    Toolboard keeps loosing heater 1
    914
    • wdenkerundefined
      wdenker @jay_s_uk
      @jay_s_uk because the m122 was pulled for one before the power was pulled and one after.
      www.bd3dcustoms.com | BD3DCUSTOMS Supercube
        jay_s_uk @wdenker
        @wdenker its probably a communication/cable issue anyway but you won't know with 3.4.5 as it doesn't tell you
        wdenkerundefined 1 Reply Last reply Reply Quote 0
        • wdenkerundefined
          wdenker @jay_s_uk
          @jay_s_uk the can cable communication light never blinks irratic. We originally had an issue with the can connection. We have resolved it since and now getting this error vs stuff just stopping like it lost connection briefly. Which is how a bad can cable presents itself.
            jay_s_uk @wdenker
            @wdenker update to 3.5b4 so you can see if there are any reports of a CAN board not communicating.
            wdenkerundefined 1 Reply Last reply Reply Quote 1
            • wdenkerundefined
              wdenker @jay_s_uk
              @jay_s_uk found a good indicator... I2C bus errors 1 is what shows when it is having the issue, errors 0 when not having the issue. So am I safe to assume it is can connection again even though nothing else indicating can connection issues? I also updated to 3.5.0-beta.4 and am not getting any notifications about can timeout or connection issues which I would have expected.
              • wdenkerundefined
                wdenker @wdenker
                @wdenker @dc42 any insight?
                  T3P3Tony administrators @wdenker
                  @wdenker Do you have the opportunity to swap the toolboard in case its a hardware issue? The I2C bus error is not directly related to the heater (its used for the LIS3DH only, however its interesting that they happen at the same time.
                  How hot are you running the toolboard?
                  • wdenkerundefined
                    wdenker @T3P3Tony
                    @T3P3Tony we swapped to new board and still getting the same issue just not as frequent. So we then decided to swap the thermistor ports to a phoenix connector instead of the JST. Seems like this has resolved the issue. What else does that error indicate or work with other than the accelerometer?
                    dc42undefined wdenkerundefined 2 Replies Last reply Reply Quote 0
                      dc42 administrators @wdenker
                      @wdenker the message "Board 121 does not have heater 1" implies that the tool board has reset. The M122 B121 report indicates that it was not a firmware crash or other software reset, because the Last Software Reset Data is shown as "not available". So it must have been a watchdog reset, hardware reset, or power failure. Therefore, we need to see M122 reports for both boards before pulling the power, to determine the reason for the tool board reset. Please ask your customer to provide this next time the fault occurs.
                      • wdenkerundefined
                        wdenker @wdenker
                        @dc42 or @T3P3Tony Here are the M122 from each board prior to power restart. Looks like toolboard ran out of memory. 2023-06-21 10:39, reason: OutOfMemory, How do I resolve that?
                        M122
                        RepRapFirmware for Duet 3 MB6HC version 3.5.0-beta.4 (2023-06-08 23:41:30) running on Duet 3 MB6HC v1.02 or later (standalone mode)
                        Board ID: 08DJM-9P63L-DJ3S0-7J9D4-3SN6J-9UMZA
                        Used output buffers: 9 of 40 (40 max)
                        Static ram: 155012
                        Dynamic ram: 121824 of which 52 recycled
                        Never used RAM 67352, free system stack 122 words
                        Tasks: NETWORK(1,ready,33.0%,139) ETHERNET(5,nWait,2.1%,317) HEAT(3,nWait,1.3%,323) Move(4,nWait,88.6%,214) CanReceiv(6,nWait,1.7%,642) CanSender(5,nWait,2.0%,326) CanClock(7,delaying,0.3%,349) TMC(4,nWait,131.2%,59) MAIN(1,running,137.7%,137) IDLE(0,ready,0.5%,30), total 398.4%
                        Owned mutexes:
                        Last reset 50:22:42 ago, cause: power up
                        Last software reset at 2023-06-17 02:19, reason: User, Gcodes spinning, available RAM 68440, slot 1
                        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043c000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
                        Error status: 0x14
                        Aux0 errors 0,6,0
                        MCU temperature: min 30.3, current 40.2, max 43.8
                        Supply voltage: min 23.8, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                        12V rail voltage: min 11.9, current 12.2, max 12.6, under voltage events: 0
                        Events: 13 queued, 13 completed
                        Driver 0: standstill, SG min 0, mspos 976, reads 2699, writes 208 timeouts 0
                        Driver 1: standstill, SG min n/a, mspos 8, reads 2896, writes 11 timeouts 0
                        Driver 2: standstill, SG min 0, mspos 80, reads 2707, writes 200 timeouts 0
                        Driver 3: standstill, SG min 0, mspos 112, reads 2738, writes 169 timeouts 0
                        Driver 4: standstill, SG min 0, mspos 880, reads 2738, writes 169 timeouts 0
                        Driver 5: standstill, SG min 0, mspos 464, reads 2700, writes 208 timeouts 0
                        Date/time: 2023-06-21 11:11:07
                        Slowest loop: 1000.15ms; fastest: 0.05ms
                        === Storage ===
                        Free file entries: 18
                        SD card longest read time 4.5ms, write time 380.9ms, max retries 0
                        DMs created 125, segments created 73, maxWait 5933869ms, bed compensation in use: mesh, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
                        no step interrupt scheduled
                        === DDARing 0 ===
                        Scheduled moves 102436, completed 102436, hiccups 0, stepErrors 0, LaErrors 0, Underruns [341, 0, 24], CDDA state -1
                        === DDARing 1 ===
                        Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0
                        Heater 0 is on, I-accum = 0.0
                        Heater 2 is on, I-accum = 0.0
                        HTTP is idle in state(s) 0
                        Telnet is idle in state(s) 0
                        File is idle in state(s) 0
                        USB is idle in state(s) 0
                        Aux is idle in state(s) 0
                        Trigger is idle in state(s) 0
                        Queue is idle in state(s) 0
                        LCD is idle in state(s) 0
                        SBC is idle in state(s) 0
                        Daemon is idle in state(s) 0
                        Aux2 is idle in state(s) 0
                        File2 is idle in state(s) 0
                        Queue2 is idle in state(s) 0
                        Q0 segments left 0, axes/extruders owned 0x80000007
                        Code queue 0 is empty
                        Code queue 1 is empty
                        === CAN ===
                        Messages queued 7095317, received 5098900, lost 0, boc 56
                        Longest wait 5ms for reply type 6029, peak Tx sync delay 623, free buffers 50 (min 47), ts 906815/906786/0
                        Tx timeouts 0,0,0,0,0,0
                        === Network ===
                        Slowest loop: 8427.39ms; fastest: 0.03ms
                        Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                        HTTP sessions: 1 of 8
                        = Ethernet =
                        Interface state: active
                        Error counts: 0 0 0 1 0 0
                        Socket states: 5 2 2 2 2 2 0 2
                        = WiFi =
                        Interface state: disabled
                        Module is disabled
                        === Multicast handler ===
                        Responder is inactive, messages received 0, responses 0
                        M122 B121
                        Diagnostics for board 121:
                        Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-beta.4 (2023-06-08 16:22:30)
                        Bootloader ID: SAMC21 bootloader version 2.4 (2021-12-10)
                        All averaging filters OK
                        Never used RAM 1812, free system stack 88 words
                        Tasks: Move(3,nWait,0.7%,111) HEAT(2,nWait,0.1%,101) CanAsync(5,nWait,0.0%,54) CanRecv(3,nWait,0.1%,75) CanClock(5,nWait,0.0%,66) ACCEL(3,nWait,0.0%,53) TMC(2,delaying,3.1%,57) MAIN(1,running,90.8%,444) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.1%,142), total 100.0%
                        Last reset 00:10:46 ago, cause: power up
                        Last software reset at 2023-06-21 10:39, reason: OutOfMemory, available RAM 12, slot 0
                        Software reset code 0x01c0 ICSR 0x00000000 SP 0x200054a8 Task Move Freestk 137 ok
                        Stack: 20005600 000062df 00000000 2000554c a5a5a5a5 00009f99 00000000 00008a67 0001f1c6 00000000 477e8400 477e8400 0000005b 007e8400 a625a5a5 a5a5a5a5 0001ee68 477e8400 477fa700 2e57b417 2e57b417 2000554c 20007100 20005108 3627cde7 00008c77 bdd53594
                        Driver 0: pos 0, 80.0 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 59686, writes 9, timeouts 3, DMA errors 0, CC errors 0, failedOp 0x72, steps req 0 done 1157273
                        Moves scheduled 13624, completed 13624, in progress 0, hiccups 468, step errors 0, maxPrep 602, maxOverdue 2022819261, maxInc 2022780880, mcErrs 0, gcmErrs 0, ebfmin 0.00, ebfmax 1.00
                        Peak sync jitter 0/5, peak Rx sync delay 261, resyncs 0/0, no timer interrupt scheduled
                        VIN voltage: min 24.6, current 24.7, max 24.8
                        MCU temperature: min 58.7C, current 60.5C, max 61.1C
                        Last sensors broadcast 0x00000000 found 0 30 ticks ago, 0 ordering errs, loop time 0
                        CAN messages queued 5200, send timeouts 0, received 19467, lost 0, free buffers 18, min 16, error reg 0
                        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 837, adv -2022819048/74672
                        Accelerometer: LIS3DH, status: 00
                        I2C bus errors 0, naks 3, other errors 0
                        Diagnostics for board 1:
                        Duet EXP3HC rev 1.02 or later firmware version 3.5.0-beta.4 (2023-06-08 16:24:05)
                        Bootloader ID: SAME5x bootloader version 2.3 (2021-01-26b1)
                        Never used RAM 156016, free system stack 172 words
                        Tasks: Move(3,nWait,1.1%,104) HEAT(2,nWait,1.2%,82) CanAsync(5,nWait,0.0%,67) CanRecv(3,nWait,1.4%,79) CanClock(5,nWait,0.4%,70) TMC(2,nWait,135.7%,69) MAIN(1,running,46.7%,456) IDLE(0,ready,0.0%,40) AIN(2,delaying,61.7%,265), total 248.2%
                        Last reset 50:23:10 ago, cause: power up
                        Last software reset data not available
                        Driver 0: pos -6382700, 320.0 steps/mm, standstill, SG min 0, mspos 464, reads 3139, writes 165 timeouts 0, steps req 6 done 4042678
                        Driver 1: pos -6382777, 320.0 steps/mm, standstill, SG min 0, mspos 880, reads 3140, writes 165 timeouts 0, steps req 6 done 4042745
                        Driver 2: pos 0, 80.0 steps/mm, standstill, SG min 0, mspos 8, reads 3295, writes 11 timeouts 0, steps req 0 done 0
                        Moves scheduled 1377083, completed 1377083, in progress 0, hiccups 0, step errors 0, maxPrep 52, maxOverdue 41, maxInc 11, mcErrs 0, gcmErrs 0, ebfmin 0.00, ebfmax 0.00
                        Peak sync jitter -8/9, peak Rx sync delay 188, resyncs 0/0, no timer interrupt scheduled
                        VIN voltage: min 24.2, current 24.3, max 24.4
                        V12 voltage: min 12.3, current 12.3, max 12.4
                        MCU temperature: min 43.1C, current 47.2C, max 51.2C
                        CAN messages queued 1451192, send timeouts 0, received 3716073, lost 0, free buffers 38, min 38, error reg ff0000
                        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 420, adv 8041/74573
                        jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
                          jay_s_uk @wdenker
                          @wdenker see this thread https://forum.duet3d.com/topic/32694/3-5-0-b4-having-random-can-error-timeouts/14
                          • wdenkerundefined
                            wdenker @jay_s_uk
                            @jay_s_uk already have tried that.
                              @wdenker the out of memory issue is new in firmware 3.5.0-beta.4. If you have already tried using a less demanding input shaping method then I suggest you revert to firmware 3.4.5 on the main board (and 3.4.4 on the tool board, which is the version included in the 3.4.5 release). Then when the problem happens again, get a M122 B121 report again before powering down.
                              • wdenkerundefined
                                wdenker @dc42
                                @dc42 Reverted as it just happened again after trying yet another input shaper. Will get those M122's as soon as it happens again.
                                • wdenkerundefined
                                  wdenker @wdenker
                                  @dc42 @T3P3Tony Here are the latest M122's
                                  M122
                                  RepRapFirmware for Duet 3 MB6HC version 3.4.5 (2022-11-30 19:35:23) running on Duet 3 MB6HC v1.02 or later (standalone mode)
                                  Used output buffers: 3 of 40 (40 max)
                                  Static ram: 152760
                                  Dynamic ram: 99104 of which 0 recycled
                                  Never used RAM 97800, free system stack 112 words
                                  Tasks: NETWORK(ready,160.6%,230) ETHERNET(notifyWait,0.3%,566) HEAT(notifyWait,0.1%,322) Move(notifyWait,7.6%,245) CanReceiv(notifyWait,0.1%,774) CanSender(notifyWait,0.1%,328) CanClock(delaying,0.0%,339) TMC(notifyWait,42.8%,57) MAIN(running,270.6%,925) IDLE(ready,0.0%,30), total 482.3%
                                  Owned mutexes:
                                  Last reset 02:00:49 ago, cause: software
                                  Last software reset at 2023-06-21 12:35, reason: User, GCodes spinning, available RAM 66660, slot 2
                                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
                                  Error status: 0x04
                                  Aux0 errors 0,1,0
                                  Step timer max interval 202
                                  MCU temperature: min 40.4, current 44.4, max 44.9
                                  Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                                  12V rail voltage: min 11.9, current 12.2, max 12.5, under voltage events: 0
                                  Events: 0 queued, 0 completed
                                  Driver 0: standstill, SG min 0, mspos 976, reads 64534, writes 29 timeouts 0
                                  Driver 1: standstill, SG min n/a, mspos 8, reads 64563, writes 0 timeouts 0
                                  Driver 2: standstill, SG min 0, mspos 112, reads 64534, writes 29 timeouts 0
                                  Driver 3: standstill, SG min 0, mspos 784, reads 64540, writes 23 timeouts 0
                                  Driver 4: standstill, SG min 0, mspos 880, reads 64540, writes 23 timeouts 0
                                  Driver 5: standstill, SG min 0, mspos 464, reads 64534, writes 29 timeouts 0
                                  Date/time: 2023-06-21 17:16:04
                                  Slowest loop: 209.40ms; fastest: 0.05ms
                                  === Storage ===
                                  Free file entries: 9
                                  SD card longest read time 3.2ms, write time 2.6ms, max retries 0
                                  DMs created 125, segments created 42, maxWait 164204ms, bed compensation in use: mesh, comp offset 0.000
                                  === MainDDARing ===
                                  Scheduled moves 155342, completed 155342, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
                                  === AuxDDARing ===
                                  Segments left: 0
                                  Movement lock held by null
                                  Code queue is empty
                                  === CAN ===
                                  Messages queued 218281, received 163468, lost 0, boc 0
                                  Longest wait 5ms for reply type 6024, peak Tx sync delay 398, free buffers 50 (min 38), ts 36122/36122/0
                                  === Network ===
                                  Slowest loop: 97.78ms; fastest: 0.03ms
                                  Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                                  = Ethernet =
                                  State: active
                                  Error counts: 0 0 0 0 0 0
                                  = WiFi =
                                  Network state is disabled
                                  WiFi module is disabled
                                  Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
                                  M122 B1
                                  Duet EXP3HC rev 1.02 or later firmware version 3.4.4 (2022-10-14 11:45:56)
                                  Never used RAM 158896, free system stack 173 words
                                  Tasks: Move(notifyWait,0.1%,100) HEAT(notifyWait,0.1%,88) CanAsync(notifyWait,0.0%,69) CanRecv(notifyWait,0.1%,80) CanClock(notifyWait,0.0%,71) TMC(notifyWait,36.7%,65) MAIN(running,56.6%,441) IDLE(ready,0.0%,40) AIN(delaying,6.3%,263), total 100.0%
                                  Last reset 02:01:37 ago, cause: software
                                  Driver 0: pos -1065745, 320.0 steps/mm,standstill, SG min 0, mspos 176, reads 16761, writes 21 timeouts 0, steps req 1235155 done 169673
                                  Driver 1: pos -1065716, 320.0 steps/mm,standstill, SG min 0, mspos 272, reads 16760, writes 21 timeouts 0, steps req 1235126 done 169644
                                  Driver 2: pos 0, 80.0 steps/mm,standstill, SG min n/a, mspos 8, reads 16782, writes 0 timeouts 0, steps req 0 done 0
                                  Moves scheduled 42040, completed 42040, in progress 0, hiccups 0, step errors 0, maxPrep 66, maxOverdue 35, maxInc 35, mcErrs 0, gcmErrs 0
                                  Peak sync jitter -7/7, peak Rx sync delay 181, resyncs 0/0, no step interrupt scheduled
                                  VIN voltage: min 24.2, current 24.2, max 24.3
                                  MCU temperature: min 47.0C, current 50.8C, max 51.4C
                                  Last sensors broadcast 0x00000000 found 0 97 ticks ago, 0 ordering errs, loop time 0
                                  CAN messages queued 58031, send timeouts 0, received 123113, lost 0, free buffers 37, min 37, error reg 0
                                  dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 418, adv 26976/74562
                                  M122 B121
                                  Duet TOOL1LC rev 1.1 or later firmware version 3.4.4 (2022-10-14 11:46:33)
                                  Never used RAM 3080, free system stack 45 words
                                  Tasks: Move(notifyWait,0.8%,91) HEAT(notifyWait,0.1%,115) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.2%,74) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,3.1%,57) MAIN(running,90.8%,441) IDLE(ready,0.0%,26) AIN(delaying,5.0%,142), total 100.0%
                                  Last reset 00:26:20 ago, cause: power up
                                  Last software reset at 2023-06-21 14:12, reason: OutOfMemory, available RAM 8, slot 1
                                  Software reset code 0x01c0 ICSR 0x00000000 SP 0x20005280 Task Move Freestk 155 ok
                                  Stack: 20005390 000062df 200053a8 200074c0 200053a8 00009f99 200052dc 00008d73 be2b253d 47c27f00 47c27f00 be2b253d 000184fe 000184fe 00000000 000184fe 00046115 200074c0 20007700 200052dc 00000001 0000939f 00000001 3dd96ede 3f64d224 47c27f00 488c22a0
                                  Driver 0: pos 2363156, 80.0 steps/mm,standstill, SG min 0, read errors 1, write errors 0, ifcnt 10, reads 64693, writes 10, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x41, steps req 2938952 done 2938952
                                  Moves scheduled 34177, completed 34177, in progress 0, hiccups 0, step errors 0, maxPrep 674, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                                  Peak sync jitter 0/5, peak Rx sync delay 222, resyncs 0/0, no step interrupt scheduled
                                  VIN voltage: min 24.6, current 24.6, max 24.8
                                  MCU temperature: min 60.9C, current 62.3C, max 63.0C
                                  Last sensors broadcast 0x00000000 found 0 24 ticks ago, 0 ordering errs, loop time 0
                                  CAN messages queued 12812, send timeouts 0, received 48548, lost 0, free buffers 37, min 36, error reg 0
                                  dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 695, adv 35663/74657
                                  • wdenkerundefined
                                    wdenker @wdenker
                                    @dc42 swapped to a new board and same thing.
                                    M122 B121
                                    6/22/2023, 5:36:59 AM M122 B121
                                    Tasks: Move(notifyWait,0.0%,91) HEAT(notifyWait,0.4%,115) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.1%,74) CanClock(notifyWait,0.1%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,18.9%,57) MAIN(running,49.4%,431) IDLE(ready,0.0%,26) AIN(delaying,31.1%,142), total 100.0%
                                    Last reset 01:53:16 ago, cause: power up
                                    Last software reset time unknown, reason: OutOfMemory, available RAM 14200, slot 1
                                    Software reset code 0x01c0 ICSR 0x00000000 SP 0x20002dd0 Task MAIN Freestk 804 ok
                                    Stack: 00004000 00005e33 00004000 000041cf a5a5a5a5 00004000 a5a5a5a5 a5a5a5a5 a5a5a5a5 0001c4c9 a5a5a5a5 0001c4e5 a5a5a5a5 000059f7 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
                                    Driver 0: pos 7117, 80.0 steps/mm,standstill, SG min 0, read errors 0, write errors 0, ifcnt 10, reads 55949, writes 10, timeouts 0, DMA errors 0, CC errors 0, steps req 9931 done 9931
                                    Moves scheduled 184, completed 184, in progress 0, hiccups 0, step errors 0, maxPrep 466, maxOverdue 328597857, maxInc 328559880, mcErrs 0, gcmErrs 0
                                    Peak sync jitter 0/5, peak Rx sync delay 215, resyncs 0/0, no step interrupt scheduled
                                    VIN voltage: min 24.1, current 24.1, max 24.3
                                    MCU temperature: min 59.0C, current 59.9C, max 66.7C
                                    Last sensors broadcast 0x00000000 found 0 145 ticks ago, 0 ordering errs, loop time 0
                                    CAN messages queued 54402, send timeouts 0, received 61362, lost 0, free buffers 37, min 37, error reg 0
                                    dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 421, adv -328597601/74643
                                    • wdenkerundefined
                                      wdenker @wdenker
                                      @dc42 @T3P3Tony turned of input shaping completely and still getting the issue.
                                      M122 B121
                                      Tasks: Move(notifyWait,1.2%,91) HEAT(notifyWait,0.1%,115) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.2%,74) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,3.1%,57) MAIN(running,90.4%,441) IDLE(ready,0.0%,26) AIN(delaying,5.1%,142), total 100.0%
                                      Last reset 00:15:20 ago, cause: power up
                                      Driver 0: pos 1648380, 80.0 steps/mm,standstill, SG min 0, read errors 0, write errors 0, ifcnt 10, reads 63259, writes 10, timeouts 0, DMA errors 0, CC errors 0, steps req 1890774 done 1890774
                                      Moves scheduled 26912, completed 26912, in progress 0, hiccups 0, step errors 0, maxPrep 665, maxOverdue 38680857, maxInc 38680857, mcErrs 0, gcmErrs 0
                                      Peak sync jitter 0/7, peak Rx sync delay 219, resyncs 0/0, no step interrupt scheduled
                                      VIN voltage: min 24.1, current 24.1, max 24.2
                                      MCU temperature: min 53.0C, current 53.0C, max 70.8C
                                      Last sensors broadcast 0x00000000 found 0 14 ticks ago, 0 ordering errs, loop time 0
                                      CAN messages queued 7817, send timeouts 0, received 35628, lost 0, free buffers 37, min 36, error reg 0
                                      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 567, adv -38680490/74658
                                        @wdenker all your recent M122 reports show the last reset cause as power up. Assuming you are not deliberately powering down and up again before you run M122, this suggests that either there is a problem with the power supply feed to the tool board (for example, a bad crimp connection), or the 5V rail of the tool board is being overloaded by something connected to the tool board and this is causing the 5V regulator to go into thermal shutdown.
                                        • wdenkerundefined
                                          wdenker @dc42
                                          @dc42 why does it show out of memory then?
