Solved Duet2 ethernet and 12864 display using ST7567
@jay_s_uk said in Duet2 ethernet and 12864 display using ST7567:
@leckietech
Which firmware?
And which version of fysetc screen?Im running RRF 3.2.2 with 12864 display using ST7567 and its got 3 on board 2811 drivers:
https://www.aliexpress.com/item/32862853197.html?spm=a2g0s.9042311.0.0.5d614c4doODGv6 -
Hello!
This is my first post on the forum, so if I apologize in advance for any gaffes I eventually make.
I've been following this topic and others related to ST7567-based LCDs for a while, and a few days ago, I was discussing with a friend about the mess that wiring it for the Duet2 can quickly become, so I made a simple adapter board and wanted to share it, in case anyone has an interest. I have tested the wiring the board is based on, but not yet the board itself (I'll make it on a protoboard before placing an order), but it does look pretty straightforward. Board sits directly over Duet2, and EXP_1/EXP_2 cables go between it and the LCD.
https://github.com/fs9/Duet-Mini12864
I would very much appreciate feedback and suggestions, should anybody have any.
@leckietech you need to run RRF 3.3 to be able to drive the WS2811 LEDs.
@dc42 I installed 3.3 and a ST7567 https://wiki.fysetc.com/Generic_12864_Panel/ to my duet2 wifi. Did the wiring loom and all seems to work fine. Communication between display and printer works, SD card access works etc.
Only thing not working is the LED.
I set the display up with M918 P2.
And then I should be able to address the Neopixel LEDs with M150. Only command accepted is M150 X2, but it doesnt drive any LED of the display.
And M150 X1 gives Error: M150: Unsupported LED strip type
Any idea what to do to make the backlight of this display work with the Duet Wifi? -
Could someone using the Fysetc 2.1 and running a DUET please post his config here? I had it running for month now, but somehow my config got erased, and I can't get the display's LEDs working again.
I need this part, with the CORRECT PIN to setup... io5.out is not the correct one, and even after looking into manual ans stuff I can't figure it out. That's very confusing to me.
M918 P2 E-4 F2000000 ; Fysetc 12864mini M950 E1 C"io5.out" T1 U3 ; create a RGB Neopixel LED strip with 3 LEDs on the Duet 3 Mini 5+ 12864_EXP1 header M150 E1 R0 U0 B255 P255 S1 F1 ; display led blue M150 E1 R255 U0 B0 P255 S1 F1 ; left encoder led red M150 E1 R0 U255 B0 P255 S1 F0 ; right encoder led green
@izeman which firmware version are you using?
@dc42 said in Duet2 ethernet and 12864 display using ST7567:
3.5.0-rc.1
Thanks!
@izeman try pin name "connlcd.np".
You're a true GENIUS. Thank you so much! Works perfectly fine now!!
@izeman I'm no genius, I'm the person who chose the pin names. We'll update the documentation. I'm glad it's working for you.
@dc42 I know, but still
Tbh pin names are the most confusing part of Duet stuff. I tried converting to Klipper to try it out, but came back to RFF as I couldn't get bltouch working - just couldn't find the correct pins ...
Nethertheless I don't think I need klipper anyway. Ordered an accelerometer now and will try input shaping. Great stuff!!
