    BL TOUCH NOT WORKING.
    IR Height Sensor
    1.6k
    • oldironjunkieundefined
      oldironjunkie @droftarts
      @droftarts Wi change as necessary later today. Have some appointments I need to make ths afternoon.
        droftarts administrators @oldironjunkie
        @oldironjunkie See where the white and black wires go here?
        oldironjunkieundefined 2 Replies Last reply Reply Quote 0
          @droftarts I have accomplished all the items. Rehooked up the power and ground to the Z-probe header. Rechecked all the wiring. Self test still peforms flawlessly. The static tect to check the probe failed. The probe will not deploy with either the M401 or the M280 P0 S10 commands. I rechecked the voltages all ok. Question I have is this. Do I need to do anything with the Z stop header. I currently have a z stop intsalled and hooked up (needed to print something asap).
          ;General preferences
          M575 P1 S1 B57600                                               ; enable support for PanelDue
          G90                                                             ; send absolute coordinates...
          M83                                                             ; ...but relative extruder moves
          M550 P"OLDIRON PRINTER"                                         ; set printer name
          ;Network
          M552 S1                                                         ; enable network
          M586 P0 S1                                                      ; enable HTTP
          M586 P1 S0                                                      ; disable FTP
          M586 P2 S0                                                      ; disable Telnet
          ;Drives
          M569 P0 S0                                                       ; physical drive 0 goes backwards
          M569 P1 S1                                                       ; physical drive 1 goes forwards
          M569 P2 S0                                                       ; physical drive 2 goes backwards
          M569 P3 S0                                                       ; physical drive 3 goes backwards
          M569 P4 S1													     ; physical drive 4 goes forwards
          ;M569 P3 S0                                                      ; physical drive 3 goes backwards
          M584 X0 Y1 Z2 E4:4:4:4                                           ; set drive mapping
          M350 X16 Y16 Z16 E8:8:8:8 I1                                     ; configure microstepping with interpolation
          M92 X79.68 Y79.44 Z400.00 E8440:454.00:454.00:454.00             ; set steps per mm
          M566 X900.00 Y900.00 Z900.00 E1600.00:1600.00:1600.00:1600.00    ; set maximum instantaneous speed changes (mm/min)
          M203 X4000.00 Y4000.00 Z1500.00 E4000.00:4000.00:4000.00:4000.00 ;set maximum speeds (mm/min)
          M201 X1000.00 Y1000.00 Z350.00 E600.00:600.00:600.00:600.00      ; set accelerations (mm/s^2)
          M906 X1000 Y1000 Z1000 E800:800:800:800 I50                      ; set motor currents (mA) and motor idle factor in per cent
          M84 S300                                                         ; Set idle timeout
          ;Axis Limits
          M208 X5 Y5 Z0 S1                                                ; set axis minima
          M208 X330 Y300 Z400 S0                                          ; set axis maxima
          ;Endstops
          M574 X1 S1 P"!xstop"                                             ; configure active-(high) LOW endstop for low end on X via pin xstop
          M574 Y1 S1 P"!ystop"                                             ; configure active-(high) LOW endstop for low end on Y via pin ystop
          M574 Z1 S1 P"!zstop"                                             ; configure active-(high) LOW endstop for low end on Z via pin zstop
          ;Z-Probe
          M950 S0 C"duex.pwm1"                                            ; Duet 2 WiFi/Ethernet + DueX2/5
          M558 P9 C"^zprobe.in" H5 F120 T6000 							; Duet 2 WiFi/Ethernet, DueX2/5
          G31 X40 Y0 Z2.5 P25												;probe offsets, trigger height and trigger value
          M557 X15:300 Y15:235 S30                                        ;define mesh grid
          ;Heaters
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4138                  ; configure sensor 0 as thermistor on pin bedtemp
          M950 H0 C"bedheat" T0                                           ; create bed heater output on bedheat and map it to sensor 0
          M307 H0 B0 S1.00                                                ; enable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                                         ; map heated bed to heater 0
          M143 H0 S120                                                    ; set temperature limit for heater 0 to 120C
          M308 S1 P"e0temp" Y"thermistor" T100000 B4138                   ; configure sensor 1 as thermistor on pin e0temp
          M950 H2 C"e0heat" T1                                            ; create nozzle heater output on e0heat and map it to sensor 1
          M307 H2 R2.584 C226.4 D8.23 S.5 V24.3							;tool heat
          ;M307 H1 B1 S.70                                                ; enable bang-bang mode for heater  and set PWM limit
          M143 H2 S350                                                    ; set temperature limit for heater 1 to 350C
          ;Fans
          M950 F0 C"fan0"                                                 ; create fan 0 on pin fan0 and set its frequency
          M106 P0 S.75 H-1 Q500                                           ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"fan1" Q500                                            ; create fan 1 on pin fan1 and set its frequency
          M106 P1 S.75 H-1 Q500                                           ; set fan 1 value. Thermostatic control is turned on
          ;Tools
          M563 P1 D1 H2 F0                           			 			; define tool 1
          M572 D0 S0.06									                ;ADDED PRESSURE ADVANCE SETTING
          G10 P1 R0 S0
          M501                                                            ; load saved parameters from non-volatile memory
          M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"              ; set voltage thresholds and actions to run on power loss
          T1                                                              ; select first tool
          G10 P0 X0 Y0 Z0                                           		; set tool 0 axis offsets
          ; deployprobe.g
          M280 P0 S10 				;code for deploying the Z probe
          ; retractprobe.g
          M280 P0 S90     			;code for retracting the Z probe
          Thye last 2 commands are in the system directory (is that where they belong)
          Any other ideas?
            @droftarts Sorry I sent the wrong config.g file hee is the correct one.
            ;Network
            ;Drives
            ;Axis Limits
            ;Endstops
            ;Z-Probe
            M558 P9 C"^zprobe.in" H3 F100 T9000 R0.5						; Duet 2 WiFi/Ethernet, DueX2/5
            ;Heaters
            ;Fans
            ;Tools
            G10 P1 R0 S0
              @oldironjunkie did you do this?
              Also, if you have a Duex v0.9 or v0.9a board, check that you have a jumper on the "5V AUX JUMPER SELECT PINS" between the 5V AUX and 5V INT pins. Without this, the PWM connector doesn't get 5V.
                @droftarts there is a jumper between pins marked "5V INT" and "5V AUX" . the header is between the endstop E2-E6 headers and the thermistor E2-E6 headers
                  @droftarts I also checked the voltage manuall with a meter and I have 4.96V dc
                    @oldironjunkie Can you post pictures of how it is wired now?
                    Can you send M98 P"config.g" and post the response from the console?
                    Edit: check the continuity of each of the wires, to make sure all of them are making a connection.
                    oldironjunkieundefined 1 Reply Last reply Reply Quote 0
                      A Former User
                      This post is deleted!
                        oldironjunkie
                        @droftarts Thanks for the response. I id find a bad connection in the tiny 5 pin factory connection on the BL touch. I fixed it by replacing the harnes with a known good one. Rechecked all and it is ok. The probe now expends and retracts with the M401 and M402 commands as it should. I did the calibration set up and I can home all axis. @ questions.How do I get to home the X and Y at the endstops in th upper right corner (where it is now) but I cannot get the z to home to the pin unless I run a G30 from the console. Also at the same time I would like to probe the z in the center of the bed (A150 and Y150) as this is where most of my prints start. Below are my homeall.g file and homez.g files. I only added the commands I need. Not sure what I need to add or comment out. Also once I get it al working correctly where do I enter the offset from the Bl touch to the nozzle. It is a consistent .59. Sorry about the questions but I am completely at a loss at this time.
                        ; homeall.g
                        ; called to home all axes
                        ; generated by RepRapFirmware Configuration Tool v3.3.3 on Wed Sep 29 2021 16:53:30 GMT-0500 (Central Daylight Time)
                        G1 H2 Z5 F6000          ; lift Z relative to current position
                        G1 H1 X-302 Y-302 F6000 ; move quickly to X and Y axis endstops and stop there (first pass)
                        G1 H2 X5 Y5 F6000       ; go back a few mm
                        G1 H1 X-302 Y-302 F180  ; move slowly to X and Y axis endstops once more (second pass)
                        G30 S-1
                        ; homez.g
                        ; called to home the Z axis
                        M98 P"homeall.g"                             ; Call the home X & Y macro to home those axes first
                        M98 P"deployprobe.g"                          ; Called to extend the BL-Touch probe pin to allow probing to take place
                        G30 S-1                                         ; Home the Z axis by probing the bed
                        M98 P"retractprobe.g"
                        • oliofundefined
                          oliof @oldironjunkie
                          @oldironjunkie 2 questions
                          1. why are your macros called extendpin.g and not deployprobe.g? Likewise for retractpin.g and retractprobe.g...
                          2. Why are you not using M401/M402 but M98 P"deployprobe.g" and M98 P"retractprobe.g"?
                          A Former User? oldironjunkieundefined 2 Replies Last reply Reply Quote 1
                            A Former User @oliof
                              oldironjunkie @oliof
                              @oliof I was using those names beacause that is what I was sent by a friend of mine. It has changes since. I will post the final files once it is done, working and tested. I am in the process of doing that now but unfortunatly life just gets in the way.
                              • oliofundefined
                                oliof @A Former User
                                @Herve_Smith M401/M402 means the firmware properly tracks whether the probe is active or not. The canonical macro names to configure these G-Codes is retractprobe.g/deployprobe.g because this was implemented before BLTouch was a thing. So its not just a question of using an aesthetically pleasing or logically right name. And in a thread called "BLTOUCH NOT WORKING" I am asking the OP -- not you -- if there is a reason for them deviating from these canonical ways.
                                I hope that helps you understand why I am asking the questions I am asking.
                                • oliofundefined
                                  @oldironjunkie life getting in the way is what happens to all of it, no worries. I would suggest using the canonical names for those macros and using M401/M402 to rule out any weird misses from mismatching macros, names and firmware expectations.
                                      @droftarts I finally got it working. I had a bad factor BL touch harness to begin with (I have a replacement coming). Before I found out that I messed with everything and got everything out of wack. I should have followed instructions and approached things logically. I now have a bed level height file, homing works great including the Z axis and my first and second prints came out great. I still have to mess with pressure advance (I just installed a new extruder) and dial in the Z height. Thanks to all that helped I really appreciate that. As for the final files here they are.
                                      ;Network
                                      ;Drives
                                      M92 X79.68 Y79.44 Z400.00 E820.0:454.00:454.00:454.00             ; set steps per mm
                                      ;Axis Limits
                                      M208 X320 Y300 Z400 S0                                          ; set axis maxima
                                      ;Endstops
                                      ;Z-Probe
                                      G31 X0 Y-40 Z.6 P25												;probe offsets, trigger height and trigger value
                                      M557 X1:320 Y1:250 S30                                        ;define mesh grid
                                      ;Heaters
                                      ;Fans
                                      ;Tools
                                      M572 D0 S0.004									                ;ADDED PRESSURE ADVANCE SETTING
                                      G10 P1 R0 S0
                                      ; deployprobe.g
                                      ; retractprobe.g
                                      ; homeall.g
                                      G1 X150 Y150 F5000
                                      G30
                                      ;G91                    ; relative positioning
                                      ;G1 Z5 F100             ; lift Z relative to current position
                                      ;G90                    ; absolute positioning
                                      ; homez.g
                                      G30                                          ; Home the Z axis by probing the bed
                                        A Former User
                                        • oliofundefined
                                          Haha, I am the pedantic one. Sure (-: Have a nice day, Herve.
                                            @oldironjunkie Great, glad you got it going! I had been over your config and wiring a number of times, which made me think it was a faulty connection somewhere. A few notes:
                                            If you're homing to the back right, your prints will come out rotated 180 degrees. Generally the origin is at the front left of the machine, so a positive X move moves the nozzle to the right, and a positive Y move moves the nozzle away from the front (or bed towards the front if you have a bed that moves in Y). Yours is moving the other way, which is not really a problem, just so long as you are aware of this. You can change this if you want; let me know and I'll show you where to make changes.
                                            You spotted that it should be G30, not G30 S-1, in your homing files.
                                            Setting the probe as M558 P9 means that the firmware knows it needs to deploy and retract the probe. You don't need to tell it to do it, either with 'deployprobe.g' or 'retractprobe.g' (these are the macros names used, any others will be ignored) or M401/M402. When you sent G30 from the console, it deployed, probed, and retracted without the need to run the other macros and commands, right?
                                            You found how to set the probe offset, using G31. For more details, see https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_testing
                                            You found how to move the nozzle to the centre of the bed. However, because you have put this directly after the homing moves, moves are still in relative mode. Add G90 before your G1 centring move to switch back to absolute positioning, ie
                                            G1 X150 Y150 F5000      ; move to centre
                                            G30
                                            There is an odd bit in your config; you have defined four extruder drivers, but they are all the same drive. And then set the parameters for them in the subsequent gcodes:
                                            You are also using the second of these in your single tool:
                                            D1 is the second extruder drive; D0 is the first. Unless you're going to add the extra extruders/tools (you do have a Duex after all) I'd clean this up by removing the drives you aren't using, and the extra parameters you have put in the other gcodes. eg:
                                            M584 X0 Y1 Z2 E4                                      ; set drive mapping
                                            M350 X16 Y16 Z16 E8 I1                                     ; configure microstepping with interpolation
                                            M92 X79.68 Y79.44 Z400.00 E454.00             ; set steps per mm
                                            M566 X900.00 Y900.00 Z900.00 E1600.00    ; set maximum instantaneous speed changes (mm/min)
                                            M203 X4000.00 Y4000.00 Z1500.00 E4000.00 ;set maximum speeds (mm/min)
                                            M201 X1000.00 Y1000.00 Z350.00 E600.00      ; set accelerations (mm/s^2)
                                            M906 X1000 Y1000 Z1000 E800 I50                      ; set motor currents (mA) and motor idle factor in per cent
                                            ;Tools
                                            M563 P1 D0 H2 F0                      ; define tool 1
                                            You currently have pressure advance set on D0, while the tool is using D1, so your pressure advance value isn't doing anything.
                                            Hope that helps!
