq-xy/125  https://forum.duet3d.com/topic/21021/dual-markforged-kinematics?_=1672244913067
                  ;M669 K1 X1:0:0:0 Y1:-1:0:-1 Z0:0:1:0 U0:0:0:1	; Matrix mapping for Axis - X:Y:Z:U
                  M669 X1:0:0:0 Y1:-1:0:-1 Z0:0:1:0 U0:0:0:1	; Matrix mapping for Axis - X:Y:Z:U
                  G21                                     ; Set Units to Millimeters
                  M552 S2                   				; enable network, note P0.0.0.0 sets auto DHCP
                  M553 P255.255.255.0						; set subnet mask
                  M554 P192.168.1.20						; set gateway
                  M586 P0 S1                              ; enable HTTP
                  M586 P1 S0                              ; disable FTP
                  M586 P2 S0                              ; disable Telnet
                  G4 S2 									; wait for expansion boards to start
                  M569 P0.0 S0 D2								; Left Z physical drive 0.0 goes forwards
                  M569 P0.1 S0 D2								; Rear Z physical drive 0.1 goes forwards
                  M569 P0.2 S0 D2								; Right Z physical drive 0.2 goes forwards
                  M569 P0.3 S1 D2								; Right U toolhead drive 0.3 goes forwards
                  M569 P0.4 S1 D2								; Left X toolhead drive 0.4 goes forwards
                  M569 P0.5 S0 D2								; Left Y drive 0.5 goes forwards
                  M569 P0.6 S1 D2								; Right Y drive 0.6 goes reverse
                  M569 P20.0 S1 D2                            ; Extruder physical drive 20.0 goes forwards Toolboard 1LC
                  M569 P21.0 S1 D2                            ; Extruder physical drive 21.0 goes forwards Toolboard 1LC
                  M569 P1.0 S0 D2                            ; Extruder physical drive 1.0 goes forwards Expansion 3HC
                  M569 P1.1 S0 D2                            ; Extruder physical drive 1.1 goes forwards Expansion 3HC
                  M569 P1.2 S1 D2                            ; Extruder physical drive 1.2 goes forwards Expansion 3HC
                  M584 Z0.0:0.1:0.2 Y0.5:0.6 X0.4 U0.3 E20.0:21.0:1.0:1.1        ; set drive mapping
                  M350 U16 X16 Y16 Z16 E16:16:16:16 I1                 			; configure microstepping with interpolation
                  M92 U80.0 X80.00 Y80.00 Z800.00 E690:690:690:690				; set steps per mm
                  M906 U2000 X2000 Y2000 Z1800 E1000:1000:1000:1000 I30				; set motor currents (mA) and motor idle factor in per cent -- safe for Duet 3 mini 5+
                  M84 S30                                 				; Set idle timeout
                  ;M98 P"0:/sys/setspeeds.g"               				; Set speed and acceleration
                  M566 U500.00 X500.00 Y500.00 Z60.00 E300:300:300:300 P1 ;E300:300 P1				;X1500.00 Y1500.00 Z6.00 E300 P1 ;E120.00 P1          ; set maximum instantaneous speed changes (mm/min)
                  M203 U30000.00 X30000.00 Y30000.00 Z1000.00 E7200:7200:7200:7200 ;E7200:3600 			;E3600.00     ; set maximum speeds (mm/min)
                  M201 U10000.00 X10000.00 Y10000.00 Z100.00 E10000:10000:10000:10000 ;E10000:3600 		;E3600.00        ; set accelerations (mm/s^2)
                  M207 S0.6 F7200 Z0.2						; firmware retraction orbiter 2.0
                  M208 X-70 U0 Y0 Z0 S1                               ; set axis minima
                  M208 X300 U380 Y306 Z300 S0 ; X310                        ; set axis maxima
                  ;M208 X-70:310 Y0:308 U0:308 Z0:300
                  M574 X1 S1 P"20.io2.in"                           ; configure active high endstops Toolhead 1 X low end
                  M574 U2 S1 P"21.io2.in"                           ; configure active high endstops Toolhead 2 U high end
                  M574 Y2 S1 P"io2.in"                           ; configure active high endstops Y.  IO0 and IO1 also are UART, so do not put endstops on them, use them elsewhere to free up UART.
                  M574 Z1 S2
                  M671 X-71:155:381 Y-1.5:305:-1.5 S5       ; NEW WIDEBOI WITH EXTRUSION SUPPORT LEADSCREW POSITIONS define positions of Z leadscrews or bed levelling screws
                  ;M671 X-4.5:155:304.5 Y-4.5:305:-4.5 S5       ; OLD NON-WIDEBOI EXTRUION SUPPORT LEADSCREW POSITIONS define positions of Z leadscrews or bed levelling screws
                  ;M557 X30:280 Y20:300 P5                        ; define 5x5 mesh grid
                  M557 X30:270 Y20:270 P5
                  M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Keenevo 600W Bed"    ; configure sensor 0 as thermistor on pin temp0
                  M950 H0 C"out0" T0 Q10												; Define Heater0 as the heated bed, bind to Sensor0
                  M140 H0 P0															; Define Heated Bed
                  M307 H0 R0.602 K0.401:0.000 D2.44 E1.35 S1.00 B0							; PID Tuning for Heater0, Heated Bed (100C)
                  M143 H0 S140 T0 A0														; Set temperature limit for Heater0 to 120C
                  M308 S1 P"20.temp0" Y"thermistor" T100000 B4725 C7.060000e-8 A"Slice Hotend 0"  ;Slice Engineering 300C thermistor, settings are online
                  M950 H1 C"20.out0" T1 Q100													; Define Heater1 as Extruder0 heater, bind to Sensor1
                  M307 H1 R2.808 K0.368:0.000 D4.56 E1.35 S1.00 B0 V23.8					; PID Tuning for Heater1, Extruder0 (240C)
                  M143 H1 S325 T1 A0													; Set temperature limit for heater 1 to 285C
                  M308 S2 P"temp1" Y"thermistor" T100000 B3950 C7.060000e-8 A"Chamber" ; configure sensor 2 as thermistor on pin temp1
                  M950 H2 C"out1" T2 ;Q10												; create chamber heater output on out1 and map it to sensor 2
                  M307 H2 R0.01 K0.200:0.000 D60 E1.35 S1.00 B1                              ; enable bang-bang mode for the chamber heater and set PWM limit
                  M141 H2												; map chamber to heater 2
                  M143 H2 S120 T2 A0									; set temperature limit for heater 2 to 60C
                  M308 S3 P"21.temp0" Y"pt1000" A"Slice Hotend 1"  ;Slice Engineering RTD PT1000 450C, settings are online
                  M950 H3 C"21.out0" T3 Q100													; Define Heater1 as Extruder0 heater, bind to Sensor1
                  M307 H3 R2.808 K0.368:0.000 D4.56 E1.35 S1.00 B0 V23.8					; PID Tuning for Heater1, Extruder0 (240C)
                  M143 H3 S425 T3 A0 ; S325														; Set temperature limit for heater 1 to 285C
                  M308 S4 P"20.temp1" Y"thermistor" A"Cooling Block" T100000 B3950 C7.060000e-8 ; Define Sensor as Chamber temperature
                  M308 S5 Y"drivers" A"4028 Power"    								; 4028 power using spare heater
                  M308 S6 Y"mcu-temp" A"Mini 5+ MCU"											; Define Sensor3 as the integrated MCU temperature sensor
                  M308 S7 Y"drivers" A"Mini 5+ TMC Drivers"									; Define Sensor4 as the TMC overheat sensor
                  M308 S8 Y"mcu-temp" P"20.dummy" A"Toolboard0 MCU"
                  M308 S9 Y"drivers" P"20.dummy" A"1LC0 Stepper"
                  M308 S10 Y"mcu-temp" P"21.dummy" A"Toolboard1 MCU"
                  M308 S11 Y"drivers" P"21.dummy" A"1LC1 Stepper"
                  M308 S12 Y"mcu-temp" P"1.dummy" A"3HC MCU"
                  M308 S13 Y"drivers" P"1.dummy" A"3HC TMC Drivers"
                  M308 S14 P"temp2" Y"thermistor" T100000 B3950 C7.060000e-8 A"Orbiter Motor" ; configure sensor 9 as thermistor on pin temp2
                  M308 S15 P"spi.cs1" Y"thermocouple-max31856" K"K" A"TC0 Chamber Heater"; define temperature sensor number 10 as a K Type thermocouple on the first port of a temperature daughter board plugged into the expansion board with CAN bus address 3.
                  M308 S16 P"spi.cs2" Y"thermocouple-max31856" K"K" A"TC1 Chamber Fins"; define temperature sensor number11 as a T Type thermocouple on the first port of a temperature daughter board plugged into the expansion board with CAN bus address 3.
                  ;M308 S17 P"21.temp1" Y"thermistor" T4500000 B5315 C3.219245e-9 A"BLUE MELLOW" 	; blue Mellow high temp thermistor (toolboard)https://duet3d.dozuki.com/Wiki/Connecting_thermistors_or_PT1000_temperature_sensors#Section_RepRapFirmware_3_x
                  ;M308 S17 P"21.temp1" Y"pt1000" T500000 B4666 C1.117125e-7 A"WHITE MELLOW" 	; white Mellow high temp pt1000 (toolboard)https://duet3d.dozuki.com/Wiki/Connecting_thermistors_or_PT1000_temperature_sensors#Section_RepRapFirmware_3_x
                  M950 H4 C"!out2" T2 Q10	;H2											; Define Heater2 as the 4028 fan power, bind to Sensor3
                  M143 H4 P2 S200 A0														; Needed M143 to set max temp so the graph scaled correctly
                  M950 F0 C"!20.out1+out1.tach" Q25000 ;Q500							; create fan 0 on pin out4 and set its frequency
                  M106 P0 C"T0 Layer Fan" L0.0 X1.0 S0 H-1 B0.1							; set fan 0 name and value. Thermostatic control is turned off
                  M950 F1 C"20.out2+out2.tach" Q500 								; Fan 1 uses out3, and using out3.tach as a tacho input
                  M106 P1 C"T0 Hotend Fan" S0 H1 T45        						; For M106 the H is sensor # and NOT heater #.  set fan 1 name and value. Thermostatic control turned on for Hotend
                  M950 F2 C"out5" Q500                   						; create fan 1 on pin out5 and set its frequency
                  M106 P2 C"Mini 5+ Board Fan" S0 H5:6:7 T45        			; set fan 1 name and value. Thermostatic control turned on for Hotend
                  M950 F3 C"!out3+out3.tach" Q25000 ; Q500                 ; Chamber Heater Fan Noctua NF-F12 Industrial
                  M106 P3 C"Chamber Heater Fan" H15 T30 ; H15 S0.3  L0.3 X0.6 B0.1 T30:40       ; set fan 1 name and value. Thermostatic control turned on for Hotend.
                  M950 F4 C"1.out3" Q500 ; ; out6 on old mini 5+                 				; create fan 4 for Water Cooling 12V Fan 4 on pin out4 and set its frequency
                  M106 P4 C"Radiator Cooling Fan" S0 H4 T35       		; set fan 1 name and value. Thermostatic control turned on for liquid cooling hotend
                  M950 F5 C"!out4+out4.tach" Q25000 ;Q500                   				; create fan 4 for Water Cooling 12V Fan 4 on pin out4 and set its frequency
                  M106 P5 C"Liquid Cooling Pump" L0.0 X1.0 S0.5 H4 ;S0.0 T20        	; set fan 4 name and value. Thermostatic control turned on for liquid cooling hotend
                  M950 F6 C"!21.out1+out1.tach" Q25000 ;Q500							; create fan 6 on pin out4 and set its frequency
                  M106 P6 C"T1 Layer Fan" L0.0 X1.0 S0 H-1 B0.1							; set fan 6 name and value. Thermostatic control is turned off
                  M950 F7 C"21.out2+out2.tach" Q500 				; Fan 7 uses out3, and using out3.tach as a tacho input
                  M106 P7 C"T1 Hotend Fan" S0 H3 T45        ; set fan 7 name and value. Thermostatic control turned on for Hotend
                  M950 F8 C"1.out6" Q500                   ; create fan 1 on pin out5 and set its frequency
                  M106 P8 C"3HC Board Fan" S0 H12:13 T45        ; set fan 1 name and value. Thermostatic control turned on for Hotend
                  M950 F9 C"!1.out4+out4.tach" Q25000 ;Q500	4028 filter fan						; create fan 0 on pin out4 and set its frequency
                  M106 P9 C"Testing Chamber Fan" H-1 T30
                  ; Tool 0 X Axis
                  M563 P0 D0 H1 X0 F0 S"Mosquito Mag Liquid"           										; define tool 0
                  G10 P0 X0 Y0 Z-0.54 ; Z-0.54	S210 R175						; set tool 0 axis offsets, set initial tool 0 active 60C and standby temperatures to 0C
                  M568 P0 S210 R175
                  ; Tool 1 U Axis
                  M563 P1 D1 H3 X3 F6 S"Mosquito Mag Air"           										; define tool 0
                  G10 P1 U0 X0 Y0 Z0 ; S210 R175	; L1					; set tool 1 axis offsets, set initial tool 1 active 60C and standby temperatures to 0C
                  M568 P1 S210 R175
                  ; Tool 2-- Toolhead 2 with ROME 1
                  M563 P2 D1:2 H3 X3 F6 S"ROME 1"						; tool 2 uses both extruders and hot end heaters, maps X to both X and U, and uses both print cooling fans
                  G10 P2 U-2.31 X0 Y0.24 Z0.00 ; Z0.04	S210 R175	; L1		; set tool 0 axis offsets, set initial tool 0 active 60C and standby temperatures to 0C
                  M567 P2 E1:1										; set mix ratio 100% on both extruders for copy mode
                  M568 P2 S210 R175
                  ; Tool 3-- Toolhead 2 with ROME 2
                  M563 P3 D1:3 H3 X3 F6 S"ROME 2"						; tool 2 uses both extruders and hot end heaters, maps X to both X and U, and uses both print cooling fans
                  G10 P3 U-2.31 X0 Y0.24 Z0.00 ; Z0.04	S210 R175	; L1		; set tool 0 axis offsets, set initial tool 0 active 60C and standby temperatures to 0C
                  M567 P3 E1:1										; set mix ratio 100% on both extruders for copy mode
                  M568 P3 S210 R175
                  ; Tool 4-- copy mode
                  ;M563 P4 D0:1 H1:3 X0:3 F0:6 S"copy mode"           ; tool 2 uses both extruders and hot end heaters, maps X to both X and U, and uses both print cooling fans
                  ;G10 P4 U-77.5 X77.5 Y0 S210 R175                              ; set tool offsets and temperatures for tool 2
                  ;M567 P4 E1:1                                         ; set mix ratio 100% on both extruders for copy mode
                  ; Tool 5-- mirror mode
                  ;M563 P5 D0:1 H1:3 X0:3 F0:6 S"mirror mode"          ; tool for mirror mode
                  ;G10 P5 U-77.5 X77.5 Y0 S210 R175                             ; tool offset for mirror mode (flipped X offset)
                  ;M567 P5 E1:1                                         ; set mix ratio 100% on both extruders for mirror mode
                  ; Z-Probe Euclid Probe
                  ;M558 P5 C"20.io0.in" H5 F400 T5000       ; set Z probe type to unmodulated and the dive height + speeds
                  M558 P8 C"^20.io0.in" H8 F400 T9000 A1 ; S0.01       ; set Z probe type to unmodulated and the dive height + speeds
                  G31 P1000 X-28 Y-20 Z9.71 ; Z9.21   ; K0           ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed
                  ;; BLTouch
                  ; M950 S0 C"io7.out"                     ; Create a servo pin on io7
                  ; M558 P9 C"io7.in" H5 F240 T10800 A5    ; set Z probe type to unmodulated and the dive height + speeds
                  ; G31 P25 X-28.00 Y-13.00 Z0.78          ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed
                  ;Accelerometer
                  M955 P20.0 I14
                  ;Input Shaper
                  M593 P"zvdd" F31		; for 10k acceleration
                  ;M593 P"mzv" F42.5		; for 15k acceleration
                  ;Filament Sensor0
                  ;M591 D0 P3 C"20.io1.in" S1
                  ;M591 D0 L27 R10:190
                  ;ROME Filament Sensor0
                  ;M591 D2 P1 C"21.io0.in" S1
                  ;M591 D2 L27 R10:190
                  ;M574 U2 S1 P"21.io0.in"                           ; configure active high endstops Toolhead 2 ROME toolhead filament sensor
                  ;M577 wait until endstop is triggered.  Does equivalent exist for a general IO sensor?
                  M950 J0 C"^!21.io0.in"
                  ;PanelDue 5i
                  M575 P1 S1 B57600
                  ;NeoPixels x3
                  M150 X3 Q4000000 ;R128 U128 B128 P128 S2 F0
                  M150 X3 R255 U255 B255 W255 P255 S2 F0      ; display led
                  ; Custom settings
                  G29 S1
                  M572 D0:1:2:3 S0.045		; set Pressure Advance K-factor
                  M501
                  M376 H3
                  ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                  global daemonLoop = true
                  ; init filament sensor error global variables
                  if !exists(global.filamentTimestamp)
                  	global filamentCounter = 0
                  	global filamentTimestamp = state.Uptime
                  ; init print time logging
                  if !exists(global.runtime)
                    M98 P"runtime.g"
                  ; init LED variables
                  if !exists(global.warmUp)
                  	global warmUp = false
                  ; Select default tool
                  M404 N1.75															; Define filament diameter for print monitor
                  T0
                    @RogerPodacter thanks. Can you confirm that you have no daemon.g file in /sys on the SD card?
                    • Exerqtorundefined
                      Exerqtor @dc42
                      Yup, no problem I know intermittent issues can suck to track down 😅👌
                        RogerPodacter @dc42
                        @dc42 ah yes, here is my daemon.g.
                        daemon.g
                        while global.daemonLoop
                        ;Heater Checks and Safety
                        	;check if Chamber heater fans are running
                        ;	if fans[3].rpm < 100
                        ;		M141 H2 S-273.1 ; disable chamber heater
                        ;Keeps a lifetime running print time variable for the printer
                        	;if global.warmUp = true
                        	;	echo "setLEDbyTemp = true"
                        	;	M98 P"0:/macros/set_LED_while_heating.gcode"
                        	if state.status == "processing"
                        		if exists(global.runtime)
                        			set global.runtime = {global.runtime + 10}
                        			echo >"runtime.g" "global runtime = " ^ {global.runtime} ^ " ; seconds AUTO GENERATED by daemon.g"
                        			;echo >"runtime.g" "minutes = "^{global.runtime}/60
                        			;echo >"runtime.g" "hours = "^{global.runtime}/60/60
                        			;echo >"runtime.g" "days = "^{global.runtime}/60/60/24
                        ;LED Controls
                        	if {state.status} == "paused"
                        		M150 R255 B255 P255 S2  ; purple
                        		M300 S4000 P50 G4 P300 M300 S4000 P50 ; double beep
                        	elif {state.status} == "processing" || {state.status} == "busy"
                        		M150 R255 U255 B255 W255 P255 S2  ; white
                        	elif {heat.heaters[0].current} > 50 || {heat.heaters[1].current} > 70
                        		M150 R255 U0 B0 W0 P255 S2  ; red
                        	elif {state.status} == "idle"
                        		M150 R0 U255 B0 W0 P255 S2  ; green
                        	else
                        		M150 R150 U0 B150 W0 P255 S2 ; purple
                        	G4 S10 ;there is a delay of 10 seconds between consecutive executions of daemon.g. This is to avoid SD
                        	; card access contention between daemon.g and a file being printed. If you need a smaller delay, put
                        	; all that code inside a while-loop, and include a shorter delay (e.g. G4 S1) at the end of the loop.
                        	;ADD SOMETHING LIKE THIS FOR HEATER SAFETY.  USE REALLY USEFUL EXAMPLE GCODE DAEMON.G FILES.
                        	;if fans[1].rpm < 100 && heat[1].heaters > 50
                        	;	abort "No fan motion detected, stopping all macros,  jobs, and  disabling heaters"
                        	;	M140 P-273.1 ; disable bed heater
                        	;	M568 P0 A0; set tool 0 to off
                        ;############ from dc42
                        ;while true
                        ;while iterations<10
                        ;  while iterations < #sensors.analog
                        ;    var red = sensors.analog[iterations].lastReading
                        ;    var green = 255 - var.red
                        ;    var blue = var.green
                        ;    M150 R{var.red} U{var.green} B{var.blue} S2 F{min(#sensors.analog-iterations-1,1)}
                        ;  G4 S3
                          ; daemeon.g
                        ; Adafruit #1426 8 led neopixel
                        ; M150 X1
                        ; if heat.heaters[1].current > 50 ; temp
                        ;  M150 R0 U255 B0 P255 S2 F1 ;M150 R{var.redValue} U{var.greenValue} B{var.blueValue} P{var.setBrightness} S{var.pixelsPerTool} F{var.F}
                        ; elif heat.heaters[1].current <= 50
                        ;  M150 R0 U0 B255 P255 S2 F1
                          • Please also provide your homing files, since you said the machine resets during homing.
                          • Although this doesn't explain the reset, I can see a problem in your config.g file. Your M669 command to set the kinematics at line 7 refers to the U axis, however the U axis doesn't exist until it is created in the M584 command at line 35. You should move the M669 command to be after the M584 command.
                          Exerqtorundefined 1 Reply Last reply Reply Quote 1
                          • Arminasundefined
                            Arminas @dc42
                            This post is deleted!
                            • Exerqtorundefined
                              Exerqtor @dc42
                              Just as a little update, i have as of today not had any more resets. I'm trying to turn out some small parts, just to see if anything can trigger a reset, but so far no luck =/
                                @Exerqtor thanks for the update. I have not yet had a reset either using your files or the file from @RogerPodacter (although I am still waiting for his homing files, and he reported that the reset occurred when homing).
                                RogerPodacterundefined Exerqtorundefined 2 Replies Last reply Reply Quote 0
                                  RogerPodacter @dc42
                                  @dc42 apologies for the delay. here are my homing files. my printer kinematics didnt work correctly, so i dont know if that was related while i was attempting the homings...
                                  homeall.g
                                  if (move.axes[0].homed && move.axes[1].homed && move.axes[2].homed && move.axes[3].homed)
                                  	echo "already homed, skipping"
                                  else
                                  	;T0
                                  	G91																	; Relative positioning
                                  	G1 Z15 F6000 H2														; Lift Z relative to current position
                                  	G1 Y999 F3000 H1												; Move X and Y-axes to the endstops and stop (first pass)
                                  	G1 Y-4 F600														; Move Y-axis to the endstop and stop (first pass)
                                  	G1 Y15 F600 H1														; Move X-axis to the endstop once more (second pass)
                                  	G1 X-999 F3000 H1 										; coarse home X, Y and U
                                  	G1 X4 F600 												; move 4mm away from the homing switches
                                  	G1 X-15 H1     												; fine home X, Y and U
                                  	G1 U999 F3000 H1 										; coarse home X, Y and U
                                  	G1 U-4 F600 												; move 4mm away from the homing switches
                                  	G1 U15 H1     												; fine home X, Y and U
                                  	G90																	; Absolute positioning
                                  	M401 ; deploy Z probe (omit if using bltouch)
                                  	; Home Z using the Z-Probe
                                  	M290 R0 S0															; Reset baby-stepping to 0
                                  	G1 X183 Y170 F6000											; Move T0 to probing point (X150, Y150), including probe offset
                                  	G30																	; Probe the bed and set Z to the probe offset
                                  	M402 ; retract probe (omit if using bltouch)
                                  homex.g
                                  M201 X500.00 U500.00    ; Reduce acceleration for homing moves
                                  G1 H2 Z5 F6000          ; Lift Z relative to current position
                                  G1 H1 X-625 F3000       ; Move quickly to X endstop and stop there (first pass)
                                  G1 X3 F600              ; Go back a few mm
                                  G1 H1 X-625 F360        ; Move slowly to X endstop once more (second pass)
                                  ;G1 H1 U625 F1800
                                  ;G1 U-3 F600
                                  ;G1 H1 U625 F360
                                  M201 X3000 U6000        ; Return to full acceleration
                                  G1 H2 Z-5 F6000         ; Lower Z relative to current position
                                  homey.g
                                  M201 X500.00 Y500.00    ; Reduce acceleration for homing moves
                                  G1 H1 Y605 F3000        ; Move quickly to Y endstop and stop there (first pass)
                                  G1 Y-3 F600             ; Go back a few mm
                                  G1 H1 Y605 F360         ; Move slowly to Y endstop once more (second pass)
                                  M201 X3000 Y6000        ; Return to full acceleration
                                  homez.g
                                  ; Euclid Probe homez.g Example Macro
                                  ; RRF3.X Firmware Example
                                  ; saveas system/homez.g
                                  ; comments and echo statements throughout are provided for convenience
                                  if !move.axes[0].homed || !move.axes[1].homed     ; If the printer hasn't been homed, home it
                                  	M98 P"0:/sys/homexy.g"
                                  M561                                            ; clear any bed transform
                                  M290 S0 R0                                      ; clear baby steps
                                  G91                                             ; relative positioning
                                  G1 H2 Z15 F6000                                  ; lift Z relative to current position to clear any obstructions
                                  M400
                                  G1 U380 F2000 ; make sure the U carriage is out of the way
                                  G90                                             ; absolute positioning
                                  ; echo "Call deployprobe.g macro"
                                  M401 P0                                         ; This runs macro file deployprobe
                                  ; echo "Return"
                                  G1 X155 Y155 F9000                            ; go to center of bed in advance of probe that point
                                  M400
                                  ; echo "G30 Command"
                                  G30                                             ; Probe the bed at the current XY position. When the probe is triggered,
        ; adjust the Z offset of the current tool to make the current position Z=0.
                                  ;G1 Z10                                          ; raise Z=10
                                  ;M400
                                  ;G4 P500
                                  ; echo "Call bed4point.g macro"
                                  ;M98 P"0:/sys/bed.g"                       ; tram bed
                                  ; echo "Return"
                                  ;G1 X145 Y162.5 F9000                              ; go back to the first probe point and reprobe 0 in case it moved
                                  ;G30
                                  ; echo "Call retractprobe.g macro"
                                  M402 P0                                         ; retract probe
                                   echo "Return"
                                  ;G1 Z10 F600                                     ; lift Z relative to current position
                                  M564 S1 H0                                      ; reset the bounding limits
                                  ; G1 X150 Y0 F9000                              ; move carriage to center front
                                  homeu.g
                                  M201 U500.00 Y500.00    ; Reduce acceleration for homing moves
                                  G1 H1 U625 F3000       ; Move quickly to X endstop and stop there (first pass)
                                  G1 U-3 F600              ; Go back a few mm
                                  G1 H1 U625 F360        ; Move slowly to X endstop once more (second pass)
                                  M201 U3000 Y6000        ; Return to full acceleration
                                  bed.g
                                  M290 R0 S0    ;  clear baby stepping
                                  M561          ;  reset all bed adjustments
                                  M400          ;  flush move queue
                                  ; echo "Running bed4point.g"
                                  ;M558 F60 A6 ;A3                              ; fix probe speed to 1mm/s
                                  ;G90
                                  ;G4 P250
                                  if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                                  	echo "not all axes homed, homing axes first"
                                  	G28
                                  G30 P0 X46 Y20 Z-99999 ; X41 X30 Y20 Z-99999 ; probe near a leadscrew
                                  G30 P1 X155 Y276 Z-99999 ;Y282 Z-99999 ; probe near a leadscrew
                                  G30 P2 X270 Y20 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
                                  echo "Current rough pass deviation: " ^ move.calibration.initial.deviation
                                  while move.calibration.initial.deviation > 0.005
                                  		if iterations >= 5
                                  			echo "Error: Max attemps failed. Deviation: " ^ move.calibration.initial.deviation
                                  			break
                                  		echo "Deviation over threshold. Executing pass" , iterations+1, "deviation", move.calibration.initial.deviation
                                  		G30 P0 X46 Y20 Z-99999 ; probe near a leadscrew
                                  		G30 P1 X155 Y276 Z-99999 ; probe near a leadscrew
                                  		echo "Current deviation: " ^ move.calibration.initial.deviation
                                  		continue
                                  echo "Final deviation: " ^ move.calibration.initial.deviation
                                  G0 X155 Y155 Z20 F9000
                                  G30
                                  ;G28 Z
                                  • Exerqtorundefined
                                    Exerqtor @dc42
                                    After a couple days without any resets, it happend again twice yesterday:
                                    power up + 00:00:03 [info] Event logging started at level debug
                                    power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-beta.4 (2023-06-08 23:40:14)
                                    power up + 00:00:03 [debug] Done!
                                    power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running.
                                    power up + 00:00:04 [warn] WiFi module started
                                    power up + 00:00:07 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.50
                                    power up + 00:00:09 [warn] HTTP client 192.168.10.100 login succeeded (session key 1366409378)
                                    2023-06-16 01:23:20 [warn] Date and time set at power up + 00:00:09
                                    power up + 00:00:08 [warn] HTTP client 192.168.10.100 login succeeded (session key 125510966)
                                    2023-06-16 10:24:14 [warn] Date and time set at power up + 00:00:08
                                    m122
                                    Board ID: FAP55-Q967A-G65J0-401GL-0S02Z-RF9TL
                                    Used output buffers: 1 of 40 (30 max)
                                    Static ram: 102996
                                    Dynamic ram: 124208 of which 16 recycled
                                    Never used RAM 11980, free system stack 180 words
                                    Tasks: NETWORK(2,nWait,126.9%,219) HEAT(3,nWait,0.5%,327) Move(4,nWait,0.1%,344) CanReceiv(6,nWait,1.1%,672) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.2%,351) TMC(4,delaying,26.0%,108) MAIN(1,running,48.1%,704) IDLE(0,ready,8.9%,29) AIN(4,delaying,18.0%,266), total 229.7%
                                    Owned mutexes:
                                    Last reset 26:40:40 ago, cause: software
                                    Last software reset at 2023-06-16 10:24, reason: HardFault invState, Gcodes spinning, available RAM 10580, slot 1
                                    Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011fa8 Task NETW Freestk 482 ok
                                    Stack: 000001ae 00000002 200014ec 00000000 2003335a 0009d43d 00000000 600f0000 00000000 00000000 00000000 00000000 20032174 00000800 20035e68 2002c558 20018670 2002c3f5 20018670 2001e920 0002fe6f 00000000 00000000 00000000 20012058 00000014 b5ddc1d1
                                    Error status: 0x00
                                    Aux0 errors 0,0,0
                                    MCU revision 3, ADC conversions started 96040137, completed 96040137, timed out 0, errs 0
                                    MCU temperature: min 35.1, current 36.3, max 39.4
                                    Supply voltage: min 23.7, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
                                    Heap OK, handles allocated/used 99/28, heap memory allocated/used/recyclable 2048/980/596, gc cycles 3588
                                    Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 33, reads 14596, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 33, reads 14596, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 147, reads 14596, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 147, reads 14595, writes 13, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6c
                                    Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 150, reads 14595, writes 13, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6a
                                    Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 43, reads 14597, writes 10, timeouts 2, DMA errors 0, CC errors 0, failedOp 0x6a
                                    Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 43, reads 14599, writes 10, timeouts 0, DMA errors 0, CC errors 0
                                    Date/time: 2023-06-17 13:04:45
                                    Slowest loop: 22.78ms; fastest: 0.14ms
                                    === Storage ===
                                    Free file entries: 18
                                    SD card longest read time 4.5ms, write time 4.2ms, max retries 0
                                    DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
                                    === DDARing 0 ===
                                    === DDARing 1 ===
                                    Heater 1 is on, I-accum = 0.0
                                    HTTP is idle in state(s) 0
                                    Daemon is doing "G4 S1        " in state(s) 0 0, running macro
                                    Q0 segments left 0, axes/extruders owned 0x0000803
                                    === CAN ===
                                    Messages queued 864369, received 1920872, lost 0, boc 0
                                    Longest wait 3ms for reply type 6053, peak Tx sync delay 277, free buffers 18 (min 17), ts 480201/480200/0
                                    === Network ===
                                    Slowest loop: 22.24ms; fastest: 0.00ms
                                    = WiFi =
                                    Module is connected to access point
                                    Firmware version 2.1beta4
                                    MAC address bc:ff:4d:e6:b1:62
                                    Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42972
                                    WiFi IP address 192.168.10.50
                                    Signal strength -50dBm, channel 1, mode 802.11n, reconnections 0
                                      @Exerqtor that's interesting, it's not the same crash as before but it is the same task (NETW) and probably the same area of code.
                                      If your machine is not being used, please can you do a couple of things to increase the load on it, in the hope that this will make the problem occur more frequently. In particular, try these:
                                      • In the DWC Machine Specific config, reduce the polling interval e.g. to 100ms
                                      • Reduce the lengths of G4 delay commands that you have in daemon.g.
                                      Exerqtorundefined 1 Reply Last reply Reply Quote 0
                                      • Exerqtorundefined
                                        Exerqtor @dc42
                                        Guess that's somewhat positive and it would help narrow down the search a little? wishfull thinking
                                        Ok I've set the "Communication update invervals" to 100ms now (if that's the one you were refering to).
                                        What do you suggest changing the daemon.g delay to? It's currently 1second, so reduce it to 300ms or something maybe?
                                          @Exerqtor I suggest you try 100ms. If that makes the response to console commands such as M122 excessively slow, increase it.
                                          • Exerqtorundefined
                                            Exerqtor @dc42
                                            Ok, then both have been set to 100ms. Now it's just to wait for a crash i guess 😅
