    Z offset changing every time I turn the printer on
    • Poloundefined
      Polo
      HI All
      I can't figure out what to do, every time I turn the printer on my Z offset change. I did follow the duet instruction how to adjust the z offset and change it on my config g. what do I'm missing ??
      Any help will be appreciated.
      Here is my config.g
      G90                                     ; send absolute coordinates...
      M83                                     ; ...but relative extruder moves
      M550 P"V-Core3"                         ; set printer name
      M669 K1                                 ; CoreXY
      G21                                     ; Set Units to Millimeters
      M552 S1                                 ; enable network
      M586 P0 S1                              ; enable HTTP
      M586 P1 S0                              ; disable FTP
      M586 P2 S0                              ; disable Telnet
      M569 P0.0 S0                            ; physical drive 0.0 goes forwards
      M569 P0.1 S0                            ; physical drive 0.1 goes forwards
      M569 P0.2 S0                            ; physical drive 0.2 goes forwards
      M569 P0.3 S1                            ; physical drive 0.3 goes forwards
      M569 P0.4 S1                            ; physical drive 0.4 goes forwards
      M569 P0.5 S0                            ; physical drive 0.5 goes forwards
      M584 X0.4 Y0.3 Z0.0:0.1:0.2 E0.5        ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z800.00 E100.0        ; set steps per mm
      M906 X1600 Y1600 Z1600 I30              ; set motor currents (mA) and motor idle factor in per cent -- safe for Duet 3 mini 5+
      M84 S30                                 ; Set idle timeout
      M566 X1000.00 Y1000.00 Z60.00 E3000.00 P1          ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z1000.00 E7200     ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z100.00 E10000        ; set accelerations (mm/s^2)
      M208 X0 Y0 Z0 S1                               ; set axis minima
      M208 X510 Y500 Z500 S0                         ; set axis maxima
      M574 X1 S1 P"io0.in"                           ; configure active high endstops
      M574 Y2 S1 P"io1.in"                           ; configure active high endstops
      M564 H0
      M671 X-4.5:250:504.5 Y-4.52:505:-4.52 S5       ; define positions of Z leadscrews or bed levelling screws
      M557 X30:280 Y30:280 P5                        ; define 5x5 mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed"    ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0 Q11                                 ; create bed heater output on out5 and map it to sensor 0, lower switching frequency to 11Hz
      M307 H1 R2.186 K0.17:0.11 D5.67 S1.00 V24.0            ; set the process parameters for heater 1
      M307 H1                                                ; report model parameters for heater 1, and whether the model is being used
      M140 H0                                                ; map heated bed to heater 0
      M143 H0 S110                                           ; set temperature limit for heater 0 to 110C
      ;; Run Bed PID Tune!! Below is an example for a 300x300 bed
      ;; M307 H0 A303.1 C356.7 D1.4 S1.00 V24.0 B0
      M950 F0 C"out4" Q500                   ; create fan 0 on pin out4 and set its frequency
      M106 P0 C"Layer Fan" S0 H-1            ; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"out3" Q500                   ; create fan 1 on pin out3 and set its frequency
      M106 P1 C"Hotend Fan" S1 H-1 T45       ; set fan 1 name and value. Thermostatic control turned on for Hotend
      M563 P0 D0 H1 F0           ; define tool 0
      G10 P0 X0 Y0 Z0            ; set tool 0 axis offsets
      G10 P0 R0 S0               ; set initial tool 0 active and standby temperatures to 0C
      M950 H1 C"out1" T1         ; create nozzle heater output on out2 and map it to sensor 1
      M307 H1 B0 S1.00           ; disable bang-bang mode for heater and set PWM limit
      M143 H1 S250               ; set the maximum temperature in C for heater
      ; EVA 2 / BMG / E3D V6
      M92 E1000.00      ; set extruder steps per mm, 0.9 angle/step (LDO Pancake)
      M906 E800         ; set extruder motor current (mA) and idle factor in per cent
      M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.060000e-8 A"Hotend"
      ;; Run Heater PID Tune!!
      ;; M307 H1 A751.5 C196.6 D4.7 S1.00 V23.9 B0
      ;; Inductive Probe
      ; M558 P5 C"!io3.in" H5 F400 T5000       ; set Z probe type to unmodulated and the dive height + speeds
      ; G31 P500 X-30 Y-15 Z0.20               ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed
      ;; BLTouch
       M950 S0 C"io2.out"                     ; Create a servo pin on io7
       M558 P9 C"io2.in" H5 F240 T10800 A5    ; set Z probe type to unmodulated and the dive height + speeds
       G31 P25 X-28.00 Y-13.00 Z1.12          ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed
      ; Select default tool
      T0
      ; Pressure Advance
      ; M572 D0 S0.02
        jay_s_uk @Polo
        @Polo might help to tell us a bit more about your machine, what type of probe you have, post your homeall and homez file, how much the z offset is changing by etc otherwise we're just guessing
        Deez3443undefined Poloundefined 2 Replies Last reply Reply Quote 0
        • Deez3443undefined
          Deez3443 @jay_s_uk
          @jay_s_uk Check "config-override.g" maybe you have z-offset comand on this file.
          Poloundefined 1 Reply Last reply Reply Quote 0
          • Poloundefined
            Polo @Deez3443
            @Deez3443 ```
            code_text
            ; Heater model parameters
            M307 H0 R0.130 K0.150:0.000 D10.00 E1.35 S1.00 B1
            M307 H1 R2.430 K0.560:0.000 D5.50 E1.35 S1.00 B0 V0.0
            ; Workplace coordinates
            G10 L2 P1 X0.00 Y0.00 Z0.00
            G10 L2 P2 X0.00 Y0.00 Z0.00
            G10 L2 P3 X0.00 Y0.00 Z0.00
            G10 L2 P4 X0.00 Y0.00 Z0.00
            G10 L2 P5 X0.00 Y0.00 Z0.00
            G10 L2 P6 X0.00 Y0.00 Z0.00
            G10 L2 P7 X0.00 Y0.00 Z0.00
            G10 L2 P8 X0.00 Y0.00 Z0.00
            G10 L2 P9 X0.00 Y0.00 Z0.00
            here is my config. override
            • Poloundefined
              Polo @jay_s_uk
              @jay_s_uk
              Hi
              I have a V-Core 500 I'm using duet3 mini WIFI with bltouch probe. Here is some information about my config
              Homeall
              code_text
              ```M201 X500.00 Y500.00    ; Reduce acceleration for homing moves
              ; BLTouch
              ;M280 P0 S160           ; Precautionary alarm release
              ;M280 P0 S90            ; Ensure the pin is raised
              G91                     ; Relative positioning
              G1 H2 Z5 F6000          ; Lift Z relative to current position
              G1 H1 X-625 Y605 F4600  ; Move quickly to X and Y axis endstops and stop there (first pass)
              G1 X3 Y-3 F600          ; Go back a few mm
              G1 H1 X-625 Y605 F1360   ; Move slowly to X and Y axis endstops once more (second pass)
              G1 H1 X-625 F1360        ; Move slowly to X and Y axis endstops once more (second pass)
              G1 H1 Y605 F1360         ; Move slowly to X and Y axis endstops once more (second pass)
              M201 X3000 Y3000        ; Return to full acceleration
              G90                     ; Absolute positioning
              G1 X250 Y250 F10000     ; Go to the center of the bed (300x300)
              ;G1 X200 Y200 F10000    ; Go to the center of the bed (400x400)
              ;G1 X250 Y250 F10000    ; Go to the center of the bed (500x500)
              G30                     ; Home Z by probing the bed
              G1 Z5 F100              ; Lift Z relative to current position
              HomeZ```
              ; BLTouch
              ;G91                     ; Relative positioning
              ;G1 Z5 F100              ; Lift Z relative to current position
              ;G90                     ; Absolute positioning
              Thanks
