    New beta firmware release 1.20beta10
    Firmware installation
    18
    59
    7.6k
      Thanks, I'll try printing that on my delta. Please share your config.g file.
      • whosrdaddyundefined
        whosrdaddy
        I'm running beta 10 on a cartesian, no problems to report.
        Seems to be a delta/scara kinematics problem…
        • Hergonowayundefined
          Hergonoway
          #1 Delta
          #2 Benchy : https://www.thingiverse.com/thing:763622
          #3 no bug reported 😮
          Additional notes : the bug is not consistent, it's not happening each time at the same place with the same gcode file. In my case on 4 benchy, it happens 3 times and each time this "offset" was temporary (see picture)
          my config :
          ;#### General preferences #####
          M111 S0 ; Debugging off
          G21 ; Work in millimetres
          M555 P5 ; Set firmware compatibility to look like Repetier
          M665 R182.25 L360.26 B150 H363.70 ; Set delta radius, diagonal rod length, printable radius and homed height
          M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
          M208 Z-2 S1 ; Set minimum Z
          ;#### Endstops ####
          M574 X2 Y2 Z2 S0 ; Define active high microswitches
          ## PROBE
          ; Setup Sensitivity : M672 S105:aaa:bbb ; Current : M672 S105:20:235 ; Reset : M672 S131:131
          M558 P5 T10000 R0.4 F200 H2 ; Smart Effector ; R= Delay, F= Probe speed, H= Dive height, T= Travel speed
          G31 P100 X0 Y0 Z-0.10 ; Set Z probe trigger value, offset and trigger height
          M557 R120 S20 ; Define mesh
          ;#### Drives ####
          M569 P0 S1 ; (X) Drive 0 goes forwards
          M569 P1 S1 ; (Y) Drive 1 goes forwards
          M569 P2 S1 ; (Z) Drive 2 goes forwards
          M569 P3 S1 ; (E0) Drive 3 goes forwards
          M92 X80 Y80 Z80 E405 ; Set steps per mm
          M84 S30 ; Set idle timeout
          M566 X1200 Y1200 Z1200 E1000 ; (JERK) Set maximum instantaneous speed changes (mm/min)  ; #OLD_1# E1200
          M203 X18000 Y18000 Z18000 E3600 ; Set maximum speeds (mm/min)
          M201 X3600 Y3600 Z3600 E1200 ; Set accelerations (mm/s^2)
          M906 X1200 Y1200 Z1200 E1200 I70 ; Set motor currents (mA) and motor idle factor in per cent
          ;#### Extruder (ADVANCE) ####
          M572 D0 S0.2 ; Extruder 0 (D) Pressure advance default S0.1 ; #OLD_1# S0
          ;M207 S3 R-0.05 F2500 T1200 Z0.4 ; Firmware retraction
          ;#### Heaters ####
          M143 H1 S260 ; Set maximum heater temperature to 300C
          M143 H0 S150 ; Set maximum bed temperature to 150C
          M305 P0 T100000 B3950 C0 R4700 ; #BED# Set thermistor + ADC parameters for heater 0
          M305 P1 X200 ; #NOZZLE# Set thermistor + ADC parameters for heater 1
          ;#### Tools ####
          M563 P0 D0 H1 ; Define tool 0 (P) uses extruder 0 (D) ,heater 1 (H) (and fan 0 -- default)
          ;#### Network ####
          M550 PDelta ; Set machine name
          M552 S1 ; Enable network
          M586 P0 S1 ; Enable HTTP
          M586 P1 S1 ; Enable FTP
          M586 P2 S0 ; Disable Telnet
          ;#### Fans ####
          M106 P0 S0 H-1 I0 F100 ; FAN 0 (P) default off (S) Thermostatic control OFF (T).
          M106 P1 T35 S1 H1 ; FAN 1 (P) triggered above 35° (T) at 100% (S) on Heater 1
          ;#### CUSTOM ####
          M501 ; Loading config-override.g
          T0 ; Default tool to be deleted at start-up
          Delta goes BrrrRRRRrrrrrRRRRrrr
          • DjDemonDundefined
            DjDemonD
            Hi David,
            1. State what machine architecture you are using (Cartesian, Delta etc.)
            Delta
            Firmware Name: RepRapFirmware for Duet WiFi
            Firmware Electronics: Duet WiFi 1.0
            Firmware Version: 1.20beta10 (2017-11-23)
            WiFi Server Version: 1.20b10
            Web Interface Version: 1.19.3
            Took two attempts to load wifiserver via sd card. I am not getting as far as being able to get to the point of the layer shift. First attempt the machine threw a heater fault (normally completely reliable) just after warmup and delta calibration so i restarted it. The console debugging is in this file
            https://1drv.ms/u/s!Apv79JfGbPIwg4RptjqtFRPVBjLS6w
            labelled console.txt.
            Then I tried again, and it crashed, stopped printing at around layer 8 nozzle on the print, nothing for a few seconds then a full reset. I powered back up saved m122, and have included console (console2.txt), eventlog and config.g.
            Hope this helps but I'm downgrading for now.
            www.precisionpiezo.co.uk
              Thanks. Unfortunately the M122 file is empty. However, I see some extruder step error reports in one of the console logs and I will take a detailed look at those. The full reset sounds as if it may be a watchdog timeout, which one other user has reported getting in beta 7 and later.
              • franzelkaundefined
                franzelka
                config.g below
                [c]
                ; Configuration file for Mini Kossel Release 3 kit from Think3DPrint3D
                ; For additional help see http://reprap.org/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer and
                ; http://reprap.org/wiki/Configuring_and_calibrating_a_delta_printer_using_the_dc42_fork_of_RepRapFirmware
                ; Prologue and communications section
                M111 S0 ; Debug off
                M550 PMiniKossel ; Machine name and Netbios name (can be anything you like)
                M551 Preprap ; Machine password (currently not used)
                M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
                ;*** Adjust the IP address and gateway in the following 2 lines to suit your network
                M552 P0.0.0.0 ; Un-comment for DHCP
                M555 P2 ; Set output to look like Marlin
                M575 P1 B57600 S1 ; Set auxiliary serial port baud rate and require checksum (for PanelDue)
                G90 ; Send absolute coordinates…
                ; The following section is not required for Firmware V1.09r and above
                ; Turn off fans: by default PWM fans on Duet V0.8.5 are inverted
                ; M106 I1 ; fans are inverting
                ; M106 S0 ; Turn off Fan 0
                ; Movement section
                M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high)
                ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration
                M665 R106.156 L215 B85 H246.073, X-0.501 Y1.067; set delta radius, diagonal rod length, printable radius and homed height
                X2.53 Y0.90 Z-3.43 ; put your endstop adjustments here, or let auto calibration find them
                M92 X80 Y80 Z80 ; Set axis steps/mm
                M906 X1000 Y1000 Z1000 E800 I60 ; Set motor currents (mA) and increase idle current to 60%
                M201 X1000 Y1000 Z1000 E1000 ; Accelerations (mm/s^2)
                M203 X20000 Y20000 Z20000 E3600 ; Maximum speeds (mm/min)
                M566 X1200 Y1200 Z1200 E600 ; Maximum instant speed changes mm/minute
                ; Heater and thermistor section
                ;*** If you have a Duet V0.6 board NOT stickered "4.7K" change R4700 to R1000 to the following M305 commands. Leave at R4700 for all Duet V0.8.5 boards
                M305 P0 T100000 B3950 R4700 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
                M305 P1 T100000 B4388 R4700 H0 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction. DC42 recommends 4388 for E3D V6 with Semitec 104-GT2 thermistor
                M305 P2 T100000 B4388 R4700 H0 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction.
                M570 S180 ; Hot end may be a little slow to heat up so allow it 180 seconds
                M143 S285 ; Allow up to 285°
                ; Tool definition section
                G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
                ;*** If you have a dual-nozzle build, un-comment the next 2 lines
                ;M563 P1 D1 H2 ; Define tool 1
                ;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
                M92 E402 ; Set extruder steps per mm
                ; Z probe section
                ;*** If you have a a switch as a zprobe instead of an IR probe, change P1 to P4 in the following M558 command
                M558 P1 X0 Y0 Z0 ; Z probe is an IR probe and is not used for homing any axes
                G31 X0 Y0 Z1.47 P500 ; Put your own value of Z-probe height here during calibration. Z1.55
                ; Epilogue
                ;*** If you are using axis compensation, put the figures in the following command
                M556 S78 X0 Y0 Z0 ; Axis compensation here
                M208 S1 Z0.0 ; set minimum Z - can be negative but not recommended. Use G92 instead.
                M501
                T0 ; select first hot end
                [/c]
                • DjDemonDundefined
                  DjDemonD
                  @dc42:
                  Sorry about the m122. I will reduce extruder steps/mm which is quite high on 1/16th with Nimble 1/8th or 1/4 would work just fine.
                    btw I simulated the high E steps/mm on my delta by configuring and selecting a dummy extruder, and I still wasn't able to get any step errors. So I'll take a look at your config and see what's different.
                    • frafaundefined
                      frafa
                      on scara I use
                      M82 ;Set extruder to absolute mode
                      can be bug come from there?
                      I can not test until Tuesday …
                      Scara with DuetWifi => Scarlette3D
                      https://youtu.be/mBF5cO8vGhI
                      • DjDemonDundefined
                        DjDemonD
                        Just to report I have had no luck getting wifiserver1.20beta10 onto my other machine a corexy, the only difference here is its a 1.02 board. Tried via the memory card several times, normal console messages installing etc but get failed to initialise wifi module, code -10. I did check I was using the updated file, not the first one which didn't work. Beta 9 wifi server working perfectly, however.
                        • demonio669undefined
                          demonio669
                          I have the same layer shift problem with beta10
                          • Shenundefined
                            Shen
                            I also have layer shift on my cartesian printer with external drivers. My stepper/driver has encoder that will generate fault signal if there is a large positional error. I did not get any fault from my driver which means there must be some thing wrong with the input signal they are receiving.
                              Hergonoway
                              @dc42:
                              printed 3 benchy, with 3 layer offset (different on each print) nothing in step error through a M122 😮
                              • Jason Kundefined
                                Jason K
                                @whosrdaddy:
                                I had the issue on my Cartesian printer. I have since restored to the previous firmware and it is fine now. I just pulled off the whole y-axis to do some tweaking so I cant pull up anymore info.
                                I sliced using S3d.
                                  It looks like these issues may be due to a lack of free RAM in beta 10. I've prepared a new version with some RAM freed up. I hope to release it tonight or tomorrow.
                                  • zlowredundefined
                                    zlowred
                                    I didn't have any WiFi disconnects since installing the WiFi firmware 1.20beta10 so I hope it is fixed finally.
                                    • DjDemonDundefined
                                      DjDemonD
                                      To be fair this is first problematic release I've encountered so that's not bad going, it is quite a complex piece of software now.
                                        demonio669
                                        @demonio669:
                                        this is my config.g
                                        ; Configuration file for Mini Kossel kit from Think3DPrint3D for testing Duet WiFi
                                        ; Communication and general
                                        M111 S0 ; Debug off
                                        M550 PKosselXXLWiFi ; Machine name and Netbios name (can be anything you like)
                                        M551 Preprap ; Machine password (used for FTP)
                                        ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
                                        ;*** Wifi Networking
                                        M552 S1 ; Enable WiFi
                                        M575 P1 B57600 S1 ; Comms parameters for PanelDue
                                        M586 P2 S1 ; Enable Telnet
                                        ; Axis and motor configuration
                                        M569 P3 S0 ; Drive 3 goes forwards
                                        M569 P4 S0 ; Drive 4 goes forwards
                                        M574 X2 Y2 Z2 S0 ; set endstop configuration (all endstops at high end, active high)
                                        ;M665 L503.000 R245.982 H575.060 B132.5 X0.022 Y0.073 Z0.000 ; set delta radius, diagonal rod length, printable radius and homed height
                                        ;M666 X-0.056 Y-0.024 Z0.079 A0.00 B0.00 ; put your endstop adjustments here, as given by auto calibration
                                        M665 L503.000 R245.965 H589.90 B132.5 X0 Y0 Z0.000
                                        M666 X0.08 Y0.01 Z-0.09 A0 B0
                                        ;M350 X16 Y16 Z16 E16 I1 ; Set 16x microstepping with interpolation
                                        ;M92 X100 Y100 Z100 ; Set axis steps/mm
                                        M906 X1400 Y1400 Z1400 E1400:1400 I60 ; Set motor currents (mA) and increase idle current to 60%
                                        M201 X1800 Y1800 Z1800 E800 ; Accelerations (mm/s^2)
                                        M203 X18000 Y18000 Z18000 E4600 ; Maximum speeds (mm/min)
                                        M566 X900 Y900 Z900 E1800 ; Maximum instant speed changes mm/minute
                                        ; Thermistors
                                        ;M106 P1 H-1 ; disable thermostatic mode for fan 1
                                        M106 P1 L255 S255 H1 T45
                                        ;M106 P2 L255 S255 H0:1:2 T40
                                        M106 P0 L255 S255 H100:101 T35 ; defino al fan 2(el que esta en la caja de la electronica como termostatico y controlado por la temperatura de la CPU y de los STEPPER DRIVERS)
                                        ; Tool definitions
                                        M563 P0 D0 H1 F2 ; Define tool 1
                                        G10 P0 S0 R0 X0 Y0 ; set tool 0 temperatures and offsets
                                        M563 P1 D1 H1 F2 ; tool 0 uses extruder drive 0 and heater 1 y Fan 2 en lugar de 0 ya que esta quemado
                                        G10 P1 S0 R0 X0 Y0 ; Set tool 1 temperatures and offsets
                                        ;M92 E663:663 ; Set extruder steps per mm
                                        ;M92 E146:418.5:663:663:663:663
                                        ;M92 E146:837:663:663:663:663
                                        ;M92 E146:830:663:663:663:663
                                        ;M92 E806:806:663:663:663:663
                                        M92 E804:804:663:663:663:663
                                        ; Z probe and compensation definition
                                        ;*** If you have a switch instead of an IR probe, change P1 to P4 in the following M558 command
                                        ;M558 P1 X0 Y0 Z0 ; Z probe is an IR probe and is not used for homing any axes
                                        ;G31 X0 Y0 Z4.80 P500 ; Set the zprobe height and threshold (put your own values here)
                                        M558 P1 X0 Y0 Z0 ; Z probe is a DC42 Differential IR PCB and is not used for homing any axes
                                        G31 X0 Y0 Z0.490 P500 ; Set the zprobe height and threshold (put your own values here)
                                        ;M556 S78 X0 Y0 Z0 ; Axis compensation here
                                        M208 S1 Z-0.2 ; set minimum Z
                                        ;M579: Scale Cartesian axes
                                        ;On a Cartesian RepRap you can get prints exactly the right size by tweaking the axis steps/mm using the M92 G Code above. But this does not work so easily for Delta and other RepRaps for which there is cross-talk between the axes. This ;command allows you to adjust the X, Y, and Z axis scales directly. So, if you print a part for which the Y length should be 100mm and measure it and find that it is 100.3mm long then you set Y0.997 (= 100/100.3).
                                        M579 X1.012 Y1.012 Z1
                                        ; Configurar la retraccion por hardware
                                        ;M207 S4.0 R-0.1 F3600 T1200 Z0.075
                                        M207 S4.5 R-0.2 F2600 T1800 Z0.09
                                        ;M207 S4 R-0.05 F2200 T1800 Z0.0
                                        ;Pressure advance M572
                                        M572 D0 S0.08
                                        ;M572 D1 S0.1
                                        ;pid autotune parameters
                                        ;M307 H0 A141.2 C398.4 D1.9 B0
                                        ;M307 H1 A758.3 C275.8 D5.8 B0
                                        M570 H1 P5 T20
                                        M557 R110 S22 ; definir un grid de radio 130 cada 22 mm para compenzar la cama
                                        M581 E0 S0 T2 C1 ; configurar el trigger 2 con el sensor del Extrusor 0, activo cuando esta imprimiendo
                                        M581 E1 S0 T3 C1 ; configurar el trigger 2 con el sensor del Extrusor 0, activo cuando esta imprimiendo
                                        M404 N1.75 D0.4 ; setear diametro de filamento y de nozzle
                                        M912 P0 S-15.4 ; Calibrar temperatura de la CPU
                                        • resamundefined
                                          resam
                                          DjDemonD: here are my Z probe repeatability metrics:
                                          https://docs.google.com/spreadsheets/d/15TNWrQdryhAFkfltrYofC_Zl10F0TGuRSZ4mP1esJtI/edit?usp=sharing
                                          Overall, my BLTouch clone achieves a range of about 60-50µm, and a standard-deviation of less than 15µm.
                                          1.20beta10 with Z-Probe type 8 didn't change very much for me though.
                                          Biggest impact was probing speed and maybe my latest upgrade to Tr8x2.
                                          • DjDemonDundefined
                                            DjDemonD
                                            Thank you that's very interesting. So it seems best case scenario it's about 50 microns as expected.
