New beta firmware release 1.20beta10
I'm running beta 10 on a cartesian, no problems to report.
Seems to be a delta/scara kinematics problem⦠-
#1 Delta
#2 Benchy : https://www.thingiverse.com/thing:763622
#3 no bug reportedAdditional notes : the bug is not consistent, it's not happening each time at the same place with the same gcode file. In my case on 4 benchy, it happens 3 times and each time this "offset" was temporary (see picture)
my config :
;############################## ;#### General preferences ##### ;############################## M111 S0 ; Debugging off G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M555 P5 ; Set firmware compatibility to look like Repetier M665 R182.25 L360.26 B150 H363.70 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them M208 Z-2 S1 ; Set minimum Z ;################## ;#### Endstops #### ;################## M574 X2 Y2 Z2 S0 ; Define active high microswitches ## PROBE ; Setup Sensitivity : M672 S105:aaa:bbb ; Current : M672 S105:20:235 ; Reset : M672 S131:131 M558 P5 T10000 R0.4 F200 H2 ; Smart Effector ; R= Delay, F= Probe speed, H= Dive height, T= Travel speed G31 P100 X0 Y0 Z-0.10 ; Set Z probe trigger value, offset and trigger height M557 R120 S20 ; Define mesh ;################ ;#### Drives #### ;################ M569 P0 S1 ; (X) Drive 0 goes forwards M569 P1 S1 ; (Y) Drive 1 goes forwards M569 P2 S1 ; (Z) Drive 2 goes forwards M569 P3 S1 ; (E0) Drive 3 goes forwards M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation M92 X80 Y80 Z80 E405 ; Set steps per mm M84 S30 ; Set idle timeout M566 X1200 Y1200 Z1200 E1000 ; (JERK) Set maximum instantaneous speed changes (mm/min) ; #OLD_1# E1200 M203 X18000 Y18000 Z18000 E3600 ; Set maximum speeds (mm/min) M201 X3600 Y3600 Z3600 E1200 ; Set accelerations (mm/s^2) M906 X1200 Y1200 Z1200 E1200 I70 ; Set motor currents (mA) and motor idle factor in per cent ;############################ ;#### Extruder (ADVANCE) #### ;############################ M572 D0 S0.2 ; Extruder 0 (D) Pressure advance default S0.1 ; #OLD_1# S0 ;M207 S3 R-0.05 F2500 T1200 Z0.4 ; Firmware retraction ;################# ;#### Heaters #### ;################# M143 H1 S260 ; Set maximum heater temperature to 300C M143 H0 S150 ; Set maximum bed temperature to 150C M305 P0 T100000 B3950 C0 R4700 ; #BED# Set thermistor + ADC parameters for heater 0 M305 P1 X200 ; #NOZZLE# Set thermistor + ADC parameters for heater 1 ;############### ;#### Tools #### ;############### M563 P0 D0 H1 ; Define tool 0 (P) uses extruder 0 (D) ,heater 1 (H) (and fan 0 -- default) G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ;################# ;#### Network #### ;################# M550 PDelta ; Set machine name M552 S1 ; Enable network M586 P0 S1 ; Enable HTTP M586 P1 S1 ; Enable FTP M586 P2 S0 ; Disable Telnet ;############## ;#### Fans #### ;############## M106 P0 S0 H-1 I0 F100 ; FAN 0 (P) default off (S) Thermostatic control OFF (T). M106 P1 T35 S1 H1 ; FAN 1 (P) triggered above 35° (T) at 100% (S) on Heater 1 ;################ ;#### CUSTOM #### ;################ M501 ; Loading config-override.g T0 ; Default tool to be deleted at start-up -
Hi David,
1. State what machine architecture you are using (Cartesian, Delta etc.)
DeltaFirmware Name: RepRapFirmware for Duet WiFi
Firmware Electronics: Duet WiFi 1.0
Firmware Version: 1.20beta10 (2017-11-23)
WiFi Server Version: 1.20b10
Web Interface Version: 1.19.3Took two attempts to load wifiserver via sd card. I am not getting as far as being able to get to the point of the layer shift. First attempt the machine threw a heater fault (normally completely reliable) just after warmup and delta calibration so i restarted it. The console debugging is in this file
https://1drv.ms/u/s!Apv79JfGbPIwg4RptjqtFRPVBjLS6w
labelled console.txt.
Then I tried again, and it crashed, stopped printing at around layer 8 nozzle on the print, nothing for a few seconds then a full reset. I powered back up saved m122, and have included console (console2.txt), eventlog and config.g.
Hope this helps but I'm downgrading for now.
Thanks. Unfortunately the M122 file is empty. However, I see some extruder step error reports in one of the console logs and I will take a detailed look at those. The full reset sounds as if it may be a watchdog timeout, which one other user has reported getting in beta 7 and later.
config.g below
[c]
; Configuration file for Mini Kossel Release 3 kit from Think3DPrint3D
; For additional help see http://reprap.org/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer and
; http://reprap.org/wiki/Configuring_and_calibrating_a_delta_printer_using_the_dc42_fork_of_RepRapFirmware; Prologue and communications section
M111 S0 ; Debug off
M550 PMiniKossel ; Machine name and Netbios name (can be anything you like)
M551 Preprap ; Machine password (currently not used)
M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
;*** Adjust the IP address and gateway in the following 2 lines to suit your network
M552 P0.0.0.0 ; Un-comment for DHCP
M555 P2 ; Set output to look like Marlin
M575 P1 B57600 S1 ; Set auxiliary serial port baud rate and require checksum (for PanelDue)G21 ; Work in millimetres
G90 ; Send absolute coordinatesā¦
M83 ; ...but relative extruder moves; The following section is not required for Firmware V1.09r and above
; Turn off fans: by default PWM fans on Duet V0.8.5 are inverted
; M106 I1 ; fans are inverting
; M106 S0 ; Turn off Fan 0; Movement section
M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high)
;*** The homed height is deliberately set too high in the following - you will adjust it during calibration
M665 R106.156 L215 B85 H246.073, X-0.501 Y1.067; set delta radius, diagonal rod length, printable radius and homed height
X2.53 Y0.90 Z-3.43 ; put your endstop adjustments here, or let auto calibration find them
M92 X80 Y80 Z80 ; Set axis steps/mm
M906 X1000 Y1000 Z1000 E800 I60 ; Set motor currents (mA) and increase idle current to 60%
M201 X1000 Y1000 Z1000 E1000 ; Accelerations (mm/s^2)
M203 X20000 Y20000 Z20000 E3600 ; Maximum speeds (mm/min)
M566 X1200 Y1200 Z1200 E600 ; Maximum instant speed changes mm/minute; Heater and thermistor section
;*** If you have a Duet V0.6 board NOT stickered "4.7K" change R4700 to R1000 to the following M305 commands. Leave at R4700 for all Duet V0.8.5 boards
M305 P0 T100000 B3950 R4700 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
M305 P1 T100000 B4388 R4700 H0 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction. DC42 recommends 4388 for E3D V6 with Semitec 104-GT2 thermistor
M305 P2 T100000 B4388 R4700 H0 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction.
M570 S180 ; Hot end may be a little slow to heat up so allow it 180 seconds
M143 S285 ; Allow up to 285°; Tool definition section
G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
;*** If you have a dual-nozzle build, un-comment the next 2 lines
;M563 P1 D1 H2 ; Define tool 1
;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
M92 E402 ; Set extruder steps per mm; Z probe section
;*** If you have a a switch as a zprobe instead of an IR probe, change P1 to P4 in the following M558 command
M558 P1 X0 Y0 Z0 ; Z probe is an IR probe and is not used for homing any axes
G31 X0 Y0 Z1.47 P500 ; Put your own value of Z-probe height here during calibration. Z1.55; Epilogue
;*** If you are using axis compensation, put the figures in the following command
M556 S78 X0 Y0 Z0 ; Axis compensation hereM208 S1 Z0.0 ; set minimum Z - can be negative but not recommended. Use G92 instead.
M501
T0 ; select first hot end
[/c] -
Sorry about the m122. I will reduce extruder steps/mm which is quite high on 1/16th with Nimble 1/8th or 1/4 would work just fine.
btw I simulated the high E steps/mm on my delta by configuring and selecting a dummy extruder, and I still wasn't able to get any step errors. So I'll take a look at your config and see what's different.
on scara I use
M82 ;Set extruder to absolute mode
can be bug come from there?
I can not test until Tuesday ⦠-
Just to report I have had no luck getting wifiserver1.20beta10 onto my other machine a corexy, the only difference here is its a 1.02 board. Tried via the memory card several times, normal console messages installing etc but get failed to initialise wifi module, code -10. I did check I was using the updated file, not the first one which didn't work. Beta 9 wifi server working perfectly, however.
I have the same layer shift problem with beta10
I also have layer shift on my cartesian printer with external drivers. My stepper/driver has encoder that will generate fault signal if there is a large positional error. I did not get any fault from my driver which means there must be some thing wrong with the input signal they are receiving.
printed 3 benchy, with 3 layer offset (different on each print) nothing in step error through a M122
Seems to be a delta/scara kinematics problemā¦I had the issue on my Cartesian printer. I have since restored to the previous firmware and it is fine now. I just pulled off the whole y-axis to do some tweaking so I cant pull up anymore info.
I sliced using S3d.
It looks like these issues may be due to a lack of free RAM in beta 10. I've prepared a new version with some RAM freed up. I hope to release it tonight or tomorrow.
I didn't have any WiFi disconnects since installing the WiFi firmware 1.20beta10 so I hope it is fixed finally.
To be fair this is first problematic release I've encountered so that's not bad going, it is quite a complex piece of software now.
this is my config.g
; Configuration file for Mini Kossel kit from Think3DPrint3D for testing Duet WiFi
; Communication and general
M111 S0 ; Debug off
M550 PKosselXXLWiFi ; Machine name and Netbios name (can be anything you like)
M551 Preprap ; Machine password (used for FTP)
;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
;*** Wifi Networking
M552 S1 ; Enable WiFiM555 P2 ; Set output to look like Marlin
M575 P1 B57600 S1 ; Comms parameters for PanelDueM586 P1 S1 ; Enable FTP
M586 P2 S1 ; Enable TelnetG21 ; Work in millimetres
M83 ; ...but relative extruder moves; Axis and motor configuration
M569 P3 S0 ; Drive 3 goes forwards
M569 P4 S0 ; Drive 4 goes forwards
M574 X2 Y2 Z2 S0 ; set endstop configuration (all endstops at high end, active high)
;*** The homed height is deliberately set too high in the following - you will adjust it during calibration;M665 L503.000 R245.982 H575.060 B132.5 X0.022 Y0.073 Z0.000 ; set delta radius, diagonal rod length, printable radius and homed height
;M666 X-0.056 Y-0.024 Z0.079 A0.00 B0.00 ; put your endstop adjustments here, as given by auto calibrationM665 L503.000 R245.965 H589.90 B132.5 X0 Y0 Z0.000
M666 X0.08 Y0.01 Z-0.09 A0 B0;M350 X16 Y16 Z16 E16 I1 ; Set 16x microstepping with interpolation
;M92 X100 Y100 Z100 ; Set axis steps/mmM350 X16 Y16 Z16 E16 I1 ; Set 16x microstepping with interpolation
M92 X100 Y100 Z100 ; Set axis steps/mmM906 X1400 Y1400 Z1400 E1400:1400 I60 ; Set motor currents (mA) and increase idle current to 60%
M201 X1800 Y1800 Z1800 E800 ; Accelerations (mm/s^2)
M203 X18000 Y18000 Z18000 E4600 ; Maximum speeds (mm/min)
M566 X900 Y900 Z900 E1800 ; Maximum instant speed changes mm/minute; Thermistors
M305 P2 T100000 B4388 R4700 H0 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction; Fans
;M106 P1 H-1 ; disable thermostatic mode for fan 1
M106 P1 L255 S255 H1 T45
;M106 P2 L255 S255 H0:1:2 T40M106 P0 L255 S255 H100:101 T35 ; defino al fan 2(el que esta en la caja de la electronica como termostatico y controlado por la temperatura de la CPU y de los STEPPER DRIVERS)
; Tool definitionsM563 P0 D0 H1 F2 ; Define tool 1
G10 P0 S0 R0 X0 Y0 ; set tool 0 temperatures and offsets
M563 P1 D1 H1 F2 ; tool 0 uses extruder drive 0 and heater 1 y Fan 2 en lugar de 0 ya que esta quemado
G10 P1 S0 R0 X0 Y0 ; Set tool 1 temperatures and offsets;M92 E663:663 ; Set extruder steps per mm
;M92 E146:418.5:663:663:663:663
;M92 E146:837:663:663:663:663
;M92 E146:830:663:663:663:663
;M92 E806:806:663:663:663:663
M92 E804:804:663:663:663:663; Z probe and compensation definition
;*** If you have a switch instead of an IR probe, change P1 to P4 in the following M558 command
;M558 P1 X0 Y0 Z0 ; Z probe is an IR probe and is not used for homing any axes
;G31 X0 Y0 Z4.80 P500 ; Set the zprobe height and threshold (put your own values here)
M558 P1 X0 Y0 Z0 ; Z probe is a DC42 Differential IR PCB and is not used for homing any axes
G31 X0 Y0 Z0.490 P500 ; Set the zprobe height and threshold (put your own values here);*** If you are using axis compensation, put the figures in the following command
;M556 S78 X0 Y0 Z0 ; Axis compensation hereM208 S1 Z-0.2 ; set minimum Z
;M579: Scale Cartesian axes
;On a Cartesian RepRap you can get prints exactly the right size by tweaking the axis steps/mm using the M92 G Code above. But this does not work so easily for Delta and other RepRaps for which there is cross-talk between the axes. This ;command allows you to adjust the X, Y, and Z axis scales directly. So, if you print a part for which the Y length should be 100mm and measure it and find that it is 100.3mm long then you set Y0.997 (= 100/100.3).M579 X1.012 Y1.012 Z1
; Configurar la retraccion por hardware
;M207 S4.0 R-0.1 F3600 T1200 Z0.075
M207 S4.5 R-0.2 F2600 T1800 Z0.09
;M207 S4 R-0.05 F2200 T1800 Z0.0;Pressure advance M572
M572 D0 S0.08
;M572 D1 S0.1;pid autotune parameters
;M307 H0 A141.2 C398.4 D1.9 B0
;M307 H1 A758.3 C275.8 D5.8 B0M570 H1 P5 T20
M557 R110 S22 ; definir un grid de radio 130 cada 22 mm para compenzar la cama
M581 E0 S0 T2 C1 ; configurar el trigger 2 con el sensor del Extrusor 0, activo cuando esta imprimiendo
M581 E1 S0 T3 C1 ; configurar el trigger 2 con el sensor del Extrusor 0, activo cuando esta imprimiendo
M404 N1.75 D0.4 ; setear diametro de filamento y de nozzleM912 P0 S-15.4 ; Calibrar temperatura de la CPU
DjDemonD: here are my Z probe repeatability metrics:
https://docs.google.com/spreadsheets/d/15TNWrQdryhAFkfltrYofC_Zl10F0TGuRSZ4mP1esJtI/edit?usp=sharingOverall, my BLTouch clone achieves a range of about 60-50µm, and a standard-deviation of less than 15µm.
1.20beta10 with Z-Probe type 8 didn't change very much for me though.
Biggest impact was probing speed and maybe my latest upgrade to Tr8x2. -
Thank you that's very interesting. So it seems best case scenario it's about 50 microns as expected.
I too have had the shift while printing after upgrading to 1.20 beta 10. I changed back to an earlier version and the shift went away. I tried the same print 3 times with shift each timeā¦.
My printer is cartesian
